inode_follow_link now takes an inode and rcu flag as well as the
dentry.
inode is used in preference to d_backing_inode(dentry), particularly
in RCU-walk mode.
selinux_inode_follow_link() gets dentry_has_perm() and
inode_has_perm() open-coded into it so that it can call
avc_has_perm_flags() in way that is safe if LOOKUP_RCU is set.
Calling avc_has_perm_flags() with rcu_read_lock() held means
that when avc_has_perm_noaudit calls avc_compute_av(), the attempt
to rcu_read_unlock() before calling security_compute_av() will not
actually drop the RCU read-lock.
However as security_compute_av() is completely in a read_lock()ed
region, it should be safe with the RCU read-lock held.
Signed-off-by: NeilBrown <neilb@suse.de>
This allows MAY_NOT_BLOCK to be passed, in RCU-walk mode, through
the new avc_has_perm_flags() to avc_audit() and thence the slow_avc_audit.
No ->inode_follow_link() methods use the nameidata arg, and
it is about to become private to namei.c.
So remove from all inode_follow_link() functions.
most of the ->d_inode uses there refer to the same inode IO would
go to, i.e. d_backing_inode()
Pass the nf_hook_state all the way down into the hook
functions themselves.
This reverts commit ca10b9e9a8ca7342ee07065289cbe74ac128c169.
No longer needed after commit eb8895debe1baba41fcb62c78a16f0c63c21662a
("tcp: tcp_make_synack() should use sock_wmalloc")
When under SYNFLOOD, we build lot of SYNACK and hit false sharing
because of multiple modifications done on sk_listener->sk_wmem_alloc
Since tcp_make_synack() uses sock_wmalloc(), there is no need
to call skb_set_owner_w() again, as this adds two atomic operations.
Convert the following where appropriate:
(1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry).
(2) S_ISREG(dentry->d_inode) to d_is_reg(dentry).
(3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more
complicated than it appears as some calls should be converted to
d_can_lookup() instead. The difference is whether the directory in
question is a real dir with a ->lookup op or whether it's a fake dir with
a ->d_automount op.
In some circumstances, we can subsume checks for dentry->d_inode not being
NULL into this, provided we the code isn't in a filesystem that expects
d_inode to be NULL if the dirent really *is* negative (ie. if we're going to
use d_inode() rather than d_backing_inode() to get the inode pointer).
Note that the dentry type field may be set to something other than
DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS
manages the fall-through from a negative dentry to a lower layer. In such a
case, the dentry type of the negative union dentry is set to the same as the
type of the lower dentry.
However, if you know d_inode is not NULL at the call site, then you can use
the d_is_xxx() functions even in a filesystem.
There is one further complication: a 0,0 chardev dentry may be labelled
DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was
intended for special directory entry types that don't have attached inodes.
The following perl+coccinelle script was used:
use strict;
my @callers;
open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') ||
die "Can't grep for S_ISDIR and co. callers";
@callers = <$fd>;
close($fd);
unless (@callers) {
print "No matches\n";
exit(0);
my @cocci = (
'expression E;',
'- S_ISLNK(E->d_inode->i_mode)',
'+ d_is_symlink(E)',
'expression E;',
'- S_ISDIR(E->d_inode->i_mode)',
'+ d_is_dir(E)',
'expression E;',
'- S_ISREG(E->d_inode->i_mode)',
'+ d_is_reg(E)' );
my $coccifile = "tmp.sp.cocci";
open($fd, ">$coccifile") || die $coccifile;
print($fd "$_\n") || die $coccifile foreach (@cocci);
close($fd);
foreach my $file (@callers) {
chomp $file;
print "Processing ", $file, "\n";
system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 ||
die "spatch failed";
[AV: overlayfs parts skipped]
Use d_is_positive() rather than testing dentry->d_inode in SELinux to get rid
of direct references to d_inode outside of the VFS.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char / misc patches from Greg KH:
"Here's the big char/misc driver update for 3.20-rc1.
