path: root/security/dummy.c
2007-07-11security: Protection for exploiting null dereference using mmapEric Paris
Add a new security check on mmap operations to see if the user is attempting to mmap to low area of the address space. The amount of space protected is indicated by the new proc tunable /proc/sys/vm/mmap_min_addr and defaults to 0, preserving existing behavior. This patch uses a new SELinux security class "memprotect." Policy already contains a number of allow rules like a_t self:process * (unconfined_t being one of them) which mean that putting this check in the process class (its best current fit) would make it useless as all user processes, which we also want to protect against, would be allowed. By taking the memprotect name of the new class it will also make it possible for us to move some of the other memory protect permissions out of 'process' and into the new class next time we bump the policy version number (which I also think is a good future idea) Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-03-14[PATCH] sanitize security_getprocattr() APIAl Viro
have it return the buffer it had allocated Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-02SELinux: Fix SA selection semanticsVenkat Yekkirala
Fix the selection of an SA for an outgoing packet to be at the same context as the originating socket/flow. This eliminates the SELinux policy's ability to use/sendto SAs with contexts other than the socket's. With this patch applied, the SELinux policy will require one or more of the following for a socket to be able to communicate with/without SAs: 1. To enable a socket to communicate without using labeled-IPSec SAs: allow socket_t unlabeled_t:association { sendto recvfrom } 2. To enable a socket to communicate with labeled-IPSec SAs: allow socket_t self:association { sendto }; allow socket_t peer_sa_t:association { recvfrom }; Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02SELinux: Return correct context for SO_PEERSECVenkat Yekkirala
Fix SO_PEERSEC for tcp sockets to return the security context of the peer (as represented by the SA from the peer) as opposed to the SA used by the local/source socket. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02SELinux: Various xfrm labeling fixesVenkat Yekkirala
Since the upstreaming of the mlsxfrm modification a few months back, testing has resulted in the identification of the following issues/bugs that are resolved in this patch set. 1. Fix the security context used in the IKE negotiation to be the context of the socket as opposed to the context of the SPD rule. 2. Fix SO_PEERSEC for tcp sockets to return the security context of the peer as opposed to the source. 3. Fix the selection of an SA for an outgoing packet to be at the same context as the originating socket/flow. The following would be the result of applying this patchset: - SO_PEERSEC will now correctly return the peer's context. - IKE deamons will receive the context of the source socket/flow as opposed to the SPD rule's context so that the negotiated SA will be at the same context as the source socket/flow. - The SELinux policy will require one or more of the following for a socket to be able to communicate with/without SAs: 1. To enable a socket to communicate without using labeled-IPSec SAs: allow socket_t unlabeled_t:association { sendto recvfrom } 2. To enable a socket to communicate with labeled-IPSec SAs: allow socket_t self:association { sendto }; allow socket_t peer_sa_t:association { recvfrom }; This Patch: Pass correct security context to IKE for use in negotiation Fix the security context passed to IKE for use in negotiation to be the context of the socket as opposed to the context of the SPD rule so that the SA carries the label of the originating socket/flow. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-11IPsec: correct semantics for SELinux policy matchingVenkat Yekkirala
Currently when an IPSec policy rule doesn't specify a security context, it is assumed to be "unlabeled" by SELinux, and so the IPSec policy rule fails to match to a flow that it would otherwise match to, unless one has explicitly added an SELinux policy rule allowing the flow to "polmatch" to the "unlabeled" IPSec policy rules. In the absence of such an explicitly added SELinux policy rule, the IPSec policy rule fails to match and so the packet(s) flow in clear text without the otherwise applicable xfrm(s) applied. The above SELinux behavior violates the SELinux security notion of "deny by default" which should actually translate to "encrypt by default" in the above case. This was first reported by Evgeniy Polyakov and the way James Morris was seeing the problem was when connecting via IPsec to a confined service on an SELinux box (vsftpd), which did not have the appropriate SELinux policy permissions to send packets via IPsec. With this patch applied, SELinux "polmatching" of flows Vs. IPSec policy rules will only come into play when there's a explicit context specified for the IPSec policy rule (which