After shrinking the common_audit_data stack usage for private LSM data I'm
not going to shrink the data union. To do this I'm going to move anything
larger than 2 void * ptrs to it's own structure and require it to be declared
separately on the calling stack. Thus hot paths which don't need more than
a couple pointer don't have to declare space to hold large unneeded
structures. I could get this down to one void * by dealing with the key
struct and the struct path. We'll see if that is helpful after taking care of
networking.
Signed-off-by: Eric Paris <eparis@redhat.com>
Linus found that the gigantic size of the common audit data caused a big
perf hit on something as simple as running stat() in a loop. This patch
requires LSMs to declare the LSM specific portion separately rather than
doing it in a union. Thus each LSM can be responsible for shrinking their
portion and don't have to pay a penalty just because other LSMs have a
bigger space requirement.
Pull second try at vfs part d#2 from Al Viro:
"Miklos' first series (with do_lookup() rewrite split into edible
chunks) + assorted bits and pieces.
The 'untangling of do_lookup()' series is is a splitup of what used to
be a monolithic patch from Miklos, so this series is basically "how do
I convince myself that his patch is correct (or find a hole in it)".
No holes found and I like the resulting cleanup, so in it went..."
Changes from try 1: Fix a boot problem with selinux, and commit messages
prettied up a bit.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (24 commits)
vfs: fix out-of-date dentry_unhash() comment
vfs: split __lookup_hash
untangling do_lookup() - take __lookup_hash()-calling case out of line.
untangling do_lookup() - switch to calling __lookup_hash()
untangling do_lookup() - merge d_alloc_and_lookup() callers
untangling do_lookup() - merge failure exits in !dentry case
untangling do_lookup() - massage !dentry case towards __lookup_hash()
untangling do_lookup() - get rid of need_reval in !dentry case
untangling do_lookup() - eliminate a loop.
untangling do_lookup() - expand the area under ->i_mutex
untangling do_lookup() - isolate !dentry stuff from the rest of it.
vfs: move MAY_EXEC check from __lookup_hash()
vfs: don't revalidate just looked up dentry
vfs: fix d_need_lookup/d_revalidate order in do_lookup
ext3: move headers to fs/ext3/
migrate ext2_fs.h guts to fs/ext2/ext2.h
new helper: ext2_image_size()
get rid of pointless includes of ext2_fs.h
ext2: No longer export ext2_fs.h to user space
mtdchar: kill persistently held vfsmount
Now that all the slow-path code is gone from these functions, we can
inline them into the main caller - avc_has_perm_flags().
Now the compiler can see that 'avc' is allocated on the stack for this
case, which helps register pressure a bit. It also actually shrinks the
total stack frame, because the stack frame that avc_has_perm_flags()
always needed (for that 'avc' allocation) is now sufficient for the
inlined functions too.
Inlining isn't bad - but mindless inlining of cold code (see the
previous commit) is.
The selinux AVC paths remain some of the hottest (and deepest) codepaths
at filename lookup time, and we make it worse by having the slow path
cases take up I$ and stack space even when they don't trigger. Gcc
tends to always want to inline functions that are just called once -
never mind that this might make for slower and worse code in the caller.
So this tries to improve on it a bit by making the slow-path cases
explicitly separate functions that are marked noinline, causing gcc to
at least no longer allocate stack space for them unless they are
actually called. It also seems to help register allocation a tiny bit,
since gcc now doesn't take the slow case code into account.
Uninlining the slow path may also allow us to inline the remaining hot
path into the one caller that actually matters: avc_has_perm_flags().
I'll have to look at that separately, but both avc_audit() and
avc_has_perm_noaudit() are now small and lean enough that inlining them
may make sense.
Pull x32 support for x86-64 from Ingo Molnar:
"This tree introduces the X32 binary format and execution mode for x86:
32-bit data space binaries using 64-bit instructions and 64-bit kernel
syscalls.
This allows applications whose working set fits into a 32 bits address
space to make use of 64-bit instructions while using a 32-bit address
space with shorter pointers, more compressed data structures, etc."
Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c}
* 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits)
x32: Fix alignment fail in struct compat_siginfo
x32: Fix stupid ia32/x32 inversion in the siginfo format
x32: Add ptrace for x32
x32: Switch to a 64-bit clock_t
x32: Provide separate is_ia32_task() and is_x32_task() predicates
x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls
x86/x32: Fix the binutils auto-detect
x32: Warn and disable rather than error if binutils too old
x32: Only clear TIF_X32 flag once
x32: Make sure TS_COMPAT is cleared for x32 tasks
fs: Remove missed ->fds_bits from cessation use of fd_set structs internally
fs: Fix close_on_exec pointer in alloc_fdtable
x32: Drop non-__vdso weak symbols from the x32 VDSO
x32: Fix coding style violations in the x32 VDSO code
x32: Add x32 VDSO support
x32: Allow x32 to be configured
x32: If configured, add x32 system calls to system call tables
x32: Handle process creation
x32: Signal-related system calls
x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Fix failure in aa_change_onexec api when the request is made from a confined
task. This failure was caused by two problems
The AA_MAY_ONEXEC perm was not being mapped correctly for this case.
The executable name was being checked as second time instead of using the
requested onexec profile name, which may not be the same as the exec
profile name. This mistake can not be exploited to grant extra permission
because of the above flaw where the ONEXEC permission was not being mapped
so it will not be granted.
BugLink: http://bugs.launchpad.net/bugs/963756
Signed-off-by: John Johansen <john.johansen@canonical.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
selinux/xfrm.h needs to #include net/flow.h or else suffer:
In file included from security/selinux/ss/services.c:69:0:
security/selinux/include/xfrm.h: In function 'selinux_xfrm_notify_policyload':
security/selinux/include/xfrm.h:53:14: error: 'flow_cache_genid' undeclared (first use in this function)
security/selinux/include/xfrm.h:53:14: note: each undeclared identifier is reported only once for each function it appears in
No functional changes. It is not sane to use UMH_KILLABLE with enum
umh_wait, but obviously we do not want another argument in
call_usermodehelper_* helpers. Kill this enum, use the plain int.
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Tejun Heo <tj@kernel.org>
A few call_usermodehelper() callers use the hardcoded constant instead of
the proper UMH_WAIT_PROC, fix them.
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Cc: Lars Ellenberg <drbd-dev@lists.linbit.com>
Cc: Michal Januszewski <spock@gentoo.org>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: Kentaro Takeda <takedakn@nttdata.co.jp>
Pull NFS client updates for Linux 3.4 from Trond Myklebust:
"New features include:
- Add NFS client support for containers.
This should enable most of the necessary functionality, including
lockd support, and support for rpc.statd, NFSv4 idmapper and
RPCSEC_GSS upcalls into the correct network namespace from which
the mount system call was issued.
- NFSv4 idmapper scalability improvements
Base the idmapper cache on the keyring interface to allow
concurrent access to idmapper entries. Start the process of
migrating users from the single-threaded daemon-based approach to
the multi-threaded request-key based approach.
- NFSv4.1 implementation id.
Allows the NFSv4.1 client and server to mutually identify each
other for logging and debugging purposes.
- Support the 'vers=4.1' mount option for mounting NFSv4.1 instead of
having to use the more counterintuitive 'vers=4,minorversion=1'.
- SUNRPC tracepoints.
Start the process of adding tracepoints in order to improve
debugging of the RPC layer.
- pNFS object layout support for autologin.
Important bugfixes include:
- Fix a bug in rpc_wake_up/rpc_wake_up_status that caused them to
fail to wake up all tasks when applied to priority waitqueues.
- Ensure that we handle read delegations correctly, when we try to
truncate a file.
- A number of fixes for NFSv4 state manager loops (mostly to do with
delegation recovery)."
