... kill their private list, while we are at it
trying to grep everything that messes with a sk_security_struct isn't easy
since we don't always call it sksec. Just rename everything sksec.
Signed-off-by: Eric Paris <eparis@redhat.com>
Signed-off-by: James Morris <jmorris@namei.org>
Several places strings tables are used that should be declared
const.
Allow runtime switching between different policy types (e.g. from a MLS/MCS
policy to a non-MLS/non-MCS policy or viceversa).
Signed-off-by: Guido Trentalancia <guido@trentalancia.com>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
If allow_unknown==deny, SELinux treats an undefined kernel security
class as an error condition rather than as a typical permission denial
and thus does not allow permissions on undefined classes even when in
permissive mode. Change the SELinux logic so that this case is handled
as a typical permission denial, subject to the usual permissive mode and
permissive domain handling.
Also drop the 'requested' argument from security_compute_av() and
helpers as it is a legacy of the original security server interface and
is unused.
Changes:
- Handle permissive domains consistently by moving up the test for a
permissive domain.
- Make security_compute_av_user() consistent with security_compute_av();
the only difference now is that security_compute_av() performs mapping
between the kernel-private class and permission indices and the policy
values. In the userspace case, this mapping is handled by libselinux.
- Moved avd_init inside the policy lock.
Based in part on a patch by Paul Moore <paul.moore@hp.com>.
Reported-by: Andrew Worsley <amworsley@gmail.com>
Signed-off-by: Stephen D. Smalley <sds@tycho.nsa.gov>
Reviewed-by: Paul Moore <paul.moore@hp.com>
Add a simple utility (scripts/selinux/genheaders) and invoke it to
generate the kernel-private class and permission indices in flask.h
and av_permissions.h automatically during the kernel build from the
security class mapping definitions in classmap.h. Adding new kernel
classes and permissions can then be done just by adding them to classmap.h.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Modify SELinux to dynamically discover class and permission values
upon policy load, based on the dynamic object class/perm discovery
logic from libselinux. A mapping is created between kernel-private
class and permission indices used outside the security server and the
policy values used within the security server.
The mappings are only applied upon kernel-internal computations;
similar mappings for the private indices of userspace object managers
is handled on a per-object manager basis by the userspace AVC. The
interfaces for compute_av and transition_sid are split for kernel
vs. userspace; the userspace functions are distinguished by a _user
suffix.
The kernel-private class indices are no longer tied to the policy
values and thus do not need to skip indices for userspace classes;
thus the kernel class index values are compressed. The flask.h
definitions were regenerated by deleting the userspace classes from
refpolicy's definitions and then regenerating the headers. Going
forward, we can just maintain the flask.h, av_permissions.h, and
classmap.h definitions separately from policy as they are no longer
tied to the policy values. The next patch introduces a utility to
automate generation of flask.h and av_permissions.h from the
classmap.h definitions.
The older kernel class and permission string tables are removed and
replaced by a single security class mapping table that is walked at
policy load to generate the mapping. The old kernel class validation
logic is completely replaced by the mapping logic.
The handle unknown logic is reworked. reject_unknown=1 is handled
when the mappings are computed at policy load time, similar to the old
handling by the class validation logic. allow_unknown=1 is handled
when computing and mapping decisions - if the permission was not able
to be mapped (i.e. undefined, mapped to zero), then it is
automatically added to the allowed vector. If the class was not able
to be mapped (i.e. undefined, mapped to zero), then all permissions
are allowed for it if allow_unknown=1.
avc_audit leverages the new security class mapping table to lookup the
class and permission names from the kernel-private indices.
The mdp program is updated to use the new table when generating the
class definitions and allow rules for a minimal boot policy for the
kernel. It should be noted that this policy will not include any
userspace classes, nor will its policy index values for the kernel
classes correspond with the ones in refpolicy (they will instead match
the kernel-private indices).
