Fix memory leakage in /security/selinux/hooks.c
The buffer always needs to be freed here; we either error
out or allocate more memory.
Reported-by: iceberg <strakh@ispras.ru>
Signed-off-by: James Morris <jmorris@namei.org>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
Currently SELinux enforcement of controls on the ability to map low memory
is determined by the mmap_min_addr tunable. This patch causes SELinux to
ignore the tunable and instead use a seperate Kconfig option specific to how
much space the LSM should protect.
The tunable will now only control the need for CAP_SYS_RAWIO and SELinux
permissions will always protect the amount of low memory designated by
CONFIG_LSM_MMAP_MIN_ADDR.
This allows users who need to disable the mmap_min_addr controls (usual reason
being they run WINE as a non-root user) to do so and still have SELinux
controls preventing confined domains (like a web server) from being able to
map some area of low memory.
Signed-off-by: Eric Paris <eparis@redhat.com>
Currently SELinux does not check CAP_SYS_RAWIO in the file_mmap hook. This
means there is no DAC check on the ability to mmap low addresses in the
memory space. This function adds the DAC check for CAP_SYS_RAWIO while
maintaining the selinux check on mmap_zero. This means that processes
which need to mmap low memory will need CAP_SYS_RAWIO and mmap_zero but will
NOT need the SELinux sys_rawio capability.
- is_single_threaded(task) is not safe unless task == current,
we can't use task->signal or task->mm.
- it doesn't make sense unless task == current, the task can
fork right after the check.
Rename it to current_is_single_threaded() and kill the argument.
This reverts commit 8113a8d80f4c6a3dc3724b39b470f3fee9c426b6.
The patch causes a stack overflow on my system during boot.
Convert avc_audit in security/selinux/avc.c to use lsm_audit.h,
for better maintainability and for less code duplication.
- changed selinux to use common_audit_data instead of
avc_audit_data
- eliminated code in avc.c and used code from lsm_audit.h instead.
I have tested to make sure that the avcs look the same before and
after this patch.
Signed-off-by: Thomas Liu <tliu@redhat.com>
Acked-by: Eric Paris <eparis@redhat.com>
Added a call to free the avc_node_cache when inside selinux_disable because
it should not waste resources allocated during avc_init if SELinux is disabled
and the cache will never be used.
The ->ptrace_may_access() methods are named confusingly - the real
ptrace_may_access() returns a bool, while these security checks have
a retval convention.
Rename it to ptrace_access_check, to reduce the confusion factor.
[ Impact: cleanup, no code changed ]
Restore the optimization to skip revalidation in selinux_file_permission
if nothing has changed since the dentry_open checks, accidentally removed by
389fb800. Also remove redundant test from selinux_revalidate_file_permission.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Reviewed-by: Paul Moore <paul.moore@hp.com>
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
Documentation/feature-removal-schedule.txt
drivers/scsi/fcoe/fcoe.c
net/core/drop_monitor.c
net/core/net-traces.c
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
The CRED patch incorrectly converted the SELinux send_sigiotask hook to
use the current task SID rather than the target task SID in its
permission check, yielding the wrong permission check. This fixes the
hook function. Detected by the ltp selinux testsuite and confirmed to
correct the test failure.
->parent.
We shouldn't worry about the tracer if current is ptraced, exec() must not
succeed if the tracer has no rights to trace this task after cred changing.
But we should notify ->real_parent which is, well, real parent.
Also, we don't need _irq to take tasklist, and we don't need parent's
->siglock to wake_up_interruptible(real_parent->signal->wait_chldexit).
Since we hold tasklist, real_parent->signal must be stable. Otherwise
spin_lock(siglock) is not safe too and can't help anyway.
Don't flush inherited SIGKILL during execve() in SELinux's post cred commit
hook. This isn't really a security problem: if the SIGKILL came before the
credentials were changed, then we were right to receive it at the time, and
should honour it; if it came after the creds were changed, then we definitely
should honour it; and in any case, all that will happen is that the process
will be scrapped before it ever returns to userspace.
We are still calling secondary_ops->sysctl even though the capabilities
module does not define a sysctl operation.
