path: root/net
2011-07-05packet: Add fanout support.David S. Miller
Fanouts allow packet capturing to be demuxed to a set of AF_PACKET sockets. Two fanout policies are implemented: 1) Hashing based upon skb->rxhash 2) Pure round-robin An AF_PACKET socket must be fully bound before it tries to add itself to a fanout. All AF_PACKET sockets trying to join the same fanout must all have the same bind settings. Fanouts are identified (within a network namespace) by a 16-bit ID. The first socket to try to add itself to a fanout with a particular ID, creates that fanout. When the last socket leaves the fanout (which happens only when the socket is closed), that fanout is destroyed. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-05packet: Add helpers to register/unregister ->prot_hookDavid S. Miller
2011-07-05Merge branch 'batman-adv/next' of git://git.open-mesh.org/linux-mergeDavid S. Miller
2011-07-05Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2011-07-05batman-adv: Replace version info instead of appending themSven Eckelmann
The version number of modules build outside of the tree can get revision numbers added. This is useful to give hints about the revision of a distribution package and the used patchset. The prepended source number or branch name doesn't add any additional information which would help to identify problems and can therefore be omitted. Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
2011-07-05batman-adv: aggregation checks should use the primary_if pointerMarek Lindner
The packet aggregation needs to ensure that only compatible packets are aggregated. Some of the checks are based on the interface number while assuming that the first interface also is the primary interface which is not always the case. This patch addresses the issue by using the primary_if pointer. Reported-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
2011-07-05batman-adv: broadcast primary OGM on all active hard-interfacesMarek Lindner
The primary interface OGM has to be broadcasted on all hard-interfaces even if the primary interface is not the first interface (if_num = 0). Therefore the code has to compare the originating interface with the primary interface instead of checking the if_num. Reported-by: Linus Luessing <linus.luessing@web.de> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
2011-07-05batman-adv: pass a unique flag arg instead of a sequence of bool onesAntonio Quartulli
now tt_local_event() takes a flags argument instead of a sequence of boolean values which would grow up with the time. Signed-off-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
2011-07-05batman-adv: add_bcast_packet_to_list() takes the sending delay as parameterAntonio Quartulli
In order to make possible to use the broadcast list for delayed sendings the "delay" parameter is now provided instead of using 1 as hardcoded value. Signed-off-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
2011-07-05batman-adv: unify flags for tt_change/tt_local_entry/tt_global_entryAntonio Quartulli
The tt_local_entry structure now has a 'flags' field. This helps to unify the flags format to all the client related structures (tt_global_entry and tt_change). The 'never_purge' field is now encoded in the 'flags' one. To optimise the usage of this field, its length has been increased to 16bit in order to use the eight leading bits (from 0 to 7) to store flags that have to be sent on the wire, while the eight ending ones are used for local computation only. Moreover 'enum tt_change_flags' is now called 'enum tt_client_flags' and the defined values apply to the tt_local_entry, tt_global_entry and the tt_change 'flags' field. Signed-off-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Marek Lindner <lindner_marek@yahoo.de>
2011-07-04dccp ccid-2: Perform congestion-window validationGerrit Renker
CCID-2's cwnd increases like TCP during slow-start, which has implications for * the local Sequence Window value (should be > cwnd), * the Ack Ratio value. Hence an exponential growth, if it does not reflect the actual network conditions, can quickly lead to instability. This patch adds congestion-window validation (RFC2861) to CCID-2: * cwnd is constrained if the sender is application limited; * cwnd is reduced after a long idle period, as suggested in the '90 paper by Van Jacobson, in RFC 2581 (sec. 4.1); * cwnd is never reduced below the RFC 3390 initial window. As marked in the comments, the code is actually almost a direct copy of the TCP congestion-window-validation algorithms. By continuing this work, it may in future be possible to use the TCP code (not possible at the moment). The mechanism can be turned off using a module parameter. Sampling of the currently-used window (moving-maximum) is however done constantly; this is used to determine the expected window, which can be exploited to regulate DCCP's Sequence Window value. This patch also sets slow-start-after-idle (RFC 4341, 5.1), i.e. it behaves like TCP when net.ipv4.tcp_slow_start_after_idle = 1. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2011-07-04dccp ccid-2: Use existing function to test for data packetsGerrit Renker
