path: root/sound/pci/emu10k1/emuproc.c
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] snd-emu10k1:Implement SPDIF/ADAT status.James Courtier-Dutton
Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] snd-emu10k1: Add support for E-Mu 1616 PCI, 1616M PCI, 0404 PCI, E-MuJames Courtier-Dutton
Notebook. Description: The .device=0x0008 chips have new, but different EMU32 in/out channels. Driver updated to make use of these EMU32 channels. Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] snd-emu10k1: Added support for emu1010, including E-Mu 1212m and E-Mu ↵James Courtier-Dutton
1820m Signed-off-by: James Courtier-Dutton <James@superbug.co.uk> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Optimize for config without PROC_FS (pci drivers)Takashi Iwai
Optimize the code when compiled without CONFIG_PROC_FS for some pci drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: PCI emu10k1Takashi Iwai
Modules: EMU10K1/EMU10K2 driver Remove xxx_t typedefs from the PCI emu10k1 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] snd-emu10k1: Found some new registers to display in debug mode.James Courtier-Dutton
Modules: EMU10K1/EMU10K2 driver Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
2005-05-29[ALSA] Fix permissions in some /proc filesTakashi Iwai
PCM Midlevel,CA0106 driver,EMU10K1/EMU10K2 driver Fix by Guillaume Chazarain <guichaz@yahoo.fr>: Some tunables in /proc have a write() function, but as their permission does not reflect it, it can be confusing to the user. So here is a patch that corrects the mode of those files. Note that I have only tested the 'xrun_debug' entry. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-29[ALSA] Improve SPDIF playback via the P16V/CA0151 chip.James Courtier-Dutton
EMU10K1/EMU10K2 driver Although we can set 44100 as the output rate, the SPDIF can do it, but the Analog output cannot. The SPDIF has the bug, whereby the Left channel arrives one sample late, so although we don't do any resampling, it is not good for AC3 non-audio output. Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
2005-05-29[ALSA] Display SPDIF in status in proc fs 'spdif-in' file.James Courtier-Dutton
2005-05-29[ALSA] clean up card featuresLee Revell
EMU10K1/EMU10K2 driver This patch converts the emu10k1 driver to use the card capabilities structure for some more things. Not extensively tested but seems to work. Signed-off-by: Lee Revell <rlrevell@joe-job.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