Add support for the new TUN LSM hooks: security_tun_dev_create(),
security_tun_dev_post_create() and security_tun_dev_attach(). This includes
the addition of a new object class, tun_socket, which represents the socks
associated with TUN devices. The _tun_dev_create() and _tun_dev_post_create()
hooks are fairly similar to the standard socket functions but _tun_dev_attach()
is a bit special. The _tun_dev_attach() is unique because it involves a
domain attaching to an existing TUN device and its associated tun_socket
object, an operation which does not exist with standard sockets and most
closely resembles a relabel operation.
Signed-off-by: Paul Moore <paul.moore@hp.com>
Acked-by: Eric Paris <eparis@parisplace.org>
Convert avc_audit in security/selinux/avc.c to use lsm_audit.h,
for better maintainability.
- changed selinux to use common_audit_data instead of
avc_audit_data
- eliminated code in avc.c and used code from lsm_audit.h instead.
Had to add a LSM_AUDIT_NO_AUDIT to lsm_audit.h so that avc_audit
can call common_lsm_audit and do the pre and post callbacks without
doing the actual dump. This makes it so that the patched version
behaves the same way as the unpatched version.
Also added a denied field to the selinux_audit_data private space,
once again to make it so that the patched version behaves like the
unpatched.
I've tested and confirmed that AVCs look the same before and after
this patch.
Signed-off-by: Thomas Liu <tliu@redhat.com>
This patch adds a new selinux hook so SELinux can arbitrate if a given
process should be allowed to trigger a request for the kernel to try to
load a module. This is a different operation than a process trying to load
a module itself, which is already protected by CAP_SYS_MODULE.
Acked-by: Serge Hallyn <serue@us.ibm.com>
This reverts commit 8113a8d80f4c6a3dc3724b39b470f3fee9c426b6.
The patch causes a stack overflow on my system during boot.
for better maintainability and for less code duplication.
avc_audit_data
I have tested to make sure that the avcs look the same before and
after this patch.
Acked-by: Eric Paris <eparis@redhat.com>
Added a call to free the avc_node_cache when inside selinux_disable because
it should not waste resources allocated during avc_init if SELinux is disabled
and the cache will never be used.
The attached patch adds support to generate audit messages on two cases.
The first one is a case when a multi-thread process tries to switch its
performing security context using setcon(3), but new security context is
not bounded by the old one.
type=SELINUX_ERR msg=audit(1245311998.599:17): \
op=security_bounded_transition result=denied \
oldcontext=system_u:system_r:httpd_t:s0 \
newcontext=system_u:system_r:guest_webapp_t:s0
The other one is a case when security_compute_av() masked any permissions
due to the type boundary violation.
type=SELINUX_ERR msg=audit(1245312836.035:32): \
op=security_compute_av reason=bounds \
scontext=system_u:object_r:user_webapp_t:s0 \
tcontext=system_u:object_r:shadow_t:s0:c0 \
tclass=file perms=getattr,open
Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com>
The selinuxfs superblock magic is used inside the IMA code, but is being
defined in two places and could someday get out of sync. This patch moves the
declaration into magic.h so it is only done once.
This patch enables applications to handle permissive domain correctly.
Since the v2.6.26 kernel, SELinux has supported an idea of permissive
domain which allows certain processes to work as if permissive mode,
even if the global setting is enforcing mode.
However, we don't have an application program interface to inform
what domains are permissive one, and what domains are not.
It means applications focuses on SELinux (XACE/SELinux, SE-PostgreSQL
and so on) cannot handle permissive domain correctly.
This patch add the sixth field (flags) on the reply of the /selinux/access
interface which is used to make an access control decision from userspace.
If the first bit of the flags field is positive, it means the required
access control decision is on permissive domain, so application should
allow any required actions, as the kernel doing.
