path: root/security/selinux/include
2014-03-10selinux: add gfp argument to security_xfrm_policy_alloc and fix callersNikolay Aleksandrov
security_xfrm_policy_alloc can be called in atomic context so the allocation should be done with GFP_ATOMIC. Add an argument to let the callers choose the appropriate way. In order to do so a gfp argument needs to be added to the method xfrm_policy_alloc_security in struct security_operations and to the internal function selinux_xfrm_alloc_user. After that switch to GFP_ATOMIC in the atomic callers and leave GFP_KERNEL as before for the rest. The path that needed the gfp argument addition is: security_xfrm_policy_alloc -> security_ops.xfrm_policy_alloc_security -> all users of xfrm_policy_alloc_security (e.g. selinux_xfrm_policy_alloc) -> selinux_xfrm_alloc_user (here the allocation used to be GFP_KERNEL only) Now adding a gfp argument to selinux_xfrm_alloc_user requires us to also add it to security_context_to_sid which is used inside and prior to this patch did only GFP_KERNEL allocation. So add gfp argument to security_context_to_sid and adjust all of its callers as well. CC: Paul Moore <paul@paul-moore.com> CC: Dave Jones <davej@redhat.com> CC: Steffen Klassert <steffen.klassert@secunet.com> CC: Fan Du <fan.du@windriver.com> CC: David S. Miller <davem@davemloft.net> CC: LSM list <linux-security-module@vger.kernel.org> CC: SELinux list <selinux@tycho.nsa.gov> Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Acked-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2014-01-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security layer updates from James Morris: "Changes for this kernel include maintenance updates for Smack, SELinux (and several networking fixes), IMA and TPM" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (39 commits) SELinux: Fix memory leak upon loading policy tpm/tpm-sysfs: active_show() can be static tpm: tpm_tis: Fix compile problems with CONFIG_PM_SLEEP/CONFIG_PNP tpm: Make tpm-dev allocate a per-file structure tpm: Use the ops structure instead of a copy in tpm_vendor_specific tpm: Create a tpm_class_ops structure and use it in the drivers tpm: Pull all driver sysfs code into tpm-sysfs.c tpm: Move sysfs functions from tpm-interface to tpm-sysfs tpm: Pull everything related to /dev/tpmX into tpm-dev.c char: tpm: nuvoton: remove unused variable tpm: MAINTAINERS: Cleanup TPM Maintainers file tpm/tpm_i2c_atmel: fix coccinelle warnings tpm/tpm_ibmvtpm: fix unreachable code warning (smatch warning) tpm/tpm_i2c_stm_st33: Check return code of get_burstcount tpm/tpm_ppi: Check return value of acpi_get_name tpm/tpm_ppi: Do not compare strcmp(a,b) == -1 ima: remove unneeded size_limit argument from ima_eventdigest_init_common() ima: update IMA-templates.txt documentation ima: pass HASH_ALGO__LAST as hash algo in ima_eventdigest_init() ima: change the default hash algorithm to SHA1 in ima_eventdigest_ng_init() ...
2014-01-12SELinux: Fix possible NULL pointer dereference in selinux_inode_permission()Steven Rostedt
While running stress tests on adding and deleting ftrace instances I hit this bug: BUG: unable to handle kernel NULL pointer dereference at 0000000000000020 IP: selinux_inode_permission+0x85/0x160 PGD 63681067 PUD 7ddbe067 PMD 0 Oops: 0000 [#1] PREEMPT CPU: 0 PID: 5634 Comm: ftrace-test-mki Not tainted 3.13.0-rc4-test-00033-gd2a6dde-dirty #20 Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006 task: ffff880078375800 ti: ffff88007ddb0000 task.ti: ffff88007ddb0000 RIP: 0010:[<ffffffff812d8bc5>] [<ffffffff812d8bc5>] selinux_inode_permission+0x85/0x160 RSP: 0018:ffff88007ddb1c48 EFLAGS: 00010246 RAX: 0000000000000000 RBX: 0000000000800000 RCX: ffff88006dd43840 RDX: 0000000000000001 RSI: 0000000000000081 RDI: ffff88006ee46000 RBP: ffff88007ddb1c88 R08: 0000000000000000 R09: ffff88007ddb1c54 R10: 6e6576652f6f6f66 R11: 0000000000000003 R12: 0000000000000000 R13: 0000000000000081 R14: ffff88006ee46000 R15: 0000000000000000 FS: 00007f217b5b6700(0000) GS:ffffffff81e21000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033^M CR2: 0000000000000020 CR3: 000000006a0fe000 