[ Upstream commit 7c68d1a6b4db9012790af7ac0f0fdc0d2083422a ]
Without proper validation of DODGY packets, we might very well
feed qdisc_pkt_len_init() with invalid GSO packets.
tcp_hdrlen() might access out-of-bound data, so let's use
skb_header_pointer() and proper checks.
Whole story is described in commit d0c081b49137 ("flow_dissector:
properly cap thoff field")
We have the goal of validating DODGY packets earlier in the stack,
so we might very well revert this fix in the future.
Cc: Willem de Bruijn <willemb@google.com>
Cc: Jason Wang <jasowang@redhat.com>
Reported-by: syzbot+9da69ebac7dddd804552@syzkaller.appspotmail.com
Acked-by: Jason Wang <jasowang@redhat.com>
[ Upstream commit ad23b750933ea7bf962678972a286c78a8fa36aa ]
Commit "net: igmp: Use correct source address on IGMPv3 reports"
introduced a check to validate the source address of locally generated
IGMPv3 packets.
Instead of checking the local interface address directly, it uses
inet_ifa_match(fl4->saddr, ifa), which checks if the address is on the
local subnet (or equal to the point-to-point address if used).
This breaks for point-to-point interfaces, so check against
ifa->ifa_local directly.
Cc: Kevin Cernekee <cernekee@chromium.org>
Fixes: a46182b00290 ("net: igmp: Use correct source address on IGMPv3 reports")
Reported-by: Sebastian Gottschall <s.gottschall@dd-wrt.com>
Signed-off-by: Felix Fietkau <nbd@nbd.name>
[ Upstream commit 95ef498d977bf44ac094778fd448b98af158a3e6 ]
In my last patch, I missed fact that cork.base.dst was not initialized
in ip6_make_skb() :
If ip6_setup_cork() returns an error, we might attempt a dst_release()
on some random pointer.
Fixes: 862c03ee1deb ("ipv6: fix possible mem leaks in ipv6_make_skb()")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit 749439bfac6e1a2932c582e2699f91d329658196 ]
The logic in __ip6_append_data() assumes that the MTU is at least large
enough for the headers. A device's MTU may be adjusted after being
added while sendmsg() is processing data, resulting in
__ip6_append_data() seeing any MTU. For an mtu smaller than the size of
the fragmentation header, the math results in a negative 'maxfraglen',
which causes problems when refragmenting any previous skb in the
skb_write_queue, leaving it possibly malformed.
Instead sendmsg returns EINVAL when the mtu is calculated to be less
than IPV6_MIN_MTU.
Found by syzkaller:
kernel BUG at ./include/linux/skbuff.h:2064!
invalid opcode: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 1 PID: 14216 Comm: syz-executor5 Not tainted 4.13.0-rc4+ #2
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
task: ffff8801d0b68580 task.stack: ffff8801ac6b8000
RIP: 0010:__skb_pull include/linux/skbuff.h:2064 [inline]
RIP: 0010:__ip6_make_skb+0x18cf/0x1f70 net/ipv6/ip6_output.c:1617
RSP: 0018:ffff8801ac6bf570 EFLAGS: 00010216
RAX: 0000000000010000 RBX: 0000000000000028 RCX: ffffc90003cce000
RDX: 00000000000001b8 RSI: ffffffff839df06f RDI: ffff8801d9478ca0
RBP: ffff8801ac6bf780 R08: ffff8801cc3f1dbc R09: 0000000000000000
R10: ffff8801ac6bf7a0 R11: 43cb4b7b1948a9e7 R12: ffff8801cc3f1dc8
R13: ffff8801cc3f1d40 R14: 0000000000001036 R15: dffffc0000000000
FS: 00007f43d740c700(0000) GS:ffff8801dc100000(0000) knlGS:0000000000000000
CR2: 00007f7834984000 CR3: 00000001d79b9000 CR4: 00000000001406e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
ip6_finish_skb include/net/ipv6.h:911 [inline]
udp_v6_push_pending_frames+0x255/0x390 net/ipv6/udp.c:1093
udpv6_sendmsg+0x280d/0x31a0 net/ipv6/udp.c:1363
inet_sendmsg+0x11f/0x5e0 net/ipv4/af_inet.c:762
sock_sendmsg_nosec net/socket.c:633 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:643
SYSC_sendto+0x352/0x5a0 net/socket.c:1750
SyS_sendto+0x40/0x50 net/socket.c:1718
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x4512e9
RSP: 002b:00007f43d740bc08 EFLAGS: 00000216 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 00000000007180a8 RCX: 00000000004512e9
RDX: 000000000000002e RSI: 0000000020d08000 RDI: 0000000000000005
RBP: 0000000000000086 R08: 00000000209c1000 R09: 000000000000001c
R10: 0000000000040800 R11: 0000000000000216 R12: 00000000004b9c69
R13: 00000000ffffffff R14: 0000000000000005 R15: 00000000202c2000
Code: 9e 01 fe e9 c5 e8 ff ff e8 7f 9e 01 fe e9 4a ea ff ff 48 89 f7 e8 52 9e 01 fe e9 aa eb ff ff e8 a8 b6 cf fd 0f 0b e8 a1 b6 cf fd <0f> 0b 49 8d 45 78 4d 8d 45 7c 48 89 85 78 fe ff ff 49 8d 85 ba
RIP: __skb_pull include/linux/skbuff.h:2064 [inline] RSP: ffff8801ac6bf570
RIP: __ip6_make_skb+0x18cf/0x1f70 net/ipv6/ip6_output.c:1617 RSP: ffff8801ac6bf570
Signed-off-by: Mike Maloney <maloney@google.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit e9191ffb65d8e159680ce0ad2224e1acbde6985c ]
Commit 513674b5a2c9 ("net: reevalulate autoflowlabel setting after
sysctl setting") removed the initialisation of
ipv6_pinfo::autoflowlabel and added a second flag to indicate
whether this field or the net namespace default should be used.
The getsockopt() handling for this case was not updated, so it
currently returns 0 for all sockets for which IPV6_AUTOFLOWLABEL is
not explicitly enabled. Fix it to return the effective value, whether
that has been set at the socket or net namespace level.
Fixes: 513674b5a2c9 ("net: reevalulate autoflowlabel setting after sysctl ...")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
[ Upstream commit dd5684ecae3bd8e44b644f50e2c12c7e57fdfef5 ]
ccid2_hc_tx_rto_expire() timer callback always restarts the timer
again and can run indefinitely (unless it is stopped outside), and after
commit 120e9dabaf55 ("dccp: defer ccid_hc_tx_delete() at dismantle time"),
which moved ccid_hc_tx_delete() (also includes sk_stop_timer()) from
dccp_destroy_sock() to sk_destruct(), this started to happen quite often.
The timer prevents releasing the socket, as a result, sk_destruct() won't
be called.
Found with LTP/dccp_ipsec tests running on the bonding device,
which later couldn't be unloaded after the tests were completed:
unregister_netdevice: waiting for bond0 to become free. Usage count = 148
Fixes: 2a91aa396739 ("[DCCP] CCID2: Initial CCID2 (TCP-Like) implementation")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
commit 916a27901de01446bcf57ecca4783f6cff493309 upstream.
The capability check in nfnetlink_rcv() verifies that the caller
has CAP_NET_ADMIN in the namespace that "owns" the netlink socket.
