path: root/sound/pci/intel8x0.c
2005-11-10[PATCH] PCI: removed unneeded .owner field from struct pci_driverGreg Kroah-Hartman
2005-11-04[ALSA] intel8x0 - Fix irq handler registrationTakashi Iwai
Modules: Intel8x0 driver - Request irq handler after proper initialization - Don't override always buggy_irq option for Nvidia Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] intel8x0 - Add ac97_quirk for Dell Inspiron 8600Karoly Lorentey
Modules: Intel8x0 driver Add AC97_TUNE_HP_ONLY quirk for Dell Inspiron 8600. Signed-off-by: Karoly Lorentey <lorentey@elte.hu> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Fix schedule_timeout usageNishanth Aravamudan
Use schedule_timeout_{,un}interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Also use human-time conversion functions instead of hard-coded division to avoid rounding issues. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] intel8x0 - fix capture for M1563Wei Ni
Modules: Intel8x0 driver 1.In intel8x0_measure_ac97_clock routine, when stop DMA, there is not stop DMA corectly, but start another PCM In2 DMA engine. 2.In do_ali_reset routine, there is only need to enable PCM IN and PCM OUT. Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2005-11-04[ALSA] Add missing KERN_* suffix to printkTakashi Iwai
Add missing KERN_* suffix to printk. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Fix the type of enable module optionTakashi Iwai
Fix the type of enable module option to bool. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] intel8x0 - Fix handling of module parametersTakashi Iwai
Modules: Intel8x0 driver - Set buggy_irq parameter before registration of irq handler. - Clean up module parameter handling. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] intel8x0 - enable ac97_quirk hp_only for Acer Aspire 3003LCiDick Streefland
Modules: Intel8x0 driver On my Acer Aspire 3003LCi laptop, the speaker volume is not controlled by the master control, but by the headphone control. Enabling the 'hp_only' quirk corrects this. The patch below adds this device to the list of known quirks. Signed-off-by: Dick Streefland <dick@streefland.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Add dummy obsoleted module options for backward compatibilityTakashi Iwai
Added dummay obsoleted module options for backward compatibility (to reduce possible bugzilla entries :) Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] intel8x0 - Suppress the codec warnings during probingTakashi Iwai
Modules: Intel8x0 driver Suppress the codec warnings during probing of codecs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] highlanderize motherboard AC97/HDA driversClemens Ladisch
Remove the code for supporting eight cards from the integrated controller drivers because There Can Be Only One controller of each type per mainboard. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-11-04[ALSA] Removing obsolete AC97_SHARED_TYPESSasha Khapyorsky
This patch cleans last ac97 audio/modem codec interception in initialization procedures (ac97_mixer_new()) and removes obsolete SHARED_TYPE 'locking' which prevents from AMC codecs to function correctly. Signed-off-by: Sasha Khapyorsky <sashak@smlink.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] set owner field in struct pci_driverClemens Ladisch
AD1889 driver,ALS4000 driver,ATIIXP driver,ATIIXP-modem driver AZT3328 driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,FM801 driver Intel8x0 driver,Intel8x0-modem driver,Maestro3 driver,RME32 driver RME96 driver,SonicVibes driver,VIA82xx driver,VIA82xx-modem driver ALI5451 driver,au88x0 driver,CS46xx driver,EMU10K1/EMU10K2 driver HDA Intel driver,ICE1712 driver,ICE1724 driver,KORG1212 driver MIXART driver,NM256 driver,RME HDSP driver,RME9652 driver Trident driver,Digigram VX222 driver,YMFPCI driver Set the module owner field in each driver's struct pci_driver to get the driver symlink in the sysfs device directory. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-09-12[ALSA] Replace with kzalloc() - pci stuffTakashi Iwai
AD1889 driver,ATIIXP driver,ATIIXP-modem driver,AZT3328 driver BT87x driver,CMIPCI driver,CS4281 driver,ENS1370/1+ driver ES1938 driver,ES1968 driver,FM801 driver,Intel8x0 driver Intel8x0-modem driver,Maestro3 driver,SonicVibes driver,VIA82xx driver VIA82xx-modem driver,AC97 Codec,AK4531 codec,au88x0 driver CA0106 driver,CS46xx driver,EMU10K1/EMU10K2 driver,HDA Codec driver HDA generic driver,HDA Intel driver,ICE1712 driver,ICE1724 driver KORG1212 driver,MIXART driver,NM256 driver,Trident driver,YMFPCI driver Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] intel8x0 - Add buggy_semaphore optionTakashi Iwai