* tag 'nfs-for-3.4-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (224 commits)
NFS: fix sb->s_id in nfs debug prints
xprtrdma: Remove assumption that each segment is <= PAGE_SIZE
xprtrdma: The transport should not bug-check when a dup reply is received
pnfs-obj: autologin: Add support for protocol autologin
NFS: Remove nfs4_setup_sequence from generic rename code
NFS: Remove nfs4_setup_sequence from generic unlink code
NFS: Remove nfs4_setup_sequence from generic read code
NFS: Remove nfs4_setup_sequence from generic write code
NFS: Fix more NFS debug related build warnings
SUNRPC/LOCKD: Fix build warnings when CONFIG_SUNRPC_DEBUG is undefined
nfs: non void functions must return a value
SUNRPC: Kill compiler warning when RPC_DEBUG is unset
SUNRPC/NFS: Add Kbuild dependencies for NFS_DEBUG/RPC_DEBUG
NFS: Use cond_resched_lock() to reduce latencies in the commit scans
NFSv4: It is not safe to dereference lsp->ls_state in release_lockowner
NFS: ncommit count is being double decremented
SUNRPC: We must not use list_for_each_entry_safe() in rpc_wake_up()
Try using machine credentials for RENEW calls
NFSv4.1: Fix a few issues in filelayout_commit_pagelist
NFSv4.1: Clean ups and bugfixes for the pNFS read/writeback/commit code
avc_audit() did a lot of jumping around and had a big stack frame, all
for the uncommon case.
Split up the uncommon case (which we really can't make go fast anyway)
into its own slow function, and mark the conditional branches
appropriately for the common likely case.
This causes avc_audit() to no longer show up as one of the hottest
functions on the branch profiles (the new "perf -b" thing), and makes
the cycle profiles look really nice and dense too.
The whole audit path is still annoyingly very much one of the biggest
costs of name lookup, so these things are worth optimizing for. I wish
we could just tell people to turn it off, but realistically we do need
it: we just need to make sure that the overhead of the necessary evil is
as low as possible.
Pull vfs pile 1 from Al Viro:
"This is _not_ all; in particular, Miklos' and Jan's stuff is not there
yet."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits)
ext4: initialization of ext4_li_mtx needs to be done earlier
debugfs-related mode_t whack-a-mole
hfsplus: add an ioctl to bless files
hfsplus: change finder_info to u32
hfsplus: initialise userflags
qnx4: new helper - try_extent()
qnx4: get rid of qnx4_bread/qnx4_getblk
take removal of PF_FORKNOEXEC to flush_old_exec()
trim includes in inode.c
um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it
um: embed ->stub_pages[] into mmu_context
gadgetfs: list_for_each_safe() misuse
ocfs2: fix leaks on failure exits in module_init
ecryptfs: make register_filesystem() the last potential failure exit
ntfs: forgets to unregister sysctls on register_filesystem() failure
logfs: missing cleanup on register_filesystem() failure
jfs: mising cleanup on register_filesystem() failure
make configfs_pin_fs() return root dentry on success
configfs: configfs_create_dir() has parent dentry in dentry->d_parent
configfs: sanitize configfs_create()
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates for 3.4 from James Morris:
"The main addition here is the new Yama security module from Kees Cook,
which was discussed at the Linux Security Summit last year. Its
purpose is to collect miscellaneous DAC security enhancements in one
place. This also marks a departure in policy for LSM modules, which
were previously limited to being standalone access control systems.
Chromium OS is using Yama, and I believe there are plans for Ubuntu,
at least.
This patchset also includes maintenance updates for AppArmor, TOMOYO
and others."
Fix trivial conflict in <net/sock.h> due to the jumo_label->static_key
rename.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits)
AppArmor: Fix location of const qualifier on generated string tables
TOMOYO: Return error if fails to delete a domain
AppArmor: add const qualifiers to string arrays
AppArmor: Add ability to load extended policy
TOMOYO: Return appropriate value to poll().
AppArmor: Move path failure information into aa_get_name and rename
AppArmor: Update dfa matching routines.
AppArmor: Minor cleanup of d_namespace_path to consolidate error handling
AppArmor: Retrieve the dentry_path for error reporting when path lookup fails
AppArmor: Add const qualifiers to generated string tables
AppArmor: Fix oops in policy unpack auditing
AppArmor: Fix error returned when a path lookup is disconnected
KEYS: testing wrong bit for KEY_FLAG_REVOKED
TOMOYO: Fix mount flags checking order.
security: fix ima kconfig warning
AppArmor: Fix the error case for chroot relative path name lookup
AppArmor: fix mapping of META_READ to audit and quiet flags
AppArmor: Fix underflow in xindex calculation
AppArmor: Fix dropping of allowed operations that are force audited
AppArmor: Add mising end of structure test to caps unpacking
Pull kmap_atomic cleanup from Cong Wang.