The SELinux "compat_net" is marked as deprecated, the time has come to
finally remove it from the kernel. Further code simplifications are
likely in the future, but this patch was intended to be a simple,
straight-up removal of the compat_net code.
Signed-off-by: Paul Moore <paul.moore@hp.com>
The current NetLabel/SELinux behavior for incoming TCP connections works but
only through a series of happy coincidences that rely on the limited nature of
standard CIPSO (only able to convey MLS attributes) and the write equality
imposed by the SELinux MLS constraints. The problem is that network sockets
created as the result of an incoming TCP connection were not on-the-wire
labeled based on the security attributes of the parent socket but rather based
on the wire label of the remote peer. The issue had to do with how IP options
were managed as part of the network stack and where the LSM hooks were in
relation to the code which set the IP options on these newly created child
sockets. While NetLabel/SELinux did correctly set the socket's on-the-wire
label it was promptly cleared by the network stack and reset based on the IP
options of the remote peer.
This patch, in conjunction with a prior patch that adjusted the LSM hook
locations, works to set the correct on-the-wire label format for new incoming
connections through the security_inet_conn_request() hook. Besides the
correct behavior there are many advantages to this change, the most significant
is that all of the NetLabel socket labeling code in SELinux now lives in hooks
which can return error codes to the core stack which allows us to finally get
ride of the selinux_netlbl_inode_permission() logic which greatly simplfies
the NetLabel/SELinux glue code. In the process of developing this patch I
also ran into a small handful of AF_INET6 cleanliness issues that have been
fixed which should make the code safer and easier to extend in the future.
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
Drop the printk message when an inode is found without an associated
dentry. This should only happen when userspace can't be accessing those
inodes and those labels will get set correctly on the next d_instantiate.
Thus there is no reason to send this message.
When I did open permissions I didn't think any sockets would have an open.
Turns out AF_UNIX sockets can have an open when they are bound to the
filesystem namespace. This patch adds a new SOCK_FILE__OPEN permission.
It's safe to add this as the open perms are already predicated on
capabilities and capabilities means we have unknown perm handling so
systems should be as backwards compatible as the policy wants them to
be.
https://bugzilla.redhat.com/show_bug.cgi?id=475224
When a context is pulled in from disk we don't know that it is null
terminated. This patch forecebly null terminates contexts when we pull
them from disk.
Currently when an inode is read into the kernel with an invalid label
string (can often happen with removable media) we output a string like:
SELinux: inode_doinit_with_dentry: context_to_sid([SOME INVALID LABEL])
returned -22 dor dev=[blah] ino=[blah]
Which is all but incomprehensible to all but a couple of us. Instead, on
EINVAL only, I plan to output a much more user friendly string and I plan to
ratelimit the printk since many of these could be generated very rapidly.
For cleanliness and efficiency remove all calls to secondary-> and instead
call capabilities code directly. capabilities are the only module that
selinux stacks with and so the code should not indicate that other stacking
might be possible.
Remove SELinux hooks which do nothing except defer to the capabilites
hooks (or in one case, replicates the function).
Remove secondary ops call to shm_shmat, which is
a noop in capabilities.
Acked-by: Serge Hallyn <serue@us.ibm.com>
Remove secondary ops call to unix_stream_connect, which is
Remove secondary ops call to task_kill, which is
Remove secondary ops call to task_setrlimit, which is
Remove unused cred_commit hook from SELinux. This
currently calls into the capabilities hook, which is a noop.
Remove secondary ops call to task_create, which is
Remove secondary ops call to file_mprotect, which is
Remove secondary ops call to inode_setattr, which is
Remove secondary ops call to inode_permission, which is
Remove secondary ops call to inode_follow_link, which is
Remove secondary ops call to inode_mknod, which is
Remove secondary ops call to inode_unlink, which is
Remove secondary ops call to inode_link, which is
Remove secondary ops call to sb_umount, which is
Remove secondary ops call to sb_mount, which is
Remove secondary ops call to bprm_committed_creds, which is
Remove secondary ops call to bprm_committing_creds, which is
Remove unused bprm_check_security hook from SELinux. This
Context mounts and genfs labeled file systems behave differently with respect to
setting file system labels. This patch brings genfs labeled file systems in line
with context mounts in that setxattr calls to them should return EOPNOTSUPP and
fscreate calls will be ignored.
