path: root/net
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->nh.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF] xfrm4: use skb_reset_network_headerArnaldo Carvalho de Melo
Setting it to skb->h.raw, which is valid, in the (to become) old pointer based world order and in the new world of offset based layer headers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF] ipv6: More skb_reset_network_header conversions related to skb_pullArnaldo Carvalho de Melo
Now related to this form: skb->nh.ipv6h = (struct ipv6hdr *)skb_put(skb, length); That, as the others, is done when skb->tail is still equal to skb->data, making the conversion to skb_reset_network_header possible. Also one more case equivalent to skb->nh.raw = skb->data, of this form: iph = (struct ipv6hdr *)skb->data; <SNIP> skb->nh.ipv6h = iph; Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Use skb_reset_network_header after skb_pushArnaldo Carvalho de Melo
Some more cases where skb->nh.iph was being set that were converted to using skb_reset_network_header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF] ipconfig: Another conversion to skb_reset_network_header related ↵Arnaldo Carvalho de Melo
to skb_put boot_pkt->iph is the first member, that is at skb->data, so just use skb_reset_network_header(). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Some more skb_put cases converted to skb_reset_network_headerArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Some more simple skb_reset_network_header conversionsArnaldo Carvalho de Melo
This time of the type: skb->nh.iph = (struct iphdr *)skb->data; That is completely equivalent to: skb->nh.raw = skb->data; Wonder why people love casts... :-) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Use skb_reset_network_header where the return of __pskb_pull was ↵Arnaldo Carvalho de Melo
being used It returns skb->data, so we can just use skb_reset_network_header after it. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Use skb_reset_network_header where the skb_pull return was being usedArnaldo Carvalho de Melo
But only in the cases where its a newly allocated skb, i.e. one where skb->tail is equal to skb->data, or just after skb_reserve, where this requirement is maintained. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Use skb_reset_network_header in skb_push casesArnaldo Carvalho de Melo
skb_push updates and returns skb->data, so we can just call skb_reset_network_header after the call to skb_push. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_network_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV6]: Use skb->nh.ipv6h instead of casting skb->nh.rawArnaldo Carvalho de Melo
nh.ipv6h is there exactly for this reason! Use it while it exists ;-) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_mac_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the mac header, it is still legal to touch skb->mac.raw directly if just adding to, subtracting from or setting it to another layer header. This one also converts some more cases to skb_reset_mac_header() that my regex missed as it had no spaces before nor after '=', ugh. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP]: Use skb_set_mac_header in tcp_collapseArnaldo Carvalho de Melo
2007-04-25[TCP]: Do the layer header setting in tcp_collapse relative to skb->dataArnaldo Carvalho de Melo
That is equal to skb->head before skb_reserve, to help in the layer header changes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF] xfrm: Use skb_set_mac_header in the memmove casesArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce skb_set_mac_header()Arnaldo Carvalho de Melo
For the cases where we want to set skb->mac.raw to an offset from skb->data. Simple cases first, the memmove ones and specially pktgen will be left for later. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[LLC]: Use skb_reset_mac_header in llc_mac_hdr_initArnaldo Carvalho de Melo
skb_push updates and returns skb->data, so we can just call skb_reset_mac_header after the call to skb_push. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[LLC]: Use skb_reset_mac_header in llc_alloc_frameArnaldo Carvalho de Melo
skb->head is equal to skb->data after alloc_skb, so reset the mac header while this is true, i.e. before skb_reserve. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_mac_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[HIPPI/FDDI]: Make {hippi,fddi}_type_trans set skb->devArnaldo Carvalho de Melo
Now all the _type_trans routines are consistent in this regard. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TR]: Make tr_type_trans set skb->devArnaldo Carvalho de Melo
2007-04-25[TR]: Use tr_hdr() were appropriateArnaldo Carvalho de Melo
2007-04-25[SOCKET]: Export __sock_recv_timestampArnaldo Carvalho de Melo
