path: root/scripts/kconfig/lkc.h
2013-06-24kconfig: loop as long as we changed some symbols in randconfigYann E. MORIN
Because of choice-in-a-choice constructs, it can happen that not all symbols are assigned a value during randconfig, leading in rare cases to this situation: ---8<--- choice-in-choice.in choice bool "A/B/C" config A bool "A" config B bool "B" if B choice bool "E/F" config E bool "E" config F bool "F" endchoice endif # B config C bool "C" endchoice ---8<--- $ ./scripts/kconfig/conf --randconfig choice-in-choice.in [--SNIP--] $ ./scripts/kconfig/conf --silentoldconfig choice-in-choice.in </dev/null [--SNIP--] A/B/C 1. A (A) > 2. B (B) 3. C (C) choice[1-3]: 2 E/F > 1. E (E) (NEW) 2. F (F) (NEW) choice[1-2]: aborted! Console input/output is redirected. Run 'make oldconfig' to update configuration. Fix this by looping in randconfig for as long as some symbol gets assigned a value. Note: this was spotted with the USB EHCI Debug Device Gadget (USB_G_DBGP), which uses this choice-in-a-choice construct, and exhibits this problem. The example above is just a stripped-down minimalist test-case. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr>
2013-06-16kconfig: Fix defconfig when one choice menu selects options that another ↵Arve Hjønnevåg
choice menu depends on The defconfig and Kconfig combination below, which is based on 3.10-rc4 Kconfigs, resulted in several options getting set to "m" instead of "y". defconfig.choice: ---8<--- CONFIG_MODULES=y CONFIG_USB_ZERO=y ---8<--- Kconfig.choice: ---8<--- menuconfig MODULES bool "Enable loadable module support" config CONFIGFS_FS tristate "Userspace-driven configuration filesystem" config OCFS2_FS tristate "OCFS2 file system support" depends on CONFIGFS_FS select CRC32 config USB_LIBCOMPOSITE tristate select CONFIGFS_FS choice tristate "USB Gadget Drivers" default USB_ETH config USB_ZERO tristate "Gadget Zero (DEVELOPMENT)" select USB_LIBCOMPOSITE config USB_ETH tristate "Ethernet Gadget (with CDC Ethernet support)" select USB_LIBCOMPOSITE endchoice config CRC32 tristate "CRC32/CRC32c functions" default y choice prompt "CRC32 implementation" depends on CRC32 default CRC32_SLICEBY8 config CRC32_SLICEBY8 bool "Slice by 8 bytes" endchoice ---8<--- $ scripts/kconfig/conf --defconfig=defconfig.choice Kconfig.choice would result in: .config: ---8<--- CONFIG_MODULES=y CONFIG_CONFIGFS_FS=m CONFIG_USB_LIBCOMPOSITE=m CONFIG_USB_ZERO=m CONFIG_CRC32=y CONFIG_CRC32_SLICEBY8=y ---8<--- when the expected result would be: .config: ---8<--- CONFIG_MODULES=y CONFIG_CONFIGFS_FS=y CONFIG_USB_LIBCOMPOSITE=y CONFIG_USB_ZERO=y CONFIG_CRC32=y CONFIG_CRC32_SLICEBY8=y ---8<--- Signed-off-by: Arve Hjønnevåg <arve@android.com> [yann.morin.1998@free.fr: add the resulting .config to commit log, remove unneeded USB_GADGET from the defconfig] Tested-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Reviewed-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: Yann E. MORIN <yann.morin.1998@free.fr>
2012-11-20kconfig: Fix malloc handling in conf toolsAlan Cox
(and get them out of the noise in the audit work) Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-11-20kconfig: get CONFIG_ prefix from the environmentYann E. MORIN
Currently, the CONFIG_ prefix is hard-coded in the kconfig frontends executables. This means that two projects that use kconfig with different prefixes can not share the same kconfig frontends. Instead of hard-coding the prefix in the frontends, get it from the environment, and revert back to hard-coded value if not found. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-11-20kconfig: add a function to get the CONFIG_ prefixYann E. MORIN
Currently, we get the CONFIG_ prefix via the CONFIG_ macro, which means the CONFIG_ prefix is hard-coded at compile time. This goes against having a run-time defined CONFIG_ prefix. Add a function that returns the CONFIG_ prefix to use (but keep the current hard-coded behavior, to be changed in a later patch). To avoid touching all the code that uses the CONFIG_ macro, we just undef it, and define it to be a call to the function. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-15kbuild: Fix compiler warning with assertion when calling 'fwrite'Arnaud Lacombe
