path: root/net
2006-03-20[BRIDGE]: netfilter inline cleanupStephen Hemminger
Move nf_bridge_alloc from header file to the one place it is used and optimize it. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: netfilter VLAN macro cleanupStephen Hemminger
Fix the VLAN macros in bridge netfilter code. Macros should not depend on magic variables. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: netfilter dont use __constant_htonsStephen Hemminger
Only use__constant_htons() for initializers and switch cases. For other uses, it is just as efficient and clearer to use htons Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: netfilter whitespaceStephen Hemminger
Run br_netfilter through Lindent to fix whitespace. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: optimize frame pass upStephen Hemminger
The netfilter hook that is used to receive frames doesn't need to be a stub. It is only called in two ways, both of which ignore the return value. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: use kzallocStephen Hemminger
Use kzalloc versus kmalloc+memset. Also don't need to do memset() of bridge address since it is in netdev private data that is already zero'd in alloc_netdev. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: use kcallocStephen Hemminger
Use kcalloc rather than kmalloc + memset. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: use setup_timerStephen Hemminger
Use the now standard setup_timer function. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE]: remove unneeded bh disablesStephen Hemminger
The STP timers run off softirq (kernel timers), so there is no need to disable bottom half in the spin locks. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE] br_netfilter: Warning fixes.Andrew Morton
net/bridge/br_netfilter.c: In function `br_nf_pre_routing': net/bridge/br_netfilter.c:427: warning: unused variable `vhdr' net/bridge/br_netfilter.c:445: warning: unused variable `vhdr' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[BRIDGE] ebtables: Build fix.Andrew Morton
net/bridge/netfilter/ebtables.c:1481: warning: initialization makes pointer from integer without a cast Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[INET]: Fix typo in Arnaldo's connection sock compat fixups.David S. Miller
"struct inet_csk" --> "struct inet_connection_sock" :-) Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP] feat: Pass dccp_minisock ptr where only the minisock is usedArnaldo Carvalho de Melo
This is in preparation for having a dccp_minisock embedded into dccp_request_sock so that feature negotiation can be done prior to creating the full blown dccp_sock. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP] minisock: Rename struct dccp_options to struct dccp_minisockArnaldo Carvalho de Melo
This will later be included in struct dccp_request_sock so that we can have per connection feature negotiation state while in the 3way handshake, when we clone the DCCP_ROLE_LISTEN socket (in dccp_create_openreq_child) we'll just copy this state from dreq_minisock to dccps_minisock. Also the feature negotiation and option parsing code will mostly touch dccps_minisock, which will simplify some stuff. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: Identation & other cleanups related to compat_[gs]etsockopt csetArnaldo Carvalho de Melo
No code changes, just tidying up, in some cases moving EXPORT_SYMBOLs to just after the function exported, etc. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SK_BUFF]: export skb_pull_rcsumArnaldo Carvalho de Melo
*** Warning: "skb_pull_rcsum" [net/bridge/bridge.ko] undefined! *** Warning: "skb_pull_rcsum" [net/8021q/8021q.ko] undefined! *** Warning: "skb_pull_rcsum" [drivers/net/pppoe.ko] undefined! *** Warning: "skb_pull_rcsum" [drivers/net/ppp_generic.ko] undefined! Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[ICSK] compat: Introduce inet_csk_compat_[gs]etsockoptArnaldo Carvalho de Melo
2006-03-20[SNAP]: Remove leftover unused hdr variableArnaldo Carvalho de Melo
2006-03-20[NET]: {get|set}sockopt compatibility layerDmitry Mishin
This patch extends {get|set}sockopt compatibility layer in order to move protocol specific parts to their place and avoid huge universal net/compat.c file in the future. Signed-off-by: Dmitry Mishin <dim@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IPV6]: remove useless test in ip6_append_dataDave Jones
We've already dereferenced 'np' a dozen times at this point, so it's safe to say it's not null. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[PKT_SCHED]: Let NET_CLS_ACT no longer depend on EXPERIMENTALAdrian Bunk
This option should IMHO no longer depend on EXPERIMENTAL. Signed-off-by: Adrian Bunk <bunk@stusta.de> ACKed-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: Replace skb_pull/skb_postpull_rcsum with skb_pull_rcsumHerbert Xu
