path: root/sound/pci/hda
2013-08-22ALSA: hda - Fix NULL dereference with CONFIG_SND_DYNAMIC_MINORS=nTakashi Iwai
Without the dynamic minor assignment, HDMI codec may have less PCM instances than the number of pins, which eventually leads to Oops. Reported-by: Stratos Karafotis <stratosk@semaphore.gr> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-08-19ALSA: hda - Add inverted digital mic fixup for Acer Aspire OneTakashi Iwai
Yet another entry, just use the existing fixup for this machine, too. Reported-by: "Nathanael D. Noblet" <nathanael@gnat.ca> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-08-16ALSA: hda - Add a fixup for Gateway LT27Takashi Iwai
Gateway LT27 needs a fixup for the inverted digital mic. Reported-by: "Nathanael D. Noblet" <nathanael@gnat.ca> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-08-12ALSA: hda - Fix missing mute controls for CX5051Takashi Iwai
We've added a fake mute control (setting the amp volume to zero) for CX5051 at commit [3868137e: ALSA: hda - Add a fake mute feature], but this feature was overlooked in the generic parser implementation. Now the driver lacks of mute controls on these codecs. The fix is just to check both AC_AMPCAP_MUTE and AC_AMPCAP_MIN_MUTE bits in each place checking the amp capabilities. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59001 Cc: <stable@vger.kernel.org> [v3.9+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-08-12ALSA: hda - Add pinfix for LG LW25 laptopTakashi Iwai
Correct the pins for a line-in and a headphone on LG LW25 laptop with ALC880 codec. Other pins seem fine. Reported-and-tested-by: Joonas Saarinen <jonskunator@gmail.com> Cc: <stable@vger.kernel.org> [v3.9+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-08-02ALSA: hda - Fix missing fixup for Mac Mini with STAC9221Takashi Iwai
A fixup for Apple Mac Mini was lost during the adaption to the generic parser because the fallback for the generic ID 8384:7680 was dropped, and it resulted in the silence output (and maybe other problems). Unfortunately, just adding the missing subsystem ID wasn't enough, in this case. The subsystem ID of this machine is 0000:0100 (what Apple thought...?), and since snd_hda_pick_fixup() doesn't take the vendor id zero into account, the driver ignored this entry. Now it's fixed to regard the vendor id zero as a valid value. Reported-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: <stable@vger.kernel.org> [v3.9+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-07-19ALSA: hda - Remove NO_PRESENCE bit override for Dell 1420n LaptopTakashi Iwai
The quirk for Dell laptops with STAC9228 overrides the pin default config of NID 0x0f to the value with AC_DEFCFG_MISC_NO_PRESENCE bit on. I'm not quite sure why this was done so, but can guess that this was introduced for avoiding this to be muted by another headphone plug. Now, after transition to the generic parser, this workaround rather causes a problem (notably as unexpected speaker mutes) because the pin is seen as if it's always plugged in. Since the generic parser can handle multiple headphone plugging gracefully, we can get rid of this override now. Reported-and-tested-by: Eric Shattow <lucent@gmail.com> Cc: <stable@vger.kernel.org> [v3.9+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-07-19ALSA: hda - Fix EAPD GPIO control for Sigmatel codecsTakashi Iwai
The EAPD GPIO is dynamically turned on/off for some machines with Sigmatel codecs, but this didn't work as expected, and it resulted in spontaneous lost of speaker outputs per HP plugging or power-saving. This patch fixes the bug by simply including spec->eapd_mask into spec->gpio_mask and spec->gpio_data bits. Reported-and-tested-by: Eric Shattow <lucent@gmail.com> Cc: <stable@vger.kernel.org> [v3.9+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-07-16ALSA: hda - Add new GPU codec ID to snd-hdaAaron Plattner
Vendor ID 0x10de0060 is used by a yet-to-be-named GPU chip. Reviewed-by: Andy Ritger <aritger@nvidia.com> Signed-off-by: Aaron Plattner <aplattner@nvidia.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-07-11Merge tag 'sound-3.11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "A few small fixes (and cleanups) for HD-audio, USB-audio and ASoC" * tag 'sound-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: usb-audio: fix regression for fixed stream quirk ALSA: hda - Keep halting ALC5505 DSP ASoC: wm8962: fix NULL pdata pointer ASoC: imx-sgtl5000: return E_PROBE_DEFER if ssi/codec not found ASoC: Samsung: Remove redundant comment ALSA: hda - Fix EAPD vmaster hook for AD1884 & co ASoC: samsung: Remove obsolete GPIO based DT pinmuxing ASoC: mxs: register saif mclk to clock framework