Lots of little things in here, all described in the changelog.
Nothing major or unusual, except maybe the binder selinux stuff, which
was all acked by the proper selinux people and they thought it best to
come through this tree.
All of this has been in linux-next with no reported issues for a while"
* tag 'char-misc-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (90 commits)
coresight: fix function etm_writel_cp14() parameter order
coresight-etm: remove check for unknown Kconfig macro
coresight: fixing CPU hwid lookup in device tree
coresight: remove the unnecessary function coresight_is_bit_set()
coresight: fix the debug AMBA bus name
coresight: remove the extra spaces
coresight: fix the link between orphan connection and newly added device
coresight: remove the unnecessary replicator property
coresight: fix the replicator subtype value
pdfdocs: Fix 'make pdfdocs' failure for 'uio-howto.tmpl'
mcb: Fix error path of mcb_pci_probe
virtio/console: verify device has config space
ti-st: clean up data types (fix harmless memory corruption)
mei: me: release hw from reset only during the reset flow
mei: mask interrupt set bit on clean reset bit
extcon: max77693: Constify struct regmap_config
extcon: adc-jack: Release IIO channel on driver remove
extcon: Remove duplicated include from extcon-class.c
Drivers: hv: vmbus: hv_process_timer_expiration() can be static
Drivers: hv: vmbus: serialize Offer and Rescind offer
- add "pstore" and "debugfs" to list of in-core exceptions
- change fstype checks to boolean equation
- change from strncmp to strcmp for checking
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
[PM: tweaked the subject line prefix to "selinux"]
Signed-off-by: Paul Moore <pmoore@redhat.com>
While the filesystem labeling method is only printed at the KERN_DEBUG
level, this still appears in dmesg and on modern Linux distributions
that create a lot of tmpfs mounts for session handling, the dmesg can
easily be filled with a lot of "SELinux: initialized (dev X ..."
messages. This patch removes this notification for the normal case
but leaves the error message intact (displayed when mounting a
filesystem with an unknown labeling behavior).
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Add security hooks to the binder and implement the hooks for SELinux.
The security hooks enable security modules such as SELinux to implement
controls over binder IPC. The security hooks include support for
controlling what process can become the binder context manager
(binder_set_context_mgr), controlling the ability of a process
to invoke a binder transaction/IPC to another process (binder_transaction),
controlling the ability of a process to transfer a binder reference to
another process (binder_transfer_binder), and controlling the ability
of a process to transfer an open file to another process (binder_transfer_file).
These hooks have been included in the Android kernel trees since Android 4.3.
(Updated to reflect upstream relocation and changes to the binder driver,
changes to the LSM audit data structures, coding style cleanups, and
to add inline documentation for the hooks).
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: Nick Kralevich <nnk@google.com>
Acked-by: Jeffrey Vander Stoep <jeffv@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security layer updates from James Morris:
"In terms of changes, there's general maintenance to the Smack,
SELinux, and integrity code.
The IMA code adds a new kconfig option, IMA_APPRAISE_SIGNED_INIT,
which allows IMA appraisal to require signatures. Support for reading
keys from rootfs before init is call is also added"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits)
selinux: Remove security_ops extern
security: smack: fix out-of-bounds access in smk_parse_smack()
VFS: refactor vfs_read()
ima: require signature based appraisal
integrity: provide a hook to load keys when rootfs is ready
ima: load x509 certificate from the kernel
integrity: provide a function to load x509 certificate from the kernel
integrity: define a new function integrity_read_file()
Security: smack: replace kzalloc with kmem_cache for inode_smack
Smack: Lock mode for the floor and hat labels
ima: added support for new kernel cmdline parameter ima_template_fmt
ima: allocate field pointers array on demand in template_desc_init_fields()
ima: don't allocate a copy of template_fmt in template_desc_init_fields()
ima: display template format in meas. list if template name length is zero
ima: added error messages to template-related functions
ima: use atomic bit operations to protect policy update interface
ima: ignore empty and with whitespaces policy lines
ima: no need to allocate entry for comment
ima: report policy load status
ima: use path names cache
security_ops is not used in this file.
