Convert avc_audit in security/selinux/avc.c to use lsm_audit.h,
for better maintainability and for less code duplication.
- changed selinux to use common_audit_data instead of
avc_audit_data
- eliminated code in avc.c and used code from lsm_audit.h instead.
I have tested to make sure that the avcs look the same before and
after this patch.
Signed-off-by: Thomas Liu <tliu@redhat.com>
Acked-by: Eric Paris <eparis@redhat.com>
Signed-off-by: James Morris <jmorris@namei.org>
Added a call to free the avc_node_cache when inside selinux_disable because
it should not waste resources allocated during avc_init if SELinux is disabled
and the cache will never be used.
The ->ptrace_may_access() methods are named confusingly - the real
ptrace_may_access() returns a bool, while these security checks have
a retval convention.
Rename it to ptrace_access_check, to reduce the confusion factor.
[ Impact: cleanup, no code changed ]
Restore the optimization to skip revalidation in selinux_file_permission
if nothing has changed since the dentry_open checks, accidentally removed by
389fb800. Also remove redundant test from selinux_revalidate_file_permission.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Reviewed-by: Paul Moore <paul.moore@hp.com>
The attached patch adds support to generate audit messages on two cases.
The first one is a case when a multi-thread process tries to switch its
performing security context using setcon(3), but new security context is
not bounded by the old one.
type=SELINUX_ERR msg=audit(1245311998.599:17): \
op=security_bounded_transition result=denied \
oldcontext=system_u:system_r:httpd_t:s0 \
newcontext=system_u:system_r:guest_webapp_t:s0
The other one is a case when security_compute_av() masked any permissions
due to the type boundary violation.
type=SELINUX_ERR msg=audit(1245312836.035:32): \
op=security_compute_av reason=bounds \
scontext=system_u:object_r:user_webapp_t:s0 \
tcontext=system_u:object_r:shadow_t:s0:c0 \
tclass=file perms=getattr,open
Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
It is a cleanup patch to cut down a line within 80 columns.
security/selinux/ss/services.c | 6 +++---
1 files changed, 3 insertions(+), 3 deletions(-)
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/feature-removal-schedule.txt
drivers/scsi/fcoe/fcoe.c
net/core/drop_monitor.c
net/core/net-traces.c
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
Audit trees defined 2 new netlink messages but the netlink mapping tables for
selinux permissions were not set up. This patch maps these 2 new operations
to AUDIT_WRITE.
Signed-off-by: Eric Paris <eparis@redhat.com>
On Tue, 2009-05-19 at 00:05 -0400, Eamon Walsh wrote:
> Recent versions of coreutils have bumped the read buffer size from 4K to
> 32K in several of the utilities.
> This means that "cat /selinux/booleans/xserver_object_manager" no longer
> works, it returns "Invalid argument" on F11. getsebool works fine.
> sel_read_bool has a check for "count > PAGE_SIZE" that doesn't seem to
> be present in the other read functions. Maybe it could be removed?
Yes, that check is obsoleted by the conversion of those functions to
using simple_read_from_buffer(), which will reduce count if necessary to
what is available in the buffer.
The selinuxfs superblock magic is used inside the IMA code, but is being
defined in two places and could someday get out of sync. This patch moves the
declaration into magic.h so it is only done once.
The CRED patch incorrectly converted the SELinux send_sigiotask hook to
use the current task SID rather than the target task SID in its
permission check, yielding the wrong permission check. This fixes the
hook function. Detected by the ltp selinux testsuite and confirmed to
correct the test failure.
->parent.
We shouldn't worry about the tracer if current is ptraced, exec() must not
succeed if the tracer has no rights to trace this task after cred changing.
But we should notify ->real_parent which is, well, real parent.
Also, we don't need _irq to take tasklist, and we don't need parent's
->siglock to wake_up_interruptible(real_parent->signal->wait_chldexit).
Since we hold tasklist, real_parent->signal must be stable. Otherwise
spin_lock(siglock) is not safe too and can't help anyway.
Don't flush inherited SIGKILL during execve() in SELinux's post cred commit
hook. This isn't really a security problem: if the SIGKILL came before the
credentials were changed, then we were right to receive it at the time, and
should honour it; if it came after the creds were changed, then we definitely
should honour it; and in any case, all that will happen is that the process
will be scrapped before it ever returns to userspace.
We are still calling secondary_ops->sysctl even though the capabilities
module does not define a sysctl operation.
This patch enables applications to handle permissive domain correctly.
