path: root/sound/isa/sb/sb16_main.c
2006-01-03[ALSA] Add PM support to SB-support codeTakashi Iwai
Modules: SB drivers,SB16/AWE driver Add PM support to SB-support code. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA SB8/SB16/SBAWETakashi Iwai
Remove xxx_t typedefs from the ISA SB8/SB16/SBAWE drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove superfluous pcm_free callbacksTakashi Iwai
Remove superflous pcm_free callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Add missing KERN_* suffix to printkTakashi Iwai
Add missing KERN_* suffix to printk. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] sound - fix .iface field of mixer control elementsClemens Ladisch
Documentation,CS46xx driver,EMU10K1/EMU10K2 driver,AD1848 driver SB16/AWE driver,CMIPCI driver,ENS1370/1+ driver,RME32 driver RME96 driver,ICE1712 driver,ICE1724 driver,KORG1212 driver RME HDSP driver,RME9652 driver This patch changes .iface to SNDRV_CTL_ELEM_IFACE_MIXER whre _PCM or _HWDEP was used in controls that are not associated with a specific PCM (sub)stream or hwdep device, and changes some controls that got inconsitent .iface values due to copy+paste errors. Furthermore, it makes sure that all control that do use _PCM or _HWDEP use the correct number in the .device field. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