Signed-off-by: Yao Dongdong <yaodongdong@huawei.com>
into for-linus
Convert WARN_ONCE() to printk() in selinux_nlmsg_perm().
After conversion from audit_log() in commit e173fb26, WARN_ONCE() was
deemed too alarmist, so switch it to printk().
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
[PM: Changed to printk(WARNING) so we catch all of the different
invalid netlink messages. In Richard's defense, he brought this
point up earlier, but I didn't understand his point at the time.]
into for-linus2
sb_finish_set_opts() can race with inode_free_security()
when initializing inode security structures for inodes
created prior to initial policy load or by the filesystem
during ->mount(). This appears to have always been
a possible race, but commit 3dc91d4 ("SELinux: Fix possible
NULL pointer dereference in selinux_inode_permission()")
made it more evident by immediately reusing the unioned
list/rcu element of the inode security structure for call_rcu()
upon an inode_free_security(). But the underlying issue
was already present before that commit as a possible use-after-free
of isec.
Shivnandan Kumar reported the list corruption and proposed
a patch to split the list and rcu elements out of the union
as separate fields of the inode_security_struct so that setting
the rcu element would not affect the list element. However,
this would merely hide the issue and not truly fix the code.
This patch instead moves up the deletion of the list entry
prior to dropping the sbsec->isec_lock initially. Then,
if the inode is dropped subsequently, there will be no further
references to the isec.
Reported-by: Shivnandan Kumar <shivnandan.k@samsung.com>
Cc: stable@vger.kernel.org
Pull security subsystem updates from James Morris.
Mostly ima, selinux, smack and key handling updates.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits)
integrity: do zero padding of the key id
KEYS: output last portion of fingerprint in /proc/keys
KEYS: strip 'id:' from ca_keyid
KEYS: use swapped SKID for performing partial matching
KEYS: Restore partial ID matching functionality for asymmetric keys
X.509: If available, use the raw subjKeyId to form the key description
KEYS: handle error code encoded in pointer
selinux: normalize audit log formatting
selinux: cleanup error reporting in selinux_nlmsg_perm()
KEYS: Check hex2bin()'s return when generating an asymmetric key ID
ima: detect violations for mmaped files
ima: fix race condition on ima_rdwr_violation_check and process_measurement
ima: added ima_policy_flag variable
ima: return an error code from ima_add_boot_aggregate()
ima: provide 'ima_appraise=log' kernel option
ima: move keyring initialization to ima_init()
PKCS#7: Handle PKCS#7 messages that contain no X.509 certs
PKCS#7: Better handling of unsupported crypto
KEYS: Overhaul key identification when searching for asymmetric keys
KEYS: Implement binary asymmetric key ID handling
Convert audit_log() call to WARN_ONCE().
Rename "type=" to nlmsg_type=" to avoid confusion with the audit record
type.
Added "protocol=" to help track down which protocol (NETLINK_AUDIT?) was used
within the netlink protocol family.
[Rewrote the patch subject line]
While SELinux largely ignores namespaces, for good reason, there are
some places where it needs to at least be aware of namespaces in order
to function correctly. Network namespaces are one example. Basic
awareness of network namespaces are necessary in order to match a
network interface's index number to an actual network device.