Since the v2.6.26 kernel, SELinux has supported an idea of permissive
domain which allows certain processes to work as if permissive mode,
even if the global setting is enforcing mode.
However, we don't have an application program interface to inform
what domains are permissive one, and what domains are not.
It means applications focuses on SELinux (XACE/SELinux, SE-PostgreSQL
and so on) cannot handle permissive domain correctly.
This patch add the sixth field (flags) on the reply of the /selinux/access
interface which is used to make an access control decision from userspace.
If the first bit of the flags field is positive, it means the required
access control decision is on permissive domain, so application should
allow any required actions, as the kernel doing.
This patch also has a side benefit. The av_decision.flags is set at
context_struct_compute_av(). It enables to check required permissions
without read_lock(&policy_rwlock).
security/selinux/avc.c | 2 +-
security/selinux/include/security.h | 4 +++-
security/selinux/selinuxfs.c | 4 ++--
security/selinux/ss/services.c | 30 +++++-------------------------
4 files changed, 11 insertions(+), 29 deletions(-)
The SELinux "compat_net" is marked as deprecated, the time has come to
finally remove it from the kernel. Further code simplifications are
likely in the future, but this patch was intended to be a simple,
straight-up removal of the compat_net code.
Signed-off-by: Paul Moore <paul.moore@hp.com>
The current NetLabel/SELinux behavior for incoming TCP connections works but
only through a series of happy coincidences that rely on the limited nature of
standard CIPSO (only able to convey MLS attributes) and the write equality
imposed by the SELinux MLS constraints. The problem is that network sockets
created as the result of an incoming TCP connection were not on-the-wire
labeled based on the security attributes of the parent socket but rather based
on the wire label of the remote peer. The issue had to do with how IP options
were managed as part of the network stack and where the LSM hooks were in
relation to the code which set the IP options on these newly created child
sockets. While NetLabel/SELinux did correctly set the socket's on-the-wire
label it was promptly cleared by the network stack and reset based on the IP
options of the remote peer.
This patch, in conjunction with a prior patch that adjusted the LSM hook
locations, works to set the correct on-the-wire label format for new incoming
connections through the security_inet_conn_request() hook. Besides the
correct behavior there are many advantages to this change, the most significant
is that all of the NetLabel socket labeling code in SELinux now lives in hooks
which can return error codes to the core stack which allows us to finally get
ride of the selinux_netlbl_inode_permission() logic which greatly simplfies
the NetLabel/SELinux glue code. In the process of developing this patch I
also ran into a small handful of AF_INET6 cleanliness issues that have been
fixed which should make the code safer and easier to extend in the future.
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
Drop the printk message when an inode is found without an associated
dentry. This should only happen when userspace can't be accessing those
inodes and those labels will get set correctly on the next d_instantiate.
Thus there is no reason to send this message.
New selinux permission to separate the ability to turn on tty auditing from
the ability to set audit rules.
When I did open permissions I didn't think any sockets would have an open.
Turns out AF_UNIX sockets can have an open when they are bound to the
filesystem namespace. This patch adds a new SOCK_FILE__OPEN permission.
It's safe to add this as the open perms are already predicated on
capabilities and capabilities means we have unknown perm handling so
systems should be as backwards compatible as the policy wants them to
be.
https://bugzilla.redhat.com/show_bug.cgi?id=475224
Rick McNeal from LSI identified a panic in selinux_netlbl_inode_permission()
caused by a certain sequence of SUNRPC operations. The problem appears to be
due to the lack of NULL pointer checking in the function; this patch adds the
pointer checks so the function will exit safely in the cases where the socket
is not completely initialized.
At some point we (okay, I) managed to break the ability for users to use the
setsockopt() syscall to set IPv4 options when NetLabel was not active on the
socket in question. The problem was noticed by someone trying to use the
"-R" (record route) option of ping:
# ping -R 10.0.0.1
ping: record route: No message of desired type
The solution is relatively simple, we catch the unlabeled socket case and
clear the error code, allowing the operation to succeed. Please note that we
still deny users the ability to override IPv4 options on socket's which have
NetLabel labeling active; this is done to ensure the labeling remains intact.
We do not need O(1) access to the tail of the avc cache lists and so we are
wasting lots of space using struct list_head instead of struct hlist_head.
This patch converts the avc cache to use hlists in which there is a single
pointer from the head which saves us about 4k of global memory.