Kernel: arch/x86_64/boot/bzImage is ready (#2) MODPOST 1816 modules WARNING: "__sock_recv_timestamp" [net/sctp/sctp.ko] undefined! WARNING: "__sock_recv_timestamp" [net/packet/af_packet.ko] undefined! WARNING: "__sock_recv_timestamp" [net/key/af_key.ko] undefined! WARNING: "__sock_recv_timestamp" [net/ipv6/ipv6.ko] undefined! WARNING: "__sock_recv_timestamp" [net/atm/atm.ko] undefined! make[2]: *** [__modpost] Error 1 make[1]: *** [modules] Error 2 make: *** [_all] Error 2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Adding SO_TIMESTAMPNS / SCM_TIMESTAMPNS supportEric Dumazet
Now that network timestamps use ktime_t infrastructure, we can add a new SOL_SOCKET sockopt SO_TIMESTAMPNS. This command is similar to SO_TIMESTAMP, but permits transmission of a 'timespec struct' instead of a 'timeval struct' control message. (nanosecond resolution instead of microsecond) Control message is labelled SCM_TIMESTAMPNS instead of SCM_TIMESTAMP A socket cannot mix SO_TIMESTAMP and SO_TIMESTAMPNS : the two modes are mutually exclusive. sock_recv_timestamp() became too big to be fully inlined so I added a __sock_recv_timestamp() helper function. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: linux-arch@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[UDP]: Use __skb_pull since we have checked it won't fail with pskb_may_pullArnaldo Carvalho de Melo
2007-04-25[NET]: New sysctls should use __read_mostly tagsEric Dumazet
net_msg_warn should be placed in the read_mostly section, to avoid performance problems on SMP Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV6]: Ensure to truncate result and return full length for sticky options.YOSHIFUJI Hideaki
Bug noticed by Chris Wright <chrisw@sous-sol.org>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV6]: Return correct result for sticky options.YOSHIFUJI Hideaki
We returned incorrect result with IPV6_RTHDRDSTOPTS, IPV6_RTHDR and IPV6_DSTOPTS. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[UDP]: deinlineStephen Hemminger
A couple of functions are exported or used indirectly so it is pointless to mark them as inline. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: deinline some functionsStephen Hemminger
Several functions are marked inline or forced inline, but it would be better to let the compiler decide. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP]: whitespace cleanupStephen Hemminger
Add whitespace around keywords. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IPV4]: cleanupStephen Hemminger
2007-04-25[WIRELESS]: use ARRAY_SIZE()Stephen Hemminger
Use ARRAY_SIZE() macro now. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] core: whitespace cleanupStephen Hemminger
Fix whitespace around keywords. Fix indentation especially of switch statements. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[UDP]: ipv6 style cleanupStephen Hemminger
Fix whitespace around keywords. Eliminate unnecessary ()'s on return statements. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[UDP]: ipv4 whitespace cleanupStephen Hemminger
Fix whitespace around keywords. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Replace CONFIG_NET_DEBUG with sysctl.Stephen Hemminger
Covert network warning messages from a compile time to runtime choice. Removes kernel config option and replaces it with new /proc/sys/net/core/warnings. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Introduce SIOCGSTAMPNS ioctl to get timestamps with nanosec resolutionEric Dumazet
Now network timestamps use ktime_t infrastructure, we can add a new ioctl() SIOCGSTAMPNS command to get timestamps in 'struct timespec'. User programs can thus access to nanosecond resolution. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP/DCCP/RANDOM]: Remove unused exports.Adrian Bunk
This patch removes the following not or no longer used exports: - drivers/char/random.c: secure_tcp_sequence_number - net/dccp/options.c: sysctl_dccp_feat_sequence_window - net/netlink/af_netlink.c: netlink_set_err Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP]: Abstract out all write queue operations.David S. Miller
This allows the write queue implementation to be changed, for example, to one which allows fast interval searching. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] TIPC: Use htons() where appropriate.YOSHIFUJI Hideaki
2007-04-25[NET] SCHED: Use htons() where appropriate.YOSHIFUJI Hideaki
2007-04-25[NET] NETFILTER: Use htonl() where appropriate.YOSHIFUJI Hideaki
2007-04-25[NET] IPV4: Use hton{s,l}() where appropriate.YOSHIFUJI Hideaki
2007-04-25[NET] IEEE80211: Use htons() where appropriate.YOSHIFUJI Hideaki
2007-04-25[NET] ETHERNET: Use htons() where appropriate.YOSHIFUJI Hideaki
2007-04-25[NET] CORE: Use htons() where appropriate.YOSHIFUJI Hideaki