It's been in -next for a long time, and it gets rid of the (no longer
used) second argument to k[un]map_atomic().
Fix up a few trivial conflicts in various drivers, and do an "evil
merge" to catch some new uses that have come in since Cong's tree.
* 'kmap_atomic' of git://github.com/congwang/linux: (59 commits)
feature-removal-schedule.txt: schedule the deprecated form of kmap_atomic() for removal
highmem: kill all __kmap_atomic() [swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename]
drbd: remove the second argument of k[un]map_atomic()
zcache: remove the second argument of k[un]map_atomic()
gma500: remove the second argument of k[un]map_atomic()
dm: remove the second argument of k[un]map_atomic()
tomoyo: remove the second argument of k[un]map_atomic()
sunrpc: remove the second argument of k[un]map_atomic()
rds: remove the second argument of k[un]map_atomic()
net: remove the second argument of k[un]map_atomic()
mm: remove the second argument of k[un]map_atomic()
lib: remove the second argument of k[un]map_atomic()
power: remove the second argument of k[un]map_atomic()
kdb: remove the second argument of k[un]map_atomic()
udf: remove the second argument of k[un]map_atomic()
ubifs: remove the second argument of k[un]map_atomic()
squashfs: remove the second argument of k[un]map_atomic()
reiserfs: remove the second argument of k[un]map_atomic()
ocfs2: remove the second argument of k[un]map_atomic()
ntfs: remove the second argument of k[un]map_atomic()
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup changes from Tejun Heo:
"Out of the 8 commits, one fixes a long-standing locking issue around
tasklist walking and others are cleanups."
* 'for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: Walk task list under tasklist_lock in cgroup_enable_task_cg_list
cgroup: Remove wrong comment on cgroup_enable_task_cg_list()
cgroup: remove cgroup_subsys argument from callbacks
cgroup: remove extra calls to find_existing_css_set
cgroup: replace tasklist_lock with rcu_read_lock
cgroup: simplify double-check locking in cgroup_attach_proc
cgroup: move struct cgroup_pidlist out from the header file
cgroup: remove cgroup_attach_task_current_cg()
Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Signed-off-by: Cong Wang <amwang@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jj/linux-apparmor into next
Signed-off-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Call sequence:
tomoyo_write_domain() --> tomoyo_delete_domain()
In 'tomoyo_delete_domain', return -EINTR if locking attempt is
interrupted by signal.
At present it returns success to its caller 'tomoyo_write_domain()'
even though domain is not deleted. 'tomoyo_write_domain()' assumes
domain is deleted and returns success to its caller. This is wrong behaviour.
'tomoyo_write_domain' should return error from tomoyo_delete_domain() to its
caller.
Signed-off-by: Santosh Nayak <santoshprasadnayak@gmail.com>
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Add the base support for the new policy extensions. This does not bring
any additional functionality, or change current semantics.
Acked-by: Kees Cook <kees@ubuntu.com>
"struct file_operations"->poll() expects "unsigned int" return value.
All files in /sys/kernel/security/tomoyo/ directory other than
/sys/kernel/security/tomoyo/query and /sys/kernel/security/tomoyo/audit should
return POLLIN | POLLRDNORM | POLLOUT | POLLWRNORM rather than -ENOSYS.
Also, /sys/kernel/security/tomoyo/query and /sys/kernel/security/tomoyo/audit
should return POLLOUT | POLLWRNORM rather than 0 when there is no data to read.
Move the path name lookup failure messages into the main path name lookup
routine, as the information is useful in more than just aa_path_perm.
Also rename aa_get_name to aa_path_name as it is not getting a reference
counted object with a corresponding put fn.
Update aa_dfa_match so that it doesn't result in an input string being
walked twice (once to get its length and another time to match)
Add a single step functions
aa_dfa_next
When __d_path and d_absolute_path fail due to the name being outside of
the current namespace no name is reported. Use dentry_path to provide
some hint as to which file was being accessed.
Post unpacking of policy a verification pass is made on x transition
indexes. When this fails a call to audit_iface is made resulting in an
oops, because audit_iface is expecting a valid buffer position but
since the failure comes from post unpack verification there is none.
Make the position argument optional so that audit_iface can be called
from post unpack verification.
The returning of -ESATLE when a path lookup fails as disconnected is wrong.
