path: root/sound/firewire/dice
2015-10-19ALSA: dice: assign converted data to the same type of variableTakashi Sakamoto
In former commit, u32 data was assigned to __be32 variable instead of an int variable. This is not enough solution because it still causes sparse warnings. dice.c:80:23: warning: incorrect type in assignment (different base types) dice.c:80:23: expected restricted __be32 [usertype] value dice.c:80:23: got unsigned int dice.c:81:21: warning: restricted __be32 degrades to integer dice.c:81:46: warning: restricted __be32 degrades to integer This commit fixes this bug. Fixes: 7c2d4c0cf5ba('ALSA: dice: Split transaction functionality into a file') Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-10-19ALSA: dice: correct variable types for __be32 dataTakashi Sakamoto
Some local variables in some functions are typed as unsigned int, while __be32 value is assigned to them. This causes sparse warnings. dice-stream.c:50:17: warning: incorrect type in assignment (different base types) dice-stream.c:50:17: expected unsigned int [unsigned] channel dice-stream.c:50:17: got restricted __be32 [usertype] <noident> dice-stream.c:74:17: warning: incorrect type in assignment (different base types) dice-stream.c:74:17: expected unsigned int [unsigned] channel dice-stream.c:74:17: got restricted __be32 [usertype] <noident> This commit fixes this bug. Fixes: 288a8d0cb04f('ALSA: dice: Change the way to start stream') Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-10-18ALSA: fireworks/bebob/oxfw/dice: enable to make as built-inTakashi Sakamoto
When committed to upstream, these four modules had wrong entries for Makefile. This forces them to be loadable modules even if they're set as built-in. This commit fixes this bug. Fixes: b5b04336015e('ALSA: fireworks: Add skelton for Fireworks based devices') Fixes: fd6f4b0dc167('ALSA: bebob: Add skelton for BeBoB based devices') Fixes: 1a4e39c2e5ca('ALSA: oxfw: Move to its own directory') Fixes: 14ff6a094815('ALSA: dice: Move file to its own directory') Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-09-29ALSA: firewire-lib: rename macros with AM824 prefixTakashi Sakamoto
This commit renames some macros just related to AM824 format. In later commit, they're moved to AM824 layer. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-09-29ALSA: firewire-lib: rename PCM format helper functionTakashi Sakamoto
Setting the format of PCM substream to AMDTP stream structure is important to set a handler to copy actual PCM samples between buffers. The processing should be in data block processing layer because essentially it has no relationship to packet streaming. This commit renames PCM format setting function to prepare for integrating AM824 layer. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-09-29ALSA: firewire-lib: move MIDI trigger helper function to AM824 layerTakashi Sakamoto
In IEC 61883-6, MIDI messages are transferred in MIDI conformant data channel. Essentially, packet streaming layer is not responsible for MIDI functionality. This commit moves MIDI trigger helper function from the layer to AM824 layer. The rest of codes related to MIDI functionality will be moved in later commits. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-09-29ALSA: firewire-lib: add helper functions to set positions of data channelsTakashi Sakamoto
In IEC 61883-6, several types of data are available in AM824 format. The data is transferred in each data channel. The position of data channel in data block differs depending on model. Current implementation has an array to map the index of data channel in an data block to the position of actual data channel. The implementation allows each driver to access the mapping directly. In later commit, the mapping is in specific structure pushed into an opaque pointer. Helper functions are required. This commit adds the helper functions for this purpose. In IEC 61883-6, AM824 format supports many data types, while this specification easily causes over-engineering. Current AM824 implementation is allowed to handle two types of data, Multi Bit Linear Audio data (=PCM samples) and MIDI conformant data (=MIDI messages). Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-09-29ALSA: firewire-lib: move PCM substream constraint to AM824 layerTakashi Sakamoto
In IEC 61883-6, PCM frames are transferred in Multi Bit Linear Audio data channel. The data channel transfers 16/20/24 bit PCM samples. Thus, PCM substream has a constrain about it. This commit moves codes related to the constraint from packet streaming layer to AM824 data block processing layer. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-09-29ALSA: firewire-lib: rename parameter setting function for AM824 with FDF fieldTakashi Sakamoto
The value of FDF field in CIP header is protocol-dependent. Thus, it's better to allow data block processing layer to decide the value in any timing. In AM824 data format, the value of FDF field in CIP header indicates N-flag and Nominal Sampling Frequency Code (sfc). The N-flag is for switching 'Clock-based rate control mode' and 'Command-based rate control mode'. In our implementation, 'Clock-based rate control mode' is just supported. Therefore, When sampling transfer frequency is decided, then the FDF can be set. This commit replaces 'amdtp_stream_set_parameters' with 'amdtp_am824_set_parameters' to set the FDF. This is the same timing to decide the ration between the number of data blocks and the number of PCM frames. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-09-29ALSA: firewire-lib: add data block processing layer for AM824 formatTakashi Sakamoto
This commit adds data block processing layer for AM824 format. The new layer initializes streaming layer with its value for fmt field. Currently, most implementation of data block processing still remains streaming layer. In later commits, these codes will be moved to the layer. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-09-29ALSA: firewire-lib: rename 'amdtp' to 'amdtp-stream' to prepare for ↵Takashi Sakamoto
functional separation In later commit, data block processing layer will be newly added. This layer will be named as 'amdtp-am824'. This commit renames current amdtp file to amdtp-stream, to distinguish it from the new layer. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-09-29ALSA: firewire-lib: add an argument for Dice's dual wire modeTakashi Sakamoto