Reinhard Tartler discovered a corner case of calling xfwrite() where the length of the string is zero. Arnaud Lacombe suggested to use assertion for the corner case, as fwrite(3) is currently used: 1) in comment printers. Empty comment are not allowed. 2) in a callback passed to expr_print(), where the string printed is either NULL OR non-empty. 3) in the lexer, auto-generated, and unused. I feel using assertion is a good solution: 1) It cleanly takes care of the above-mentioned corner case. 2) It can be easily disabled by defining NDEBUG. 3) It asserts xfwrite() is simply a wrapper for fwrite(). Reported-by: Reinhard Tartler <Reinhard.Tartler@informatik.uni-erlangen.de> Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Jean Sacren <sakiwit@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-07-30Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) kconfig: Introduce IS_ENABLED(), IS_BUILTIN() and IS_MODULE() xconfig: Abort close if configuration cannot be saved kconfig: fix missing "0x" prefix from S_HEX symbol in autoconf.h kconfig/nconf: remove useless conditionnal kconfig/nconf: prevent segfault on empty menu kconfig/nconf: use the generic menu_get_ext_help() nconfig: Avoid Wunused-but-set warning kconfig/conf: mark xfgets() private kconfig: remove pending prototypes for kconfig_load() kconfig/conf: add command line options' description kconfig/conf: reduce the scope of `defconfig_file' kconfig: use calloc() for expr allocation kconfig: introduce specialized printer kconfig: do not overwrite symbol direct dependency in assignment kconfig/gconf: silent missing prototype warnings kconfig/gconf: kill deadcode kconfig: nuke LKC_DIRECT_LINK cruft kconfig: nuke reference to SWIG kconfig: add missing <stdlib.h> inclusion kconfig: add missing <ctype.h> inclusion ... Fix up conflicts in scripts/kconfig/Makefile
2011-07-04Merge branch 'kconfig-trivial' of git://github.com/lacombar/linux-2.6 into ↵Michal Marek
kbuild/kconfig
2011-07-02kconfig/conf: mark xfgets() privateArnaud Lacombe
This function has not much reason to be public. In the mean time, convert declaration from K&R C to ISO C. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-07-02kconfig: remove pending prototypes for kconfig_load()Arnaud Lacombe
Commit 5a6f8d2bd9e3392569ed6f29ea4d7210652f929b removed `kconfig_load()', however, it missed an hidden prototypes in `lkc.h'. Fix this. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-07-01kconfig: introduce specialized printerArnaud Lacombe
Make conf_write_symbol() grammar agnostic to be able to use it from different code path. These path pass a printer callback which will print a symbol's name and its value in different format. conf_write_symbol()'s job become mostly only to prepare a string for the printer. This avoid to have to pass specialized flag to generic functions Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> [mmarek: rebased on top of de12518 (kconfig: autogenerated config_is_xxx macro)] Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-06-09kconfig: kill no longer needed reference to YYDEBUGArnaud Lacombe
2011-06-06kconfig: nuke LKC_DIRECT_LINK cruftArnaud Lacombe
This interface is not (and has never been ?) used by any frontend, just get rid of it. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
2011-01-10Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: nconf: handle comment entries within choice/endchoice kconfig: fix warning kconfig: Make expr_copy() take a const argument kconfig: simplify select-with-unmet-direct-dependency warning kconfig: add more S_INT and S_HEX consistency checks kconfig: fix `zconfdebug' extern declaration kconfig/conf: merge duplicate switch's case kconfig: fix typos kbuild/gconf: add dummy inline for bind_textdomain_codeset() kbuild/nconf: fix spaces damage kconfig: nuke second argument of conf_write_symbol() kconfig: do not define AUTOCONF_INCLUDED kconfig: the day kconfig warns about "select"-abuse has come
2010-12-15kconfig: fix `zconfdebug' extern declarationArnaud Lacombe
This symbol is only exist if YYDEBUG is defined. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-12-15kbuild/gconf: add dummy inline for bind_textdomain_codeset()Arnaud Lacombe
This symbols is used by gconf. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-11-22kconfig: add an option to determine a menu's visibilityArnaud Lacombe
This option is aimed to add the possibility to control a menu's visibility without adding dependency to the expression to all the submenu. Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Tested-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-09-19kconfig: constify file nameArnaud Lacombe
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Reviewed-by: Michal Marek <mmarek@suse.cz>
2010-09-19kconfig: allow PACKAGE to be defined on the compiler's command-lineArnaud Lacombe
2010-09-19kconfig: allow build-time definition of the internal config prefixArnaud Lacombe
2010-08-13kconfig: Fix warning: ignoring return value of 'fgets'Jean Sacren
This fix facilitates fgets() either it returns on success or on error or when end of file occurs. Signed-off-by: Jean Sacren <sakiwit@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-13kconfig: Fix warning: ignoring return value of 'fwrite'Jean Sacren