Since AppArmor is rejecting the access return -EACCES instead.
This also fixes a bug in complain (learning) mode where disconnected paths
are denied because -ESTALE errors are not ignored causing failures that
can change application behavior.
The test for "if (cred->request_key_auth->flags & KEY_FLAG_REVOKED) {"
should actually testing that the (1 << KEY_FLAG_REVOKED) bit is set.
The current code actually checks for KEY_FLAG_DEAD.
The keyctl_set_timeout function isn't exported to other parts of the
kernel, but I want to use it for the NFS idmapper. I already have the
key, but I wanted a generic way to set the timeout.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Userspace can pass in arbitrary combinations of MS_* flags to mount().
If both MS_BIND and one of MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE are
passed, device name which should be checked for MS_BIND was not checked because
MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE had higher priority than MS_BIND.
If both one of MS_BIND/MS_MOVE and MS_REMOUNT are passed, device name which
should not be checked for MS_REMOUNT was checked because MS_BIND/MS_MOVE had
higher priority than MS_REMOUNT.
Fix these bugs by changing priority to MS_REMOUNT -> MS_BIND ->
MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE -> MS_MOVE as with do_mount() does.
Also, unconditionally return -EINVAL if more than one of
MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE is passed so that TOMOYO will not
generate inaccurate audit logs, for commit 7a2e8a8f "VFS: Sanity check mount
flags passed to change_mnt_propagation()" clarified that these flags must be
exclusively passed.
Fix IMA kconfig warning on non-X86 architectures:
warning: (IMA) selects TCG_TIS which has unmet direct dependencies
(TCG_TPM && X86)
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
When a chroot relative pathname lookup fails it is falling through to
do a d_absolute_path lookup. This is incorrect as d_absolute_path should
only be used to lookup names for namespace absolute paths.
The mapping of AA_MAY_META_READ for the allow mask was also being mapped
to the audit and quiet masks. This would result in some operations being
audited when the should not.
This flaw was hidden by the previous audit bug which would drop some
messages that where supposed to be audited.
If the xindex value stored in the accept tables is 0, the extraction of
that value will result in an underflow (0 - 4).
In properly compiled policy this should not happen for file rules but
it may be possible for other rule types in the future.
To exploit this underflow a user would have to be able to load a corrupt
policy, which requires CAP_MAC_ADMIN, overwrite system policy in kernel
memory or know of a compiler error resulting in the flaw being present
for loaded policy (no such flaw is known at this time).
The audit permission flag, that specifies an audit message should be
provided when an operation is allowed, was being ignored in some cases.
This is because the auto audit mode (which determines the audit mode from
system flags) was incorrectly assigned the same value as audit mode. The
shared value would result in messages that should be audited going through
a second evaluation as to whether they should be audited based on the
auto audit, resulting in some messages being dropped.
The unpacking of struct capsx is missing a check for the end of the
caps structure. This can lead to unpack failures depending on what else
is packed into the policy file being unpacked.
Since the parser needs to know which rlimits are known to the kernel,
export the list via a mask file in the "rlimit" subdirectory in the
securityfs "features" directory.
Signed-off-by: Kees Cook <kees@ubuntu.com>
Create the "file" directory in the securityfs for tracking features
related to files.
This adds the "features" subdirectory to the AppArmor securityfs
to display boolean features flags and the known capability mask.
Use a file tree structure to represent the AppArmor securityfs.
Replace the fd_sets in struct fdtable with an array of unsigned longs and then
use the standard non-atomic bit operations rather than the FD_* macros.
This:
(1) Removes the abuses of struct fd_set:
(a) Since we don't want to allocate a full fd_set the vast majority of the
time, we actually, in effect, just allocate a just-big-enough array of
unsigned longs and cast it to an fd_set type - so why bother with the
fd_set at all?
(b) Some places outside of the core fdtable handling code (such as
SELinux) want to look inside the array of unsigned longs hidden inside
the fd_set struct for more efficient iteration over the entire set.
(2) Eliminates the use of FD_*() macros in the kernel completely.
(3) Permits the __FD_*() macros to be deleted entirely where not exposed to
userspace.
Link: http://lkml.kernel.org/r/20120216174954.23314.48147.stgit@warthog.procyon.org.uk
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