This patch corrects a problem with network interfaces added to a
non-init namespace, and can be reproduced with the following commands:
[NOTE: the NetLabel configuration is here only to active the dynamic
networking controls ]
# netlabelctl unlbl add default address:0.0.0.0/0 \
label:system_u:object_r:unlabeled_t:s0
# netlabelctl unlbl add default address:::/0 \
# netlabelctl cipsov4 add pass doi:100 tags:1
# netlabelctl map add domain:lspp_test_netlabel_t \
protocol:cipsov4,100
# ip link add type veth
# ip netns add myns
# ip link set veth1 netns myns
# ip a add dev veth0 10.250.13.100/24
# ip netns exec myns ip a add dev veth1 10.250.13.101/24
# ip l set veth0 up
# ip netns exec myns ip l set veth1 up
# ping -c 1 10.250.13.101
# ip netns exec myns ping -c 1 10.250.13.100
Reported-by: Jiri Jaburek <jjaburek@redhat.com>
security_file_set_fowner always returns 0, so make it f_setown and
__f_setown void return functions and fix up the error handling in the
callers.
Cc: linux-security-module@vger.kernel.org
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
Push ipv4 and ipv6 nf hooks into single array and register/unregister
them via single call.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
A previous commit c0828e50485932b7e019df377a6b0a8d1ebd3080 ("selinux:
process labeled IPsec TCP SYN-ACK packets properly in
selinux_ip_postroute()") mistakenly left out a 'break' from a switch
statement which caused problems with IPv6 traffic.
Thanks to Florian Westphal for reporting and debugging the issue.
Reported-by: Florian Westphal <fwestpha@redhat.com>
If the callee SID is bounded by the caller SID, then allowing
the transition to occur poses no risk of privilege escalation and we can
therefore safely allow the transition to occur. Add this exemption
for both the case where a transition was explicitly requested by the
application and the case where an automatic transition is defined in
policy.
Reviewed-by: Andy Lutomirski <luto@amacapital.net>
Linux 3.16
into next
This reverts commit 4da6daf4d3df5a977e4623963f141a627fd2efce.
Unfortunately, the commit in question caused problems with Bluetooth
devices, specifically it caused them to get caught in the newly
created BUG_ON() check. The AF_ALG problem still exists, but will be
addressed in a future patch.
into next
The sock_graft() hook has special handling for AF_INET, AF_INET, and
AF_UNIX sockets as those address families have special hooks which
label the sock before it is attached its associated socket.
Unfortunately, the sock_graft() hook was missing a default approach
to labeling sockets which meant that any other address family which
made use of connections or the accept() syscall would find the
returned socket to be in an "unlabeled" state. This was recently
demonstrated by the kcrypto/AF_ALG subsystem and the newly released
cryptsetup package (cryptsetup v1.6.5 and later).
This patch preserves the special handling in selinux_sock_graft(),
but adds a default behavior - setting the sock's label equal to the
associated socket - which resolves the problem with AF_ALG and
presumably any other address family which makes use of accept().
Tested-by: Milan Broz <gmazyland@gmail.com>
When flushing the AVC, such as during a policy load, the various
network caches are also flushed, with each making a call to
synchronize_net() which has shown to be expensive in some cases.
This patch consolidates the network cache flushes into a single AVC
callback which only calls synchronize_net() once for each AVC cache
flush.
Reported-by: Jaejyn Shin <flagon22bass@gmail.com>
Linux 3.15
git://git.kernel.org/pub/scm/linux/kernel/git/sergeh/linux-security
Pull security layer updates from Serge Hallyn:
"This is a merge of James Morris' security-next tree from 3.14 to
yesterday's master, plus four patches from Paul Moore which are in
linux-next, plus one patch from Mimi"
* 'serge-next-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sergeh/linux-security:
ima: audit log files opened with O_DIRECT flag
selinux: conditionally reschedule in hashtab_insert while loading selinux policy
selinux: conditionally reschedule in mls_convert_context while loading selinux policy
selinux: reject setexeccon() on MNT_NOSUID applications with -EACCES
selinux: Report permissive mode in avc: denied messages.