Resulted in about a 1.5% decrease in time spent in avc_has_perm_noaudit based
on oprofile sampling of tbench. Although likely within the noise....
The code making use of struct avc_cache was not easy to read thanks to liberal
use of &avc_cache.{slots_lock,slots}[hvalue] throughout. This patch simply
creates local pointers and uses those instead of the long global names.
It appears there was an intention to have the security server only decide
certain permissions and leave other for later as some sort of a portential
performance win. We are currently always deciding all 32 bits of
permissions and this is a useless couple of branches and wasted space.
This patch completely drops the av.decided concept.
This in a 17% reduction in the time spent in avc_has_perm_noaudit
based on oprofile sampling of a tbench benchmark.
we are often needlessly jumping through hoops when it comes to avd
entries in avc_has_perm_noaudit and we have extra initialization and memcpy
which are just wasting performance. Try to clean the function up a bit.
This patch resulted in a 13% drop in time spent in avc_has_perm_noaudit in my
Currently SELinux code has an atomic which was intended to track how many
times an avc entry was used and to evict entries when they haven't been
used recently. Instead we never let this atomic get above 1 and evict when
it is first checked for eviction since it hits zero. This is a total waste
of time so I'm completely dropping ae.used.
This change resulted in about a 3% faster avc_has_perm_noaudit when running
oprofile against a tbench benchmark.
Reviewed by: Paul Moore <paul.moore@hp.com>
The avc update node callbacks do not check the seqno of the caller with the
seqno of the node found. It is possible that a policy change could happen
(although almost impossibly unlikely) in which a permissive or
permissive_domain decision is not valid for the entry found. Simply pass
and check that the seqno of the caller and the seqno of the node found
match.
When a context is pulled in from disk we don't know that it is null
terminated. This patch forecebly null terminates contexts when we pull
them from disk.
Currently when an inode is read into the kernel with an invalid label
string (can often happen with removable media) we output a string like:
SELinux: inode_doinit_with_dentry: context_to_sid([SOME INVALID LABEL])
returned -22 dor dev=[blah] ino=[blah]
Which is all but incomprehensible to all but a couple of us. Instead, on
EINVAL only, I plan to output a much more user friendly string and I plan to
ratelimit the printk since many of these could be generated very rapidly.
For cleanliness and efficiency remove all calls to secondary-> and instead
call capabilities code directly. capabilities are the only module that
selinux stacks with and so the code should not indicate that other stacking
might be possible.
fs/namei.c
Manually merged per:
diff --cc fs/namei.c
index 734f2b5,bbc15c2..0000000
--- a/fs/namei.c
+++ b/fs/namei.c
@@@ -860,9 -848,8 +849,10 @@@ static int __link_path_walk(const char
nd->flags |= LOOKUP_CONTINUE;
err = exec_permission_lite(inode);
if (err == -EAGAIN)
- err = vfs_permission(nd, MAY_EXEC);
+ err = inode_permission(nd->path.dentry->d_inode,
+ MAY_EXEC);
+ if (!err)
+ err = ima_path_check(&nd->path, MAY_EXEC);
if (err)
break;
@@@ -1525,14 -1506,9 +1509,14 @@@ int may_open(struct path *path, int acc
flag &= ~O_TRUNC;
- error = vfs_permission(nd, acc_mode);
+ error = inode_permission(inode, acc_mode);
if (error)
return error;
- error = ima_path_check(&nd->path,
++ error = ima_path_check(path,
+ acc_mode & (MAY_READ | MAY_WRITE | MAY_EXEC));
+ if (error)
+ return error;
* An append-only file must be opened in append mode for writing.
Remove SELinux hooks which do nothing except defer to the capabilites
hooks (or in one case, replicates the function).
Remove secondary ops call to shm_shmat, which is
a noop in capabilities.
Acked-by: Serge Hallyn <serue@us.ibm.com>
Remove secondary ops call to unix_stream_connect, which is
Remove secondary ops call to task_kill, which is
Remove secondary ops call to task_setrlimit, which is
Remove unused cred_commit hook from SELinux. This
currently calls into the capabilities hook, which is a noop.
Remove secondary ops call to task_create, which is
Remove secondary ops call to file_mprotect, which is
Remove secondary ops call to inode_setattr, which is
Remove secondary ops call to inode_permission, which is
Remove secondary ops call to inode_follow_link, which is
Remove secondary ops call to inode_mknod, which is
Remove secondary ops call to inode_unlink, which is
Remove secondary ops call to inode_link, which is