also means there's corresponding SELinux policy allowing appropriate domains/flows to polmatch to this context). Secondly, when a security module is loaded (in this case, SELinux), the security_xfrm_policy_lookup() hook can return errors other than access denied, such as -EINVAL. We were not handling that correctly, and in fact inverting the return logic and propagating a false "ok" back up to xfrm_lookup(), which then allowed packets to pass as if they were not associated with an xfrm policy. The solution for this is to first ensure that errno values are correctly propagated all the way back up through the various call chains from security_xfrm_policy_lookup(), and handled correctly. Then, flow_cache_lookup() is modified, so that if the policy resolver fails (typically a permission denied via the security module), the flow cache entry is killed rather than having a null policy assigned (which indicates that the packet can pass freely). This also forces any future lookups for the same flow to consult the security module (e.g. SELinux) for current security policy (rather than, say, caching the error on the flow cache entry). This patch: Fix the selinux side of things. This makes sure SELinux polmatching of flow contexts to IPSec policy rules comes into play only when an explicit context is associated with the IPSec policy rule. Also, this no longer defaults the context of a socket policy to the context of the socket since the "no explicit context" case is now handled properly. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-09-22[NetLabel]: SELinux supportVenkat Yekkirala
Add NetLabel support to the SELinux LSM and modify the socket_post_create() LSM hook to return an error code. The most significant part of this patch is the addition of NetLabel hooks into the following SELinux LSM hooks: * selinux_file_permission() * selinux_socket_sendmsg() * selinux_socket_post_create() * selinux_socket_sock_rcv_skb() * selinux_socket_getpeersec_stream() * selinux_socket_getpeersec_dgram() * selinux_sock_graft() * selinux_inet_conn_request() The basic reasoning behind this patch is that outgoing packets are "NetLabel'd" by labeling their socket and the NetLabel security attributes are checked via the additional hook in selinux_socket_sock_rcv_skb(). NetLabel itself is only a labeling mechanism, similar to filesystem extended attributes, it is up to the SELinux enforcement mechanism to perform the actual access checks. In addition to the changes outlined above this patch also includes some changes to the extended bitmap (ebitmap) and multi-level security (mls) code to import and export SELinux TE/MLS attributes into and out of NetLabel. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[MLSXFRM]: Auto-labeling of child socketsVenkat Yekkirala
This automatically labels the TCP, Unix stream, and dccp child sockets as well as openreqs to be at the same MLS level as the peer. This will result in the selection of appropriately labeled IPSec Security Associations. This also uses the sock's sid (as opposed to the isec sid) in SELinux enforcement of secmark in rcv_skb and postroute_last hooks. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[MLSXFRM]: Default labeling of socket specific IPSec policiesVenkat Yekkirala
This defaults the label of socket-specific IPSec policies to be the same as the socket they are set on. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[MLSXFRM]: Add flow labelingVenkat Yekkirala
This labels the flows that could utilize IPSec xfrms at the points the flows are defined so that IPSec policy and SAs at the right label can be used. The following protos are currently not handled, but they should continue to be able to use single-labeled IPSec like they currently do. ipmr ip_gre ipip igmp sit sctp ip6_tunnel (IPv6 over IPv6 tunnel device) decnet Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[MLSXFRM]: Flow based matching of xfrm policy and stateVenkat Yekkirala
This implements a seemless mechanism for xfrm policy selection and state matching based on the flow sid. This also includes the necessary SELinux enforcement pieces. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[MLSXFRM]: Add security sid to sockVenkat Yekkirala
This adds security for IP sockets at the sock level. Security at the sock level is needed to enforce the SELinux security policy for security associations even when a sock is orphaned (such as in the TCP LAST_ACK state). This will also be used to enforce SELinux controls over data arriving at or leaving a child socket while it's still waiting to be accepted. Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[AF_UNIX]: Kernel memory leak fix for af_unix datagram getpeersec patchCatherine Zhang