CR4: 00000000000007f0 Call Trace: security_inode_permission+0x1c/0x30 __inode_permission+0x41/0xa0 inode_permission+0x18/0x50 link_path_walk+0x66/0x920 path_openat+0xa6/0x6c0 do_filp_open+0x43/0xa0 do_sys_open+0x146/0x240 SyS_open+0x1e/0x20 system_call_fastpath+0x16/0x1b Code: 84 a1 00 00 00 81 e3 00 20 00 00 89 d8 83 c8 02 40 f6 c6 04 0f 45 d8 40 f6 c6 08 74 71 80 cf 02 49 8b 46 38 4c 8d 4d cc 45 31 c0 <0f> b7 50 20 8b 70 1c 48 8b 41 70 89 d9 8b 78 04 e8 36 cf ff ff RIP selinux_inode_permission+0x85/0x160 CR2: 0000000000000020 Investigating, I found that the inode->i_security was NULL, and the dereference of it caused the oops. in selinux_inode_permission(): isec = inode->i_security; rc = avc_has_perm_noaudit(sid, isec->sid, isec->sclass, perms, 0, &avd); Note, the crash came from stressing the deletion and reading of debugfs files. I was not able to recreate this via normal files. But I'm not sure they are safe. It may just be that the race window is much harder to hit. What seems to have happened (and what I have traced), is the file is being opened at the same time the file or directory is being deleted. As the dentry and inode locks are not held during the path walk, nor is the inodes ref counts being incremented, there is nothing saving these structures from being discarded except for an rcu_read_lock(). The rcu_read_lock() protects against freeing of the inode, but it does not protect freeing of the inode_security_struct. Now if the freeing of the i_security happens with a call_rcu(), and the i_security field of the inode is not changed (it gets freed as the inode gets freed) then there will be no issue here. (Linus Torvalds suggested not setting the field to NULL such that we do not need to check if it is NULL in the permission check). Note, this is a hack, but it fixes the problem at hand. A real fix is to restructure the destroy_inode() to call all the destructor handlers from the RCU callback. But that is a major job to do, and requires a lot of work. For now, we just band-aid this bug with this fix (it works), and work on a more maintainable solution in the future. Link: http://lkml.kernel.org/r/20140109101932.0508dec7@gandalf.local.home Link: http://lkml.kernel.org/r/20140109182756.17abaaa8@gandalf.local.home Cc: stable@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-12selinux: look for IPsec labels on both inbound and outbound packetsPaul Moore
Previously selinux_skb_peerlbl_sid() would only check for labeled IPsec security labels on inbound packets, this patch enables it to check both inbound and outbound traffic for labeled IPsec security labels. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Cc: stable@vger.kernel.org Signed-off-by: Paul Moore <pmoore@redhat.com>
2013-12-09selinux: look for IPsec labels on both inbound and outbound packetsPaul Moore
2013-11-26Merge tag 'v3.12'Paul Moore
Linux 3.12
2013-11-19SELinux: Update policy version to support constraints infoRichard Haines
Update the policy version (POLICYDB_VERSION_CONSTRAINT_NAMES) to allow holding of policy source info for constraints. Signed-off-by: Richard Haines <richard_c_haines@btinternet.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Paul Moore <pmoore@redhat.com>
2013-11-08Merge tag 'v3.12'Paul Moore
Linux 3.12
2013-10-04selinux: remove 'flags' parameter from avc_audit()Linus Torvalds
Now avc_audit() has no more users with that parameter. Remove it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-04selinux: avc_has_perm_flags has no more usersLinus Torvalds
.. so get rid of it. The only indirect users were all the avc_has_perm() callers which just expanded to have a zero flags argument. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-18Merge git://git.infradead.org/users/eparis/selinuxPaul Moore
Conflicts: security/selinux/hooks.c Pull Eric's existing SELinux tree as there are a number of patches in there that are not yet upstream. There was some minor fixup needed to resolve a conflict in security/selinux/hooks.c:selinux_set_mnt_opts() between the labeled NFS patches and Eric's security_fs_use() simplification patch.