This fix facilitates fwrite() in both confdata.c and expr.c, either it succeeds in writing, or an error occurs, or the end of file is reached. Signed-off-by: Jean Sacren <sakiwit@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-03kconfig: add savedefconfigSam Ravnborg
savedefconfig will save a minimal config to a file named "defconfig". The config symbols are saved in the same order as they appear in the menu structure so it should be possible to map them to the relevant menus if desired. The implementation was tested against several minimal configs for arm which was created using brute-force. There was one regression related to default numbers which had their valid range further limited by another symbol. Sample: config FOO int "foo" default 4 config BAR int "bar" range 0 FOO If FOO is set to 3 then BAR cannot take a value higher than 3. But the current implementation will set BAR equal to 4. This is seldomly used and the final configuration is OK, and the fix was non-trivial. So it was documented in the code and left as is. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-08-03kconfig: refactor code in symbol.cSam Ravnborg
Move logic to determine default for a choice to a separate function. No functional changes. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-02-02kconfig: new configuration interface (nconfig)nir.tzachar@gmail.com
This patch was inspired by the kernel projects page, where an ncurses replacement for menuconfig was mentioned (by Sam Ravnborg). Building on menuconfig, this patch implements a more modern look interface using ncurses and ncurses' satellite libraries (menu, panel, form). The implementation does not depend on lxdialog, which is currently distributed with the kernel. Signed-off-by: Nir Tzachar <nir.tzachar@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-02-02menuconfig: wrap long help linesVadim Bendebury (вб)
Help text for certain config options is very extensive (the text includes the names of all other options the option in question depends on). Long lines are not wrapped, making it impossible to see the list without scrolling horizontally. This patch adds some logic which wraps help screen lines at word boundaries to prevent truncating. Tested by running ARCH=powerpc make menuconfig O=/tmp/build which shows that the long lines are now wrapped, and ARCH=powerpc make xconfig O=/tmp/build to demonstrate that it still compiles and operates as expected. Signed-off-by: Vadim Bendebury <vbendeb@google.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-06-09kconfig: do not hardcode "include/config/auto.conf" filenameMarkus Heidelberg
Regardless of KCONFIG_AUTOCONFIG, the filename written as a Make target into "include/config/auto.conf.cmd" was always the default one. Of course this doesn't make it work for the Kernel kbuild system, since there the filename is hardcoded at several places in the Makefiles. Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-25kconfig: set all new symbols automaticallyRoman Zippel
Add conf_set_all_new_symbols() which set all symbols (which don't have a value yet) to a specifed value. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-04kconfig: fix MAC OS X warnings in menuconfigSam Ravnborg
Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Timur Tabi <timur@freescale.com>
2008-01-28kconfig: environment symbol supportRoman Zippel
Add the possibility to import a value from the environment into kconfig via the option syntax. Beside flexibility this has the advantage providing proper dependencies. Documented the options syntax. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02kconfig/menuconfig: do not hardcode '.config'Sam Ravnborg
Export and use the function conf_get_configname() to retreive the default configuration filename. Suggested by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-12-13[PATCH] kconfig: make sym_change_count static, let it be altered by 2 ↵Karsten Wiese
functions only Those two functions are void sym_set_change_count(int count) and void sym_add_change_count(int count) All write accesses to sym_change_count are replaced by calls to above functions. Variable and changer-functions are moved to confdata.c. IMO thats ok, as sym_change_count is an attribute of the .config's change state. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-09kconfig: KCONFIG_OVERWRITECONFIGRoman Zippel
If you set KCONFIG_OVERWRITECONFIG in environment, Kconfig will not break symlinks when .config is a symlink to somewhere else. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-09kconfig: add defconfig_list/module optionRoman Zippel
This makes it possible to change two options which were hardcoded sofar. 1. Any symbol can now take the role of CONFIG_MODULES 2. The more useful option is to change the list of default file names, which kconfig uses to load the base configuration if .config isn't available. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-09kconfig: add symbol option config syntaxRoman Zippel