Warning in scanf string typing
Smack: Label cgroup files for systemd
Smack: Verify read access on file open - v3
security: Convert use of typedef ctl_table to struct ctl_table
Smack: bidirectional UDS connect check
Smack: Correctly remove SMACK64TRANSMUTE attribute
SMACK: Fix handling value==NULL in post setxattr
bugfix patch for SMACK
Smack: adds smackfs/ptrace interface
Smack: unify all ptrace accesses in the smack
Smack: fix the subject/object order in smack_ptrace_traceme()
Minor improvement of 'smack_sb_kern_mount'
smack: fix key permission verification
KEYS: Move the flags representing required permission to linux/key.h
We presently prevent processes from using setexecon() to set the
security label of exec()'d processes when NO_NEW_PRIVS is enabled by
returning an error; however, we silently ignore setexeccon() when
exec()'ing from a nosuid mounted filesystem. This patch makes things
a bit more consistent by returning an error in the setexeccon()/nosuid
case.
Acked-by: Andy Lutomirski <luto@amacapital.net>
We cannot presently tell from an avc: denied message whether access was in
fact denied or was allowed due to global or per-domain permissive mode.
Add a permissive= field to the avc message to reflect this information.
Acked-by: Eric Paris <eparis@redhat.com>
case.
File-private locks have been merged into Linux for v3.15, and *now*
people are commenting that the name and macro definitions for the new
file-private locks suck.
...and I can't even disagree. The names and command macros do suck.
We're going to have to live with these for a long time, so it's
important that we be happy with the names before we're stuck with them.
The consensus on the lists so far is that they should be rechristened as
"open file description locks".
The name isn't a big deal for the kernel, but the command macros are not
visually distinct enough from the traditional POSIX lock macros. The
glibc and documentation folks are recommending that we change them to
look like F_OFD_{GETLK|SETLK|SETLKW}. That lessens the chance that a
programmer will typo one of the commands wrong, and also makes it easier
to spot this difference when reading code.
This patch makes the following changes that I think are necessary before
v3.15 ships:
1) rename the command macros to their new names. These end up in the uapi
headers and so are part of the external-facing API. It turns out that
glibc doesn't actually use the fcntl.h uapi header, but it's hard to
be sure that something else won't. Changing it now is safest.
2) make the the /proc/locks output display these as type "OFDLCK"
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Carlos O'Donell <carlos@redhat.com>
Cc: Stefan Metzmacher <metze@samba.org>
Cc: Frank Filz <ffilzlnx@mindspring.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into next
Pull file locking updates from Jeff Layton:
"Highlights:
- maintainership change for fs/locks.c. Willy's not interested in
maintaining it these days, and is OK with Bruce and I taking it.
- fix for open vs setlease race that Al ID'ed
- cleanup and consolidation of file locking code
- eliminate unneeded BUG() call
- merge of file-private lock implementation"
* 'locks-3.15' of git://git.samba.org/jlayton/linux:
locks: make locks_mandatory_area check for file-private locks
locks: fix locks_mandatory_locked to respect file-private locks
locks: require that flock->l_pid be set to 0 for file-private locks
locks: add new fcntl cmd values for handling file private locks
locks: skip deadlock detection on FL_FILE_PVT locks
locks: pass the cmd value to fcntl_getlk/getlk64
locks: report l_pid as -1 for FL_FILE_PVT locks
locks: make /proc/locks show IS_FILE_PVT locks as type "FLPVT"
locks: rename locks_remove_flock to locks_remove_file
locks: consolidate checks for compatible filp->f_mode values in setlk handlers
locks: fix posix lock range overflow handling
locks: eliminate BUG() call when there's an unexpected lock on file close
locks: add __acquires and __releases annotations to locks_start and locks_stop
locks: remove "inline" qualifier from fl_link manipulation functions
locks: clean up comment typo
locks: close potential race between setlease and open
MAINTAINERS: update entry for fs/locks.c
Pull security subsystem updates from James Morris:
"Apart from reordering the SELinux mmap code to ensure DAC is called
before MAC, these are minor maintenance updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits)
selinux: correctly label /proc inodes in use before the policy is loaded
selinux: put the mmap() DAC controls before the MAC controls
selinux: fix the output of ./scripts/get_maintainer.pl for SELinux
evm: enable key retention service automatically
ima: skip memory allocation for empty files
evm: EVM does not use MD5
ima: return d_name.name if d_path fails
integrity: fix checkpatch errors
ima: fix erroneous removal of security.ima xattr
security: integrity: Use a more current logging style
MAINTAINERS: email updates and other misc. changes
ima: reduce memory usage when a template containing the n field is used
ima: restore the original behavior for sending data with ima template
Integrity: Pass commname via get_task_comm()
fs: move i_readcount
ima: use static const char array definitions
security: have cap_dentry_init_security return error
ima: new helper: file_inode(file)
kernel: Mark function as static in kernel/seccomp.c
capability: Use current logging styles
Linux 3.14
Due to some unfortunate history, POSIX locks have very strange and
unhelpful semantics. The thing that usually catches people by surprise
is that they are dropped whenever the process closes any file descriptor
associated with the inode.
