path: root/sound/pci/maestro3.c
2012-08-14ALSA: PCI: Replace CONFIG_PM with CONFIG_PM_SLEEPTakashi Iwai
Otherwise we may get compile warnings due to unused functions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-19Merge branch 'topic/pm-convert' into for-nextTakashi Iwai
This merges the changes for converting to new PM ops for platform and some other drivers. Also move some header files to local places from the public include/sound.
2012-07-03ALSA: Convert to new pm_ops for PCI driversTakashi Iwai
Straightforward conversion to the new pm_ops from the legacy suspend/resume ops. Since we change vx222, vx_core and vxpocket have to be converted, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-06-18ALSA: maestro3: Remove unused AC97 register definitionsEzequiel Garcia
Signed-off-by: Ezequiel Garcia <elezegarcia@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-24ALSA: pci: clean up using module_pci_driver()Takashi Iwai
2011-12-19ALSA: module_param: make bool parameters really boolRusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-10-31sound: fix drivers needing module.h not moduleparam.hPaul Gortmaker
The implicit presence of module.h lured several users into incorrectly thinking that they only needed/used modparam.h but once we clean up the module.h presence, these will show up as build failures, so fix 'em now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-14ALSA: mpu401: clean up interrupt specificationClemens Ladisch
The semantics of snd_mpu401_uart_new()'s interrupt parameters are somewhat counterintuitive: To prevent the function from allocating its own interrupt, either the irq number must be invalid, or the irq_flags parameter must be zero. At the same time, the irq parameter being invalid specifies that the mpu401 code has to work without an interrupt allocated by the caller. This implies that, if there is an interrupt and it is allocated by the caller, the irq parameter must be set to a valid-looking number which then isn't actually used. With the removal of IRQF_DISABLED, zero becomes a valid irq_flags value, which forces us to handle the parameters differently. This patch introduces a new flag MPU401_INFO_IRQ_HOOK for when the device interrupt is handled by the caller, and makes the allocation of the interrupt to depend only on the irq parameter. As suggested by Takashi, the irq_flags parameter was dropped because, when used, it had the constant value IRQF_DISABLED. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-14ALSA: es1968,maestro3 - Use work for hw-volume controlTakashi Iwai
Instead of tasklet, use workq for handling the hw-volume control. This reduces lots of spinlocks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ALSA: use KBUILD_MODNAME for request_irq argument in sound/pci/*Takashi Iwai
The name argument of request_irq() appears in /proc/interrupts, and it's quite ugly when the name entry contains a space or special letters. In general, it's simpler and more readable when the module name appears there, so let's replace all entries with KBUILD_MODNAME. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10ALSA: Use KBUILD_MODNAME for pci_driver.name entriesTakashi Iwai
The convention for pci_driver.name entry in kernel drivers seem to be the module name or equivalent ones. But, so far, almost all PCI sound drivers use more verbose name like "ABC Xyz (12)", and these are fairly confusing when appearing as a file name. This patch converts the all pci_driver.name entries in sound/pci/* to use KBUILD_MODNAME for more unified appearance. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-08ALSA: maestro3: Clear interrupts before enabling themVille Syrjälä
Avoid spurious interrupts when initializing the device. Signed-off-by: Ville Syrjälä <syrjala@sci.fi> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-23ALSA: snd-maestro3: Make hardware volume buttons an input device (rev2)Hans de Goede
While working on the sound suspend / resume problems with my laptop I noticed that the hardware volume handling code in essence just detects key presses, and then does some hardcoded modification of the master volume based on which key is pressed. This made me think that clearly the right thing to do here is just report these keypresses to userspace and let userspace decide what to with them. This patch adds a Kconfig option which when enabled reports the volume buttons as keypresses using an input device. When enabled this option also gets rid of the ugly direct ac97 writes from the tasklet, the ac97lock and the need for using a tasklet in general. As an added bonus the keys now work identical to volume keys on a (usb) keyboard with multimedia keys, providing visual feedback of the volume level change, and a better range of the volume control (with a properly configured desktop environment). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-22ALSA: snd-meastro3: Document hardware volume control a bitHans de Goede