This patch also has a side benefit. The av_decision.flags is set at
context_struct_compute_av(). It enables to check required permissions
without read_lock(&policy_rwlock).
security/selinux/avc.c | 2 +-
security/selinux/include/security.h | 4 +++-
security/selinux/selinuxfs.c | 4 ++--
security/selinux/ss/services.c | 30 +++++-------------------------
4 files changed, 11 insertions(+), 29 deletions(-)
The current NetLabel/SELinux behavior for incoming TCP connections works but
only through a series of happy coincidences that rely on the limited nature of
standard CIPSO (only able to convey MLS attributes) and the write equality
imposed by the SELinux MLS constraints. The problem is that network sockets
created as the result of an incoming TCP connection were not on-the-wire
labeled based on the security attributes of the parent socket but rather based
on the wire label of the remote peer. The issue had to do with how IP options
were managed as part of the network stack and where the LSM hooks were in
relation to the code which set the IP options on these newly created child
sockets. While NetLabel/SELinux did correctly set the socket's on-the-wire
label it was promptly cleared by the network stack and reset based on the IP
options of the remote peer.
This patch, in conjunction with a prior patch that adjusted the LSM hook
locations, works to set the correct on-the-wire label format for new incoming
connections through the security_inet_conn_request() hook. Besides the
correct behavior there are many advantages to this change, the most significant
is that all of the NetLabel socket labeling code in SELinux now lives in hooks
which can return error codes to the core stack which allows us to finally get
ride of the selinux_netlbl_inode_permission() logic which greatly simplfies
the NetLabel/SELinux glue code. In the process of developing this patch I
also ran into a small handful of AF_INET6 cleanliness issues that have been
fixed which should make the code safer and easier to extend in the future.
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
New selinux permission to separate the ability to turn on tty auditing from
the ability to set audit rules.
When I did open permissions I didn't think any sockets would have an open.
Turns out AF_UNIX sockets can have an open when they are bound to the
filesystem namespace. This patch adds a new SOCK_FILE__OPEN permission.
It's safe to add this as the open perms are already predicated on
capabilities and capabilities means we have unknown perm handling so
systems should be as backwards compatible as the policy wants them to
be.
https://bugzilla.redhat.com/show_bug.cgi?id=475224
It appears there was an intention to have the security server only decide
certain permissions and leave other for later as some sort of a portential
performance win. We are currently always deciding all 32 bits of
permissions and this is a useless couple of branches and wasted space.
This patch completely drops the av.decided concept.
This in a 17% reduction in the time spent in avc_has_perm_noaudit
based on oprofile sampling of a tbench benchmark.
There is no easy way to tell if a file system supports SELinux security labeling.
Because of this a new flag is being added to the super block security structure
to indicate that the particular super block supports labeling. This flag is set
for file systems using the xattr, task, and transition labeling methods unless
that behavior is overridden by context mounts.
Signed-off-by: David P. Quigley <dpquigl@tycho.nsa.gov>
Signed-off-by: James Morris <jmorris@macbook.localdomain>
code.
The super block security structure currently has three fields for what are
essentially flags. The flags field is used for mount options while two other
char fields are used for initialization and proc flags. These latter two fields are
essentially bit fields since the only used values are 0 and 1. These fields
have been collapsed into the flags field and new bit masks have been added for
them. The code is also fixed to work with these new flags.
I started playing with pahole today and decided to put it against the
selinux structures. Found we could save a little bit of space on x86_64
(and no harm on i686) just reorganizing some structs.
Object size changes:
av_inherit: 24 -> 16
selinux_class_perm: 48 -> 40
context: 80 -> 72
Admittedly there aren't many of av_inherit or selinux_class_perm's in
the kernel (33 and 1 respectively) But the change to the size of struct
context reverberate out a bit. I can get some hard number if they are
needed, but I don't see why they would be. We do change which cacheline
context->len and context->str would be on, but I don't see that as a
problem since we are clearly going to have to load both if the context
is to be of any value. I've run with the patch and don't seem to be
having any problems.