We're now starting to have quite a number of places that do skb_pull followed immediately by an skb_postpull_rcsum. We can merge these two operations into one function with skb_pull_rcsum. This makes sense since most pull operations on receive skb's need to update the checksum. I've decided to make this out-of-line since it is fairly big and the fast path where hardware checksums are enabled need to call csum_partial anyway. Since this is a brand new function we get to add an extra check on the len argument. As it is most callers of skb_pull ignore its return value which essentially means that there is no check on the len argument. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DECnet]: Use RCU locking in dn_rules.cSteven Whitehouse
As per Robert Olsson's patch for ipv4, this is the DECnet version to keep the code "in step". It changes the list of rules to use RCU rather than an rwlock. Inspired-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: Steven Whitehouse <steve@chygwyn.com> Signed-off-by: Patrick Caulfield <patrick@tykepenguin.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DECnet]: Patch to fix recvmsg() flag checkPatrick Caulfield
This patch means that 64bit kernel/32bit userland platforms will now work correctly with DECnet. Signed-off-by: Patrick Caulfield <patrick@tykepenguin.com> Signed-off-by: Steven Whitehouse <steve@chygwyn.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DECnet]: Endian annotation and fixes for DECnet.Steven Whitehouse
The typedef for dn_address has been removed in favour of using __le16 or __u16 directly as appropriate. All the DECnet header files are updated accordingly. The byte ordering of dn_eth2dn() and dn_dn2eth() are both changed since just about all their callers wanted network order rather than host order, so the conversion is now done in the functions themselves. Several missed endianess conversions have been picked up during the conversion process. The nh_gw field in struct dn_fib_info has been changed from a 32 bit field to 16 bits as it ought to be. One or two cases of using htons rather than dn_htons in the routing code have been found and fixed. There are still a few warnings to fix, but this patch deals with the important cases. Signed-off-by: Steven Whitehouse <steve@chygwyn.com> Signed-off-by: Patrick Caulfield <patrick@tykepenguin.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SECURITY]: TCP/UDP getpeersecCatherine Zhang
This patch implements an application of the LSM-IPSec networking controls whereby an application can determine the label of the security association its TCP or UDP sockets are currently connected to via getsockopt and the auxiliary data mechanism of recvmsg. Patch purpose: This patch enables a security-aware application to retrieve the security context of an IPSec security association a particular TCP or UDP socket is using. The application can then use this security context to determine the security context for processing on behalf of the peer at the other end of this connection. In the case of UDP, the security context is for each individual packet. An example application is the inetd daemon, which could be modified to start daemons running at security contexts dependent on the remote client. Patch design approach: - Design for TCP The patch enables the SELinux LSM to set the peer security context for a socket based on the security context of the IPSec security association. The application may retrieve this context using getsockopt. When called, the kernel determines if the socket is a connected (TCP_ESTABLISHED) TCP socket and, if so, uses the dst_entry cache on the socket to retrieve the security associations. If a security association has a security context, the context string is returned, as for UNIX domain sockets. - Design for UDP Unlike TCP, UDP is connectionless. This requires a somewhat different API to retrieve the peer security context. With TCP, the peer security context stays the same throughout the connection, thus it can be retrieved at any time between when the connection is established and when it is torn down. With UDP, each read/write can have different peer and thus the security context might change every time. As a result the security context retrieval must be done TOGETHER with the packet retrieval. The solution is to build upon the existing Unix domain socket API for retrieving user credentials. Linux offers the API for obtaining user credentials via ancillary messages (i.e., out of band/control messages that are bundled together with a normal message). Patch implementation details: - Implementation for TCP The security context can be retrieved by applications using getsockopt with the existing SO_PEERSEC flag. As an example (ignoring error checking): getsockopt(sockfd, SOL_SOCKET, SO_PEERSEC, optbuf, &optlen); printf("Socket peer context is: %s\n", optbuf); The SELinux function, selinux_socket_getpeersec, is extended to check for labeled security associations for connected (TCP_ESTABLISHED == sk->sk_state) TCP sockets only. If so, the socket has a dst_cache of struct dst_entry values that may refer to security associations. If these have security associations with security contexts, the security context is returned. getsockopt returns a buffer that contains a security context string or the buffer is unmodified. - Implementation for UDP To retrieve the security context, the application first indicates to the kernel such desire by setting the