path: root/sound/oss/maestro.c
2006-03-23[PATCH] sem2mutex: sound/oss/Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] drivers/sound/oss: Replace pci_module_init() with pci_register_driver()Greg Kroah-Hartman
Replace obsolete pci_module_init() with pci_register_driver(). Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se>
2006-01-06[PATCH] oss: remove deprecated PM interface from maestro driverPatrick Mochel
This change removes the old, deprecated interface from the maestro driver, including the pm_{,un}register() calls, the local storage of the pmdev object and the reference to the old header files. This change is done to assist in eradicating the users of the legacy interface so as to help facilitate the removal of the interface itself. The check_suspend() function and associated logic was not removed, even though it is now unnecessary. Note that this driver has been obsoleted by an ALSA equivalent. Acked-by: Zach Brown <zab@zabbo.net> Signed-off-by: Patrick Mochel <mochel@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] move pm_register/etc. to CONFIG_PM_LEGACY, pm_legacy.hJeff Garzik
Since few people need the support anymore, this moves the legacy pm_xxx functions to CONFIG_PM_LEGACY, and include/linux/pm_legacy.h. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] remove redundant NULL checks before kfree() in sound/ and avoid ↵Jesper Juhl
casting pointers about to be kfree()'ed Checking a pointer for NULL before calling kfree() on it is redundant, kfree() deals with NULL pointers just fine. This patch removes such checks from sound/ This patch also makes another, but closely related, change. It avoids casting pointers about to be kfree()'ed. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