Signed-off-by: David P. Quigley <dpquigl@tycho.nsa.gov>
Signed-off-by: James Morris <jmorris@macbook.localdomain>
There is no easy way to tell if a file system supports SELinux security labeling.
Because of this a new flag is being added to the super block security structure
to indicate that the particular super block supports labeling. This flag is set
for file systems using the xattr, task, and transition labeling methods unless
that behavior is overridden by context mounts.
code.
The super block security structure currently has three fields for what are
essentially flags. The flags field is used for mount options while two other
char fields are used for initialization and proc flags. These latter two fields are
essentially bit fields since the only used values are 0 and 1. These fields
have been collapsed into the flags field and new bit masks have been added for
them. The code is also fixed to work with these new flags.
Fix a regression in cap_capable() due to:
commit 3b11a1decef07c19443d24ae926982bc8ec9f4c0
Author: David Howells <dhowells@redhat.com>
Date: Fri Nov 14 10:39:26 2008 +1100
CRED: Differentiate objective and effective subjective credentials on a task
The problem is that the above patch allows a process to have two sets of
credentials, and for the most part uses the subjective credentials when
accessing current's creds.
There is, however, one exception: cap_capable(), and thus capable(), uses the
real/objective credentials of the target task, whether or not it is the current
task.
Ordinarily this doesn't matter, since usually the two cred pointers in current
point to the same set of creds. However, sys_faccessat() makes use of this
facility to override the credentials of the calling process to make its test,
without affecting the creds as seen from other processes.
One of the things sys_faccessat() does is to make an adjustment to the
effective capabilities mask, which cap_capable(), as it stands, then ignores.
The affected capability check is in generic_permission():
if (!(mask & MAY_EXEC) || execute_ok(inode))
if (capable(CAP_DAC_OVERRIDE))
return 0;
This change passes the set of credentials to be tested down into the commoncap
and SELinux code. The security functions called by capable() and
has_capability() select the appropriate set of credentials from the process
being checked.
This can be tested by compiling the following program from the XFS testsuite:
* t_access_root.c - trivial test program to show permission bug.
* Written by Michael Kerrisk - copyright ownership not pursued.
* Sourced from: http://linux.derkeiler.com/Mailing-Lists/Kernel/2003-10/6030.html
#include <limits.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#include <sys/stat.h>
#define UID 500
#define GID 100
#define PERM 0
#define TESTPATH "/tmp/t_access"
static void
errExit(char *msg)
perror(msg);
exit(EXIT_FAILURE);
} /* errExit */
static void
accessTest(char *file, int mask, char *mstr)
printf("access(%s, %s) returns %d\n", file, mstr, access(file, mask));
} /* accessTest */
int
main(int argc, char *argv[])
int fd, perm, uid, gid;
char *testpath;
char cmd[PATH_MAX + 20];
testpath = (argc > 1) ? argv[1] : TESTPATH;
perm = (argc > 2) ? strtoul(argv[2], NULL, 8) : PERM;
uid = (argc > 3) ? atoi(argv[3]) : UID;
gid = (argc > 4) ? atoi(argv[4]) : GID;
unlink(testpath);
fd = open(testpath, O_RDWR | O_CREAT, 0);
if (fd == -1) errExit("open");
if (fchown(fd, uid, gid) == -1) errExit("fchown");
if (fchmod(fd, perm) == -1) errExit("fchmod");
close(fd);
snprintf(cmd, sizeof(cmd), "ls -l %s", testpath);
system(cmd);
if (seteuid(uid) == -1) errExit("seteuid");
accessTest(testpath, 0, "0");
accessTest(testpath, R_OK, "R_OK");
accessTest(testpath, W_OK, "W_OK");
accessTest(testpath, X_OK, "X_OK");
accessTest(testpath, R_OK | W_OK, "R_OK | W_OK");
accessTest(testpath, R_OK | X_OK, "R_OK | X_OK");
accessTest(testpath, W_OK | X_OK, "W_OK | X_OK");
accessTest(testpath, R_OK | W_OK | X_OK, "R_OK | W_OK | X_OK");
exit(EXIT_SUCCESS);
} /* main */
This can be run against an Ext3 filesystem as well as against an XFS
filesystem. If successful, it will show:
[root@andromeda src]# ./t_access_root /tmp/xxx 0 4043 4043
---------- 1 dhowells dhowells 0 2008-12-31 03:00 /tmp/xxx
access(/tmp/xxx, 0) returns 0
access(/tmp/xxx, R_OK) returns 0
access(/tmp/xxx, W_OK) returns 0
access(/tmp/xxx, X_OK) returns -1
access(/tmp/xxx, R_OK | W_OK) returns 0
access(/tmp/xxx, R_OK | X_OK) returns -1
access(/tmp/xxx, W_OK | X_OK) returns -1
access(/tmp/xxx, R_OK | W_OK | X_OK) returns -1
If unsuccessful, it will show:
---------- 1 dhowells dhowells 0 2008-12-31 02:56 /tmp/xxx
access(/tmp/xxx, R_OK) returns -1
access(/tmp/xxx, W_OK) returns -1
access(/tmp/xxx, R_OK | W_OK) returns -1
I've also tested the fix with the SELinux and syscalls LTP testsuites.