2013-07-09Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Okay this is the big one, I was stalled on the fbdev pull req as I stupidly let fbdev guys merge a patch I required to fix a warning with some patches I had, they ended up merging the patch from the wrong place, but the warning should be fixed. In future I'll just take the patch myself! Outside drm: There are some snd changes for the HDMI audio interactions on haswell, they've been acked for inclusion via my tree. This relies on the wound/wait tree from Ingo which is already merged. Major changes: AMD finally released the dynamic power management code for all their GPUs from r600->present day, this is great, off by default for now but also a huge amount of code, in fact it is most of this pull request. Since it landed there has been a lot of community testing and Alex has sent a lot of fixes for any bugs found so far. I suspect radeon might now be the biggest kernel driver ever :-P p.s. radeon.dpm=1 to enable dynamic powermanagement for anyone. New drivers: Renesas r-car display unit. Other highlights: - core: GEM CMA prime support, use new w/w mutexs for TTM reservations, cursor hotspot, doc updates - dvo chips: chrontel 7010B support - i915: Haswell (fbc, ips, vecs, watermarks, audio powerwell), Valleyview (enabled by default, rc6), lots of pll reworking, 30bpp support (this time for sure) - nouveau: async buffer object deletion, context/register init updates, kernel vp2 engine support, GF117 support, GK110 accel support (with external nvidia ucode), context cleanups. - exynos: memory leak fixes, Add S3C64XX SoC series support, device tree updates, common clock framework support, - qxl: cursor hotspot support, multi-monitor support, suspend/resume support - mgag200: hw cursor support, g200 mode limiting - shmobile: prime support - tegra: fixes mostly I've been banging on this quite a lot due to the size of it, and it seems to okay on everything I've tested it on." * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (811 commits) drm/radeon/dpm: implement vblank_too_short callback for si drm/radeon/dpm: implement vblank_too_short callback for cayman drm/radeon/dpm: implement vblank_too_short callback for btc drm/radeon/dpm: implement vblank_too_short callback for evergreen drm/radeon/dpm: implement vblank_too_short callback for 7xx drm/radeon/dpm: add checks against vblank time drm/radeon/dpm: add helper to calculate vblank time drm/radeon: remove stray line in old pm code drm/radeon/dpm: fix display_gap programming on rv7xx drm/nvc0/gr: fix gpc firmware regression drm/nouveau: fix minor thinko causing bo moves to not be async on kepler drm/radeon/dpm: implement force performance level for TN drm/radeon/dpm: implement force performance level for ON/LN drm/radeon/dpm: implement force performance level for SI drm/radeon/dpm: implement force performance level for cayman drm/radeon/dpm: implement force performance levels for 7xx/eg/btc drm/radeon/dpm: add infrastructure to force performance levels drm/radeon: fix surface setup on r1xx drm/radeon: add support for 3d perf states on older asics drm/radeon: set default clocks for SI when DPM is disabled ...
2013-07-08ALSA: hda - Keep halting ALC5505 DSPTakashi Iwai
ALC5505 DSP is enabled even though we don't use the features yet at all. This results in the unnecessarily high power consumption, more than 100mV higher. Until we implement the DSP support, better to bypass DSP for saving more power. Reported-by: Mengdong Lin <mengdong.lin@intel.com> [Patch modified by Mengdong to cal alc5505_dsp_init() with extra acl5505_dsp_halt().] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "The usual stuff from trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) treewide: relase -> release Documentation/cgroups/memory.txt: fix stat file documentation sysctl/net.txt: delete reference to obsolete 2.4.x kernel spinlock_api_smp.h: fix preprocessor comments treewide: Fix typo in printk doc: device tree: clarify stuff in usage-model.txt. open firmware: "/aliasas" -> "/aliases" md: bcache: Fixed a typo with the word 'arithmetic' irq/generic-chip: fix a few kernel-doc entries frv: Convert use of typedef ctl_table to struct ctl_table sgi: xpc: Convert use of typedef ctl_table to struct ctl_table doc: clk: Fix incorrect wording Documentation/arm/IXP4xx fix a typo Documentation/networking/ieee802154 fix a typo Documentation/DocBook/media/v4l fix a typo Documentation/video4linux/si476x.txt fix a typo Documentation/virtual/kvm/api.txt fix a typo Documentation/early-userspace/README fix a typo Documentation/video4linux/soc-camera.txt fix a typo lguest: fix CONFIG_PAE -> CONFIG_x86_PAE in comment ...