An example of what's going on using struct av_inherit would be:
form: to:
struct av_inherit { struct av_inherit {
u16 tclass; const char **common_pts;
const char **common_pts; u32 common_base;
u32 common_base; u16 tclass;
(notice all I did was move u16 tclass to the end of the struct instead
of the beginning)
Memory layout before the change:
struct av_inherit {
u16 tclass; /* 2 */
/* 6 bytes hole */
const char** common_pts; /* 8 */
u32 common_base; /* 4 */
/* 4 byes padding */
/* size: 24, cachelines: 1 */
/* sum members: 14, holes: 1, sum holes: 6 */
/* padding: 4 */
Memory layout after the change:
struct av_inherit {
const char ** common_pts; /* 8 */
u16 tclass; /* 2 */
/* 2 bytes padding */
/* size: 16, cachelines: 1 */
/* sum members: 14, holes: 0, sum holes: 0 */
/* padding: 2 */
Add a 'kernel_service' object class to SELinux and give this object class two
access vectors: 'use_as_override' and 'create_files_as'.
The first vector is used to grant a process the right to nominate an alternate
process security ID for the kernel to use as an override for the SELinux
subjective security when accessing stuff on behalf of another process.
For example, CacheFiles when accessing the cache on behalf on a process
accessing an NFS file needs to use a subjective security ID appropriate to the
cache rather then the one the calling process is using. The cachefilesd
daemon will nominate the security ID to be used.
The second vector is used to grant a process the right to nominate a file
creation label for a kernel service to use.
Make execve() take advantage of copy-on-write credentials, allowing it to set
up the credentials in advance, and then commit the whole lot after the point
of no return.
This patch and the preceding patches have been tested with the LTP SELinux
testsuite.
This patch makes several logical sets of alteration:
(1) execve().
The credential bits from struct linux_binprm are, for the most part,
replaced with a single credentials pointer (bprm->cred). This means that
all the creds can be calculated in advance and then applied at the point
of no return with no possibility of failure.
I would like to replace bprm->cap_effective with:
cap_isclear(bprm->cap_effective)
but this seems impossible due to special behaviour for processes of pid 1
(they always retain their parent's capability masks where normally they'd
be changed - see cap_bprm_set_creds()).
The following sequence of events now happens:
(a) At the start of do_execve, the current task's cred_exec_mutex is
locked to prevent PTRACE_ATTACH from obsoleting the calculation of
creds that we make.
(a) prepare_exec_creds() is then called to make a copy of the current
task's credentials and prepare it. This copy is then assigned to
bprm->cred.
This renders security_bprm_alloc() and security_bprm_free()
unnecessary, and so they've been removed.
(b) The determination of unsafe execution is now performed immediately
after (a) rather than later on in the code. The result is stored in
bprm->unsafe for future reference.
(c) prepare_binprm() is called, possibly multiple times.
(i) This applies the result of set[ug]id binaries to the new creds
attached to bprm->cred. Personality bit clearance is recorded,
but now deferred on the basis that the exec procedure may yet
fail.
(ii) This then calls the new security_bprm_set_creds(). This should
calculate the new LSM and capability credentials into *bprm->cred.
This folds together security_bprm_set() and parts of
security_bprm_apply_creds() (these two have been removed).
Anything that might fail must be done at this point.
(iii) bprm->cred_prepared is set to 1.
bprm->cred_prepared is 0 on the first pass of the security
calculations, and 1 on all subsequent passes. This allows SELinux
in (ii) to base its calculations only on the initial script and
not on the interpreter.
(d) flush_old_exec() is called to commit the task to execution. This
performs the following steps with regard to credentials:
(i) Clear pdeath_signal and set dumpable on certain circumstances that
may not be covered by commit_creds().
(ii) Clear any bits in current->personality that were deferred from
(c.i).
(e) install_exec_creds() [compute_creds() as was] is called to install the
new credentials. This performs the following steps with regard to
credentials:
(i) Calls security_bprm_committing_creds() to apply any security
requirements, such as flushing unauthorised files in SELinux, that
must be done before the credentials are changed.
This is made up of bits of security_bprm_apply_creds() and
security_bprm_post_apply_creds(), both of which have been removed.
This function is not allowed to fail; anything that might fail
must have been done in (c.ii).
(ii) Calls commit_creds() to apply the new credentials in a single
assignment (more or less). Possibly pdeath_signal and dumpable
should be part of struct creds.