However, xt_osf_fingers is shared by all net namespaces on the
system. An unprivileged user can create user and net namespaces
in which he holds CAP_NET_ADMIN to bypass the netlink_net_capable()
check:
vpnns -- nfnl_osf -f /tmp/pf.os
vpnns -- nfnl_osf -f /tmp/pf.os -d
These non-root operations successfully modify the systemwide OS
fingerprint list. Add new capable() checks so that they can't.
Signed-off-by: Kevin Cernekee <cernekee@chromium.org>
Acked-by: Michal Kubecek <mkubecek@suse.cz>
commit 4b380c42f7d00a395feede754f0bc2292eebe6e5 upstream.
However, nfnl_cthelper_list is shared by all net namespaces on the
check:
$ nfct helper list
nfct v1.4.4: netlink error: Operation not permitted
$ vpnns -- nfct helper list
.name = ftp,
.queuenum = 0,
.l3protonum = 2,
.l4protonum = 6,
.priv_data_len = 24,
.status = enabled,
Add capable() checks in nfnetlink_cthelper, as this is cleaner than
trying to generalize the solution.
commit d4689846881d160a4d12a514e991a740bcb5d65a upstream.
If an invalid CANFD frame is received, from a driver or from a tun
interface, a Kernel warning is generated.
This patch replaces the WARN_ONCE by a simple pr_warn_once, so that a
kernel, bootet with panic_on_warn, does not panic. A printk seems to be
more appropriate here.
Reported-by: syzbot+e3b775f40babeff6e68b@syzkaller.appspotmail.com
Suggested-by: Dmitry Vyukov <dvyukov@google.com>
Acked-by: Oliver Hartkopp <socketcan@hartkopp.net>
Cc: linux-stable <stable@vger.kernel.org>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
commit 8cb68751c115d176ec851ca56ecfbb411568c9e8 upstream.
If an invalid CAN frame is received, from a driver or from a tun
Reported-by: syzbot+4386709c0c1284dca827@syzkaller.appspotmail.com
commit 4e765b4972af7b07adcb1feb16e7a525ce1f6b28 upstream.
If a message sent to a PF_KEY socket ended with an incomplete extension
header (fewer than 4 bytes remaining), then parse_exthdrs() read past
the end of the message, into uninitialized memory. Fix it by returning
-EINVAL in this case.
Reproducer:
#include <linux/pfkeyv2.h>
#include <sys/socket.h>
#include <unistd.h>
int main()
int sock = socket(PF_KEY, SOCK_RAW, PF_KEY_V2);
char buf[17] = { 0 };
struct sadb_msg *msg = (void *)buf;
msg->sadb_msg_version = PF_KEY_V2;
msg->sadb_msg_type = SADB_DELETE;
msg->sadb_msg_len = 2;
write(sock, buf, 17);
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
commit 06b335cb51af018d5feeff5dd4fd53847ddb675a upstream.
If a message sent to a PF_KEY socket ended with one of the extensions
that takes a 'struct sadb_address' but there were not enough bytes
remaining in the message for the ->sa_family member of the 'struct
sockaddr' which is supposed to follow, then verify_address_len() read
past the end of the message, into uninitialized memory. Fix it by
returning -EINVAL in this case.
This bug was found using syzkaller with KMSAN.
Reproducer:
#include <unistd.h>
int main()
char buf[24] = { 0 };
struct sadb_address *addr = (void *)(msg + 1);
msg->sadb_msg_len = 3;
addr->sadb_address_len = 1;
addr->sadb_address_exttype = SADB_EXT_ADDRESS_SRC;
write(sock, buf, 24);
Reported-by: Alexander Potapenko <glider@google.com>
commit 06e7e776ca4d36547e503279aeff996cbb292c16 upstream.
In the function l2cap_parse_conf_rsp and in the function
l2cap_parse_conf_req the following variable is declared without
initialization:
struct l2cap_conf_efs efs;
In addition, when parsing input configuration parameters in both of
these functions, the switch case for handling EFS elements may skip the
memcpy call that will write to the efs variable:
case L2CAP_CONF_EFS:
if (olen == sizeof(efs))
memcpy(&efs, (void *)val, olen);
The olen in the above if is attacker controlled, and regardless of that
if, in both of these functions the efs variable would eventually be
added to the outgoing configuration request that is being built:
l2cap_add_conf_opt(&ptr, L2CAP_CONF_EFS, sizeof(efs), (unsigned long) &efs);
So by sending a configuration request, or response, that contains an
L2CAP_CONF_EFS element, but with an element length that is not
sizeof(efs) - the memcpy to the uninitialized efs variable can be
avoided, and the uninitialized variable would be returned to the
attacker (16 bytes).
This issue has been assigned CVE-2017-1000410
Cc: Marcel Holtmann <marcel@holtmann.org>
Cc: Gustavo Padovan <gustavo@padovan.org>
Cc: Johan Hedberg <johan.hedberg@gmail.com>
Signed-off-by: Ben Seri <ben@armis.com>
[ Upstream commit 3bb23421a504f01551b7cb9dff0e41dbf16656b0 ]
We need to update lastuse to to the most updated value between what
is already set and the new value.
If HW matching fails, i.e. because of an issue, the stats are not updated
but it could be that software did match and updated lastuse.
Fixes: 5712bf9c5c30 ("net/sched: act_mirred: Use passed lastuse argument")
Fixes: 9fea47d93bcc ("net/sched: act_gact: Update statistics when offloaded to hardware")
Signed-off-by: Roi Dayan <roid@mellanox.com>
Reviewed-by: Paul Blakey <paulb@mellanox.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
[ Upstream commit 71891e2dab6b55a870f8f7735e44a2963860b5c6 ]
In kernel log ths message appears on every boot:
"warning: `NetworkChangeNo' uses legacy ethtool link settings API,
link modes are only partially reported"
When ethtool link settings API changed, it started complaining about
usages of old API. Ironically, the original patch was from google but
the application using the legacy API is chrome.
Linux ABI is fixed as much as possible. The kernel must not break it
and should not complain about applications using legacy API's.
This patch just removes the warning since using legacy API's
in Linux is perfectly acceptable.
Fixes: 3f1ac7a700d0 ("net: ethtool: add new ETHTOOL_xLINKSETTINGS API")
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Signed-off-by: David Decotigny <decot@googlers.com>
[ Upstream commit 862c03ee1deb7e19e0f9931682e0294ecd1fcaf9 ]
ip6_setup_cork() might return an error, while memory allocations have
been done and must be rolled back.
Fixes: 6422398c2ab0 ("ipv6: introduce ipv6_make_skb")
Cc: Vlad Yasevich <vyasevich@gmail.com>
Reported-by: Mike Maloney <maloney@google.com>
Acked-by: Mike Maloney <maloney@google.com>
[ Upstream commit 7d11f77f84b27cef452cee332f4e469503084737 ]
set rm->atomic.op_active to 0 when rds_pin_pages() fails
or the user supplied address is invalid,
this prevents a NULL pointer usage in rds_atomic_free_op()
Signed-off-by: Mohamed Ghannam <simo.ghannam@gmail.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
[ Upstream commit c095508770aebf1b9218e77026e48345d719b17c ]
When args->nr_local is 0, nr_pages gets also 0 due some size
calculation via rds_rm_size(), which is later used to allocate
pages for DMA, this bug produces a heap Out-Of-Bound write access
to a specific memory region.
