Similarly like the previous commit for PCI drivers, remove
dev_set_drvdata(NULL) and pnp_set_drvdata(NULL) calls in ISA drivers
now.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
The implicit presence of module.h lured several users into
incorrectly thinking that they only needed/used modparam.h
but once we clean up the module.h presence, these will show
up as build failures, so fix 'em now.
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled],
We run all interrupt handlers with interrupts disabled
and we even check and yell when an interrupt handler
returns with interrupts enabled (see commit [b738a50a:
genirq: Warn when handler enables interrupts]).
So now this flag is a NOOP and can be removed.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
The semantics of snd_mpu401_uart_new()'s interrupt parameters are
somewhat counterintuitive: To prevent the function from allocating its
own interrupt, either the irq number must be invalid, or the irq_flags
parameter must be zero. At the same time, the irq parameter being
invalid specifies that the mpu401 code has to work without an interrupt
allocated by the caller. This implies that, if there is an interrupt
and it is allocated by the caller, the irq parameter must be set to
a valid-looking number which then isn't actually used.
With the removal of IRQF_DISABLED, zero becomes a valid irq_flags value,
which forces us to handle the parameters differently.
This patch introduces a new flag MPU401_INFO_IRQ_HOOK for when the
device interrupt is handled by the caller, and makes the allocation of
the interrupt to depend only on the irq parameter. As suggested by
Takashi, the irq_flags parameter was dropped because, when used, it had
the constant value IRQF_DISABLED.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Some drivers in sound/isa/* don't handle the error code properly
from snd_card_create(). This patch fixes these places.
Convert from snd_card_new() to the new snd_card_create() function.
Rename functions and structures from the former
cs4321_lib to names more corresponding with the
new name: wss_lib.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Reviewed-by: Rene Herman <rene.herman@gmail.com>
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Rename file include/sound/cs4231.h
into include/sound/wss.h
This header file exists only for some hacks to adapt alsa-driver
tree. It's useless for building in the kernel. Let's move a few
lines in it to sound/core.h and remove it.
With this patch, sound/driver.h isn't removed but has just a single
compile warning to include it. This should be really killed in
future.
This removes the pnp_resource_change use from the ALSA ISAPnP drivers. In
2.4 these were useful in providing an easy path to setting the resources,
but in 2.6 they retain function as a layering violation only.
This makes for a nice cleanup (-550 lines) of ALSA but moreover, ALSA is the
only remaining user of pnp_init_resource_table(), pnp_resource_change() and
pnp_manual_config_dev() (and, in fact, of 'struct pnp_resource_table') in
the tree outide of drivers/pnp itself meaning it makes for more cleanup
potential inside the PnP layer.
Thomas Renninger acked their removal from that side, you did from the ALSA
side (CC list just copied from that thread).
Against current alsa-kernel HG. Many more potential cleanups in there, but
this _only_ removes the pnp_resource_change code. Compile tested against
current alsa-kernel HG and compile- and use-tested against 2.6.23.x (few
offsets).
Cc: Thomas Renninger <trenn@suse.de>
Signed-off-by: Rene Herman <rene.herman@gmail.com>
isa_register_driver() returns an error if no device is found
and it's no fatal error for the drivers with pnp support.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
isapnp[] is only used for CONFIG_PNP. If this configuration option is
not set, do not declare the array.
Cc: Adam Belay <ambx1@neo.rr.com>
Cc: Takashi Iwai <tiwai@suse.de>
Signed-off-by: David Rientjes <rientjes@google.com>
isa_bus: delete snd_ prefix from the (sysfs visible) device/driver names.
Port the rest of ALSA ISA drivers to use isa_driver framework
instead of platform_driver.
Instead of using a somewhat algorithmic approach of initializing the
YSS225's registers, just use a simple series of port/value pairs.
This makes it easier to later replace or entirely remove the register
data blob.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Cc: Jaroslav Kysela <perex@suse.cz>
Removed zero-initializations of static variables.
A tiny optimization.
Unregister the platform device again if the probe was unsuccessful.
This restores the behaviour of not loading the driver on probe() failure.
Signed-off-by: Rene Herman <rene.herman@keyaccess.nl>
Continue with the next one on error from device registration.
This would seem the correct thing to do, even if it's not the probe()
error that we're getting.
Remove the assumption that pnp_register_card_driver() returns the
number of devices claimed. And fix some __init/__devinit issues.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Acked-by: Takashi Iwai <tiwai@suse.de>
Fix the check of enable module option in probe of platform_device drivers.
It shouldn't break the loop but just ignore if enable[i] is false.
Fix compilation of some ISA drivers without CONFIG_PNP.
Call platform_device_unregister() for all platform devices that we've
registered.
Modules: Wavefront drivers
Rewrite the probe/remove with platform_device.
Remove xxx_t typedefs from the ISA Wavefront driver.
- Remove vmalloc wrapper
- Add release_and_free_resource() to remove kfree_nocheck() from each driver
and simplify the code
ISA,CMI8330 driver,ES18xx driver,OPL3SA2 driver,Sound Galaxy driver
Sound Scape driver,AD1848 driver,CS4231 driver,CS4236+ driver
ES1688 driver,GUS Classic driver,GUS Extreme driver,GUS MAX driver
AMD InterWave driver,Opti9xx drivers,SB16/AWE driver,SB8 driver
Wavefront drivers
- Added snd_card_set_generic_dev() call.
- Added SND_GENERIC_DRIVER to Kconfig.
- Clean up the error path in probe if necessary.
infrastructure for it.
Let it rip!