(iii) Unlocks the task's cred_replace_mutex, thus allowing
PTRACE_ATTACH to take place.
(iv) Clears The bprm->cred pointer as the credentials it was holding
are now immutable.
(v) Calls security_bprm_committed_creds() to apply any security
alterations that must be done after the creds have been changed.
SELinux uses this to flush signals and signal handlers.
(f) If an error occurs before (d.i), bprm_free() will call abort_creds()
to destroy the proposed new credentials and will then unlock
cred_replace_mutex. No changes to the credentials will have been
made.
(2) LSM interface.
A number of functions have been changed, added or removed:
(*) security_bprm_alloc(), ->bprm_alloc_security()
(*) security_bprm_free(), ->bprm_free_security()
Removed in favour of preparing new credentials and modifying those.
(*) security_bprm_apply_creds(), ->bprm_apply_creds()
(*) security_bprm_post_apply_creds(), ->bprm_post_apply_creds()
Removed; split between security_bprm_set_creds(),
security_bprm_committing_creds() and security_bprm_committed_creds().
(*) security_bprm_set(), ->bprm_set_security()
Removed; folded into security_bprm_set_creds().
(*) security_bprm_set_creds(), ->bprm_set_creds()
New. The new credentials in bprm->creds should be checked and set up
as appropriate. bprm->cred_prepared is 0 on the first call, 1 on the
second and subsequent calls.
(*) security_bprm_committing_creds(), ->bprm_committing_creds()
(*) security_bprm_committed_creds(), ->bprm_committed_creds()
New. Apply the security effects of the new credentials. This
includes closing unauthorised files in SELinux. This function may not
fail. When the former is called, the creds haven't yet been applied
to the process; when the latter is called, they have.
The former may access bprm->cred, the latter may not.
(3) SELinux.
SELinux has a number of changes, in addition to those to support the LSM
interface changes mentioned above:
(a) The bprm_security_struct struct has been removed in favour of using
the credentials-under-construction approach.
(c) flush_unauthorized_files() now takes a cred pointer and passes it on
to inode_has_perm(), file_has_perm() and dentry_open().
Acked-by: James Morris <jmorris@namei.org>
git://git.infradead.org/users/pcmoore/lblnet-2.6_next into next
Previous work enabled the use of address based NetLabel selectors, which
while highly useful, brought the potential for additional per-packet overhead
when used. This patch attempts to mitigate some of that overhead by caching
the NetLabel security attribute struct within the SELinux socket security
structure. This should help eliminate the need to recreate the NetLabel
secattr structure for each packet resulting in less overhead.
Previous work enabled the use of address based NetLabel selectors, which while
highly useful, brought the potential for additional per-packet overhead when
used. This patch attempts to solve that by applying NetLabel socket labels
when sockets are connect()'d. This should alleviate the per-packet NetLabel
labeling for all connected sockets (yes, it even works for connected DGRAM
sockets).
Reviewed-by: James Morris <jmorris@namei.org>
This patch builds upon the new NetLabel address selector functionality by
providing the NetLabel KAPI and CIPSO engine support needed to enable the
new packet-based labeling. The only new addition to the NetLabel KAPI at
this point is shown below:
* int netlbl_skbuff_setattr(skb, family, secattr)
... and is designed to be called from a Netfilter hook after the packet's
IP header has been populated such as in the FORWARD or LOCAL_OUT hooks.
This patch also provides the necessary SELinux hooks to support this new
functionality. Smack support is not currently included due to uncertainty
regarding the permissions needed to expand the Smack network access controls.
At some point I think I messed up and dropped the calls to netlbl_skbuff_err()
which are necessary for CIPSO to send error notifications to remote systems.
This patch re-introduces the error handling calls into the SELinux code.
The purpose of this patch is to assign per-thread security context
under a constraint. It enables multi-threaded server application
to kick a request handler with its fair security context, and
helps some of userspace object managers to handle user's request.
When we assign a per-thread security context, it must not have wider
permissions than the original one. Because a multi-threaded process
shares a single local memory, an arbitary per-thread security context
also means another thread can easily refer violated information.