2013-07-04ALSA: hda - Fix EAPD vmaster hook for AD1884 & coTakashi Iwai
ad1884_fixup_hp_eapd() tries to set the NID for controlling the speaker EAPD from the pin configuration. But the current code can't work expectedly since it sets spec->eapd_nid before calling the generic parser where the autocfg pins are set up. This patch changes the function to set spec->eapd_nid after the generic parser call while it sets vmaster hook unconditionally. The spec->eapd_nid check is moved in the hook function itself instead. Cc: <stable@vger.kernel.org> [v3.9+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-07-01ALSA: hda - Add Dell SSID to support Headset Mic recordingKailang Yang
This is X5 Precision - Diesel platform. Signed-off-by: Kailang Yang <kailang@realtek.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-28treewide: relase -> releaseGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-06-28ALSA: Replace the magic number 44 with constTakashi Iwai
The char arrays with size 44 are for the name string of snd_ctl_elem_id. Define the constant and replace the raw numbers with it for clarifying better. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-28ALSA: hda - Fix the max length of control name in generic parserTakashi Iwai
add_control_with_pfx() in hda_generic.c assumes a shorter name string for the control element, and this resulted in the truncation of the long but valid string like "Headphone Surround Switch" in the middle. This patch aligns the max size to the actual limit of snd_ctl_elem_id, 44. Cc: <stable@vger.kernel.org> [v3.9+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-28ALSA: hda - Guess what, it's two more Dell headset mic quirksDavid Henningsson
Add two more machines that need quirks for headset mics to work. Tested-by: Shawn Wang <shawn.wang@canonical.com> BugLink: https://bugs.launchpad.net/bugs/1195636 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-28ALSA: hda - Yet another Dell headset mic quirkDavid Henningsson
This quirk is needed for the headset mic to work on this Dell machine. BugLink: https://bugs.launchpad.net/bugs/1195597 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-28ALSA: hda - Add support for ALC5505 DSP power-save modeKailang Yang
This patch adds the power-saving control for ALC5505 DSP on some Realtek codecs. Signed-off-by: Kailang Yang <kailang@realtek.com> Tested-by: Mengdong Lin <mengdong.lin@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-28Merge tag 'drm-intel-next-2013-06-18' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into drm-next Last 3.11 feature pull. I have a few odds bits and pieces and fixes in my queue, I'll sort them out later on to see what's for 3.11-fixes and what's for 3.12. But nothing to hold this here up imo. Highlights: - more hangcheck work from Mika and Chris to prepare for arb robustness - trickle feed fixes from Ville - first parts of the shared pch pll rework, with some basic hw state readout and cross-checking (this shuts up the confused pch pll refcount WARN that Linus just recently forwarded) - Haswell audio power well support from Wang Xingchao (alsa bits acked by Takashi) - some cleanups and asserts sprinkling around the plane/gamma enabling sequence from Ville - more gtt refactoring from Ben - clear up the adjusted->mode vs. pixel clock vs. port clock confusion - 30bpp support, this time for real hopefully * tag 'drm-intel-next-2013-06-18' of git://people.freedesktop.org/~danvet/drm-intel: (97 commits) drm/i915: remove a superflous semi-colon drm/i915: Kill useless "Enable panel fitter" comments drm/i915: Remove extra "ring" from error message drm/i915: simplify the reduced clock handling for pch plls drm/i915: stop killing pfit on i9xx drm/i915: explicitly set up PIPECONF (and gamma table) on haswell drm/i915: set up PIPECONF explicitly for i9xx/vlv platforms drm/i915: set up PIPECONF explicitly on ilk-ivb drm/i915: find guilty batch buffer on ring resets drm/i915: store ring hangcheck action drm/i915: add batch bo to i915_add_request() drm/i915: change i915_add_request to macro drm/i915: add i915_gem_context_get_hang_stats() drm/i915: add struct i915_ctx_hang_stats drm/i915: Try harder to disable trickle feed on VLV drm/i915: fix up pch pll enabling for pixel multipliers drm/i915: hw state readout and cross-checking for shared dplls drm/i915: WARN on lack of shared dpll drm/i915: split up intel_modeset_check_state drm/i915: extract readout_hw_state from setup_hw_state ... Conflicts: drivers/gpu/drm/i915/intel_display.c drivers/gpu/drm/i915/intel_fb.c drivers/gpu/drm/i915/intel_sdvo.c