2013-08-28Revert "SELinux: do not handle seclabel as a special flag"Eric Paris
This reverts commit 308ab70c465d97cf7e3168961dfd365535de21a6. It breaks my FC6 test box. /dev/pts is not mounted. dmesg says SELinux: mount invalid. Same superblock, different security settings for (dev devpts, type devpts) Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-07-31net: split rt_genid for ipv4 and ipv6fan.du
Current net name space has only one genid for both IPv4 and IPv6, it has below drawbacks: - Add/delete an IPv4 address will invalidate all IPv6 routing table entries. - Insert/remove XFRM policy will also invalidate both IPv4/IPv6 routing table entries even when the policy is only applied for one address family. Thus, this patch attempt to split one genid for two to cater for IPv4 and IPv6 separately in a fine granularity. Signed-off-by: Fan Du <fan.du@windriver.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-25Add SELinux policy capability for always checking packet and peer classes.Chris PeBenito
Currently the packet class in SELinux is not checked if there are no SECMARK rules in the security or mangle netfilter tables. Some systems prefer that packets are always checked, for example, to protect the system should the netfilter rules fail to load or if the nefilter rules were maliciously flushed. Add the always_check_network policy capability which, when enabled, treats SECMARK as enabled, even if there are no netfilter SECMARK rules and treats peer labeling as enabled, even if there is no Netlabel or labeled IPSEC configuration. Includes definition of "redhat1" SELinux policy capability, which exists in the SELinux userpace library, to keep ordering correct. The SELinux userpace portion of this was merged last year, but this kernel change fell on the floor. Signed-off-by: Chris PeBenito <cpebenito@tresys.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-07-25SELinux: pass a superblock to security_fs_useEric Paris
Rather than passing pointers to memory locations, strings, and other stuff just give up on the separation and give security_fs_use the superblock. It just makes the code easier to read (even if not easier to reuse on some other OS) Signed-off-by: Eric Paris <eparis@redhat.com>
2013-07-25SELinux: do not handle seclabel as a special flagEric Paris
Instead of having special code around the 'non-mount' seclabel mount option just handle it like the mount options. Signed-off-by: Eric Paris <eparis@redhat.com>
2013-07-25SELinux: change sbsec->behavior to shortEric Paris
We only have 6 options, so char is good enough, but use a short as that packs nicely. This shrinks the superblock_security_struct just a little bit. Signed-off-by: Eric Paris <eparis@redhat.com>
2013-07-25SELinux: renumber the superblock optionsEric Paris
Just to make it clear that we have mount time options and flags, separate them. Since I decided to move the non-mount options above above 0x10, we need a short instead of a char. (x86 padding says this takes up no additional space as we have a 3byte whole in the structure) Signed-off-by: Eric Paris <eparis@redhat.com>
2013-07-25SELinux: rename SE_SBLABELSUPP to SBLABEL_MNTEric Paris
Just a flag rename as we prepare to make it not so special. Signed-off-by: Eric Paris <eparis@redhat.com>
2013-07-25selinux: remove the BUG_ON() from selinux_skb_xfrm_sid()Paul Moore
Remove the BUG_ON() from selinux_skb_xfrm_sid() and propogate the error code up to the caller. Also check the return values in the only caller function, selinux_skb_peerlbl_sid(). Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-07-25selinux: cleanup the XFRM headerPaul Moore
Remove the unused get_sock_isec() function and do some formatting fixes. Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-07-25selinux: cleanup selinux_xfrm_sock_rcv_skb() and selinux_xfrm_postroute_last()Paul Moore
Some basic simplification and comment reformatting. Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-07-25lsm: split the xfrm_state_alloc_security() hook implementationPaul Moore
The xfrm_state_alloc_security() LSM hook implementation is really a multiplexed hook with two different behaviors depending on the arguments passed to it by the caller. This patch splits the LSM hook implementation into two new hook implementations, which match the LSM hooks in the rest of the kernel: * xfrm_state_alloc * xfrm_state_alloc_acquire Also included in this patch are the necessary changes to the SELinux code; no other LSMs are affected. Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2013-06-08SELinux: Add new labeling type native labelsDavid Quigley