From: Catherine Zhang <cxzhang@watson.ibm.com> This patch implements a cleaner fix for the memory leak problem of the original unix datagram getpeersec patch. Instead of creating a security context each time a unix datagram is sent, we only create the security context when the receiver requests it. This new design requires modification of the current unix_getsecpeer_dgram LSM hook and addition of two new hooks, namely, secid_to_secctx and release_secctx. The former retrieves the security context and the latter releases it. A hook is required for releasing the security context because it is up to the security module to decide how that's done. In the case of Selinux, it's a simple kfree operation. Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: Remove obsolete #include <linux/config.h> remove obsolete swsusp_encrypt arch/arm26/Kconfig typos Documentation/IPMI typos Kconfig: Typos in net/sched/Kconfig v9fs: do not include linux/version.h Documentation/DocBook/mtdnand.tmpl: typo fixes typo fixes: specfic -> specific typo fixes in Documentation/networking/pktgen.txt typo fixes: occuring -> occurring typo fixes: infomation -> information typo fixes: disadvantadge -> disadvantage typo fixes: aquire -> acquire typo fixes: mecanism -> mechanism typo fixes: bandwith -> bandwidth fix a typo in the RTC_CLASS help text smb is no longer maintained Manually merged trivial conflict in arch/um/kernel/vmlinux.lds.S
2006-06-30[PATCH] SELinux: Add security hook definition for getioprio and insert hooksDavid Quigley
Add a new security hook definition for the sys_ioprio_get operation. At present, the SELinux hook function implementation for this hook is identical to the getscheduler implementation but a separate hook is introduced to allow this check to be specialized in the future if necessary. This patch also creates a helper function get_task_ioprio which handles the access check in addition to retrieving the ioprio value for the task. Signed-off-by: David Quigley <dpquigl@tycho.nsa.gov> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] SELinux: extend task_kill hook to handle signals sent by AIO completionDavid Quigley
This patch extends the security_task_kill hook to handle signals sent by AIO completion. In this case, the secid of the task responsible for the signal needs to be obtained and saved earlier, so a security_task_getsecid() hook is added, and then this saved value is passed subsequently to the extended task_kill hook for use in checking. Signed-off-by: David Quigley <dpquigl@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[NETLINK]: Encapsulate eff_cap usage within security framework.Darrel Goeddel
This patch encapsulates the usage of eff_cap (in netlink_skb_params) within the security framework by extending security_netlink_recv to include a required capability parameter and converting all direct usage of eff_caps outside of the lsm modules to use the interface. It also updates the SELinux implementation of the security_netlink_send and security_netlink_recv hooks to take advantage of the sid in the netlink_skb_params struct. This also enables SELinux to perform auditing of netlink capability checks. Please apply, for 2.6.18 if possible. Signed-off-by: Darrel Goeddel <dgoeddel@trustedcs.com> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-26[PATCH] keys: sort out key quota systemDavid Howells
Add the ability for key creation to overrun the user's quota in some circumstances - notably when a session keyring is created and assigned to a process that didn't previously have one. This means it's still possible to log in, should PAM require the creation of a new session keyring, and fix an overburdened key quota. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] SELinux: add task_movememory hookDavid Quigley
This patch adds new security hook, task_movememory, to be called when memory owened by a task is to be moved (e.g. when migrating pages to a this hook is identical to the setscheduler implementation, but a separate hook introduced to allow this check to be specialized in the future if necessary. Since the last posting, the hook has been renamed following feedback from Christoph Lameter. Signed-off-by: David Quigley <dpquigl@tycho.nsa.gov> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org> Cc: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@muc.de> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] lsm: add task_setioprio hookJames Morris
Implement an LSM hook for setting a task's IO priority, similar to the hook for setting a tasks's nice value. A previous version of this LSM hook was included in an older version of multiadm by Jan Engelhardt, although I don't recall it being submitted upstream. Also included is the corresponding SELinux hook, which re-uses the setsched permission in the proccess class. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[PATCH] selinux: add hooks for key subsystemMichael LeMay
Introduce SELinux hooks to support the access key retention subsystem within the kernel. Incorporate new flask headers from a modified version of the SELinux reference policy, with support for the new security class representing retained keys. Extend the "key_alloc" security hook with a task parameter representing the intended ownership context for the key being allocated. Attach security information to root's default keyrings within the SELinux initialization routine. Has passed David's testsuite. Signed-off-by: Michael LeMay <mdlemay@epoch.ncsc.mil> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[LSM-IPsec]: SELinux AuthorizeCatherine Zhang