IP_PASSSEC option via getsockopt. Then the application retrieves the security context using the auxiliary data mechanism. An example server application for UDP should look like this: toggle = 1; toggle_len = sizeof(toggle); setsockopt(sockfd, SOL_IP, IP_PASSSEC, &toggle, &toggle_len); recvmsg(sockfd, &msg_hdr, 0); if (msg_hdr.msg_controllen > sizeof(struct cmsghdr)) { cmsg_hdr = CMSG_FIRSTHDR(&msg_hdr); if (cmsg_hdr->cmsg_len <= CMSG_LEN(sizeof(scontext)) && cmsg_hdr->cmsg_level == SOL_IP && cmsg_hdr->cmsg_type == SCM_SECURITY) { memcpy(&scontext, CMSG_DATA(cmsg_hdr), sizeof(scontext)); } } ip_setsockopt is enhanced with a new socket option IP_PASSSEC to allow a server socket to receive security context of the peer. A new ancillary message type SCM_SECURITY. When the packet is received we get the security context from the sec_path pointer which is contained in the sk_buff, and copy it to the ancillary message space. An additional LSM hook, selinux_socket_getpeersec_udp, is defined to retrieve the security context from the SELinux space. The existing function, selinux_socket_getpeersec does not suit our purpose, because the security context is copied directly to user space, rather than to kernel space. Testing: We have tested the patch by setting up TCP and UDP connections between applications on two machines using the IPSec policies that result in labeled security associations being built. For TCP, we can then extract the peer security context using getsockopt on either end. For UDP, the receiving end can retrieve the security context using the auxiliary data mechanism of recvmsg. Signed-off-by: Catherine Zhang <cxzhang@watson.ibm.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[XFRM]: Fix aevent related crashPatrick McHardy
When xfrm_user isn't loaded xfrm_nl is NULL, which makes IPsec crash because xfrm_aevent_is_on passes the NULL pointer to netlink_has_listeners as socket. A second problem is that the xfrm_nl pointer is not cleared when the socket is releases at module unload time. Protect references of xfrm_nl from outside of xfrm_user by RCU, check that the socket is present in xfrm_aevent_is_on and set it to NULL when unloading xfrm_user. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TCP]: sysctl to allow TCP window > 32767 sans wscaleRick Jones
Back in the dark ages, we had to be conservative and only allow 15-bit window fields if the window scale option was not negotiated. Some ancient stacks used a signed 16-bit quantity for the window field of the TCP header and would get confused. Those days are long gone, so we can use the full 16-bits by default now. There is a sysctl added so that we can still interact with such old stacks Signed-off-by: Rick Jones <rick.jones2@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[IPV4] ARP: Alloc acceptance of unsolicited ARP via netdevice sysctl.Neil Horman
Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TIPC]: Avoid compiler warningPer Liden
Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TIPC]: Reduce stack usagePer Liden
The node_map struct can be quite large (516 bytes) and allocating two of them on the stack is not a good idea since we might only have a 4K stack to start with. Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TIPC]: CleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - #if 0 the following unused global functions: - name_table.c: tipc_nametbl_print() - name_table.c: tipc_nametbl_dump() - net.c: tipc_net_next_node() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TIPC]: Remove unused functionsPer Liden
2006-03-20[TIPC]: Remove inlines from *.cSam Ravnborg
With reference to latest discussions on linux-kernel with respect to inline here is a patch for tipc to remove all inlines as used in the .c files. See also chapter 14 in Documentation/CodingStyle. Before: text data bss dec hex filename 102990 5292 1752 110034 1add2 tipc.o Now: text data bss dec hex filename 101190 5292 1752 108234 1a6ca tipc.o This is a nice text size reduction which will improve icache usage. In some cases bigger (> 4 lines) functions where declared inline and used in many places, they are most probarly no longer inlined by gcc resulting in the size reduction. There are several one liners that no longer are declared inline, but gcc should inline these just fine without the inline hint. With this patch applied one warning is added about an unused static function - that was hidded by utilising inline before. The function in question were kept so this patch is solely a inline removal patch. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TIPC]: Fix simple sparse warningsSam Ravnborg
Tried to run the new tipc stack through sparse. Following patch fixes all cases where 0 was used as replacement of NULL. Use NULL to document this is a pointer and to silence sparse. This brough sparse warning count down with 127 to 24 warnings. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NETFILTER]: Fix warnings in ip_nat_snmp_basic.cDavid S. Miller
