path: root/sound/pci/ice1712/hoontech.c
2008-04-24[ALSA] ice1712 - Fix hoontech MIDI inputAlan Horstmann
Fixes the problems with Midi In on Hoontech/STA dsp24 cards, for example with DSP2000 box, without restricting the box configurations available. Also adds mpu_401 name strings. Signed-off-by: Alan Horstmann <gineera@aspect135.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] ice1712, ice1724 - Code clean upTakashi Iwai
Clean up ice1712/ice1724 codes. The board-specific data is allocated locally in each code instead of having an ungly union in struct ice1712. Also, fix coding issues in prodigy_hifi.c. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] ice1712 - fixed midi input for Hoontech C-PortsJaroslav Kysela
See ALSA bug#1846 for more details. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-05-11[ALSA] ice1712: build fixesRalf Baechle
CC [M] sound/pci/ice1712/ice1712.o sound/pci/ice1712/ice1712.c:290: error: snd_ice1712_mixer_digmix_route_ac97 causes a section type conflict sound/pci/ice1712/ice1712.c:1630: error: snd_ice1712_eeprom causes a section type conflict ... Gcc like its __devinitdata readable not const, it seems. An alternative fix would be to remove the __devinitdata attribute but that would result in slight runtime bloat. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add 'const' to files in pci/ice1712/Takashi Iwai
Mark a lot of data as 'const' Signed-of-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-03-22[ALSA] semaphore -> mutex (PCI part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI ICE1712Takashi Iwai
Modules: ICE1712 driver Remove xxx_t typedefs from the PCI ICE1712 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