This patch contains a fix for the previous patch that adds security contexts to IPsec policies and security associations. In the previous patch, no authorization (besides the check for write permissions to SAD and SPD) is required to delete IPsec policies and security assocations with security contexts. Thus a user authorized to change SAD and SPD can bypass the IPsec policy authorization by simply deleteing policies with security contexts. To fix this security hole, an additional authorization check is added for removing security policies and security associations with security contexts. Note that if no security context is supplied on add or present on policy to be deleted, the SELinux module allows the change unconditionally. The hook is called on deletion when no context is present, which we may want to change. At present, I left it up to the module. LSM changes: The patch adds two new LSM hooks: xfrm_policy_delete and xfrm_state_delete. The new hooks are necessary to authorize deletion of IPsec policies that have security contexts. The existing hooks xfrm_policy_free and xfrm_state_free lack the context to do the authorization, so I decided to split authorization of deletion and memory management of security data, as is typical in the LSM interface. Use: The new delete hooks are checked when xfrm_policy or xfrm_state are deleted by either the xfrm_user interface (xfrm_get_policy, xfrm_del_sa) or the pfkey interface (pfkey_spddelete, pfkey_delete). SELinux changes: The new policy_delete and state_delete functions are added. Signed-off-by: Catherine Zhang <cxzhang@watson.ibm.com> Signed-off-by: Trent Jaeger <tjaeger@cse.psu.edu> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-01[PATCH] change lspp ipc auditingSteve Grubb
Hi, The patch below converts IPC auditing to collect sid's and convert to context string only if it needs to output an audit record. This patch depends on the inode audit change patch already being applied. Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-03-25Merge branch 'audit.b3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b3' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: (22 commits) [PATCH] fix audit_init failure path [PATCH] EXPORT_SYMBOL patch for audit_log, audit_log_start, audit_log_end and audit_format [PATCH] sem2mutex: audit_netlink_sem [PATCH] simplify audit_free() locking [PATCH] Fix audit operators [PATCH] promiscuous mode [PATCH] Add tty to syscall audit records [PATCH] add/remove rule update [PATCH] audit string fields interface + consumer [PATCH] SE Linux audit events [PATCH] Minor cosmetic cleanups to the code moved into auditfilter.c [PATCH] Fix audit record filtering with !CONFIG_AUDITSYSCALL [PATCH] Fix IA64 success/failure indication in syscall auditing. [PATCH] Miscellaneous bug and warning fixes [PATCH] Capture selinux subject/object context information. [PATCH] Exclude messages by message type [PATCH] Collect more inode information during syscall processing. [PATCH] Pass dentry, not just name, in fsnotify creation hooks. [PATCH] Define new range of userspace messages. [PATCH] Filter rule comparators ... Fixed trivial conflict in security/selinux/hooks.c
2006-03-20[SECURITY] getpeersec: Fix build breakageArnaldo Carvalho de Melo
A recent changeset removes dummy_socket_getpeersec, replacing it with two new functions, but still references the removed function in the security_fixup_ops table, fix it by doing the replacement operation in the fixup table too. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SECURITY]: TCP/UDP getpeersecCatherine Zhang
This patch implements an application of the LSM-IPSec networking controls whereby an application can determine the label of the security association its TCP or UDP sockets are currently connected to via getsockopt and the auxiliary data mechanism of recvmsg. Patch purpose: This patch enables a security-aware application to retrieve the security context of an IPSec security association a particular TCP or UDP socket is using. The application can then use this security context to determine the security context for processing on behalf of the peer at the other end of this connection. In the case of UDP, the security context is for each individual packet. An example application is the inetd daemon, which could be modified to start daemons running at security contexts dependent on the remote client. Patch design approach: - Design for TCP The patch enables the SELinux LSM to set the peer security context for a socket based on the security context of the IPSec security association. The application may retrieve this context using getsockopt. When called, the kernel determines if the socket is a connected (TCP_ESTABLISHED) TCP socket and, if so, uses the dst_entry