This is extremely problematic for people developing file servers that
need to implement byte-range locks. Developers often need a "lock
management" facility to ensure that file descriptors are not closed
until all of the locks associated with the inode are finished.
Additionally, "classic" POSIX locks are owned by the process. Locks
taken between threads within the same process won't conflict with one
another, which renders them useless for synchronization between threads.
This patchset adds a new type of lock that attempts to address these
issues. These locks conflict with classic POSIX read/write locks, but
have semantics that are more like BSD locks with respect to inheritance
and behavior on close.
This is implemented primarily by changing how fl_owner field is set for
these locks. Instead of having them owned by the files_struct of the
process, they are instead owned by the filp on which they were acquired.
Thus, they are inherited across fork() and are only released when the
last reference to a filp is put.
These new semantics prevent them from being merged with classic POSIX
locks, even if they are acquired by the same process. These locks will
also conflict with classic POSIX locks even if they are acquired by
the same process or on the same file descriptor.
The new locks are managed using a new set of cmd values to the fcntl()
syscall. The initial implementation of this converts these values to
"classic" cmd values at a fairly high level, and the details are not
exposed to the underlying filesystem. We may eventually want to push
this handing out to the lower filesystem code but for now I don't
see any need for it.
Also, note that with this implementation the new cmd values are only
available via fcntl64() on 32-bit arches. There's little need to
add support for legacy apps on a new interface like this.
This patch is based on an earlier patch by Eric Paris, he describes
the problem below:
"If an inode is accessed before policy load it will get placed on a
list of inodes to be initialized after policy load. After policy
load we call inode_doinit() which calls inode_doinit_with_dentry()
on all inodes accessed before policy load. In the case of inodes
in procfs that means we'll end up at the bottom where it does:
/* Default to the fs superblock SID. */
isec->sid = sbsec->sid;
if ((sbsec->flags & SE_SBPROC) && !S_ISLNK(inode->i_mode)) {
if (opt_dentry) {
isec->sclass = inode_mode_to_security_class(...)
rc = selinux_proc_get_sid(opt_dentry,
isec->sclass,
&sid);
if (rc)
goto out_unlock;
isec->sid = sid;
Since opt_dentry is null, we'll never call selinux_proc_get_sid()
and will leave the inode labeled with the label on the superblock.
I believe a fix would be to mimic the behavior of xattrs. Look
for an alias of the inode. If it can't be found, just leave the
inode uninitialized (and pick it up later) if it can be found, we
should be able to call selinux_proc_get_sid() ..."
On a system exhibiting this problem, you will notice a lot of files in
/proc with the generic "proc_t" type (at least the ones that were
accessed early in the boot), for example:
# ls -Z /proc/sys/kernel/shmmax | awk '{ print $4 " " $5 }'
system_u:object_r:proc_t:s0 /proc/sys/kernel/shmmax
However, with this patch in place we see the expected result:
system_u:object_r:sysctl_kernel_t:s0 /proc/sys/kernel/shmmax
Cc: Eric Paris <eparis@redhat.com>
