path: root/sound/pci/rme32.c
2009-01-12ALSA: Convert to snd_card_create() in sound/pci/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in sound/pci/*. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: rme32.c fix integer as NULL pointer warningHarvey Harrison
kernel style does assignment outside of if() statements. sound/pci/rme32.c:1353:71: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] pcm: add snd_pcm_rate_to_rate_bit() helperClemens Ladisch
Add a snd_pcm_rate_to_rate_bit() function to factor out common code used by several drivers. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Add snd_pcm_group_for_each_entry() for code cleanupTakashi Iwai
Added a new macro snd_pcm_group_for_each_entry() just for code cleanup. Old macros, snd_pcm_group_for_each() and snd_pcm_group_substream_entry(), are removed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] Remove IRQF_DISABLED for shared PCI irqsTakashi Iwai
Fix IRQ flags for PCI devices. The shared IRQs for PCI devices shouldn't be allocated with IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't be used. The patch removes unnecessary cast in request_irq and free_irq, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-12[ALSA] Fix section mismatch errors in ALSA PCI driversTakashi Iwai
Fixed 'section mismatch' errors in ALSA PCI drivers: - removed invalid __devinitdata from pci id tables - fix/remove __devinit of functions called in suspend/resume Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[ALSA] Fix races in irq handler and ioremapTakashi Iwai
Call ioremap before request_irq for avoiding possible races in the irq handler. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] add __devinitdata to all pci_device_idHenrik Kretzschmar
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-28[PATCH] Typo fixesAlexey Dobriyan
Fix a lot of typos. Eyeballed by jmc@ in OpenBSD. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI RME32Takashi Iwai
Modules: RME32 driver Remove xxx_t typedefs from the PCI RME32 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-11-04[ALSA] Add missing KERN_* suffix to printkTakashi Iwai
Add missing KERN_* suffix to printk. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-14[PATCH] add PCI IDs so RME32 and RME96 drivers buildRoland Dreier
While doing an allyesconfig build, I noticed that the commit commit 8cdfd2519c6c9a1e6057dc5970b2542b35895738 Author: Takashi Iwai <tiwai@suse.de> Date: Wed Sep 7 14:08:11 2005 +0200 [ALSA] Remove superfluous PCI ID definitions broke the RME32 and RME96 drivers, since the PCI IDs they use seem to have changed names. Here's a patch to fix this -- compile tested only, since I have no idea what the hardware even is. Fix the build of the RME32 and RME96 drivers by having them use the PCI_DEVICE_ID_RME_xxx names defined in <linux/pci_ids.h> instead of the PCI_DEVICE_ID_xxx names that they used to define themselves. Also fix the typo in the id PCI_DEVICE_IDRME__DIGI96_8_PAD_OR_PST so the name is PCI_DEVICE_ID_RME_DIGI96_8_PAD_OR_PST. Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[ALSA] set owner field in struct pci_driverClemens Ladisch
AD1889 driver,ALS4000 driver,ATIIXP driver,ATIIXP-modem driver AZT3328 driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,FM801 driver Intel8x0 driver,Intel8x0-modem driver,Maestro3 driver,RME32 driver RME96 driver,SonicVibes driver,VIA82xx driver,VIA82xx-modem driver ALI5451 driver,au88x0 driver,CS46xx driver,EMU10K1/EMU10K2 driver HDA Intel driver,ICE1712 driver,ICE1724 driver,KORG1212 driver MIXART driver,NM256 driver,RME HDSP driver,RME9652 driver Trident driver,Digigram VX222 driver,YMFPCI driver Set the module owner field in each driver's struct pci_driver to get the driver symlink in the sysfs device directory. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-09-12[ALSA] Remove superfluous PCI ID definitionsTakashi Iwai
CS46xx driver,EMU10K1/EMU10K2 driver,PCM Midlevel,Trident driver YMFPCI driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,Intel8x0 driver Intel8x0-modem driver,Maestro3 driver,RME32 driver,RME96 driver SonicVibes driver,VIA82xx driver,ALI5451 driver,ICE1712 driver ICE1724 driver,NM256 driver,RME HDSP driver,RME9652 driver Remove superfluous PCI ID definitions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] sparse address space annotationsClemens Ladisch
ALSA Core,RawMidi Midlevel,ALSA<-OSS emulation,ALSA sequencer RME32 driver,RME96 driver,EMU10K1/EMU10K2 driver,NM256 driver Add sparse annotations where we do strange this with __iomem/__user pointers. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-08-30[ALSA] sound - fix .iface field of mixer control elementsClemens Ladisch
Documentation,CS46xx driver,EMU10K1/EMU10K2 driver,AD1848 driver SB16/AWE driver,CMIPCI driver,ENS1370/1+ driver,RME32 driver RME96 driver,ICE1712 driver,ICE1724 driver,KORG1212 driver RME HDSP driver,RME9652 driver This patch changes .iface to SNDRV_CTL_ELEM_IFACE_MIXER whre _PCM or _HWDEP was used in controls that are not associated with a specific PCM (sub)stream or hwdep device, and changes some controls that got inconsitent .iface values due to copy+paste errors. Furthermore, it makes sure that all control that do use _PCM or _HWDEP use the correct number in the .device field. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-05-29[ALSA] Replace pci_module_init() with pci_register_driver()Takashi Iwai
Documentation,ALS4000 driver,ATIIXP driver,ATIIXP-modem driver AZT3328 driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,FM801 driver Intel8x0 driver,Intel8x0-modem driver,Maestro3 driver,RME32 driver RME96 driver,SonicVibes driver,VIA82xx driver,VIA82xx-modem driver ALI5451 driver,au88x0 driver,CA0106 driver,CS46xx driver EMU10K1/EMU10K2 driver,HDA Intel driver,ICE1712 driver,ICE1724 driver KORG1212 driver,MIXART driver,NM256 driver,RME HDSP driver RME9652 driver,Trident driver,Digigram VX222 driver,YMFPCI driver Replace the obsolete pci_module_init() with pci_register_driver(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