cache on the socket to retrieve the security associations. If a security association has a security context, the context string is returned, as for UNIX domain sockets. - Design for UDP Unlike TCP, UDP is connectionless. This requires a somewhat different API to retrieve the peer security context. With TCP, the peer security context stays the same throughout the connection, thus it can be retrieved at any time between when the connection is established and when it is torn down. With UDP, each read/write can have different peer and thus the security context might change every time. As a result the security context retrieval must be done TOGETHER with the packet retrieval. The solution is to build upon the existing Unix domain socket API for retrieving user credentials. Linux offers the API for obtaining user credentials via ancillary messages (i.e., out of band/control messages that are bundled together with a normal message). Patch implementation details: - Implementation for TCP The security context can be retrieved by applications using getsockopt with the existing SO_PEERSEC flag. As an example (ignoring error checking): getsockopt(sockfd, SOL_SOCKET, SO_PEERSEC, optbuf, &optlen); printf("Socket peer context is: %s\n", optbuf); The SELinux function, selinux_socket_getpeersec, is extended to check for labeled security associations for connected (TCP_ESTABLISHED == sk->sk_state) TCP sockets only. If so, the socket has a dst_cache of struct dst_entry values that may refer to security associations. If these have security associations with security contexts, the security context is returned. getsockopt returns a buffer that contains a security context string or the buffer is unmodified. - Implementation for UDP To retrieve the security context, the application first indicates to the kernel such desire by setting the IP_PASSSEC option via getsockopt. Then the application retrieves the security context using the auxiliary data mechanism. An example server application for UDP should look like this: toggle = 1; toggle_len = sizeof(toggle); setsockopt(sockfd, SOL_IP, IP_PASSSEC, &toggle, &toggle_len); recvmsg(sockfd, &msg_hdr, 0); if (msg_hdr.msg_controllen > sizeof(struct cmsghdr)) { cmsg_hdr = CMSG_FIRSTHDR(&msg_hdr); if (cmsg_hdr->cmsg_len <= CMSG_LEN(sizeof(scontext)) && cmsg_hdr->cmsg_level == SOL_IP && cmsg_hdr->cmsg_type == SCM_SECURITY) { memcpy(&scontext, CMSG_DATA(cmsg_hdr), sizeof(scontext)); } } ip_setsockopt is enhanced with a new socket option IP_PASSSEC to allow a server socket to receive security context of the peer. A new ancillary message type SCM_SECURITY. When the packet is received we get the security context from the sec_path pointer which is contained in the sk_buff, and copy it to the ancillary message space. An additional LSM hook, selinux_socket_getpeersec_udp, is defined to retrieve the security context from the SELinux space. The existing function, selinux_socket_getpeersec does not suit our purpose, because the security context is copied directly to user space, rather than to kernel space. Testing: We have tested the patch by setting up TCP and UDP connections between applications on two machines using the IPSec policies that result in labeled security associations being built. For TCP, we can then extract the peer security context using getsockopt on either end. For UDP, the receiving end can retrieve the security context using the auxiliary data mechanism of recvmsg. Signed-off-by: Catherine Zhang <cxzhang@watson.ibm.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[PATCH] Miscellaneous bug and warning fixesDustin Kirkland
This patch fixes a couple of bugs revealed in new features recently added to -mm1: * fixes warnings due to inconsistent use of const struct inode *inode * fixes bug that prevent a kernel from booting with audit on, and SELinux off due to a missing function in security/dummy.c * fixes a bug that throws spurious audit_panic() messages due to a missing return just before an error_path label * some reasonable house cleaning in audit_ipc_context(), audit_inode_context(), and audit_log_task_context() Signed-off-by: Dustin Kirkland <dustin.kirkland@us.ibm.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-03-20[PATCH] Capture selinux subject/object context information.Dustin Kirkland
This patch extends existing audit records with subject/object context information. Audit records associated with filesystem inodes, ipc, and tasks now contain SELinux label information in the field "subj" if the item is performing the action, or in "obj" if the item is the receiver of an action. These labels are collected via hooks in SELinux and appended to the appropriate record in the audit code. This additional information is required for Common Criteria Labeled Security Protection Profile (LSPP). [AV: fixed kmalloc flags use] [folded leak fixes] [folded cleanup from akpm (kfree(NULL)] [folded audit_inode_context() leak fix] [folded akpm's fix for audit_ipc_perm() definition in case of !CONFIG_AUDIT] Signed-off-by: Dustin Kirkland <dustin.kirkland@us.ibm.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-01-11[PATCH] move capable() to capability.hRandy.Dunlap