2013-06-25ALSA: hda - Add missing alc_inv_dmic_sync() call in alc269_resume()Takashi Iwai
As some of ALC269 quirks use the inverted dmic feature, we need to call alc_inv_dmic_sync() in the resume callback like in alc_resume(), too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-25ALSA: hda - Remove superfluous stac_resume()Takashi Iwai
The stac_resume() is exactly what the default resume code does, so we don't have to define and use it doubly. Let's cut it off. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-25ALSA: hda/hdmi - poll eld at resume timeWang Xingchao
Hdmi driver may not receive intrinsic event from gfx side when it's in runtime suspend mode. There's no ELD info when exit from runtime suspend. This patch avoid missing ELD info. Signed-off-by: Wang Xingchao <xingchao.wang@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-25ALSA: hda - clean up code to reset hda linkMengdong Lin
This patch is a cleanup to the previous patch "reset hda link during system/ runtime suspend". In this patch - azx_enter_link_reset() and azx_exit_link_reset() are defined for entering and exiting the link reset respectively. azx_link_reset() is no longer used and replaced by azx_enter_link_reset(). - azx_reset() reuses the above two new functions for a link reset cycle Signed-off-by: Mengdong Lin <mengdong.lin@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-25ALSA: hda - Add In-driver connection infoWang Xingchao
Pin's connection list may change dynamically with hot-plug event on Intel Haswell chip. Users would see connections be "0" in codec#. when play audio on this pin, software driver choose converter from cache connections. So add "In-driver connection" info to avoid confuse when raw connections are different with cache connection. Signed-off-by: Wang Xingchao <xingchao.wang@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-25ALSA: hda - Use auto_mute_via_amp=1 for VT1708Takashi Iwai
We've got bug report wrt many machines with VT1708 (e.g. IBM POS machines) showing the broken auto-mute behavior. It turned out that the problem is that the pin control values of the speaker and line-out pins are completely ignored. As a workaround, let's use the newly introduced feature of the generic parser, to control the mute via amp on pins. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-25ALSA: hda - Add auto_mute_via_amp flag to generic parserTakashi Iwai
Add a new flag, auto_mute_via_amp, to determine the behavior of the headphone / line-out auto-mute. When this flag is set, the generic driver mutes the speaker and line outputs via the amp mute of each pin, instead of changing the pin control values. This is introduced for devices that don't work expectedly with the pin control values; for example, some devices are known to keep enabling the speaker outputs no matter which pin control values are set on the speaker pins. The driver doesn't check actually whether the pins have the output amp caps, but assumes that the proper mixer (mute) controls are created on all these pins. If not the case, you can't use this flag for your device. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-24ALSA: hda - Remove unused variableWang Xingchao
2013-06-24ALSA: hda - reset hda link during system/runtime suspendMengdong Lin
If all the codecs report ClkStopOK (OK to stop bus clock) after being put to D3, this patch will reset the HDA link before the controller is put to D3. So the link will be in reset during system or runtime suspend, the bus clock stops and the codecs are in D3(ClkStop) state. This may help to reduce power consumption by dozens of mW on some peripheral hda codecs. Signed-off-by: Mengdong Lin <mengdong.lin@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-20ALSA: hda - Make Thinkpad X220-tablet use generic parserDavid Henningsson
Like the X220, this quirk was added to support docking station, so enable the fixup instead. According to Jan, the generic parser works equal or better than the current parser. This was tested under a 3.9 kernel. Reported-by: Jan Alexander Steffens <jan.steffens@gmail.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-19ALSA: hda - Fix missing Mic Boost controls for VIA codecsTakashi Iwai