This replaces a switch statement with a test, using the equivalent function dccp_data_packet(skb). It also doubles the range of the field `rx_num_data_pkts' by changing the type from `int' to `u32', avoiding signed/unsigned comparison with the u16 field `dccps_r_ack_ratio'. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2011-07-04dccp ccid-2: move rfc 3390 function into header fileGerrit Renker
This moves CCID-2's initial window function into the header file, since several parts throughout the CCID-2 code need to call it (CCID-2 still uses RFC 3390). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Leandro Melo de Sales <leandro@ic.ufal.br>
2011-07-04dccp: cosmetics of info messageGerrit Renker
Change the CCID (de)activation message to start with the protocol name, as 'CCID' is already in there. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2011-07-04dccp: combine the functionality of enqeueing and cloningGerrit Renker
Realising the following call pattern, * first dccp_entail() is called to enqueue a new skb and * then skb_clone() is called to transmit a clone of that skb, this patch integrates both into the same function. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2011-07-04dccp: Clean up slow-path input processingGerrit Renker
This patch rearranges the order of statements of the slow-path input processing (i.e. any other state than OPEN), to resolve the following issues. 1. Dependencies: the order of statements now better matches RFC 4340, 8.5, i.e. step 7 is before step 9 (previously 9 was before 7), and parsing options in step 8 (which may consume resources) now comes after step 7. 2. Sequence number checks are omitted if in state LISTEN/REQUEST, due to the note underneath the table in RFC 4340, 7.5.3. As a result, CCID processing is now indeed confined to OPEN/PARTOPEN states, i.e. congestion control is performed only on the flow of data packets. This avoids pathological cases of doing congestion control on those messages which set up and terminate the connection. 3. Packets are now passed on to Ack Vector / CCID processing only after - step 7 (receive unexpected packets), - step 9 (receive Reset), - step 13 (receive CloseReq), - step 14 (receive Close) and only if the state is PARTOPEN. This simplifies CCID processing: - in LISTEN/CLOSED the CCIDs are non-existent; - in RESPOND/REQUEST the CCIDs have not yet been negotiated; - in CLOSEREQ and active-CLOSING the node has already closed this socket; - in passive-CLOSING the client is waiting for its Reset. In the last case, RFC 4340, 8.3 leaves it open to ignore further incoming data, which is the approach taken here. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
2011-07-03af_econet: Use current logging styles and neateningJoe Perches
Use pr_fmt() without KBUILD_MODNAME to allow AUN and econet prefixes. Convert printks with KERN_DEBUG to pr_debug. Hoist assigns from if. 80 column wrapping. Move open braces to end of line. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-03netpoll: Remove wrapper function netpoll_pollJoe Perches
Too trivial to live. cc: WANG Cong <amwang@redhat.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-03netpoll: Remove unused EXPORT_SYMBOLs of netpoll_poll and netpoll_poll_devJoe Perches
Unused symbols waste space. Commit 0e34e93177fb "(netpoll: add generic support for bridge and bonding devices)" added the symbol more than a year ago with the promise of "future use". Because it is so far unused, remove it for now. It can be easily readded if or when it actually needs to be used. cc: WANG Cong <amwang@redhat.com> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01Merge branch 'for-next' of ↵David S. Miller
git://git2.kernel.org/pub/scm/linux/kernel/git/lowpan/lowpan
2011-07-01net: rds: fix const array syntaxGreg Dietsche
Correct the syntax so that both array and pointer are const. Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01x25: Reduce switch/case indentJoe Perches
Make the case labels the same indent as the switch. git diff -w shows 80 column line reflowing. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01sunrpc: Reduce switch/case indentJoe Perches
2011-07-01sctp: Reduce switch/case indentJoe Perches
Make the case labels the same indent as the switch. git diff -w shows useless break;s removed after returns and a comment added to an unnecessary default: break; because of a dubious gcc warning. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01netrom: Reduce switch/case indentJoe Perches