This adds the general framework to the parser to define options for config symbols with a syntax like: config FOO option bar[="arg"] Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2006-06-09kconfig: allow loading multiple configurationsRoman Zippel
Extend conf_read_simple() so it can load multiple configurations. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-11-09[PATCH] kconfig: stricter error checking for .configRoman Zippel
Add some more checks during the parsing of .config, so that after parsing sym_change_count reflects the correct state whether the .config is correct and in sync with the Kconfig or if it needs saving. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] kconfig: improve error handling in the parserRoman Zippel
Add a few error tokens to the parser to catch common errors and print more descriptive error messages. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] kconfig: simplify symbol type parsingRoman Zippel
This simplifies the parser a bit by merging the various symbol types into a single token and adds the type to the keyword hash. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] kconfig: use gperf for kconfig keywordsRoman Zippel
Use gperf to generate a hash for the kconfig keywords. This greatly reduces the size of the generated scanner and makes it easier to extend kconfig. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fix build on nls free systemsYuri Vasilevski
I made a patch that detects if libintl.h (needed for nls) is present on the host system and if it's not, it nls support is disabled by providing dummies for the used nls functions. This way if there is nls support on the host system the *config targets will build according to Arnaldo Carvalho de Melo's i18n modifications, else it just uses the original English messages. I have also made a bug report at kernel's bugzilla: http://bugzilla.kernel.org/show_bug.cgi?id=5501 And there is a discussion about this problem in Gentoo's bugzilla: http://bugs.gentoo.org/show_bug.cgi?id=99810 Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] kconfig: trivial cleanupblaisorblade@yahoo.it
Replace all menu_add_prop mimicking menu_add_prompt with the latter func. I've had to add a return value to menu_add_prompt for one usage. I've rebuilt scripts/kconfig/zconf.tab.c_shipped by hand to reflect changes in the source (I've not the same Bison version so regenerating it wouldn't have been not a good idea), and compared it with what Roman itself did some time ago, and it's the same. So I guess this can be finally merged. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-05-05[PATCH] Kconfig i18n supportArnaldo Carvalho de Melo
This patch adds i18n support for make *config, allowing users to have the config process in their own language. No printk was harmed in the process, don't worry, so all the bug reports, kernel messages, etc, remain in english, just the user tools to configure the kernel are internationalized. Users not interested in translations can just unset the related LANG, LC_ALL, etc env variables and have the config process in plain english, something like: LANG= make menuconfig is enough for having the whole config process in english. Or just don't install any translation file. Translations for brazilian portuguese are being done by a team of volunteers at: http://www.visionflex.inf.br/kernel_ptbr/pmwiki.php/Principal/Traducoes To start the translation process: make update-po-config This will generate the pot template named scripts/kconfig/linux.pot, copy it to, say, ~/es.po, to start the translation for spanish. To test your translation, as root issue this command: msgfmt -o /usr/share/locale/es/LC_MESSAGES/linux.mo ~/es.po Replace "es" with your language code. Then execute, for instance: make menuconfig The current patch doesn't use any optimization to reduce the size of the generated .mo file, it is possible to use the config option as a key, but this doesn't prevent the current patch from being used or the translations done under the current scheme to be in any way lost if we chose to do any kind of keying. Thanks to Fabricio Vaccari for starting the pt_BR (brazilian portuguese) translation effort, Thiago Maciera for helping me with the gconf.cc (QT frontent) i18n coding and to all the volunteers that are already working on the first translation, to pt_BR. I left the question on whether to ship the translations with the stock kernel sources to be discussed here, please share your suggestions. Signed-off-by: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org Signed-off-by: Andrew Morton <akpm@osdl.org>