While working on a fix for the volume being muted on the allegro in my Compaq EVO N600C after suspend, I've learned a few things about the hardware volume control worth documenting. The actual fix for the suspend / resume issue is in the next patch in this set. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-22ALSA: snd-meastro3: Ignore spurious HV interrupts during suspend / resumeHans de Goede
Ignore spurious HV interrupts during suspend / resume, this avoids mistaking them for a mute button press. This is not very pretty but it seems the only way to fix the master volume control gets muted after suspend issue I'm seeing. Note that the es1968 driver is doing exactly the same. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-04-22ALSA: snd-meastro3: Add amp_gpio quirk for Compaq EVO N600CHans de Goede
Without this quirk sound stops working after suspend resume. With this quirk, one still needs to manually unmute the master volume control after a suspend / / resume cycle. That is fixed in another patch in this set. Note that this patch was submitted to the alsa bug tracker a long time ago: https://bugtrack.alsa-project.org/alsa-bug/view.php?id=4319 Signed-off-by: Hans de Goede <hdegoede@redhat.com> CC: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-09sound: use DEFINE_PCI_DEVICE_TABLEAlexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() to make PCI device ids go to .devinit.rodata section, so they can be discarded in some cases, and make them const. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-07dma-mapping: replace all DMA_28BIT_MASK macro with DMA_BIT_MASK(28)Yang Hongyang
Replace all DMA_28BIT_MASK macro with DMA_BIT_MASK(28) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-12ALSA: Convert to snd_card_create() in sound/pci/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in sound/pci/*. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-18ALSA: hda - Convert from takslet_hi_schedule() to tasklet_schedule()Takashi Iwai
Replace all tasklet_hi_schedule() callers with the normal tasklet_schedule(). The former often causes troubles with RT-kernels, and has actually no merit. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-13ALSA: Kill snd_assert() in sound/pci/*Takashi Iwai
Kill snd_assert() in sound/pci/*, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
Conflicts: sound/pci/Kconfig
2008-07-10firmware: convert maestro3 driver to use firmware loader exclusivelyDavid Woodhouse
2008-07-10maestro3: treat firmware data as constDavid Woodhouse
The maestro3 driver is byte-swapping its firmware to be host-endian in advance, when it doesn't seem to be necessary -- we could just use le16_to_cpu() as we load it. Doing that means that we need to switch the in-tree firmware to be little-endian too. Take the least intrusive way of doing this, which is to switch the existing snd_m3_convert_from_le() function to convert _to_ little-endian instead, and use it on the in-tree firmware instead of the loaded firmware. It's a bit suboptimal but doesn't matter much right now because we're about to remove the special cases for the in-tree version anyway. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2008-06-06[ALSA] maestro3: Fix hw volume on HP OmniBookVille Syrjälä
Make the hw volume buttons work correctly on some HP OmniBook laptops. The original quirk was apparently applied a bit too early and it was also lacking some critial register writes. This improved sequence was discovered by trial and error (like the original sequence). Tested and found working on OB500 and OB6000 laptops. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] Fix synchronize_irq() bugs, redundanciesJeff Garzik
free_irq() calls synchronize_irq() for you, so there is no need for drivers to manually do the same thing (again). Thus, calls where sync-irq immediately precedes free-irq can be simplified. However, during this audit several bugs were noticed, where free-irq is preceded by a "irq >= 0" check... but the sync-irq call is not covered by the same check. So, where sync-irq could not be eliminated completely, the missing check was added. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] sound: maestro3.c fix shadowed variable warningsHarvey Harrison
change id to elem_id as it is used to initialize each mixer element sound/pci/maestro3.c:2071:25: warning: symbol 'id' shadows an earlier one sound/pci/maestro3.c:67:13: originally declared here index is used in each of these places to count over the dsp's memory, change to the name dsp_index sound/pci/maestro3.c:2572:9: warning: symbol 'index' shadows an earlier one sound/pci/maestro3.c:66:12: originally declared here sound/pci/maestro3.c:2604:9: warning: symbol 'index' shadows an earlier one sound/pci/maestro3.c:66:12: originally declared here [tiwai - fixed coding style issues as well] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] sound/pci: remove line duplications in definesNicolas Kaiser