[ Upstream commit b8fd0823e0770c2d5fdbd865bccf0d5e058e5287 ]
Use AF_INET6 instead of AF_INET in IPv6-related code path
Signed-off-by: Andrii Vladyka <tulup@mail.ru>
[ Upstream commit 23263ec86a5f44312d2899323872468752324107 ]
When an ip6_tunnel is in mode 'any', where the transport layer
protocol can be either 4 or 41, dst_cache must be disabled.
This is because xfrm policies might apply to only one of the two
protocols. Caching dst would cause xfrm policies for one protocol
incorrectly used for the other.
Signed-off-by: Eli Cooper <elicooper@gmx.com>
[ Upstream commit 78bbb15f2239bc8e663aa20bbe1987c91a0b75f6 ]
A vlan device with vid 0 is allow to creat by not able to be fully
cleaned up by unregister_vlan_dev() which checks for vlan_id!=0.
Also, VLAN 0 is probably not a valid number and it is kinda
"reserved" for HW accelerating devices, but it is probably too
late to reject it from creation even if makes sense. Instead,
just remove the check in unregister_vlan_dev().
Fixes: ad1afb003939 ("vlan_dev: VLAN 0 should be treated as "no vlan tag" (802.1p packet)")
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit cef0acd4d7d4811d2d19cd0195031bf0dfe41249 upstream.
Add a flag that indicates that the WEP ICV was stripped from an
RX packet, allowing the device to not transfer that if it's
already checked.
Signed-off-by: David Spinadel <david.spinadel@intel.com>
Cc: Kalle Valo <kvalo@codeaurora.org>
commit bdcf0a423ea1c40bbb40e7ee483b50fc8aa3d758 upstream.
In testing, we found that nfsd threads may call set_groups in parallel
for the same entry cached in auth.unix.gid, racing in the call of
groups_sort, corrupting the groups for that entry and leading to
permission denials for the client.
This patch:
- Make groups_sort globally visible.
- Move the call to groups_sort to the modifiers of group_info
- Remove the call to groups_sort from set_groups
Link: http://lkml.kernel.org/r/20171211151420.18655-1-thiago.becker@gmail.com
Signed-off-by: Thiago Rafael Becker <thiago.becker@gmail.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
Reviewed-by: NeilBrown <neilb@suse.com>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
commit 600647d467c6d04b3954b41a6ee1795b5ae00550 upstream.
Fix BBR so that upon notification of a loss recovery undo BBR resets
long-term bandwidth sampling.
Under high reordering, reordering events can be interpreted as loss.
If the reordering and spurious loss estimates are high enough, this
can cause BBR to spuriously estimate that we are seeing loss rates
high enough to trigger long-term bandwidth estimation. To avoid that
problem, this commit resets long-term bandwidth sampling on loss
recovery undo events.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Reviewed-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
commit 2f6c498e4f15d27852c04ed46d804a39137ba364 upstream.
the full pipe detection (STARTUP exit) state machine.
could previously cause BBR to spuriously estimate that the pipe is
full.
Since spurious loss recovery means that our overall sending will have
slowed down spuriously, this commit gives a flow more time to probe
robustly for bandwidth and decide the pipe is really full.
[ Upstream commit d4761754b4fb2ef8d9a1e9d121c4bec84e1fe292 ]
Mark tcp_sock during a SACK reneging event and invalidate rate samples
while marked. Such rate samples may overestimate bw by including packets
that were SACKed before reneging.
< ack 6001 win 10000 sack 7001:38001
< ack 7001 win 0 sack 8001:38001 // Reneg detected
> seq 7001:8001 // RTO, SACK cleared.
< ack 38001 win 10000
In above example the rate sample taken after the last ack will count
7001-38001 as delivered while the actual delivery rate likely could
be much lower i.e. 7001-8001.
This patch adds a new field tcp_sock.sack_reneg and marks it when we
declare SACK reneging and entering TCP_CA_Loss, and unmarks it after
the last rate sample was taken before moving back to TCP_CA_Open. This
patch also invalidates rate samples taken while tcp_sock.is_sack_reneg
is set.
Fixes: b9f64820fb22 ("tcp: track data delivery rate for a TCP connection")
Signed-off-by: Yousuk Seung <ysseung@google.com>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Priyaranjan Jha <priyarjha@google.com>
[ Upstream commit 35b99dffc3f710cafceee6c8c6ac6a98eb2cb4bf ]
skb_complete_tx_timestamp must ingest the skb it is passed. Call
kfree_skb if the skb cannot be enqueued.
Fixes: b245be1f4db1 ("net-timestamp: no-payload only sysctl")
Fixes: 9ac25fc06375 ("net: fix socket refcounting in skb_complete_tx_timestamp()")
Reported-by: Richard Cochran <richardcochran@gmail.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 21b5944350052d2583e82dd59b19a9ba94a007f0 ]
(I can trivially verify that that idr_remove in cleanup_net happens
after the network namespace count has dropped to zero --EWB)
Function get_net_ns_by_id() does not check for net::count
after it has found a peer in netns_ids idr.
It may dereference a peer, after its count has already been
finaly decremented. This leads to double free and memory
corruption:
put_net(peer) rtnl_lock()
atomic_dec_and_test(&peer->count) [count=0] ...
__put_net(peer) get_net_ns_by_id(net, id)
spin_lock(&cleanup_list_lock)
list_add(&net->cleanup_list, &cleanup_list)
spin_unlock(&cleanup_list_lock)
queue_work() peer = idr_find(&net->netns_ids, id)
| get_net(peer) [count=1]
| (use after final put)
v ...
cleanup_net() ...
spin_lock(&cleanup_list_lock) ...
list_replace_init(&cleanup_list, ..) ...
spin_unlock(&cleanup_list_lock) ...
... put_net(peer)
... atomic_dec_and_test(&peer->count) [count=0]
... spin_lock(&cleanup_list_lock)
... list_add(&net->cleanup_list, &cleanup_list)
... spin_unlock(&cleanup_list_lock)
... queue_work()
... rtnl_unlock()
rtnl_lock() ...
for_each_net(tmp) { ...
id = __peernet2id(tmp, peer) ...
spin_lock_irq(&tmp->nsid_lock) ...
idr_remove(&tmp->netns_ids, id) ...
net_drop_ns() ...
net_free(peer) ...
v
cleanup_net()
(Second free of peer)
Also, put_net() on the right cpu may reorder with left's cpu
list_replace_init(&cleanup_list, ..), and then cleanup_list
will be corrupted.
Since cleanup_net() is executed in worker thread, while
put_net(peer) can happen everywhere, there should be
enough time for concurrent get_net_ns_by_id() to pick
the peer up, and the race does not seem to be unlikely.
The patch fixes the problem in standard way.
(Also, there is possible problem in peernet2id_alloc(), which requires
check for net::count under nsid_lock and maybe_get_net(peer), but
in current stable kernel it's used under rtnl_lock() and it has to be
safe. Openswitch begun to use peernet2id_alloc(), and possibly it should
be fixed too. While this is not in stable kernel yet, so I'll send
a separate message to netdev@ later).
Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
Fixes: 0c7aecd4bde4 "netns: add rtnl cmd to add and get peer netns ids"
Reviewed-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit 84aeb437ab98a2bce3d4b2111c79723aedfceb33 ]
The early call to br_stp_change_bridge_id in bridge's newlink can cause
a memory leak if an error occurs during the newlink because the fdb
entries are not cleaned up if a different lladdr was specified, also
another minor issue is that it generates fdb notifications with
ifindex = 0. Another unrelated memory leak is the bridge sysfs entries
which get added on NETDEV_REGISTER event, but are not cleaned up in the
newlink error path. To remove this special case the call to
br_stp_change_bridge_id is done after netdev register and we cleanup the
bridge on changelink error via br_dev_delete to plug all leaks.
This patch makes netlink bridge destruction on newlink error the same as
dellink and ioctl del which is necessary since at that point we have a
fully initialized bridge device.
To reproduce the issue:
$ ip l add br0 address 00:11:22:33:44:55 type bridge group_fwd_mask 1
RTNETLINK answers: Invalid argument
$ rmmod bridge
[ 1822.142525] =============================================================================
[ 1822.143640] BUG bridge_fdb_cache (Tainted: G O ): Objects remaining in bridge_fdb_cache on __kmem_cache_shutdown()
[ 1822.144821] -----------------------------------------------------------------------------
[ 1822.145990] Disabling lock debugging due to kernel taint
[ 1822.146732] INFO: Slab 0x0000000092a844b2 objects=32 used=2 fp=0x00000000fef011b0 flags=0x1ffff8000000100
[ 1822.147700] CPU: 2 PID: 13584 Comm: rmmod Tainted: G B O 4.15.0-rc2+ #87
[ 1822.148578] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 1822.150008] Call Trace:
[ 1822.150510] dump_stack+0x78/0xa9
[ 1822.151156] slab_err+0xb1/0xd3
[ 1822.151834] ? __kmalloc+0x1bb/0x1ce
[ 1822.152546] __kmem_cache_shutdown+0x151/0x28b
[ 1822.153395] shutdown_cache+0x13/0x144
[ 1822.154126] kmem_cache_destroy+0x1c0/0x1fb
[ 1822.154669] SyS_delete_module+0x194/0x244
[ 1822.155199] ? trace_hardirqs_on_thunk+0x1a/0x1c
[ 1822.155773] entry_SYSCALL_64_fastpath+0x23/0x9a
[ 1822.156343] RIP: 0033:0x7f929bd38b17
[ 1822.156859] RSP: 002b:00007ffd160e9a98 EFLAGS: 00000202 ORIG_RAX: 00000000000000b0
[ 1822.157728] RAX: ffffffffffffffda RBX: 00005578316ba090 RCX: 00007f929bd38b17
[ 1822.158422] RDX: 00007f929bd9ec60 RSI: 0000000000000800 RDI: 00005578316ba0f0
[ 1822.159114] RBP: 0000000000000003 R08: 00007f929bff5f20 R09: 00007ffd160e8a11
[ 1822.159808] R10: 00007ffd160e9860 R11: 0000000000000202 R12: 00007ffd160e8a80
[ 1822.160513] R13: 0000000000000000 R14: 0000000000000000 R15: 00005578316ba090
[ 1822.161278] INFO: Object 0x000000007645de29 @offset=0
[ 1822.161666] INFO: Object 0x00000000d5df2ab5 @offset=128
Fixes: 30313a3d5794 ("bridge: Handle IFLA_ADDRESS correctly when creating bridge device")
Fixes: 5b8d5429daa0 ("bridge: netlink: register netdevice before executing changelink")
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
[ Upstream commit b4681c2829e24943aadd1a7bb3a30d41d0a20050 ]
Since commit 0ddcf43d5d4a ("ipv4: FIB Local/MAIN table collapse") the
local table uses the same trie allocated for the main table when custom
rules are not in use.
When a net namespace is dismantled, the main table is flushed and freed
(via an RCU callback) before the local table. In case the callback is
invoked before the local table is iterated, a use-after-free can occur.
Fix this by iterating over the FIB tables in reverse order, so that the
main table is always freed after the local table.
v3: Reworded comment according to Alex's suggestion.
v2: Add a comment to make the fix more explicit per Dave's and Alex's
feedback.
Fixes: 0ddcf43d5d4a ("ipv4: FIB Local/MAIN table collapse")
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Acked-by: Alexander Duyck <alexander.h.duyck@intel.com>
[ Upstream commit 74c4b656c3d92ec4c824ea1a4afd726b7b6568c8 ]
commit 8d79266bc48c ("ip6_tunnel: add collect_md mode to IPv6 tunnels")
introduced new exit point in ipxip6_rcv. however rcu_read_unlock is
missing there. this diff is fixing this
v1->v2:
instead of doing rcu_read_unlock in place, we are going to "drop"
section (to prevent skb leakage)
Fixes: 8d79266bc48c ("ip6_tunnel: add collect_md mode to IPv6 tunnels")
Signed-off-by: Nikita V. Shirokov <tehnerd@fb.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit 8cb38a602478e9f806571f6920b0a3298aabf042 ]
The patch(180d8cd942ce) replaces all uses of struct sock fields'
memory_pressure, memory_allocated, sockets_allocated, and sysctl_mem
to accessor macros. But the sockets_allocated field of sctp sock is
not replaced at all. Then replace it now for unifying the code.
Fixes: 180d8cd942ce ("foundations of per-cgroup memory pressure controlling.")
Cc: Glauber Costa <glommer@parallels.com>
Signed-off-by: Tonghao Zhang <zhangtonghao@didichuxing.com>
[ Upstream commit 8f659a03a0ba9289b9aeb9b4470e6fb263d6f483 ]
inet->hdrincl is racy, and could lead to uninitialized stack pointer
usage, so its value should be read only once.
Fixes: c008ba5bdc9f ("ipv4: Avoid reading user iov twice after raw_probe_proto_opt")
[ Upstream commit 30791ac41927ebd3e75486f9504b6d2280463bf0 ]
The MD5-key that belongs to a connection is identified by the peer's
IP-address. When we are in tcp_v4(6)_reqsk_send_ack(), we are replying
to an incoming segment from tcp_check_req() that failed the seq-number
checks.
Thus, to find the correct key, we need to use the skb's saddr and not
the daddr.
This bug seems to have been there since quite a while, but probably got
unnoticed because the consequences are not catastrophic. We will call
tcp_v4_reqsk_send_ack only to send a challenge-ACK back to the peer,
thus the connection doesn't really fail.
Fixes: 9501f9722922 ("tcp md5sig: Let the caller pass appropriate key for tcp_v{4,6}_do_calc_md5_hash().")
Signed-off-by: Christoph Paasch <cpaasch@apple.com>
[ Upstream commit c589e69b508d29ed8e644dfecda453f71c02ec27 ]
This commit records the "full bw reached" decision in a new
full_bw_reached bit. This is a pure refactor that does not change the
current behavior, but enables subsequent fixes and improvements.
In particular, this enables simple and clean fixes because the full_bw
and full_bw_cnt can be unconditionally zeroed without worrying about
forgetting that we estimated we filled the pipe in Startup. And it
enables future improvements because multiple code paths can be used
for estimating that we filled the pipe in Startup; any new code paths
only need to set this bit when they think the pipe is full.
