path: root/sound/core/hwdep.c
2008-08-13ALSA: Kill snd_assert() in sound/core/*Takashi Iwai
Kill snd_assert() in sound/core/*, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-02-12[PATCH] mark struct file_operations const 9Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[ALSA] snd_hwdep_release() racefixKarsten Wiese
snd_card_file_remove() can free the snd_card. Touch hw->* only before calling snd_card_file_remove(). Unrelated: Allow hwdep devices not to have own ops.release(); Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] alsa core: convert to list_for_each_entry*Johannes Berg
This patch converts most uses of list_for_each to list_for_each_entry all across alsa. In some place apparently an item can be on a list with different pointers so of course that isn't compatible with list_for_each, I therefore didn't touch those places. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-10-06[ALSA] Dereference after free in snd_hwdep_release()Florin Malita
snd_card_file_remove() may free hw->card so we can't dereference hw->card->module after that. Coverity ID 1420. Signed-off-by: Florin Malita <fmalita@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Unregister device files at disconnectionTakashi Iwai
Orignally proposed by Sam Revitch <sam.revitch@gmail.com>. Unregister device files at disconnection to avoid the futher accesses. Also, the dev_unregister callback is removed and replaced with the combination of disconnect + free. A new function snd_card_free_when_closed() is introduced, which is used in USB disconnect callback. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] Fix disconnection of proc interfaceTakashi Iwai
- Add the linked list to each proc entry to enable a single-shot disconnection (unregister) - Deprecate snd_info_unregister(), use snd_info_free_entry() - Removed NULL checks of snd_info_free_entry() Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] semaphore -> mutex (core part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Optimize for config without PROC_FSTakashi Iwai
Modules: HWDEP Midlevel,ALSA Core,PCM Midlevel,Timer Midlevel Optimize the code when compiled without CONFIG_PROC_FS. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] dynamic minors (3/6): store device-specific object pointers dynamicallyClemens Ladisch
Instead of storing the pointers to the device-specific structures in an array, put them into the struct snd_minor, and look them up dynamically. This makes the device type modules independent of the minor number encoding. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] dynamic minors (1/6): store device type in struct snd_minorClemens Ladisch
Instead of a comment string, store the device type in the snd_minor structure. This makes snd_minor more flexible, and has the nice side effect that we don't need anymore to create a separate snd_minor template for registering a device but can pass the file_operations directly to snd_register_device(). Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] Add error messagesTakashi Iwai
Add error messages in the critial error path to be more verbose. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: HwdepTakashi Iwai
Modules: HWDEP Midlevel Remove xxx_t typedefs from the core hwdep codes. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] fix improper CONFIG_SND_MAJOR usageClemens Ladisch
Modules: HWDEP Midlevel,PCM Midlevel,RawMidi Midlevel,ALSA Core Replace usage of CONFIG_SND_MAJOR with snd_major, where appropriate. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-09-12[ALSA] Replace with kzalloc() - core stuffTakashi Iwai
Control Midlevel,ALSA Core,HWDEP Midlevel,PCM Midlevel,RawMidi Midlevel Timer Midlevel,ALSA<-OSS emulation Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