Tested-by: J. Bruce Fields <bfields@citi.umich.edu>
[ver #2]"
This reverts commit 14eaddc967b16017d4a1a24d2be6c28ecbe06ed8.
David has a better version to come.
commit 5ff7711e635b32f0a1e558227d030c7e45b4a465
Date: Wed Dec 31 02:52:28 2008 +0000
task.
return 0;
This change splits capable() from has_capability() down into the commoncap and
SELinux code. The capable() security op now only deals with the current
process, and uses the current process's subjective creds. A new security op -
task_capable() - is introduced that can check any task's objective creds.
strictly the capable() security op is superfluous with the presence of the
task_capable() op, however it should be faster to call the capable() op since
two fewer arguments need be passed down through the various layers.
#include <limits.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#define UID 500
#define GID 100
#define PERM 0
static void
errExit(char *msg)
perror(msg);
exit(EXIT_FAILURE);
} /* errExit */
static void
} /* accessTest */
int
char *testpath;
unlink(testpath);
close(fd);
system(cmd);
exit(EXIT_SUCCESS);
} /* main */
This patch is the first step towards removing the old "compat_net" code from
the kernel. Secmark, the "compat_net" replacement was first introduced in
2.6.18 (September 2006) and the major Linux distributions with SELinux support
have transitioned to Secmark so it is time to start deprecating the "compat_net"
mechanism. Testing a patched version of 2.6.28-rc6 with the initial release of
Fedora Core 5 did not show any problems when running in enforcing mode.
This patch adds an entry to the feature-removal-schedule.txt file and removes
the SECURITY_SELINUX_ENABLE_SECMARK_DEFAULT configuration option, forcing
Secmark on by default although it can still be disabled at runtime. The patch
also makes the Secmark permission checks "dynamic" in the sense that they are
only executed when Secmark is configured; this should help prevent problems
with older distributions that have not yet migrated to Secmark.
Acked-by: James Morris <jmorris@namei.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits)
net: Allow dependancies of FDDI & Tokenring to be modular.
igb: Fix build warning when DCA is disabled.
net: Fix warning fallout from recent NAPI interface changes.
gro: Fix potential use after free
sfc: If AN is enabled, always read speed/duplex from the AN advertising bits
sfc: When disabling the NIC, close the device rather than unregistering it
sfc: SFT9001: Add cable diagnostics
sfc: Add support for multiple PHY self-tests
sfc: Merge top-level functions for self-tests
sfc: Clean up PHY mode management in loopback self-test
sfc: Fix unreliable link detection in some loopback modes
sfc: Generate unique names for per-NIC workqueues
802.3ad: use standard ethhdr instead of ad_header
802.3ad: generalize out mac address initializer
802.3ad: initialize ports LACPDU from const initializer
802.3ad: remove typedef around ad_system
802.3ad: turn ports is_individual into a bool
802.3ad: turn ports is_enabled into a bool
802.3ad: make ntt bool
ixgbe: Fix set_ringparam in ixgbe to use the same memory pools.
Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due
to the conversion to %pI (in this networking merge) and the addition of
doing IPv6 addresses (from the earlier merge of CIFS).
