path: root/scripts/kconfig/gconf.c
2005-07-28[PATCH] fix gconfig crashJoachim Nilsson
I ran glade-2 on the glade file, fixed two missing stock icons and cleaned up the C code that inserts the single/split/full modes. The rest of the patch is minor cleanups only. I refrained from using all the included xpm icons in images.c (like qconf.cc does) in favour of using the stock Gtk+ icons instead. Oh, yes there was a "back" bug in split mode that I also removed, oh well... It has been tested with success by several people, including Jesper Juhl, Randy Dunlap and myself. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] Kconfig i18n supportArnaldo Carvalho de Melo
This patch adds i18n support for make *config, allowing users to have the config process in their own language. No printk was harmed in the process, don't worry, so all the bug reports, kernel messages, etc, remain in english, just the user tools to configure the kernel are internationalized. Users not interested in translations can just unset the related LANG, LC_ALL, etc env variables and have the config process in plain english, something like: LANG= make menuconfig is enough for having the whole config process in english. Or just don't install any translation file. Translations for brazilian portuguese are being done by a team of volunteers at: http://www.visionflex.inf.br/kernel_ptbr/pmwiki.php/Principal/Traducoes To start the translation process: make update-po-config This will generate the pot template named scripts/kconfig/linux.pot, copy it to, say, ~/es.po, to start the translation for spanish. To test your translation, as root issue this command: msgfmt -o /usr/share/locale/es/LC_MESSAGES/linux.mo ~/es.po Replace "es" with your language code. Then execute, for instance: make menuconfig The current patch doesn't use any optimization to reduce the size of the generated .mo file, it is possible to use the config option as a key, but this doesn't prevent the current patch from being used or the translations done under the current scheme to be in any way lost if we chose to do any kind of keying. Thanks to Fabricio Vaccari for starting the pt_BR (brazilian portuguese) translation effort, Thiago Maciera for helping me with the gconf.cc (QT frontent) i18n coding and to all the volunteers that are already working on the first translation, to pt_BR. I left the question on whether to ship the translations with the stock kernel sources to be discussed here, please share your suggestions. Signed-off-by: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org Signed-off-by: Andrew Morton <akpm@osdl.org>