Note that this fix intentionally reduces the width of the full_bw_cnt
counter, since we have never used the most significant bit.
[ Upstream commit 14e138a86f6347c6199f610576d2e11c03bec5f0 ]
RDS currently doesn't check if the length of the control message is
large enough to hold the required data, before dereferencing the control
message data. This results in following crash:
BUG: KASAN: stack-out-of-bounds in rds_rdma_bytes net/rds/send.c:1013
[inline]
BUG: KASAN: stack-out-of-bounds in rds_sendmsg+0x1f02/0x1f90
net/rds/send.c:1066
Read of size 8 at addr ffff8801c928fb70 by task syzkaller455006/3157
CPU: 0 PID: 3157 Comm: syzkaller455006 Not tainted 4.15.0-rc3+ #161
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:53
print_address_description+0x73/0x250 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x25b/0x340 mm/kasan/report.c:409
__asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:430
rds_rdma_bytes net/rds/send.c:1013 [inline]
rds_sendmsg+0x1f02/0x1f90 net/rds/send.c:1066
sock_sendmsg_nosec net/socket.c:628 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:638
___sys_sendmsg+0x320/0x8b0 net/socket.c:2018
__sys_sendmmsg+0x1ee/0x620 net/socket.c:2108
SYSC_sendmmsg net/socket.c:2139 [inline]
SyS_sendmmsg+0x35/0x60 net/socket.c:2134
entry_SYSCALL_64_fastpath+0x1f/0x96
RIP: 0033:0x43fe49
RSP: 002b:00007fffbe244ad8 EFLAGS: 00000217 ORIG_RAX: 0000000000000133
RAX: ffffffffffffffda RBX: 00000000004002c8 RCX: 000000000043fe49
RDX: 0000000000000001 RSI: 000000002020c000 RDI: 0000000000000003
RBP: 00000000006ca018 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000217 R12: 00000000004017b0
R13: 0000000000401840 R14: 0000000000000000 R15: 0000000000000000
To fix this, we verify that the cmsg_len is large enough to hold the
data to be read, before proceeding further.
Reported-by: syzbot <syzkaller-bugs@googlegroups.com>
Signed-off-by: Avinash Repaka <avinash.repaka@oracle.com>
Reviewed-by: Yuval Shaia <yuval.shaia@oracle.com>
[ Upstream commit 513674b5a2c9c7a67501506419da5c3c77ac6f08 ]
sysctl.ip6.auto_flowlabels is default 1. In our hosts, we set it to 2.
If sockopt doesn't set autoflowlabel, outcome packets from the hosts are
supposed to not include flowlabel. This is true for normal packet, but
not for reset packet.
The reason is ipv6_pinfo.autoflowlabel is set in sock creation. Later if
we change sysctl.ip6.auto_flowlabels, the ipv6_pinfo.autoflowlabel isn't
changed, so the sock will keep the old behavior in terms of auto
flowlabel. Reset packet is suffering from this problem, because reset
packet is sent from a special control socket, which is created at boot
time. Since sysctl.ipv6.auto_flowlabels is 1 by default, the control
socket will always have its ipv6_pinfo.autoflowlabel set, even after
user set sysctl.ipv6.auto_flowlabels to 1, so reset packset will always
have flowlabel. Normal sock created before sysctl setting suffers from
the same issue. We can't even turn off autoflowlabel unless we kill all
socks in the hosts.
To fix this, if IPV6_AUTOFLOWLABEL sockopt is used, we use the
autoflowlabel setting from user, otherwise we always call
ip6_default_np_autolabel() which has the new settings of sysctl.
Note, this changes behavior a little bit. Before commit 42240901f7c4
(ipv6: Implement different admin modes for automatic flow labels), the
autoflowlabel behavior of a sock isn't sticky, eg, if sysctl changes,
existing connection will change autoflowlabel behavior. After that
commit, autoflowlabel behavior is sticky in the whole life of the sock.
With this patch, the behavior isn't sticky again.
Cc: Martin KaFai Lau <kafai@fb.com>
Cc: Tom Herbert <tom@quantonium.net>
Signed-off-by: Shaohua Li <shli@fb.com>
[ Upstream commit 93c647643b48f0131f02e45da3bd367d80443291 ]
Currently, a nlmon link inside a child namespace can observe systemwide
netlink activity. Filter the traffic so that nlmon can only sniff
netlink messages from its own netns.
Test case:
vpnns -- bash -c "ip link add nlmon0 type nlmon; \
ip link set nlmon0 up; \
tcpdump -i nlmon0 -q -w /tmp/nlmon.pcap -U" &
sudo ip xfrm state add src 10.1.1.1 dst 10.1.1.2 proto esp \
spi 0x1 mode transport \
auth sha1 0x6162633132330000000000000000000000000000 \
enc aes 0x00000000000000000000000000000000
grep --binary abc123 /tmp/nlmon.pcap
[ Upstream commit a46182b00290839fa3fa159d54fd3237bd8669f0 ]
Closing a multicast socket after the final IPv4 address is deleted
from an interface can generate a membership report that uses the
source IP from a different interface. The following test script, run
from an isolated netns, reproduces the issue:
#!/bin/bash
ip link add dummy0 type dummy
ip link add dummy1 type dummy
ip link set dummy0 up
ip link set dummy1 up
ip addr add 10.1.1.1/24 dev dummy0
ip addr add 192.168.99.99/24 dev dummy1
tcpdump -U -i dummy0 &
socat EXEC:"sleep 2" \
UDP4-DATAGRAM:239.101.1.68:8889,ip-add-membership=239.0.1.68:10.1.1.1 &
sleep 1
ip addr del 10.1.1.1/24 dev dummy0
sleep 5
kill %tcpdump
RFC 3376 specifies that the report must be sent with a valid IP source
address from the destination subnet, or from address 0.0.0.0. Add an
extra check to make sure this is the case.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
[ Upstream commit b9b312a7a451e9c098921856e7cfbc201120e1a7 ]
syzkaller reported crashes in IPv6 stack [1]
Xin Long found that lo MTU was set to silly values.
IPv6 stack reacts to changes to small MTU, by disabling itself under
RTNL.
But there is a window where threads not using RTNL can see a wrong
device mtu. This can lead to surprises, in mld code where it is assumed
the mtu is suitable.
Fix this by reading device mtu once and checking IPv6 minimal MTU.
[1]
skbuff: skb_over_panic: text:0000000010b86b8d len:196 put:20
head:000000003b477e60 data:000000000e85441e tail:0xd4 end:0xc0 dev:lo
kernel BUG at net/core/skbuff.c:104!