Documentation,Intel8x0 driver Added buggy_semaphore module option to snd-intel8x0 driver for a workaround for hardwards with buggy codec semaphores. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Remove superfluous PCI ID definitionsTakashi Iwai
CS46xx driver,EMU10K1/EMU10K2 driver,PCM Midlevel,Trident driver YMFPCI driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,Intel8x0 driver Intel8x0-modem driver,Maestro3 driver,RME32 driver,RME96 driver SonicVibes driver,VIA82xx driver,ALI5451 driver,ICE1712 driver ICE1724 driver,NM256 driver,RME HDSP driver,RME9652 driver Remove superfluous PCI ID definitions. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] intel8x0 - Add quirk for IBM NetVisa A30pTakashi Iwai
Intel8x0 driver Added ac97_quirk entry for IBM NetVisa A30p. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] intel8x0 - Add quirk for FSC 4010Takashi Iwai
Intel8x0 driver Added ac97_quirk for FSC 4010. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] intel8x0 - add AC97_TUNE_MUTE_LED quirk for HP nx8220 laptop 103c:0934Daniel Horchner
Intel8x0 driver Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2005-08-30[ALSA] HP nx6110 quirksSergey Vlasov
Intel8x0 driver,AC97 Codec The HP nx6110 laptop needs to have Headphone Jack Sense enabled so that the internal speakers will be turned off when headphones are plugged in. Also ac97_quirk=hp_only is needed to make a single Master volume in the mixer instead of separate volumes for internal speakers and headphones, which just confuses the user. Signed-off-by: Sergey Vlasov <vsu@altlinux.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] intel8x0 - Fix PMTakashi Iwai
Intel8x0 driver Fixed the PCM resume of intel8x0. Restores the requested register setting. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-07-30merge 2.6.13-rc4 with ACPI's to-linus treeLen Brown
2005-07-29/home/lenb/src/to-linus branch 'acpi-2.6.12'Len Brown
2005-07-29[ACPI] fix resume issues on Asus L5DRafael J. Wysocki
http://bugzilla.kernel.org/show_bug.cgi?id=4416 Signed-off-by: Rafael J. Wysocki <rjwysocki@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-28[ALSA] sound/pci: fix-up sleeping pathsNishanth Aravamudan
ENS1370/1+ driver,ES1968 driver,Intel8x0 driver,VIA82xx driver VIA82xx-modem driver,AC97 Codec,ALI5451 driver,CS46xx driver MIXART driver,RME HDSP driver,Trident driver,YMFPCI driver Description: Fix-up sleeping in sound/pci. These changes fall under the following two categories: 1) Replace schedule_timeout() with msleep() to guarantee the task delays as expected. This also involved replacing/removing custom sleep functions. 2) Do not assume jiffies will only increment by one if you request a 1 jiffy sleep, i.e. use time_after/time_before in while loops. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2005-07-28[ALSA] Fix resume of intel8x0Takashi Iwai
Intel8x0 driver,AC97 Codec Fix resume of intel8x0 driver. The ac97 codec didn't restore some registers properly, and the restore of ICH4 SPDIF and SDIN settings was missing. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-06-22[ALSA] Add FSC T3010 quirkTakashi Iwai
Intel8x0 driver Added ac97_quirk for FSC T3010. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-06-22[ALSA] AC97 - renamed vendor/device to subvendor/subdevice where appropriateJames Courtier-Dutton
Intel8x0 driver To avoid confusion, the structure members vendor/device were renamed to subvendor/subdevice, because we compare them with PCI subsystem vendor and subsystem device. Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
2005-05-29[ALSA] Replace pci_module_init() with pci_register_driver()Takashi Iwai
Documentation,ALS4000 driver,ATIIXP driver,ATIIXP-modem driver AZT3328 driver,BT87x driver,CMIPCI driver,CS4281 driver ENS1370/1+ driver,ES1938 driver,ES1968 driver,FM801 driver Intel8x0 driver,Intel8x0-modem driver,Maestro3 driver,RME32 driver RME96 driver,SonicVibes driver,VIA82xx driver,VIA82xx-modem driver ALI5451 driver,au88x0 driver,CA0106 driver,CS46xx driver EMU10K1/EMU10K2 driver,HDA Intel driver,ICE1712 driver,ICE1724 driver KORG1212 driver,MIXART driver,NM256 driver,RME HDSP driver RME9652 driver,Trident driver,Digigram VX222 driver,YMFPCI driver Replace the obsolete pci_module_init() with pci_register_driver(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-05[PATCH] intel8x0: fix for Intel AC'97 audio driverJason Gaston
This patch fixes a typo in the Intel AC'97 audio driver intel8x0.c for Intel ESB2. Signed-off-by: Jason Gaston <Jason.d.gaston@intel.com> Cc: <tiwai@suse.de> Cc: <perex@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] intel8x0: AC'97 audio patch for Intel ESB2Jason Gaston
This patch adds the Intel ESB2 DID's to the intel8x0.c file for AC'97 audio support. Signed-off-by:  Jason Gaston <Jason.d.gaston@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