There currently doesn't exist a labeling type that is adequate for use with labeled NFS. Since NFS doesn't really support xattrs we can't use the use xattr labeling behavior. For this we developed a new labeling type. The native labeling type is used solely by NFS to ensure NFS inodes are labeled at runtime by the NFS code instead of relying on the SELinux security server on the client end. Acked-by: Eric Paris <eparis@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Matthew N. Dodd <Matthew.Dodd@sparta.com> Signed-off-by: Miguel Rodel Felipe <Rodel_FM@dsi.a-star.edu.sg> Signed-off-by: Phua Eu Gene <PHUA_Eu_Gene@dsi.a-star.edu.sg> Signed-off-by: Khin Mi Mi Aung <Mi_Mi_AUNG@dsi.a-star.edu.sg> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-01-14tun: fix LSM/SELinux labeling of tun/tap devicesPaul Moore
This patch corrects some problems with LSM/SELinux that were introduced with the multiqueue patchset. The problem stems from the fact that the multiqueue work changed the relationship between the tun device and its associated socket; before the socket persisted for the life of the device, however after the multiqueue changes the socket only persisted for the life of the userspace connection (fd open). For non-persistent devices this is not an issue, but for persistent devices this can cause the tun device to lose its SELinux label. We correct this problem by adding an opaque LSM security blob to the tun device struct which allows us to have the LSM security state, e.g. SELinux labeling information, persist for the lifetime of the tun device. In the process we tweak the LSM hooks to work with this new approach to TUN device/socket labeling and introduce a new LSM hook, security_tun_dev_attach_queue(), to approve requests to attach to a TUN queue via TUNSETQUEUE. The SELinux code has been adjusted to match the new LSM hooks, the other LSMs do not make use of the LSM TUN controls. This patch makes use of the recently added "tun_socket:attach_queue" permission to restrict access to the TUNSETQUEUE operation. On older SELinux policies which do not define the "tun_socket:attach_queue" permission the access control decision for TUNSETQUEUE will be handled according to the SELinux policy's unknown permission setting. Signed-off-by: Paul Moore <pmoore@redhat.com> Acked-by: Eric Paris <eparis@parisplace.org> Tested-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-14selinux: add the "attach_queue" permission to the "tun_socket" classPaul Moore
Add a new permission to align with the new TUN multiqueue support, "tun_socket:attach_queue". The corresponding SELinux reference policy patch is show below: diff --git a/policy/flask/access_vectors b/policy/flask/access_vectors index 28802c5..a0664a1 100644 --- a/policy/flask/access_vectors +++ b/policy/flask/access_vectors @@ -827,6 +827,9 @@ class kernel_service class tun_socket inherits socket +{ + attach_queue +} class x_pointer inherits x_device Signed-off-by: Paul Moore <pmoore@redhat.com> Acked-by: Eric Paris <eparis@parisplace.org> Tested-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-18xfrm: invalidate dst on policy insertion/deletionNicolas Dichtel
When a policy is inserted or deleted, all dst should be recalculated. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-23Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull the big VFS changes from Al Viro: "This one is *big* and changes quite a few things around VFS. What's in there: - the first of two really major architecture changes - death to open intents. The former is finally there; it was very long in making, but with Miklos getting through really hard and messy final push in fs/namei.c, we finally have it. Unlike his variant, this one doesn't introduce struct opendata; what we have instead is ->atomic_open() taking preallocated struct file * and passing everything via its fields. Instead of returning struct file *, it returns -E... on error, 0 on success and 1 in "deal with it yourself" case (e.g. symlink found on server, etc.). See comments before fs/namei.c:atomic_open(). That made a lot of goodies finally possible and quite a few are in that pile: ->lookup(), ->d_revalidate() and ->create() do not get struct nameidata * anymore; ->lookup() and ->d_revalidate() get lookup flags instead, ->create() gets "do we want it exclusive" flag. With the introduction of new helper (kern_path_locked()) we are rid of all struct nameidata instances outside of fs/namei.c; it's still visible in namei.h, but not for long. Come the next cycle, declaration will move either to fs/internal.h or to fs/namei.c itself. [me, miklos, hch] - The second major change: behaviour of final fput(). Now we have __fput() done without any locks held by caller *and* not from deep in call stack. That obviously lifts a lot of constraints on the locking in there. Moreover, it's legal now to call fput() from atomic contexts (which has immediately simplified life for aio.c). We also don't need anti-recursion logics in __scm_destroy() anymore. There is a price, though - the damn thing has become partially asynchronous. For fput() from normal process we are guaranteed that pending __fput() will be done before the caller returns to userland, exits or gets stopped for ptrace. For kernel threads and atomic contexts it's done via schedule_work(), so theoretically we might need a way to make sure it's