path: root/security/tomoyo/file.c
2010-08-02TOMOYO: Use pathname specified by policy rather than execve()Tetsuo Handa
Commit c9e69318 "TOMOYO: Allow wildcard for execute permission." changed execute permission and domainname to accept wildcards. But tomoyo_find_next_domain() was using pathname passed to execve() rather than pathname specified by the execute permission. As a result, processes were not able to transit to domains which contain wildcards in their domainnames. This patch passes pathname specified by the execute permission back to tomoyo_find_next_domain() so that processes can transit to domains which contain wildcards in their domainnames. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Rename symbols.Tetsuo Handa
Use shorter name in order to make it easier to fit 80 columns limit. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Aggregate reader functions.Tetsuo Handa
Now lists are accessible via array index. Aggregate reader functions using index. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Use array of "struct list_head".Tetsuo Handa
Assign list id and make the lists as array of "struct list_head". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Merge tomoyo_path_group and tomoyo_number_groupTetsuo Handa
"struct tomoyo_path_group" and "struct tomoyo_number_group" are identical. Rename tomoyo_path_group/tomoyo_number_group to tomoyo_group and tomoyo_path_group_member to tomoyo_path_group and tomoyo_number_group_member to tomoyo_unmber_group. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Merge functions.Tetsuo Handa
Embed tomoyo_path_number_perm2() into tomoyo_path_number_perm(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Remove wrapper function for reading keyword.Tetsuo Handa
Keyword strings are read-only. We can directly access them to reduce code size. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
Use shorter name in order to make it easier to fix 80 columns limit. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Use callback for permission check.Tetsuo Handa
We can use callback function since parameters are passed via "const struct tomoyo_request_info". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Pass parameters via structure.Tetsuo Handa
To make it possible to use callback function, pass parameters via "struct tomoyo_request_info". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Use common code for open and mkdir etc.Tetsuo Handa
tomoyo_file_perm() and tomoyo_path_permission() are similar. We can embed tomoyo_file_perm() into tomoyo_path_permission(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Use callback for updating entries.Tetsuo Handa
Use common code for elements using "struct list_head" + "bool" structure. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Use common structure for list element.Tetsuo Handa
Use common "struct list_head" + "bool" structure. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
Use common "struct list_head" + "bool" + "u8" structure and use common code for elements using that structure. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Update profile structure.Tetsuo Handa
This patch allows users to change access control mode for per-operation basis. This feature comes from non LSM version of TOMOYO which is designed for permitting users to use SELinux and TOMOYO at the same time. SELinux does not care filename in a directory whereas TOMOYO does. Change of filename can change how the file is used. For example, renaming index.txt to .htaccess will change how the file is used. Thus, letting SELinux to enforce read()/write()/mmap() etc. restriction and letting TOMOYO to enforce rename() restriction is an example usage of this feature. What is unfortunate for me is that currently LSM does not allow users to use SELinux and LSM version of TOMOYO at the same time... Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Allow wildcard for execute permission.Tetsuo Handa
Some applications create and execute programs dynamically. We need to accept wildcard for execute permission because such programs contain random suffix in their filenames. This patch loosens up regulation of string parameters. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Support longer pathname.Tetsuo Handa
Allow pathnames longer than 4000 bytes. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Split files into some pieces.Tetsuo Handa
security/tomoyo/common.c became too large to read. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Add interactive enforcing mode.Tetsuo Handa
Since the behavior of the system is restricted by policy, we may need to update policy when you update packages. We need to update policy in the following cases. * The pathname of files has changed. * The dependency of files has changed. * The access permissions required has increased. The ideal way to update policy is to rebuild from the scratch using learning mode. But it is not desirable to change from enforcing mode to other mode if the system has once entered in production state. Suppose MAC could support per-application enforcing mode, the MAC becomes useless if an application that is not running in enforcing mode was cracked. For example, the whole system becomes vulnerable if only HTTP server application is running in learning mode to rebuild policy for the application. So, in TOMOYO Linux, updating policy is done while the system is running in enforcing mode. This patch implements "interactive enforcing mode" which allows administrators to judge whether to accept policy violation in enforcing mode or not. A demo movie is available at http://www.youtube.com/watch?v=b9q1Jo25LPA . Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Add mount restriction.Tetsuo Handa
mount(2) has three string and one numeric parameters. Split mount restriction code from security/tomoyo/file.c . Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Split file access control functions by type of parameters.Tetsuo Handa
Check numeric parameters for operations that deal them (e.g. chmod/chown/ioctl). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Use structure for passing common arguments.Tetsuo Handa
Use "struct tomoyo_request_info" instead of passing individual arguments. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-08-02TOMOYO: Add numeric values grouping support.Tetsuo Handa