Some VIA codecs like VT1708S have Mic boost amps in the mic pins but they aren't exposed in the capability bits. In the past driver code, we override the pin caps and create mic boost controls forcibly. While transition to the generic parser, we lost the mic boost controls although the pin caps are still overridden, because the generic parser code checks the widget caps, too. So this patch adds a new helper function to allow the override of the given widget capability bits, and makes VIA codecs driver to add the missing input-amp capability bit. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59861 Cc: <stable@vger.kernel.org> [v3.9+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-18ALSA: hda - Use snd_hda_check_power_state() in patch_hdmi.cTakashi Iwai
... instead of open codes. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-18ALSA: hda - Avoid choose same converter for unused pinsWang Xingchao
For Intel Haswell HDMI codecs, the pins choose converter 0 by default. This would cause conflict when playing audio on unused pins,the pin with physical device connected would get audio data too. i.e. Pin 0/1/2 default choose converter 0, pin 1 has HDMI monitor connected. when play audio on Pin 0 or pin 2, pin 1 could get audio data too. This patch configure unused pins to choose different converter. Signed-off-by: Wang Xingchao <xingchao.wang@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-18ALSA: hda - Cache the MUX selection for generic HDMITakashi Iwai
When a selection to a converter MUX is changed in hdmi_pcm_open(), it should be cached so that the given connection can be restored properly at PM resume. We need just to replace the corresponding snd_hda_codec_write() call with snd_hda_codec_write_cache(). Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-18ALSA: hda - Haswell converter power state D0 verifyWang Xingchao
Haswell converters maybe in wrong power state before usage. i.e. only converter 0 is in D0, converter 1/2 are in D3. When pin choose converter 1/2, there's no audio output, this cause dependency when playing differnt stream on pins. AUD_PWRST ConvertorA_Widget_Power_State_Current D0 AUD_PWRST ConvertorA_Widget_Power_State_Requsted D0 AUD_PWRST ConvertorB_Widget_Power_State_Current D3 AUD_PWRST ConvertorB_Widget_Power_State_Requested D3 AUD_PWRST ConvC_Widget_PwrSt_Curr D3 AUD_PWRST ConvC_Widget_PwrSt_Req D3 This patch check converter's power state and set D0 if it's in D3 mode. Signed-off-by: Wang Xingchao <xingchao.wang@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-18ALSA: hda - Fix return value of snd_hda_check_power_state()Takashi Iwai
The refactoring by commit 9040d102 introduced the new function snd_hda_check_power_state(). This function is supposed to return true if the state already reached to the target state, but it actually returns false for that. An utterly stupid typo while copy & paste. Fortunately this didn't influence on much behavior because powering up AFG usually powers up the child widgets, too. But the finer power control must have been broken by this bug. Cc: <stable@vger.kernel.org> [v3.9+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-17Merge branch 'for-linus' into for-nextTakashi Iwai
* for-linus: ALSA: hda - Add models for Dell headset jacks
2013-06-17ALSA: hda - Add models for Dell headset jacksDavid Henningsson
These headset jacks keep coming in on more and more platforms, and it's possible I don't catch them all. Make it easier to test and verify by making models. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
* for-linus: (635 commits) ALSA: usb-audio: Fix invalid volume resolution for Logitech HD Webcam c310 ALSA: hda - Fix pin configurations for MacBook Air 4,2 ALSA: usb-audio: work around Android accessory firmware bug ALSA: hda - Headset mic support for three more machines Linux 3.10-rc6 smp.h: Use local_irq_{save,restore}() in !SMP version of on_each_cpu(). powerpc: Fix missing/delayed calls to irq_work powerpc: Fix emulation of illegal instructions on PowerNV platform powerpc: Fix stack overflow crash in resume_kernel when ftracing snd_pcm_link(): fix a leak... use can_lookup() instead of direct checks of ->i_op->lookup move exit_task_namespaces() outside of exit_notify() fput: task_work_add() can fail if the caller has passed exit_task_work() xfs: don't shutdown log recovery on validation errors xfs: ensure btree root split sets blkno correctly xfs: fix implicit padding in directory and attr CRC formats xfs: don't emit v5 superblock warnings on write mei: me: clear interrupts on the resume path mei: nfc: fix nfc device freeing mei: init: Flush scheduled work before resetting the device ...