Modules linked in:
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.15.0-rc2-mm1+ #39
Google 01/01/2011
RIP: 0010:skb_panic+0x15c/0x1f0 net/core/skbuff.c:100
RSP: 0018:ffff8801db307508 EFLAGS: 00010286
RAX: 0000000000000082 RBX: ffff8801c517e840 RCX: 0000000000000000
RDX: 0000000000000082 RSI: 1ffff1003b660e61 RDI: ffffed003b660e95
RBP: ffff8801db307570 R08: 1ffff1003b660e23 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffffffff85bd4020
R13: ffffffff84754ed2 R14: 0000000000000014 R15: ffff8801c4e26540
FS: 0000000000000000(0000) GS:ffff8801db300000(0000) knlGS:0000000000000000
CR2: 0000000000463610 CR3: 00000001c6698000 CR4: 00000000001406e0
Call Trace:
<IRQ>
skb_over_panic net/core/skbuff.c:109 [inline]
skb_put+0x181/0x1c0 net/core/skbuff.c:1694
add_grhead.isra.24+0x42/0x3b0 net/ipv6/mcast.c:1695
add_grec+0xa55/0x1060 net/ipv6/mcast.c:1817
mld_send_cr net/ipv6/mcast.c:1903 [inline]
mld_ifc_timer_expire+0x4d2/0x770 net/ipv6/mcast.c:2448
call_timer_fn+0x23b/0x840 kernel/time/timer.c:1320
expire_timers kernel/time/timer.c:1357 [inline]
__run_timers+0x7e1/0xb60 kernel/time/timer.c:1660
run_timer_softirq+0x4c/0xb0 kernel/time/timer.c:1686
__do_softirq+0x29d/0xbb2 kernel/softirq.c:285
invoke_softirq kernel/softirq.c:365 [inline]
irq_exit+0x1d3/0x210 kernel/softirq.c:405
exiting_irq arch/x86/include/asm/apic.h:540 [inline]
smp_apic_timer_interrupt+0x16b/0x700 arch/x86/kernel/apic/apic.c:1052
apic_timer_interrupt+0xa9/0xb0 arch/x86/entry/entry_64.S:920
Tested-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit b5476022bbada3764609368f03329ca287528dc8 ]
IPv4 stack reacts to changes to small MTU, by disabling itself under
RTNL.
device mtu. This can lead to surprises, in igmp code where it is
assumed the mtu is suitable.
Fix this by reading device mtu once and checking IPv4 minimal MTU.
This patch adds missing IPV4_MIN_MTU define, to not abuse
ETH_MIN_MTU anymore.
[ Upstream commit cf5d74b85ef40c202c76d90959db4d850f301b95 ]
With the commit 76174004a0f19785 (tcp: do not slow start when cwnd equals
ssthresh), the comparison to the reduced cwnd in tcp_vegas_ssthresh() would
under-evaluate the ssthresh.
Signed-off-by: Hoang Tran <hoang.tran@uclouvain.be>
[ Upstream commit 1f372c7bfb23286d2bf4ce0423ab488e86b74bb2 ]
The NS for DAD are sent on admin up as long as a valid qdisc is found.
A race condition exists by which these packets will not egress the
interface if the operational state of the lower device is not yet up.
The solution is to delay DAD until the link is operationally up
according to RFC2863. Rather than only doing this, follow the existing
code checks by deferring IPv6 device initialization altogether. The fix
allows DAD on devices like tunnels that are controlled by userspace
control plane. The fix has no impact on regular deployments, but means
that there is no IPv6 connectivity until the port has been opened in
the case of port-based network access control, which should be
desirable.
Signed-off-by: Mike Manning <mmanning@brocade.com>
[ Upstream commit 77c1c03c5b8ef28e55bb0aff29b1e006037ca645 ]
We must call security_release_secctx to free the memory returned by
security_secid_to_secctx, otherwise memory may be leaked forever.
Fixes: ef493bd930ae ("netfilter: nfnetlink_queue: add security context information")
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
[ Upstream commit ffefb6f4d6ad699a2b5484241bc46745a53235d0 ]
Our chosen ic_dev may be anywhere in our list of ic_devs, and we may
free it before attempting to close others. When we compare d->dev and
ic_dev->dev, we're potentially dereferencing memory returned to the
allocator. This causes KASAN to scream for each subsequent ic_dev we
check.
As there's a 1-1 mapping between ic_devs and netdevs, we can instead
compare d and ic_dev directly, which implicitly handles the !ic_dev
case, and avoids the use-after-free. The ic_dev pointer may be stale,
but we will not dereference it.
Original splat:
[ 6.487446] ==================================================================
[ 6.494693] BUG: KASAN: use-after-free in ic_close_devs+0xc4/0x154 at addr ffff800367efa708
[ 6.503013] Read of size 8 by task swapper/0/1
[ 6.507452] CPU: 5 PID: 1 Comm: swapper/0 Not tainted 4.11.0-rc3-00002-gda42158 #8
[ 6.514993] Hardware name: AppliedMicro Mustang/Mustang, BIOS 3.05.05-beta_rc Jan 27 2016
[ 6.523138] Call trace:
[ 6.525590] [<ffff200008094778>] dump_backtrace+0x0/0x570
[ 6.530976] [<ffff200008094d08>] show_stack+0x20/0x30
[ 6.536017] [<ffff200008bee928>] dump_stack+0x120/0x188
[ 6.541231] [<ffff20000856d5e4>] kasan_object_err+0x24/0xa0
[ 6.546790] [<ffff20000856d924>] kasan_report_error+0x244/0x738
[ 6.552695] [<ffff20000856dfec>] __asan_report_load8_noabort+0x54/0x80
[ 6.559204] [<ffff20000aae86ac>] ic_close_devs+0xc4/0x154
[ 6.564590] [<ffff20000aaedbac>] ip_auto_config+0x2ed4/0x2f1c
[ 6.570321] [<ffff200008084b04>] do_one_initcall+0xcc/0x370
[ 6.575882] [<ffff20000aa31de8>] kernel_init_freeable+0x5f8/0x6c4
[ 6.581959] [<ffff20000a16df00>] kernel_init+0x18/0x190
[ 6.587171] [<ffff200008084710>] ret_from_fork+0x10/0x40
[ 6.592468] Object at ffff800367efa700, in cache kmalloc-128 size: 128
[ 6.598969] Allocated:
[ 6.601324] PID = 1
[ 6.603427] save_stack_trace_tsk+0x0/0x418
[ 6.607603] save_stack_trace+0x20/0x30
[ 6.611430] kasan_kmalloc+0xd8/0x188
[ 6.615087] ip_auto_config+0x8c4/0x2f1c
[ 6.619002] do_one_initcall+0xcc/0x370
[ 6.622832] kernel_init_freeable+0x5f8/0x6c4
[ 6.627178] kernel_init+0x18/0x190
[ 6.630660] ret_from_fork+0x10/0x40
[ 6.634223] Freed:
[ 6.636233] PID = 1
[ 6.638334] save_stack_trace_tsk+0x0/0x418
[ 6.642510] save_stack_trace+0x20/0x30
[ 6.646337] kasan_slab_free+0x88/0x178
[ 6.650167] kfree+0xb8/0x478
[ 6.653131] ic_close_devs+0x130/0x154
[ 6.656875] ip_auto_config+0x2ed4/0x2f1c
[ 6.660875] do_one_initcall+0xcc/0x370
[ 6.664705] kernel_init_freeable+0x5f8/0x6c4
[ 6.669051] kernel_init+0x18/0x190
[ 6.672534] ret_from_fork+0x10/0x40
[ 6.676098] Memory state around the buggy address:
[ 6.680880] ffff800367efa600: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6.688078] ffff800367efa680: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 6.695276] >ffff800367efa700: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 6.702469] ^
[ 6.705952] ffff800367efa780: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 6.713149] ffff800367efa800: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 6.720343] ==================================================================
[ 6.727536] Disabling lock debugging due to kernel taint
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: netdev@vger.kernel.org
[ Upstream commit 75c689dca98851d65ef5a27e5ce26b625b68751c ]
In the commit 93557f53e1fb ("netfilter: nf_conntrack: nf_conntrack snmp
helper"), the snmp_helper is replaced by nf_nat_snmp_hook. So the
snmp_helper is never registered. But it still tries to unregister the
snmp_helper, it could cause the panic.