In IEC 61883-6, one data block represents one event. In ALSA, the event is one PCM frame. Therefore, when processing one data block, current implementation counts one PCM frame. On the other hand, Dice platform has a quirk called as 'dual wire' at higher sampling rate. In detail, see comment of commit 6eb6c81eee2a ("ALSA: dice: Split stream functionality into a file"). Currently, to handle this quirk, AMDTP stream structure has a 'double_pcm_frames' member. When this is enabled, two PCM frames are counted. Each driver set this flag by accessing the structure member directly. In future commit, some members related to AM824 data block will be moved to specific structure, to separate packet streaming layer and data block processing layer. The access will be limited by opaque pointer. For this reason, this commit adds an argument into amdtp_stream_set_parameter() to set the flag. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-09-29ALSA: firewire-lib: return error code when amdtp_stream_set_parameters() ↵Takashi Sakamoto
detects error Currently, amdtp_stream_set_parameters() returns no error even if wrong arguments are given. This is not good for streaming layer because drivers can continue processing ignoring capability of streaming layer. This commit changes this function to return error code. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-29ALSA: fireworks/bebob/dice/oxfw: fix substreams counting at vmalloc failureTakashi Sakamoto
In PCM core, when hw_params() in each driver returns error, the state of PCM substream is kept as 'open'. In this case, current drivers for sound units on IEEE 1394 bus doesn't decrement substream counter in hw_free() correctly. This causes these drivers to keep streams even if not required. This commit fixes this bug. When snd_pcm_lib_alloc_vmalloc_buffer() fails, hw_params function in each driver returns without incrementing the counter. Reported-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-03-10Revert "ALSA: dice: fix wrong offsets for Dice interface"Takashi Sakamoto
This reverts commit 8cdebf71098c07168ef6335e2f1f35d85dbe3049. The reverted commit breaks out-stream functionality of Dice driver. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-03-01ALSA: dice: fix wrong offsets for Dice interfaceTakashi Sakamoto
For received packet stream, the offset of 'RX_SEQ_START' locates after the offset of 'RX_NUMBER_MIDI', although current macro and proc output includes wrong offsets. Fortunately, this bug doesn't affect streaming functionality because these macro is not used. This commit fixes these wrong macro and outputs. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-02-23ALSA: fireworks/bebob/dice/oxfw: make it possible to shutdown safelyTakashi Sakamoto
A part of these drivers, especially BeBoB driver, are programmed to wait some events. Thus the drivers should not destroy any data in .remove() context. This commit moves some destructors from 'struct fw_driver.remove()' to 'struct snd_card.private_free()' to shutdown safely. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Cc: <stable@vger.kernel.org> # 3.19+ Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-02-23ALSA: fireworks/bebob/dice/oxfw: allow stream destructor after releasing runtimeTakashi Sakamoto
Currently stream destructor in each driver has a problem to be called in a context in which sound card object is released, because the destructors call amdtp_stream_pcm_abort() and touch PCM runtime data. The PCM runtime data is destroyed in application's context with snd_pcm_close(), on the other hand PCM substream data is destroyed after sound card object is released, in most case after all of ALSA character devices are released. When PCM runtime is destroyed and PCM substream is remained, amdtp_stream_pcm_abort() touches PCM runtime data and causes Null-pointer-dereference. This commit changes stream destructors and allows each driver to call it after releasing runtime. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Cc: <stable@vger.kernel.org> # 3.19+ Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-02-23ALSA: fireworks/bebob/dice/oxfw: add reference-counting for FireWire unitTakashi Sakamoto
Fireworks and Dice drivers try to touch instances of FireWire unit after sound card object is released, while references to the unit is decremented in .remove(). When unplugging during streaming, sound card object is released after .remove(), thus Fireworks and Dice drivers causes GPF or Null-pointer-dereferencing to application processes because an instance of FireWire unit was already released. This commit adds reference-counting for FireWire unit in drivers to allow them to touch an instance of FireWire unit after .remove(). In most case, any operations after .remove() may be failed safely. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Cc: <stable@vger.kernel.org> # 3.19+ Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: dice: Add support for MIDI capture/playbackTakashi Sakamoto
This commit adds a support for MIDI capture/playback When MIDI substrams already start streaming and PCM substreams are going to join at different sampling rate, streams are stopped once. Then sampling rate is changed and streams are restarted. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: dice: Add support for capturing PCM samplesTakashi Sakamoto
This commit adds a support for capturing PCM samples. When opposite PCM substream is already running, available sampling rate is limited at current one. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: dice: Support for non SYT-Match sampling clock source modeTakashi Sakamoto
This commit allows this driver to handle devices with non SYT-Match sampling clock source. When sampling clock source is SYT-Match mode, devices handle 'presentation timestamp' in received packets and generates sampling clock according to the information. In this case, driver is synchronization master and must transfer correct value in SYT field of each packets in outgoing stream, then the outgoing stream is a master stream. On the other hand, non SYT-Match mode, devices do this. So drivers must pick up the value in SYT field of incoming packets and use the value for outgoing stream. Currently firewire-lib module achieve this work. Furthermore, without SYT-Match and internal clock source, the sampling rate should be fixed for the other devices connected to the handled device. This commit add a restriction of sampling rate at this situation. With these implementations, this driver has no need to set clock source. This commit remove set function. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: dice: Add support for duplex streams with synchronizationTakashi Sakamoto