finished; so far only one such place had been found, but there might be more. There's flush_delayed_fput() (do all pending __fput()) and there's __fput_sync() (fput() analog doing __fput() immediately). I hope we won't need them often; see warnings in fs/file_table.c for details. [me, based on task_work series from Oleg merged last cycle] - sync series from Jan - large part of "death to sync_supers()" work from Artem; the only bits missing here are exofs and ext4 ones. As far as I understand, those are going via the exofs and ext4 trees resp.; once they are in, we can put ->write_super() to the rest, along with the thread calling it. - preparatory bits from unionmount series (from dhowells). - assorted cleanups and fixes all over the place, as usual. This is not the last pile for this cycle; there's at least jlayton's ESTALE work and fsfreeze series (the latter - in dire need of fixes, so I'm not sure it'll make the cut this cycle). I'll probably throw symlink/hardlink restrictions stuff from Kees into the next pile, too. Plus there's a lot of misc patches I hadn't thrown into that one - it's large enough as it is..." * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (127 commits) ext4: switch EXT4_IOC_RESIZE_FS to mnt_want_write_file() btrfs: switch btrfs_ioctl_balance() to mnt_want_write_file() switch dentry_open() to struct path, make it grab references itself spufs: shift dget/mntget towards dentry_open() zoran: don't bother with struct file * in zoran_map ecryptfs: don't reinvent the wheels, please - use struct completion don't expose I_NEW inodes via dentry->d_inode tidy up namei.c a bit unobfuscate follow_up() a bit ext3: pass custom EOF to generic_file_llseek_size() ext4: use core vfs llseek code for dir seeks vfs: allow custom EOF in generic_file_llseek code vfs: Avoid unnecessary WB_SYNC_NONE writeback during sys_sync and reorder sync passes vfs: Remove unnecessary flushing of block devices vfs: Make sys_sync writeout also block device inodes vfs: Create function for iterating over block devices vfs: Reorder operations during sys_sync quota: Move quota syncing to ->sync_fs method quota: Split dquot_quota_sync() to writeback and cache flushing part vfs: Move noop_backing_dev_info check from sync into writeback ...
2012-07-23switch dentry_open() to struct path, make it grab references itselfAl Viro
2012-07-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull SELinux regression fixes from James Morris. Andrew Morton has a box that hit that open perms problem. I also renamed the "epollwakeup" selinux name for the new capability to be "block_suspend", to match the rename done by commit d9914cf66181 ("PM: Rename CAP_EPOLLWAKEUP to CAP_BLOCK_SUSPEND"). * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: SELinux: do not check open perms if they are not known to policy SELinux: include definition of new capabilities
2012-07-16SELinux: include definition of new capabilitiesEric Paris
The kernel has added CAP_WAKE_ALARM and CAP_EPOLLWAKEUP. We need to define these in SELinux so they can be mediated by policy. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-04-09SELinux: avc: remove the useless fields in avc_add_callbackWanlong Gao
avc_add_callback now just used for registering reset functions in initcalls, and the callback functions just did reset operations. So, reducing the arguments to only one event is enough now. Signed-off-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Signed-off-by: Eric Paris <eparis@redhat.com>
2012-04-09SELinux: unify the selinux_audit_data and selinux_late_audit_dataEric Paris
We no longer need the distinction. We only need data after we decide to do an audit. So turn the "late" audit data into just "data" and remove what we currently have as "data". Signed-off-by: Eric Paris <eparis@redhat.com>
2012-04-09SELinux: remove auditdeny from selinux_audit_dataEric Paris
It's just takin' up space. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-04-09SELinux: delay initialization of audit data in selinux_inode_permissionEric Paris
We pay a rather large overhead initializing the common_audit_data. Since we only need this information if we actually emit an audit message there is little need to set it up in the hot path. This patch splits the functionality of avc_has_perm() into avc_has_perm_noaudit(), avc_audit_required() and slow_avc_audit(). But we take care of setting up to audit between required() and the actual audit call. Thus saving measurable time in a hot path. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Eric Paris <eparis@redhat.com>
2012-04-09SELinux: add default_type statementsEric Paris
Because Fedora shipped userspace based on my development tree we now have policy version 27 in the wild defining only default user, role, and range. Thus to add default_type we need a policy.28. Signed-off-by: Eric Paris <eparis@redhat.com>
2012-04-09SELinux: allow default source/target selectors for user/role/rangeEric Paris