Now remove the useless snmp_helper and the unregister call in the
error handler.
Fixes: 93557f53e1fb ("netfilter: nf_conntrack: nf_conntrack snmp helper")
Signed-off-by: Gao Feng <fgao@ikuai8.com>
[ Upstream commit 83d90219a5df8d950855ce73229a97b63605c317 ]
The nf_ct_helper_hash table is protected by nf_ct_helper_mutex, while
nfct_helper operation is protected by nfnl_lock(NFNL_SUBSYS_CTHELPER).
So it's possible that one CPU is walking the nf_ct_helper_hash for
cthelper add/get/del, another cpu is doing nf_conntrack_helpers_unregister
at the same time. This is dangrous, and may cause use after free error.
Note, delete operation will flush all cthelpers added via nfnetlink, so
using rcu to do protect is not easy.
Now introduce a dummy list to record all the cthelpers added via
nfnetlink, then we can walk the dummy list instead of walking the
nf_ct_helper_hash. Also, keep nfnl_cthelper_dump_table unchanged, it
may be invoked without nfnl_lock(NFNL_SUBSYS_CTHELPER) held.
[ Upstream commit 95f255211396958c718aef8c45e3923b5211ea7b ]
This change basically codifies what I think was already the limitations on
the busy_poll and busy_read sysctl interfaces. We weren't checking the
lower bounds and as such could input negative values. The behavior when
that was used was dependent on the architecture. In order to prevent any
issues with that I am just disabling support for values less than 0 since
this way we don't have to worry about any odd behaviors.
By limiting the sysctl values this way it also makes it consistent with how
we handle the SO_BUSY_POLL socket option since the value appears to be
reported as a signed integer value and negative values are rejected.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
[ Upstream commit ec4fbd64751de18729eaa816ec69e4b504b5a7a2 ]
Dmitry reported a lockdep splat [1] (false positive) that we can fix
by releasing the spinlock before calling icmp_send() from ip_expire()
This is a false positive because sending an ICMP message can not
possibly re-enter the IP frag engine.
[1]
[ INFO: possible circular locking dependency detected ]
4.10.0+ #29 Not tainted
modprobe/12392 is trying to acquire lock:
(_xmit_ETHER#2){+.-...}, at: [<ffffffff837a8182>] spin_lock
include/linux/spinlock.h:299 [inline]
(_xmit_ETHER#2){+.-...}, at: [<ffffffff837a8182>] __netif_tx_lock
include/linux/netdevice.h:3486 [inline]
sch_direct_xmit+0x282/0x6d0 net/sched/sch_generic.c:180
but task is already holding lock:
(&(&q->lock)->rlock){+.-...}, at: [<ffffffff8389a4d1>] spin_lock
ip_expire+0x51/0x6c0 net/ipv4/ip_fragment.c:201
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&(&q->lock)->rlock){+.-...}:
validate_chain kernel/locking/lockdep.c:2267 [inline]
__lock_acquire+0x2149/0x3430 kernel/locking/lockdep.c:3340
lock_acquire+0x2a1/0x630 kernel/locking/lockdep.c:3755
__raw_spin_lock include/linux/spinlock_api_smp.h:142 [inline]
_raw_spin_lock+0x33/0x50 kernel/locking/spinlock.c:151
spin_lock include/linux/spinlock.h:299 [inline]
ip_defrag+0x3a2/0x4130 net/ipv4/ip_fragment.c:669
ip_check_defrag+0x4e3/0x8b0 net/ipv4/ip_fragment.c:713
packet_rcv_fanout+0x282/0x800 net/packet/af_packet.c:1459
deliver_skb net/core/dev.c:1834 [inline]
dev_queue_xmit_nit+0x294/0xa90 net/core/dev.c:1890
xmit_one net/core/dev.c:2903 [inline]
dev_hard_start_xmit+0x16b/0xab0 net/core/dev.c:2923
sch_direct_xmit+0x31f/0x6d0 net/sched/sch_generic.c:182
__dev_xmit_skb net/core/dev.c:3092 [inline]
__dev_queue_xmit+0x13e5/0x1e60 net/core/dev.c:3358
dev_queue_xmit+0x17/0x20 net/core/dev.c:3423
neigh_resolve_output+0x6b9/0xb10 net/core/neighbour.c:1308
neigh_output include/net/neighbour.h:478 [inline]
ip_finish_output2+0x8b8/0x15a0 net/ipv4/ip_output.c:228
ip_do_fragment+0x1d93/0x2720 net/ipv4/ip_output.c:672
ip_fragment.constprop.54+0x145/0x200 net/ipv4/ip_output.c:545
ip_finish_output+0x82d/0xe10 net/ipv4/ip_output.c:314
NF_HOOK_COND include/linux/netfilter.h:246 [inline]
ip_output+0x1f0/0x7a0 net/ipv4/ip_output.c:404
dst_output include/net/dst.h:486 [inline]
ip_local_out+0x95/0x170 net/ipv4/ip_output.c:124
ip_send_skb+0x3c/0xc0 net/ipv4/ip_output.c:1492
ip_push_pending_frames+0x64/0x80 net/ipv4/ip_output.c:1512
raw_sendmsg+0x26de/0x3a00 net/ipv4/raw.c:655
inet_sendmsg+0x164/0x5b0 net/ipv4/af_inet.c:761
___sys_sendmsg+0x4a3/0x9f0 net/socket.c:1985
__sys_sendmmsg+0x25c/0x750 net/socket.c:2075
SYSC_sendmmsg net/socket.c:2106 [inline]
SyS_sendmmsg+0x35/0x60 net/socket.c:2101
do_syscall_64+0x2e8/0x930 arch/x86/entry/common.c:281
return_from_SYSCALL_64+0x0/0x7a
-> #0 (_xmit_ETHER#2){+.-...}:
check_prev_add kernel/locking/lockdep.c:1830 [inline]
check_prevs_add+0xa8f/0x19f0 kernel/locking/lockdep.c:1940
__netif_tx_lock include/linux/netdevice.h:3486 [inline]
neigh_hh_output include/net/neighbour.h:468 [inline]
neigh_output include/net/neighbour.h:476 [inline]
ip_finish_output2+0xf6c/0x15a0 net/ipv4/ip_output.c:228
ip_finish_output+0xa29/0xe10 net/ipv4/ip_output.c:316
icmp_push_reply+0x372/0x4d0 net/ipv4/icmp.c:394
icmp_send+0x156c/0x1c80 net/ipv4/icmp.c:754
ip_expire+0x40e/0x6c0 net/ipv4/ip_fragment.c:239
call_timer_fn+0x241/0x820 kernel/time/timer.c:1268
expire_timers kernel/time/timer.c:1307 [inline]
__run_timers+0x960/0xcf0 kernel/time/timer.c:1601
run_timer_softirq+0x21/0x80 kernel/time/timer.c:1614