The constraint on a per-thread security context requires a new domain
has to be equal or weaker than its original one, when it tries to assign
a per-thread security context.
Bounds relationship between two types is a way to ensure a domain can
never have wider permission than its bounds. We can define it in two
explicit or implicit ways.
The first way is using new TYPEBOUNDS statement. It enables to define
a boundary of types explicitly. The other one expand the concept of
existing named based hierarchy. If we defines a type with "." separated
name like "httpd_t.php", toolchain implicitly set its bounds on "httpd_t".
This feature requires a new policy version.
The 24th version (POLICYDB_VERSION_BOUNDARY) enables to ship them into
kernel space, and the following patch enables to handle it.
This reverts commit 811f3799279e567aa354c649ce22688d949ac7a9.
From Eric Paris:
"Please drop this patch for now. It deadlocks on ntfs-3g. I need to
rework it to handle fuse filesystems better. (casey was right)"
Currently if a FS is mounted for which SELinux policy does not define an
fs_use_* that FS will either be genfs labeled or not labeled at all.
This decision is based on the existence of a genfscon rule in policy and
is irrespective of the capabilities of the filesystem itself. This
patch allows the kernel to check if the filesystem supports security
xattrs and if so will use those if there is no fs_use_* rule in policy.
An fstype with a no fs_use_* rule but with a genfs rule will use xattrs
if available and will follow the genfs rule.
This can be particularly interesting for things like ecryptfs which
actually overlays a real underlying FS. If we define excryptfs in
policy to use xattrs we will likely get this wrong at times, so with
this path we just don't need to define it!
Overlay ecryptfs on top of NFS with no xattr support:
SELinux: initialized (dev ecryptfs, type ecryptfs), uses genfs_contexts
Overlay ecryptfs on top of ext4 with xattr support:
SELinux: initialized (dev ecryptfs, type ecryptfs), uses xattr
It is also useful as the kernel adds new FS we don't need to add them in
policy if they support xattrs and that is how we want to handle them.
Remove inherit field from inode_security_struct, per Stephen Smalley:
"Let's just drop inherit altogether - dead field."
reorder inode_security_struct to remove padding on 64 bit builds
size reduced from 72 to 64 bytes increasing objects per slab to 64.
Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk>
Formatting and syntax changes
whitespace, tabs to spaces, trailing space
put open { on same line as struct def
remove unneeded {} after if statements
change printk("Lu") to printk("llu")
convert asm/uaccess.h to linux/uaacess.h includes
remove unnecessary asm/bug.h includes
convert all users of simple_strtol to strict_strtol
Introduce SELinux support for deferred mapping of security contexts in
the SID table upon policy reload, and use this support for inode
security contexts when the context is not yet valid under the current
policy. Only processes with CAP_MAC_ADMIN + mac_admin permission in
policy can set undefined security contexts on inodes. Inodes with
such undefined contexts are treated as having the unlabeled context
until the context becomes valid upon a policy reload that defines the
context. Context invalidation upon policy reload also uses this
support to save the context information in the SID table and later
recover it upon a subsequent policy reload that defines the context
again.
This support is to enable package managers and similar programs to set
down file contexts unknown to the system policy at the time the file
is created in order to better support placing loadable policy modules
in packages and to support build systems that need to create images of
different distro releases with different policies w/o requiring all of
the contexts to be defined or legal in the build host policy.
With this patch applied, the following sequence is possible, although
in practice it is recommended that this permission only be allowed to
specific program domains such as the package manager.