Make the case labels the same indent as the switch. git diff -w shows code on same line as case moved to separate lines and a "/* Fallthrough */" comment added where appropriate. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01lapb: Reduce switch/case indentJoe Perches
Make the case labels the same indent as the switch. git diff -w shows 80 column reflowing. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01ipv6: Reduce switch/case indentJoe Perches
Make the case labels the same indent as the switch. git diff -w shows 80 column reflowing, removal of a useless break after return, and moving open brace after case instead of separate line. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01ipv4: Reduce switch/case indentJoe Perches
Make the case labels the same indent as the switch. git diff -w shows no difference. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01netfilter: Reduce switch/case indentJoe Perches
Make the case labels the same indent as the switch. git diff -w shows miscellaneous 80 column wrapping, comment reflowing and a comment for a useless gcc warning for an otherwise unused default: case. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01ipconfig: Reduce switch/case indentJoe Perches
Make the case labels the same indent as the switch. git diff -w shows miscellaneous 80 column wrapping. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01econet: Reduce switch/case indentJoe Perches
Make the case labels the same indent as the switch. Simplify a default case / return (unreached) Remove unnecessary break after return. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01decnet: Reduce switch/case indentJoe Perches
Make the case labels the same indent as the switch. git diff -w shows differences for line wrapping. (fit multiple lines to 80 columns, join where possible) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01appletalk: Reduce switch/case indentJoe Perches
Make the case labels the same indent as the switch. (git diff -w net/appletalk shows no difference) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01rtnl: provide link dump consistency infoThomas Graf
This patch adds a change sequence counter to each net namespace which is bumped whenever a netdevice is added or removed from the list. If such a change occurred while a link dump took place, the dump will have the NLM_F_DUMP_INTR flag set in the first message which has been interrupted and in all subsequent messages of the same dump. Note that links may still be modified or renamed while a dump is taking place but we can guarantee for userspace to receive a complete list of links and not miss any. Testing: I have added 500 VLAN netdevices to make sure the dump is split over multiple messages. Then while continuously dumping links in one process I also continuously deleted and re-added a dummy netdevice in another process. Multiple dumps per seconds have had the NLM_F_DUMP_INTR flag set. I guess we can wait for Johannes patch to hit net-next via the wireless tree. I just wanted to give this some testing right away. Signed-off-by: Thomas Graf <tgraf@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-30Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2011-06-30ieee802154: free skb buffer if dev isn't runningAlexander Smirnov
Signed-off-by: Alexander Smirnov <alex.bluesman.smirnov@gmail.com> Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
2011-06-30ieee802154: it's IEEE 802.15.4, not ZigBeeDmitry Eremin-Solenikov
2011-06-30ieee802154: support specifying hw address for created devicesDmitry Eremin-Solenikov
2011-06-29mac80211: propagate information about STA WME support downArik Nemtsov
Add a memeber to the ieee80211_sta structure to indicate whether the STA supports WME. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-29DSA: Enable cascading in multi-chip 6131 configurationBarry Grussling
This patch enables the 6131 family of chips to forward DSA packets to other switch chips. This is needed if multiple DSA chips are used in a device. Without this patch the chip will drop any DSA packets not destined for it. This patch only enables the forwarding of DSA packets if multiple chips are used in the switch configuration. Signed-off-by: Barry Grussling <barry@grussling.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-28Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-tx.c
2011-06-27mac80211: dynamic PS - don't enter PS when TX frames are pendingArik Nemtsov
Use the tx_frames_pending() driver callback to determine if Tx frames are pending for its internal queues. If so postpone the dynamic PS timeout to avoid interrupting Tx traffic. The commit e8306f989483e4b97a8b37dd268de6c8c6f35e75 enabled this behavior for drivers with IEEE80211_HW_PS_NULLFUNC_STACK. We enable this for all drivers supporting dynamic PS. This patch helps improve performance in noisy environments. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-27mac80211: Drop DS Channel PARAM in directed probePaul Stewart