net/ipv4/netfilter/ip_nat_snmp_basic.c: In function 'asn1_header_decode': net/ipv4/netfilter/ip_nat_snmp_basic.c:248: warning: 'len' may be used uninitialized in this function net/ipv4/netfilter/ip_nat_snmp_basic.c:248: warning: 'def' may be used uninitialized in this function net/ipv4/netfilter/ip_nat_snmp_basic.c: In function 'snmp_translate': net/ipv4/netfilter/ip_nat_snmp_basic.c:672: warning: 'l' may be used uninitialized in this function net/ipv4/netfilter/ip_nat_snmp_basic.c:668: warning: 'type' may be used uninitialized in this function Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP]: Fix uninitialized var warnings in dccp_parse_options().David S. Miller
2006-03-20[NET]: sem2mutex part 2Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET] sem2mutex: net/Arjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: dev_put/dev_hold cleanupStephen Hemminger
Get rid of the old __dev_put macro that is just a hold over from pre 2.6 kernel. And turn dev_hold into an inline instead of a macro. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP] options: Make dccp_insert_options & friends yell on errorArnaldo Carvalho de Melo
And not the silly LIMIT_NETDEBUG and silently return without inserting the option requested. Also drop some old debugging messages associated to option insertion. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP]: Remove leftover dccp_send_response prototypeArnaldo Carvalho de Melo
2006-03-20[DCCP]: ditch dccp_v[46]_ctl_send_ackArnaldo Carvalho de Melo
Merging it with its only user: dccp_v[46]_reqsk_send_ack. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP]: Use sk->sk_prot->max_header consistently for non-data packetsArnaldo Carvalho de Melo
Using this also provides opportunities for introducing inet_csk_alloc_skb that would call alloc_skb, account it to the sock and skb_reserve(max_header), but I'll leave this for later, for now using sk_prot->max_header consistently is enough. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[DCCP] options: Fix handling of ackvecs in DATA packetsArnaldo Carvalho de Melo
I.e. they should be just ignored, but we have to use 'break', not 'continue', as we have to possibly reset the mandatory flag. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[ATM]: Fix build after neigh->parms->neigh_destructor change.David S. Miller
2006-03-20[NET]: use fget_light() in net/socket.cBenjamin LaHaise
Here's an updated copy of the patch to use fget_light in net/socket.c. Rerunning the tests show a drop of ~80Mbit/s on average, which looks bad until you see the drop in cpu usage from ~89% to ~82%. That will get fixed in another patch... Before: max 8113.70, min 8026.32, avg 8072.34 87380 16384 16384 10.01 8045.55 87.11 87.11 1.774 1.774 87380 16384 16384 10.01 8065.14 90.86 90.86 1.846 1.846 87380 16384 16384 10.00 8077.76 89.85 89.85 1.822 1.822 87380 16384 16384 10.00 8026.32 89.80 89.80 1.833 1.833 87380 16384 16384 10.01 8108.59 89.81 89.81 1.815 1.815 87380 16384 16384 10.01 8034.53 89.01 89.01 1.815 1.815 87380 16384 16384 10.00 8113.70 90.45 90.45 1.827 1.827 87380 16384 16384 10.00 8111.37 89.90 89.90 1.816 1.816 87380 16384 16384 10.01 8077.75 87.96 87.96 1.784 1.784 87380 16384 16384 10.00 8062.70 90.25 90.25 1.834 1.834 After: max 8035.81, min 7963.69, avg 7998.14 87380 16384 16384 10.01 8000.93 82.11 82.11 1.682 1.682 87380 16384 16384 10.01 8016.17 83.67 83.67 1.710 1.710 87380 16384 16384 10.01 7963.69 83.47 83.47 1.717 1.717 87380 16384 16384 10.01 8014.35 81.71 81.71 1.671 1.671 87380 16384 16384 10.00 7967.68 83.41 83.41 1.715 1.715 87380 16384 16384 10.00 7995.22 81.00 81.00 1.660 1.660 87380 16384 16384 10.00 8002.61 83.90 83.90 1.718 1.718 87380 16384 16384 10.00 8035.81 81.71 81.71 1.666 1.666 87380 16384 16384 10.01 8005.36 82.56 82.56 1.690 1.690 87380 16384 16384 10.00 7979.61 82.50 82.50 1.694 1.694 Signed-off-by: Benjamin LaHaise <bcrl@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: minor net_rx_action optimizationStephen Hemminger
The functions list_del followed by list_add_tail is equivalent to the existing inline list_move_tail. list_move_tail avoids unnecessary _LIST_POISON. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: Move destructor from neigh->ops to neigh_paramsMichael S. Tsirkin
struct neigh_ops currently has a destructor field, which no in-kernel drivers outside of infiniband use. The infiniband/ulp/ipoib in-tree driver stashes some info in the neighbour structure (the results of the second-stage lookup from ARP results to real link-level path), and it uses neigh->ops->destructor to get a callback so it can clean up this extra info when a neighbour is freed. We've run into problems with this: since the destructor is in an ops field that is shared between neighbours that may belong to different net devices, there's no way to set/clear it safely. The following patch moves this field to neigh_parms where it can be safely set, together with its twin neigh_setup. Two additional patches in the patch series update ipoib to use this new interface. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[PKTGEN]: Updates version.Luiz Capitulino
Due to the thread's lock changes, we're at a new version now. Signed-off-by: Luiz Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: David S. Miller <davem@davemloft.net>