Remove line duplications in defines. Acked-by: Thomas Sailer <sailer@ife.ee.ethz.ch> Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] remove incorrect usage of SNDRV_PCM_INFO_SYNC_START and ↵Clemens Ladisch
snd_pcm_set_sync() Set the SNDRV_PCM_INFO_SYNC_START flag and the substream's sync ID (only) if the substream actually can be linked to another one. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] add MODULE_FIRMWARE entriesClemens Ladisch
Add MODULE_FIRMWARE() entries, where appropriate. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Don't use request_firmware if internal firmwares are definedTakashi Iwai
Don't use request_firmware() if the internal firmwares are defined via Kconfig. Otherwise it results in a significant delay at loading time (minutes). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Enable Kconfig options for external firmwaresTakashi Iwai
Some drivers are already ifdefs for enabling external firmwares but not defined in Kconfig. Now they appear as the kernel configs. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] maestro3 - Use quirk list helper functionTakashi Iwai
Clean up maestro3 amp and GPIO quirks using snd_pci_quirk_lookup(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] maestro3: add request_firmware()Clemens Ladisch
Load the ASSP codes using request_firmware(), if possible, instead of using the built-in blobs. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] Remove IRQF_DISABLED for shared PCI irqsTakashi Iwai
Fix IRQ flags for PCI devices. The shared IRQs for PCI devices shouldn't be allocated with IRQF_DISABLED. Also, when MSI is enabled, IRQF_SHARED shouldn't be used. The patch removes unnecessary cast in request_irq and free_irq, too. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-20[ALSA] use the ALIGN macroClemens Ladisch
Use the ALIGN macro instead of manual calculations. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] Various fixes for suspend/resume of ALSA PCI driversTakashi Iwai
- Check the return value of pci_enable_device() and request_irq() in the suspend. If any error occurs there, disable the device using snd_card_disconnect(). - Call pci_set_power_state() properly with pci_choose_state(). - Fix the order to call pci_set_power_state(). - Removed obsolete house-made PM codes in some drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-12[ALSA] Fix section mismatch errors in ALSA PCI driversTakashi Iwai
Fixed 'section mismatch' errors in ALSA PCI drivers: - removed invalid __devinitdata from pci id tables - fix/remove __devinit of functions called in suspend/resume Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[ALSA] Change an arugment of snd_mpu401_uart_new() to bit flagsTakashi Iwai
Change the 5th argument of snd_mpu401_uart_new() to bit flags instead of a boolean. The argument takes bits that consist of MPU401_INFO_XXX flags. The callers that used the value 1 there are replaced with MPU401_INFO_INTEGRATED. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] add __devinitdata to all pci_device_idHenrik Kretzschmar
Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] sound/pci/: remove duplicate #include'sAdrian Bunk
There's no reason for #include'ing linux/dma-mapping.h more than once. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-31[ALSA] maestro3.c: fix BUG, optimizationAndreas Mohr
- fix brown-paper-bag locking bug (lock() / return / unlock()) - improve central function snd_m3_update_ptr() (avoid expensive integer divisions) - add cpu_relax() to busy-wait I/O loop as recommended (does this require special macro support in ALSA for older kernels??) - constify several structs - spelling updates Signed-off-by: Andreas Mohr <andi@lisas.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-28[PATCH] Replace 0xff.. with correct DMA_xBIT_MASKMatthias Gehre
Replace all occurences of 0xff.. in calls to function pci_set_dma_mask() and pci_set_consistant_dma_mask() with the corresponding DMA_xBIT_MASK from linux/dma-mapping.h. Signed-off-by: Matthias Gehre <M.Gehre@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] Intruduce DMA_28BIT_MASKTobias Klauser
This patch introduces the DMA_28BIT_MASK constant in dma-mapping.h ALSA drivers using this mask are changed to use the new constant. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Jaroslav Kysela <perex@suse.cz>
2006-01-03[ALSA] maestro3 - Fix PM supportTakashi Iwai
Modules: Maestro3 driver Fix PM support on maestro3 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI Maestro3Takashi Iwai
Modules: Maestro3 driver Remove xxx_t typedefs from the PCI Maestro3 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
