path: root/scripts/kconfig/lxdialog/inputbox.c
2008-04-28kconfig: reversed borderlines in inputboxRoel Kluin
Fix reversal of dlg.border.atr and dlg.dialog.atr for draw_box() Makes the inputbox look like expected Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-28kconfig: gettext support for lxdialogEGRY Gabor
Gettext support for lxdialog. Signed-off-by: Egry Gabor <gaboregry1@t-online.hu> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org>
2006-09-30kconfig/lxdialog: support resizeSam Ravnborg
In all dialogs now properly catch KEY_RESIZE and take proper action. In mconf try to behave sensibly when a dialog routine returns -ERRDISPLAYTOOSMALL. The original check for a screnn size of 80x19 is kept for now. It may make sense to remove it later, but thats anyway what much text is adjusted for. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: let <ESC><ESC> behave as expectedSam Ravnborg
<ESC><ESC> is used to step one back in the dialogs. When lxdialog became built-in pressing <ESC> once would cause one step back and pressing <ESC><ESC> would cause two steps back. This patch - based on concept from Roman Zippel <zippel@linux-m68k.org> - makes one <ESC> a noop and pressing <ESC><ESC> will cause one step backward. In addition the final yes/no dialog now has the option to go back to the the kernel configuration. So if you get too far out you can now go back to configuring the kernel without saving and starting all over again. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/menuconfig: lxdialog is now built-inSam Ravnborg
lxdialog was previously called as an external program causing screen to flicker when used. With this patch lxdialog is now built-in. It is loosly based om previous work by: Petr Baudis <pasky@ucw.cz> Following is a list of changes: o Moved build of dialog routings to kconfig Makefile o menubox + checklist uses a new item list to hold all menu items o in util.c implmented helper function to deal with item list o menubox now uses parameters to save scroll state (avoids temp file) o textbox now get text to be displayed as parameter and not a file o make sure to properly delete subwin's before main windows o killed unused files: lxdialog.c msgbox.c o modified return value for ESC to match direct calling o in a few places the code has been adjusted to 80 char wide o in textbox a small refactoring was made to make code remotely readable o in mconf removed all unused stuff (functions/variables) Following is a list of know short comings: a) pressing ESC twice will be interpreted as two ESC presses b) resize does not work. menuconfig needs to be restarted to be adjusted Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-09-30kconfig/lxdialog: refactor color supportSam Ravnborg
Clean up and refactor color support. All color support are now in util.c including color definitions. In the process introduced a global variable named 'dlg' which is used all over to set color - thats the reason why all files are changed. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-16kconfig: move lxdialog to scripts/kconfig/lxdialogSam Ravnborg
The only lxdialog user i kconfig - for menuconfig. So move it to reflect this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