- Move capable() from sched.h to capability.h; - Use <linux/capability.h> where capable() is used (in include/, block/, ipc/, kernel/, a few drivers/, mm/, security/, & sound/; many more drivers/ to go) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[LSM-IPSec]: Security association restriction.Trent Jaeger
This patch series implements per packet access control via the extension of the Linux Security Modules (LSM) interface by hooks in the XFRM and pfkey subsystems that leverage IPSec security associations to label packets. Extensions to the SELinux LSM are included that leverage the patch for this purpose. This patch implements the changes necessary to the XFRM subsystem, pfkey interface, ipv4/ipv6, and xfrm_user interface to restrict a socket to use only authorized security associations (or no security association) to send/receive network packets. Patch purpose: The patch is designed to enable access control per packets based on the strongly authenticated IPSec security association. Such access controls augment the existing ones based on network interface and IP address. The former are very coarse-grained, and the latter can be spoofed. By using IPSec, the system can control access to remote hosts based on cryptographic keys generated using the IPSec mechanism. This enables access control on a per-machine basis or per-application if the remote machine is running the same mechanism and trusted to enforce the access control policy. Patch design approach: The overall approach is that policy (xfrm_policy) entries set by user-level programs (e.g., setkey for ipsec-tools) are extended with a security context that is used at policy selection time in the XFRM subsystem to restrict the sockets that can send/receive packets via security associations (xfrm_states) that are built from those policies. A presentation available at www.selinux-symposium.org/2005/presentations/session2/2-3-jaeger.pdf from the SELinux symposium describes the overall approach. Patch implementation details: On output, the policy retrieved (via xfrm_policy_lookup or xfrm_sk_policy_lookup) must be authorized for the security context of the socket and the same security context is required for resultant security association (retrieved or negotiated via racoon in ipsec-tools). This is enforced in xfrm_state_find. On input, the policy retrieved must also be authorized for the socket (at __xfrm_policy_check), and the security context of the policy must also match the security association being used. The patch has virtually no impact on packets that do not use IPSec. The existing Netfilter (outgoing) and LSM rcv_skb hooks are used as before. Also, if IPSec is used without security contexts, the impact is minimal. The LSM must allow such policies to be selected for the combination of socket and remote machine, but subsequent IPSec processing proceeds as in the original case. Testing: The pfkey interface is tested using the ipsec-tools. ipsec-tools have been modified (a separate ipsec-tools patch is available for version 0.5) that supports assignment of xfrm_policy entries and security associations with security contexts via setkey and the negotiation using the security contexts via racoon. The xfrm_user interface is tested via ad hoc programs that set security contexts. These programs are also available from me, and contain programs for setting, getting, and deleting policy for testing this interface. Testing of sa functions was done by tracing kernel behavior. Signed-off-by: Trent Jaeger <tjaeger@cse.psu.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-30[PATCH] Keys: Add LSM hooks for key management [try #3]David Howells
The attached patch adds LSM hooks for key management facilities. The notable changes are: (1) The key struct now supports a security pointer for the use of security modules. This will permit key labelling and restrictions on which programs may access a key. (2) Security modules get a chance to note (or abort) the allocation of a key. (3) The key permission checking can now be enhanced by the security modules; the permissions check consults LSM if all other checks bear out. (4) The key permissions checking functions now return an error code rather than a boolean value. (5) An extra permission has been added to govern the modification of attributes (UID, GID, permissions). Note that there isn't an LSM hook specifically for each keyctl() operation, but rather the permissions hook allows control of individual operations based on the permission request bits. Key management access control through LSM is enabled by automatically if both CONFIG_KEYS and CONFIG_SECURITY are enabled. This should be applied on top of the patch ensubjected: [PATCH] Keys: Possessor permissions should be additive Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Chris Wright <chrisw@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] SELinux: canonicalize getxattr()James Morris