This commit adds support for AMDTP in-stream. As a result, Dice driver supports full duplex streams with synchronization. AMDTP can transfer timestamps in its packets. By handling the timestamp, devices can synchronize to the other devices or drivers on the same bus. When Dice chipset is 'enabled', it starts streams with correct settings. This 'enable' register is global, thus, when a stream is started to run, an opposite stream can't start unless turning off 'enable'. Therefore a pair of streams must be running. This causes a loss of CPU usage when single stream is needed for neither playbacking or capturing. This commit assumes that playback-only models also have a functionality to transmit stream for delivering timestamps. Currently, sampling clock source is restricted to SYT-Match mode. This is improved in followed commit. I note that at SYT-Match mode, Dice can select from 4 streams for synchronization but this driver uses the 1st stream only for simplicity. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-10ALSA: dice: Change the way to start streamTakashi Sakamoto
Streaming functionality can start streams when rate is given but currently some codes are in PCM functionality. This commit changes the way to start stream and add some arrangement to make it easy to understand the way. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-01ALSA: dice: fix semicolon.cocci warningsFengguang Wu
sound/firewire/dice/dice-transaction.c:34:2-3: Unneeded semicolon Removes unneeded semicolon. Generated by: scripts/coccinelle/misc/semicolon.cocci CC: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-11-29ALSA: dice: Add new functions for constraints of PCM parametersTakashi Sakamoto
This commit adds a new functions and some arrangement for PCM restriction. This arrangement is due to the number of channels which each Dice device has. I note that minimum number for period becomes 2, instead of 1 because its PCM functionality has SNDRV_PCM_INFO_BATCH, this means that the driver uses double (or more) buffering so the minimum number for period should be 2. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-11-29ALSA: dice: Split proc interface into a fileTakashi Sakamoto
This commit adds a file and move some codes related to proc output. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-11-29ALSA: dice: Split hwdep functionality into a fileTakashi Sakamoto
This commit adds a file and move some codes related to hwdep functionality. This interface is designed for mixer/control application. By using hwdep interface, the application can get information about firewire node, can lock/unlock kernel streaming and can get notification at starting/stopping kernel streaming. Additionally, this interface give a way to read Dice notification. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-11-29ALSA: dice: Split PCM functionality into a fileTakashi Sakamoto
This commit adds a file and move some codes related to PCM functionality. Currently PCM playback is supported. PCM capture will be supported in followed commits. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-11-29ALSA: dice: Split stream functionality into a fileTakashi Sakamoto
This commit adds a file with some helper functions for streaming, and move some codes into the file with some arrangements. Well-known CMP is not used to start/stop streams for Dice chipset. It's achieved by writing to specific address. We call this way as 'enable'. When devices are 'enabled', streaming starts in registered isochronous channel. Some helper functions are already implemented in previous commit. Basically, the stream is compliant to IEC 61883-6, so-called as AMDTP. But Dice has a specific quirk, so called-as 'Dual Wire'. This quirk is applied at 176.4/192.0kHz. In this mode, each packet includes double number of events than number in the specification, and stream runs at a half of sampling rate. There is another quirk at bus reset. Dice chipset handles drivers' request but don't re-enable streaming. So stream should be stopped. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-11-29ALSA: dice: Split transaction functionality into a fileTakashi Sakamoto
This commit adds a file with some helper functions for transaction, and move some codes into the file with some arrangements. For Dice chipset, well-known FCP or AV/C commands are not used to control devices. It's achieved by read/write transactions into specific addresses. Dice's address area is split into 5 areas. Each area has its own role. The offset for each area can be got by reading head of the address area. By reading these areas, drivers can get to know device status. By writing these areas, drivers can change device status. Dice has a specific mechanism called as 'notification'. When device status is changed, Dice devices tells the event by sending transaction. This notification is sent to an address which drivers register in advance. But this causes an issue to drivers. To handle the notification, drivers need to allocate its own callback function to the address region in host controller. This region is exclusive. For the other applications, drivers must give a mechanism to read the received notification. For this purpose, Dice driver already implements hwdep interface. Dice chipset doesn't allow drivers to register several addresses. In this reason, when this driver is applied to a device, the other drivers should _not_ try to register its own address to the device. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-11-29ALSA: dice: Move file to its own directoryTakashi Sakamoto
In followed commits, dice driver is split into several files. For easily managing these files, this commit adds subdirectory and move file into the directory. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