__do_softirq+0x31f/0xbe7 kernel/softirq.c:284
invoke_softirq kernel/softirq.c:364 [inline]
irq_exit+0x1cc/0x200 kernel/softirq.c:405
exiting_irq arch/x86/include/asm/apic.h:657 [inline]
smp_apic_timer_interrupt+0x76/0xa0 arch/x86/kernel/apic/apic.c:962
apic_timer_interrupt+0x93/0xa0 arch/x86/entry/entry_64.S:707
__read_once_size include/linux/compiler.h:254 [inline]
atomic_read arch/x86/include/asm/atomic.h:26 [inline]
rcu_dynticks_curr_cpu_in_eqs kernel/rcu/tree.c:350 [inline]
__rcu_is_watching kernel/rcu/tree.c:1133 [inline]
rcu_is_watching+0x83/0x110 kernel/rcu/tree.c:1147
rcu_read_lock_held+0x87/0xc0 kernel/rcu/update.c:293
radix_tree_deref_slot include/linux/radix-tree.h:238 [inline]
filemap_map_pages+0x6d4/0x1570 mm/filemap.c:2335
do_fault_around mm/memory.c:3231 [inline]
do_read_fault mm/memory.c:3265 [inline]
do_fault+0xbd5/0x2080 mm/memory.c:3370
handle_pte_fault mm/memory.c:3600 [inline]
__handle_mm_fault+0x1062/0x2cb0 mm/memory.c:3714
handle_mm_fault+0x1e2/0x480 mm/memory.c:3751
__do_page_fault+0x4f6/0xb60 arch/x86/mm/fault.c:1397
do_page_fault+0x54/0x70 arch/x86/mm/fault.c:1460
page_fault+0x28/0x30 arch/x86/entry/entry_64.S:1011
Possible unsafe locking scenario:
CPU0 CPU1
lock(&(&q->lock)->rlock);
lock(_xmit_ETHER#2);
*** DEADLOCK ***
10 locks held by modprobe/12392:
#0: (&mm->mmap_sem){++++++}, at: [<ffffffff81329758>]
__do_page_fault+0x2b8/0xb60 arch/x86/mm/fault.c:1336
#1: (rcu_read_lock){......}, at: [<ffffffff8188cab6>]
filemap_map_pages+0x1e6/0x1570 mm/filemap.c:2324
#2: (&(ptlock_ptr(page))->rlock#2){+.+...}, at: [<ffffffff81984a78>]
pte_alloc_one_map mm/memory.c:2944 [inline]
alloc_set_pte+0x13b8/0x1b90 mm/memory.c:3072
#3: (((&q->timer))){+.-...}, at: [<ffffffff81627e72>]
lockdep_copy_map include/linux/lockdep.h:175 [inline]
call_timer_fn+0x1c2/0x820 kernel/time/timer.c:1258
#4: (&(&q->lock)->rlock){+.-...}, at: [<ffffffff8389a4d1>] spin_lock
#5: (rcu_read_lock){......}, at: [<ffffffff8389a633>]
ip_expire+0x1b3/0x6c0 net/ipv4/ip_fragment.c:216
#6: (slock-AF_INET){+.-...}, at: [<ffffffff839b3313>] spin_trylock
include/linux/spinlock.h:309 [inline]
#6: (slock-AF_INET){+.-...}, at: [<ffffffff839b3313>] icmp_xmit_lock
net/ipv4/icmp.c:219 [inline]
icmp_send+0x803/0x1c80 net/ipv4/icmp.c:681
#7: (rcu_read_lock_bh){......}, at: [<ffffffff838ab9a1>]
ip_finish_output2+0x2c1/0x15a0 net/ipv4/ip_output.c:198
#8: (rcu_read_lock_bh){......}, at: [<ffffffff836d1dee>]
__dev_queue_xmit+0x23e/0x1e60 net/core/dev.c:3324
#9: (dev->qdisc_running_key ?: &qdisc_running_key){+.....}, at:
[<ffffffff836d3a27>] dev_queue_xmit+0x17/0x20 net/core/dev.c:3423
stack backtrace:
CPU: 0 PID: 12392 Comm: modprobe Not tainted 4.10.0+ #29
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x2ee/0x3ef lib/dump_stack.c:52
print_circular_bug+0x307/0x3b0 kernel/locking/lockdep.c:1204
RIP: 0010:__read_once_size include/linux/compiler.h:254 [inline]
RIP: 0010:atomic_read arch/x86/include/asm/atomic.h:26 [inline]
RIP: 0010:rcu_dynticks_curr_cpu_in_eqs kernel/rcu/tree.c:350 [inline]
RIP: 0010:__rcu_is_watching kernel/rcu/tree.c:1133 [inline]
RIP: 0010:rcu_is_watching+0x83/0x110 kernel/rcu/tree.c:1147
RSP: 0000:ffff8801c391f120 EFLAGS: 00000a03 ORIG_RAX: ffffffffffffff10
RAX: dffffc0000000000 RBX: ffff8801c391f148 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 000055edd4374000 RDI: ffff8801dbe1ae0c
RBP: ffff8801c391f1a0 R08: 0000000000000002 R09: 0000000000000000
R10: dffffc0000000000 R11: 0000000000000002 R12: 1ffff10038723e25
R13: ffff8801dbe1ae00 R14: ffff8801c391f680 R15: dffffc0000000000
</IRQ>
RIP: 0033:0x7f83172f2786
RSP: 002b:00007fffe859ae80 EFLAGS: 00010293
RAX: 000055edd4373040 RBX: 00007f83175111c8 RCX: 000055edd4373238
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 00007f8317510970
RBP: 00007fffe859afd0 R08: 0000000000000009 R09: 0000000000000000
R10: 0000000000000064 R11: 0000000000000000 R12: 000055edd4373040
R13: 0000000000000000 R14: 00007fffe859afe8 R15: 0000000000000000
[ Upstream commit 557d054c01da0337ca81de9e9d9206d57245b57e ]
Until now, tipc_nametbl_unsubscribe() is called at subscriptions
reference count cleanup. Usually the subscriptions cleanup is
called at subscription timeout or at subscription cancel or at
subscriber delete.
We have ignored the possibility of this being called from other
locations, which causes deadlock as we try to grab the
tn->nametbl_lock while holding it already.
CPU1: CPU2:
tipc_nametbl_publish
spin_lock_bh(&tn->nametbl_lock)
tipc_nametbl_insert_publ
tipc_nameseq_insert_publ
tipc_subscrp_report_overlap
tipc_subscrp_get
tipc_subscrp_send_event
tipc_close_conn
tipc_subscrb_release_cb
tipc_subscrb_delete
tipc_subscrp_put
tipc_subscrp_put
tipc_subscrp_kref_release
<<grab nametbl_lock again>>
CPU1: CPU2:
tipc_nametbl_stop
tipc_purge_publications
tipc_nameseq_remove_publ
tipc_subscrp_get
tipc_close_conn
tipc_subscrb_delete
tipc_subscrp_put
tipc_subscrp_put
In this commit, we advance the calling of tipc_nametbl_unsubscribe()
from the refcount cleanup to the intended callers.
Fixes: d094c4d5f5c7 ("tipc: add subscription refcount to avoid invalid delete")
Reported-by: John Thompson <thompa.atl@gmail.com>
Acked-by: Jon Maloy <jon.maloy@ericsson.com>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Signed-off-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com>