This patch adds numeric values grouping support, which is useful for grouping numeric values such as file's UID, DAC's mode, ioctl()'s cmd number. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-17TOMOYO: Add pathname grouping support.Tetsuo Handa
This patch adds pathname grouping support, which is useful for grouping pathnames that cannot be represented using /\{dir\}/ pattern. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-10TOMOYO: Use stack memory for pending entry.Tetsuo Handa
Use stack memory for pending entry to reduce kmalloc() which will be kfree()d. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-06TOMOYO: Use mutex_lock_interruptible.Tetsuo Handa
Some of TOMOYO's functions may sleep after mutex_lock(). If OOM-killer selected a process which is waiting at mutex_lock(), the to-be-killed process can't be killed. Thus, replace mutex_lock() with mutex_lock_interruptible() so that the to-be-killed process can immediately return from TOMOYO's functions. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-05-06Merge branch 'master' into nextJames Morris
2010-05-06TOMOYO: Use GFP_NOFS rather than GFP_KERNEL.Tetsuo Handa
In Ubuntu, security_path_*() hooks are exported to Unionfs. Thus, prepare for being called from inside VFS functions because I'm not sure whether it is safe to use GFP_KERNEL or not. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-17TOMOYO: Remove __func__ from tomoyo_is_correct_path/domainTetsuo Handa
__func__ is used for only debug printk(). We can remove it. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-02-16TOMOYO: Remove unneeded parameter.Tetsuo Handa
tomoyo_path_perm() tomoyo_path2_perm() and tomoyo_check_rewrite_permission() always receive tomoyo_domain(). We can move it from caller to callee. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-02-16TOMOYO: Use shorter names.Tetsuo Handa
Use shorter name to reduce newlines needed for 80 columns limit. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-02-15TOMOYO: Add garbage collector.Tetsuo Handa
This patch adds garbage collector support to TOMOYO. Elements are protected by "struct srcu_struct tomoyo_ss". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-02-15TOMOYO: Merge headers.Tetsuo Handa
Gather structures and constants scattered around security/tomoyo/ directory. This is for preparation for adding garbage collector since garbage collector needs to know structures and constants which TOMOYO uses. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-02-15TOMOYO: Add refcounter on string data.Tetsuo Handa
Add refcounter to "struct tomoyo_name_entry" and replace tomoyo_save_name() with tomoyo_get_name()/tomoyo_put_name() pair so that we can kfree() when garbage collector is added. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-02-11TOMOYO: Reduce lines by using common path for addition and deletion.Tetsuo Handa
Since the codes for adding an entry and removing an entry are similar, we can save some lines by using "if (is_delete) { ... } else { ... }" branches. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-02-08TOMOYO: Extract bitfieldTetsuo Handa
Since list elements are rounded up to kmalloc() size rather than sizeof(int), saving one byte by using bitfields is no longer helpful. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-01-27TOMOYO: Remove usage counter for temporary memory.Tetsuo Handa
TOMOYO was using own memory usage counter for detecting memory leak. But as kernel 2.6.31 introduced memory leak detection mechanism ( CONFIG_DEBUG_KMEMLEAK ), we no longer need to have own counter. We remove usage counter for memory used for permission checks, but we keep usage counter for memory used for policy so that we can apply quota. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-01-18Merge branch 'master' into nextJames Morris
2010-01-11TOMOYO: Remove memory pool for list elements.Tetsuo Handa
Currently, TOMOYO allocates memory for list elements from memory pool allocated by kmalloc(PAGE_SIZE). But that makes it difficult to kfree() when garbage collector is added. Thus, remove memory pool and use kmalloc(sizeof()). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2010-01-11TOMOYO: Replace rw_semaphore by mutex.Tetsuo Handa
Since readers no longer use down_read(), writers no longer need to use rw_semaphore. Replace individual rw_semaphore by single mutex. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-12-22Sanitize f_flags helpersAl Viro
* pull ACC_MODE to fs.h; we have several copies all over the place * nightmarish expression calculating f_mode by f_flags deserves a helper too (OPEN_FMODE(flags)) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-15TOMOYO: Use RCU primitives for list operationTetsuo Handa
Replace list operation with RCU primitives and replace down_read()/up_read() with srcu_read_lock()/srcu_read_unlock(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-12-09Merge branch 'master' into nextJames Morris
2009-12-08TOMOYO: Add rest of file operation restrictions.Tetsuo Handa
LSM hooks for chmod()/chown()/chroot() are now ready. This patch utilizes these hooks. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-11-20security/tomoyo: Remove now unnecessary handling of security_sysctl.Eric W. Biederman
Now that sys_sysctl is an emulation on top of proc sys all sysctl operations look like normal filesystem operations and we don't need to use the special sysctl hook to authenticate them. Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-06-09TOMOYO: Add description of lists and structures.Tetsuo Handa
This patch adds some descriptions of lists and structures. This patch contains no code changes. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-04TOMOYO: Remove unused parameter.Tetsuo Handa
TOMOYO 2.2.0 does not check argv[] and envp[] upon execve(). We don't need to pass "struct tomoyo_page_buffer". Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-03TOMOYO: Simplify policy reader.Tetsuo Handa
We can directly assign the result of tomoyo_io_printf() to done flag. Signed-off-by: Kentaro Takeda <takedakn@nttdata.co.jp> Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Toshiharu Harada <haradats@nttdata.co.jp> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-03TOMOYO: Remove redundant markers.Tetsuo Handa
Remove '/***** START/STOP *****/' markers. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