2013-06-17ALSA: hda - Fix pin configurations for MacBook Air 4,2Takashi Iwai
MacBook Air 4,2 requires the whole default pin configuration table to be overridden by the driver, as usual, as Apple's machines don't set up properly after boot. Otherwise mic won't work, and other ill effect may happen. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59381 Reported-and-tested-by: Peter John Hartman <peterjohnhartman@gmail.com> Cc: <stable@vger.kernel.org> [v3.9+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-17ALSA: hda - Headset mic support for three more machinesDavid Henningsson
They need these quirks to have headset mic support. BugLink: https://bugs.launchpad.net/bugs/1189363 Tested-by: Shawn Wang <shawn.wang@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-06ALSA: hda - Add power-welll support for haswell HDAWang Xingchao
For Intel Haswell chip, HDA controller and codec have power well dependency from GPU side. This patch added support to request/release power well in audio driver. Power save feature should be enabled to get runtime power saving. There's deadlock when request_module(i915) in azx_probe. It looks like: device_lock(audio pci device) -> azx_probe -> module_request (or symbol_request) -> modprobe (userspace) -> i915 init -> drm_pci_init -> pci_register_driver -> bus_add_driver -> driver_attach -> which in turn tries all locks on pci bus, and when it tries the one on the audio device, it will deadlock. This patch introduce a work to store remaining probe stuff, and let request_module run in safe work context. Signed-off-by: Wang Xingchao <xingchao.wang@linux.intel.com> Reviewed-by: Takashi Iwai <tiwai@suse.de> Reviewed-by: Liam Girdwood <liam.r.girdwood@intel.com> Reviewed-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-06-06ALSA: hda - Move azx_first_init() into azx_probe_continue()Takashi Iwai
This is a preliminary work for the upcoming Haswell HDMI audio fixes. azx_first_init() function can be safely called after the f/w loader, since the f/w loader doesn't require the sound hardware initialization beforehand. Moving it into azx_probe_continue() cleans up the code flow a bit. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-06-06ALSA: hda - Fix runtime PM checkWang Xingchao
The device can support runtime PM no matter whether it support signal wakeup or not. For some chips like Haswell which doesnot support PME by default, this patch let haswell Display HD-A controller enter runtime suspend, and bring more power saving whith power-well feature enabled. Signed-off-by: Wang Xingchao <xingchao.wang@linux.intel.com> Reviewed-by: Takashi Iwai <tiwai@suse.de> Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-06-06ALSA: hda - Don't take unresponsive D3 transition too seriousTakashi Iwai
When a codec is powered off, some systems don't respond properly after D3 FG transition, while the driver still expects the response and tries to fall back to different modes (polling and single-cmd). When the fallback happens, the driver stays in that mode, and falling back to the single-cmd mode means it'll loose the unsol event handling, too. The unresponsiveness at D3 isn't too serious, thus this fallback is mostly superfluous. We can gracefully ignore the error there so that the driver keeps the normal operation mode. This patch adds a new bit flag for codec read/write, set in the power transition stage, which is notified to the controller driver via a new bus->no_response_fallback flag. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-06ALSA: hda - Introduce bit flags to snd_hda_codec_read/write()Takashi Iwai
snd_hda_codec_read(), snd_hda_codec_write() & co take the argument "direct" that indicates whether the given NID is a direct reference or an indirect reference. However, the indirect reference is practically unimplemented and never exists. And moreover, we don't need the indication of indirect reference at this high level, as NID can be represented in 16bit values at this point. Meanwhile, there are some cases where it'd be nice to give some operational options to these functions. So, we can reuse this argument as a new bit flag! Pretty frugal, eh? All callers so far pass zero to this argument, thus there is no behavior change by this replacement. The real usage of this new bit option will be added in the following patches. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-06ALSA: hda - Drop hard dependency on CONFIG_SND_DYNAMIC_MINORSTakashi Iwai
Currently HDMI codec driver sets the hard dependency (reverse selection) on CONFIG_SND_DYNAMIC_MINORS because the recent codecs may support more than two PCMs. But, this doesn't mean that we need always this option, since there can be a single PCM stream even with the modern codecs. This patch drops the hard dependency again but give more sensible error message when no enough PCMs are available due to the lack of this option. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-05ALSA: hda/via - Use standard snd_hda_shutup_pins()Takashi Iwai
Just a minor clean up. Signed-off-by: Takashi Iwai <tiwai@suse.de>