This patch allows SELinux to canonicalize the value returned from getxattr() via the security_inode_getsecurity() hook, which is called after the fs level getxattr() function. The purpose of this is to allow the in-core security context for an inode to override the on-disk value. This could happen in cases such as upgrading a system to a different labeling form (e.g. standard SELinux to MLS) without needing to do a full relabel of the filesystem. In such cases, we want getxattr() to return the canonical security context that the kernel is using rather than what is stored on disk. The implementation hooks into the inode_getsecurity(), adding another parameter to indicate the result of the preceding fs-level getxattr() call, so that SELinux knows whether to compare a value obtained from disk with the kernel value. We also now allow getxattr() to work for mountpoint labeled filesystems (i.e. mount with option context=foo_t), as we are able to return the kernel value to the user. Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: net/*Al Viro
2005-09-09[PATCH] remove the inode_post_link and inode_post_rename LSM hooksStephen Smalley
This patch removes the inode_post_link and inode_post_rename LSM hooks as they are unused (and likely useless). Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] Remove security_inode_post_create/mkdir/symlink/mknod hooksStephen Smalley
This patch removes the inode_post_create/mkdir/mknod/symlink LSM hooks as they are obsoleted by the new inode_init_security hook that enables atomic inode security labeling. If anyone sees any reason to retain these hooks, please speak now. Also, is anyone using the post_rename/link hooks; if not, those could also be removed. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] security: enable atomic inode security labelingStephen Smalley
The following patch set enables atomic security labeling of newly created inodes by altering the fs code to invoke a new LSM hook to obtain the security attribute to apply to a newly created inode and to set up the incore inode security state during the inode creation transaction. This parallels the existing processing for setting ACLs on newly created inodes. Otherwise, it is possible for new inodes to be accessed by another thread via the dcache prior to complete security setup (presently handled by the post_create/mkdir/... LSM hooks in the VFS) and a newly created inode may be left unlabeled on the disk in the event of a crash. SELinux presently works around the issue by ensuring that the incore inode security label is initialized to a special SID that is inaccessible to unprivileged processes (in accordance with policy), thereby preventing inappropriate access but potentially causing false denials on legitimate accesses. A simple test program demonstrates such false denials on SELinux, and the patch solves the problem. Similar such false denials have been encountered in real applications. This patch defines a new inode_init_security LSM hook to obtain the security attribute to apply to a newly created inode and to set up the incore inode security state for it, and adds a corresponding hook function implementation to SELinux. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] setuid core dumpAlan Cox
Add a new `suid_dumpable' sysctl: This value can be used to query and set the core dump mode for setuid or otherwise protected/tainted binaries. The modes are 0 - (default) - traditional behaviour. Any process which has changed privilege levels or is execute only will not be dumped 1 - (debug) - all processes dump core when possible. The core dump is owned by the current user and no security is applied. This is intended for system debugging situations only. Ptrace is unchecked. 2 - (suidsafe) - any binary which normally would not be dumped is dumped readable by root only. This allows the end user to remove such a dump but not access it directly. For security reasons core dumps in this mode will not overwrite one another or other files. This mode is appropriate when adminstrators are attempting to debug problems in a normal environment. (akpm: > > +EXPORT_SYMBOL(suid_dumpable); > > EXPORT_SYMBOL_GPL? No problem to me. > > if (current->euid == current->uid && current->egid == current->gid) > > current->mm->dumpable = 1; > > Should this be SUID_DUMP_USER? Actually the feedback I had from last time was that the SUID_ defines should go because its clearer to follow the numbers. They can go everywhere (and there are lots of places where dumpable is tested/used as a bool in untouched code) > Maybe this should be renamed to `dump_policy' or something. Doing that > would help us catch any code which isn't using the #defines, too. Fair comment. The patch was designed to be easy to maintain for Red Hat rather than for merging. Changing that field would create a gigantic diff because it is used all over the place. ) Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
