path: root/sound/isa/ad1816a/ad1816a.c
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] sound/isa: kill pnp_resource_changeRene Herman
This removes the pnp_resource_change use from the ALSA ISAPnP drivers. In 2.4 these were useful in providing an easy path to setting the resources, but in 2.6 they retain function as a layering violation only. This makes for a nice cleanup (-550 lines) of ALSA but moreover, ALSA is the only remaining user of pnp_init_resource_table(), pnp_resource_change() and pnp_manual_config_dev() (and, in fact, of 'struct pnp_resource_table') in the tree outide of drivers/pnp itself meaning it makes for more cleanup potential inside the PnP layer. Thomas Renninger acked their removal from that side, you did from the ALSA side (CC list just copied from that thread). Against current alsa-kernel HG. Many more potential cleanups in there, but this _only_ removes the pnp_resource_change code. Compile tested against current alsa-kernel HG and compile- and use-tested against 2.6.23.x (few offsets). Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-05-11[ALSA] ad1816a: Fix modprobe snd_mpu401 && modprobe snd_ad1816aRask Ingemann Lambertsen
The ad1816a driver fails if the mpu401 driver has been loaded first. This patch against linux 2.6.20 fixes it by just ignoring the MPU-401 device in that case, so that the rest of the sound card can be used. The ad1816a driver already handles the MPU-401 device being unavailable due to lack of resources in the same way. Signed-off-by: Rask Ingemann Lambertsen <rask@sygehus.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-22[ALSA] sound/isa/ad1816a/ad1816a.c: check kmalloc() return valueAmit Choudhary
Check the return value of kmalloc() in function snd_card_ad1816a_pnp(), in file sound/isa/ad1816a/ad1816a.c. Signed-off-by: Amit Choudhary <amit2030@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] PNP: adjust pnp_register_card_driver() signature: ad1816aBjorn Helgaas
Remove the assumption that pnp_register_card_driver() returns the number of devices claimed. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[ALSA] ad1816a - Clean up PnP codeTakashi Iwai
Modules: AD1816A driver Clean up PnP code of ad1816a driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: ISA AD1816ATakashi Iwai
Modules: AD1816A driver Remove xxx_t typedefs from the ISA AD1816A driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] ad1816a - Add clockfreq module optionTakashi Iwai
Documentation,AD1816A driver Added clockfreq module option for the card with a different clock frequency than 33kHz. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-29[ALSA] Add PnP ID ADS7180Takashi Iwai
AD1816A driver Added PnP ID 'ADS7180' (AD1816?). Signed-off-by: Takashi Iwai <tiwai@suse.de>