# rmdir baz
# rm bar
# touch bar
# chcon -t foo_exec_t bar # foo_exec_t is not yet defined
chcon: failed to change context of `bar' to `system_u:object_r:foo_exec_t': Invalid argument
# mkdir -Z system_u:object_r:foo_exec_t baz
mkdir: failed to set default file creation context to `system_u:object_r:foo_exec_t': Invalid argument
# cat setundefined.te
policy_module(setundefined, 1.0)
require {
type unconfined_t;
type unlabeled_t;
files_type(unlabeled_t)
allow unconfined_t self:capability2 mac_admin;
# make -f /usr/share/selinux/devel/Makefile setundefined.pp
# semodule -i setundefined.pp
# ls -Zd bar baz
-rw-r--r-- root root system_u:object_r:unlabeled_t bar
drwxr-xr-x root root system_u:object_r:unlabeled_t baz
# cat foo.te
policy_module(foo, 1.0)
type foo_exec_t;
files_type(foo_exec_t)
# make -f /usr/share/selinux/devel/Makefile foo.pp
# semodule -i foo.pp # defines foo_exec_t
# ls -Zd bar baz
-rw-r--r-- root root user_u:object_r:foo_exec_t bar
drwxr-xr-x root root system_u:object_r:foo_exec_t baz
# semodule -r foo
# ls -Zd bar baz
# ls -Zd bar baz
# semodule -r setundefined foo
# chcon -t foo_exec_t bar # no longer defined and not allowed
# rmdir baz
Make secctx_to_secid() take constant secdata.
Add missing consts to xattr function arguments.
Cc: Andreas Gruenbacher <agruen@suse.de>
This patch changes selinux/include/security.h to fix whitespace and syntax issues. Things that
are fixed may include (does not not have to include)
whitespace at end of lines
spaces followed by tabs
spaces used instead of tabs
spacing around parenthesis
location of { around structs and else clauses
location of * in pointer declarations
removal of initialization of static data to keep it in the right section
useless {} in if statemetns
useless checking for NULL before kfree
fixing of the indentation depth of switch statements
no assignments in if statements
and any number of other things I forgot to mention
This patch changes objsec.h to fix whitespace and syntax issues. Things that
This patch changes netlabel.h to fix whitespace and syntax issues. Things that
This patch changes avc_ss.h to fix whitespace and syntax issues. Things that
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
security: fix up documentation for security_module_enable
Security: Introduce security= boot parameter
Audit: Final renamings and cleanup
SELinux: use new audit hooks, remove redundant exports
Audit: internally use the new LSM audit hooks
LSM/Audit: Introduce generic Audit LSM hooks
SELinux: remove redundant exports
Netlink: Use generic LSM hook
Audit: use new LSM hooks instead of SELinux exports
SELinux: setup new inode/ipc getsecid hooks
LSM: Introduce inode_getsecid and ipc_getsecid hooks
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6.26: (1090 commits)
[NET]: Fix and allocate less memory for ->priv'less netdevices
[IPV6]: Fix dangling references on error in fib6_add().
[NETLABEL]: Fix NULL deref in netlbl_unlabel_staticlist_gen() if ifindex not found
[PKT_SCHED]: Fix datalen check in tcf_simp_init().
[INET]: Uninline the __inet_inherit_port call.
[INET]: Drop the inet_inherit_port() call.
SCTP: Initialize partial_bytes_acked to 0, when all of the data is acked.
[netdrvr] forcedeth: internal simplifications; changelog removal
phylib: factor out get_phy_id from within get_phy_device
PHY: add BCM5464 support to broadcom PHY driver
cxgb3: Fix __must_check warning with dev_dbg.
tc35815: Statistics cleanup
natsemi: fix MMIO for PPC 44x platforms
[TIPC]: Cleanup of TIPC reference table code
[TIPC]: Optimized initialization of TIPC reference table
[TIPC]: Remove inlining of reference table locking routines
e1000: convert uint16_t style integers to u16
ixgb: convert uint16_t style integers to u16
sb1000.c: make const arrays static
sb1000.c: stop inlining largish static functions
Rename the se_str and se_rule audit fields elements to
lsm_str and lsm_rule to avoid confusion.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com>
Thank you, git.
Much like we added a network node cache, this patch adds a network port
cache. The design is taken almost completely from the network node cache
which in turn was taken from the network interface cache. The basic idea is
to cache entries in a hash table based on protocol/port information. The
hash function only takes the port number into account since the number of
different protocols in use at any one time is expected to be relatively
small.