Do not send DS Channel parameter for directed probe requests in order to maximize the chance that we get a response. Some badly-behaved APs don't respond when this parameter is included. Signed-off-by: Paul Stewart <pstew@chromium.org> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-27mac80211: reestablish mis-configured existing Rx BA sessionsArik Nemtsov
When forming a Rx BA session, sometimes the ADDBA response gets lost. This leads to a situation where the session is configured locally, but doesn't exist on the remote side. Subsequent ADDBA requests are declined by mac80211. Fix this by assuming the session state of the initiator is the correct one. When receiving an unexpected ADDBA request on a TID with an active Rx BA session, delete the existing one and establish a new session. Signed-off-by: Arik Nemtsov <arik@wizery.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-27bluetooth: uses crypto interfaces, select CRYPTORandy Dunlap
Recent changes to hci_core.c use crypto interfaces, so select CRYPTO to make sure that those interfaces are present. Fixes these build errors when CRYPTO is not enabled: net/built-in.o: In function `hci_register_dev': (.text+0x4cf86): undefined reference to `crypto_alloc_base' net/built-in.o: In function `hci_unregister_dev': (.text+0x4f912): undefined reference to `crypto_destroy_tfm' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-27mac80211: restrict advertised HW scan ratesJohannes Berg
Advertise only user-requested bitrates in a HW scan. Note that the hw_scan API doesn't currently have a way of asking for a specific probe request bitrate, so we might end up using a bitrate that we don't advertise as supported. I'll fix that later. Also add a hexdump printk to hwsim to verify this. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-27wireless: unify QoS control field definitionsJohannes Berg
Move all that mac80211 has into the generic ieee80211.h header file and use them. At the same time move them from mask+shift to just bits and rename them for consistent names. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-27mac80211: fix rx->key NULL dereference during mic failureArik Nemtsov
Sometimes when reporting a MIC failure rx->key may be unset. This code path is hit when receiving a packet meant for a multicast address, and decryption is performed in HW. Fortunately, the failing key_idx is not used for anything up to (and including) usermode, so we allow ourselves to drop it on the way up when a key cannot be retrieved. Signed-off-by: Arik Nemtsov <arik@wizery.com> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-27net_sched: fix dequeuer fairnessjamal
Results on dummy device can be seen in my netconf 2011 slides. These results are for a 10Gige IXGBE intel nic - on another i5 machine, very similar specs to the one used in the netconf2011 results. It turns out - this is a hell lot worse than dummy and so this patch is even more beneficial for 10G. Test setup: ---------- System under test sending packets out. Additional box connected directly dropping packets. Installed prio qdisc on the eth device and default netdev default length of 1000 used as is. The 3 prio bands each were set to 100 (didnt factor in the results). 5 packet runs were made and the middle 3 picked. results ------- The "cpu" column indicates the which cpu the sample was taken on, The "Pkt runx" carries the number of packets a cpu dequeued when forced to be in the "dequeuer" role. The "avg" for each run is the number of times each cpu should be a "dequeuer" if the system was fair. 3.0-rc4 (plain) cpu Pkt run1 Pkt run2 Pkt run3 ================================================ cpu0 21853354 21598183 22199900 cpu1 431058 473476 393159 cpu2 481975 477529 458466 cpu3 23261406 23412299 22894315 avg 11506948 11490372 11486460 3.0-rc4 with patch and default weight 64 cpu Pkt run1 Pkt run2 Pkt run3 ================================================ cpu0 13205312 13109359 13132333 cpu1 10189914 10159127 10122270 cpu2 10213871 10124367 10168722 cpu3 13165760 13164767 13096705 avg 11693714 11639405 11630008 As you can see the system is still not perfect but is a lot better than what it was before... At the moment we use the old backlog weight, weight_p which is 64 packets. It seems to be reasonably fine with that value. The system could be made more fair if we reduce the weight_p (as per my presentation), but we are going to affect the shared backlog weight. Unless deemed necessary, I think the default value is fine. If not we could add yet another knob. Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-24net: Kill unuseful net/TUNABLE doc in kernel sourceShan Wei
File net/TUNABLE has never be updated since git age. For some tunable parameters which user can control with proc file-system, They are all in ip-sysctl.txt doc. For tunable parameters that only at compile time, no meaning to note them. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