When new objects are created we have great and flexible rules to determine the type of the new object. We aren't quite as flexible or mature when it comes to determining the user, role, and range. This patch adds a new ability to specify the place a new objects user, role, and range should come from. For users and roles it can come from either the source or the target of the operation. aka for files the user can either come from the source (the running process and todays default) or it can come from the target (aka the parent directory of the new file) examples always are done with directory context: system_u:object_r:mnt_t:s0-s0:c0.c512 process context: unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023 [no rule] unconfined_u:object_r:mnt_t:s0 test_none [default user source] unconfined_u:object_r:mnt_t:s0 test_user_source [default user target] system_u:object_r:mnt_t:s0 test_user_target [default role source] unconfined_u:unconfined_r:mnt_t:s0 test_role_source [default role target] unconfined_u:object_r:mnt_t:s0 test_role_target [default range source low] unconfined_u:object_r:mnt_t:s0 test_range_source_low [default range source high] unconfined_u:object_r:mnt_t:s0:c0.c1023 test_range_source_high [default range source low-high] unconfined_u:object_r:mnt_t:s0-s0:c0.c1023 test_range_source_low-high [default range target low] unconfined_u:object_r:mnt_t:s0 test_range_target_low [default range target high] unconfined_u:object_r:mnt_t:s0:c0.c512 test_range_target_high [default range target low-high] unconfined_u:object_r:mnt_t:s0-s0:c0.c512 test_range_target_low-high Signed-off-by: Eric Paris <eparis@redhat.com>
2012-04-03SELinux: do not allocate stack space for AVC data unless neededEric Paris
Instead of declaring the entire selinux_audit_data on the stack when we start an operation on declare it on the stack if we are going to use it. We know it's usefulness at the end of the security decision and can declare it there. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-03SELinux: remove avd from selinux_audit_dataEric Paris
We do not use it. Remove it. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-03LSM: shrink sizeof LSM specific portion of common_audit_dataEric Paris
Linus found that the gigantic size of the common audit data caused a big perf hit on something as simple as running stat() in a loop. This patch requires LSMs to declare the LSM specific portion separately rather than doing it in a union. Thus each LSM can be responsible for shrinking their portion and don't have to pay a penalty just because other LSMs have a bigger space requirement. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-26SELinux: selinux/xfrm.h needs net/flow.hDavid Howells
selinux/xfrm.h needs to #include net/flow.h or else suffer: In file included from security/selinux/ss/services.c:69:0: security/selinux/include/xfrm.h: In function 'selinux_xfrm_notify_policyload': security/selinux/include/xfrm.h:53:14: error: 'flow_cache_genid' undeclared (first use in this function) security/selinux/include/xfrm.h:53:14: note: each undeclared identifier is reported only once for each function it appears in Signed-off-by: David Howells <dhowells@redhat.com>
2011-09-09selinux: sparse fix: fix several warnings in the security server codeJames Morris
Fix several sparse warnings in the SELinux security server code. Signed-off-by: James Morris <jmorris@namei.org>
2011-09-09selinux: sparse fix: fix warnings in netlink codeJames Morris
Fix sparse warnings in SELinux Netlink code. Signed-off-by: James Morris <jmorris@namei.org>
2011-09-09selinux: sparse fix: eliminate warnings for selinuxfsJames Morris
Fixes several sparse warnings for selinuxfs.c Signed-off-by: James Morris <jmorris@namei.org>
2011-09-09selinux: sparse fix: declare selinux_disable() in security.hJames Morris
Sparse fix: declare selinux_disable() in security.h Signed-off-by: James Morris <jmorris@namei.org>
2011-09-09selinux: sparse fix: move selinux_complete_initJames Morris
Sparse fix: move selinux_complete_init Signed-off-by: James Morris <jmorris@namei.org>
2011-08-01doc: Update the email address for Paul Moore in various source filesPaul Moore
My @hp.com will no longer be valid starting August 5, 2011 so an update is necessary. My new email address is employer independent so we don't have to worry about doing this again any time soon. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-24Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into ↵James Morris
for-linus Conflicts: lib/flex_array.c security/selinux/avc.c security/selinux/hooks.c security/selinux/ss/policydb.c security/smack/smack_lsm.c Manually resolve conflicts. Signed-off-by: James Morris <jmorris@namei.org>
2011-05-19selinux: avoid unnecessary avc cache stat hit countLinus Torvalds
There is no point in counting hits - we can calculate it from the number of lookups and misses. This makes the avc statistics a bit smaller, and makes the code generation better too. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
