After moving the assignment of GAR/ISS from dccp_connect_init() to
dccp_transmit_skb(), the former function becomes very small, so that
a merger with dccp_connect() suggests itself.
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
This fixes a problem and a potential loophole with regard to seqno/ackno
validity: currently the initial adjustments to AWL/SWL are only performed
once at the begin of the connection, during the handshake.
Since the Sequence Window feature is always greater than Wmin=32 (7.5.2),
it is however necessary to perform these adjustments at least for the first
W/W' (variables as per 7.5.1) packets in the lifetime of a connection.
This requirement is complicated by the fact that W/W' can change at any time
during the lifetime of a connection.
Therefore it is better to perform that safety check each time SWL/AWL are
updated, as implemented by the patch.
A second problem solved by this patch is that the remote/local Sequence Window
feature values (which set the bounds for AWL/SWL/SWH) are undefined until the
feature negotiation has completed.
During the initial handshake we have more stringent sequence number protection;
the changes added by this patch effect that {A,S}W{L,H} are within the correct
bounds at the instant that feature negotiation completes (since the SeqWin
feature activation handlers call dccp_update_gsr/gss()).
Add a seqlock in struct neighbour to protect neigh->ha[], and avoid
dirtying neighbour in stress situation (many different flows / dsts)
Dirtying takes place because of read_lock(&n->lock) and n->used writes.
Switching to a seqlock, and writing n->used only on jiffies changes
permits less dirtying.
net/core/ethtool.c
Several other ethtool functions leave heap uncleared (potentially) by
drivers. Some interfaces appear safe (eeprom, etc), in that the sizes
are well controlled. In some situations (e.g. unchecked error conditions),
the heap will remain unchanged in areas before copying back to userspace.
Note that these are less of an issue since these all require CAP_NET_ADMIN.
Cc: stable@kernel.org
Signed-off-by: Kees Cook <kees.cook@canonical.com>
Acked-by: Ben Hutchings <bhutchings@solarflare.com>
Stanse found that mpc_push frees skb and then it dereferences it. It
is a typo, new_skb should be dereferenced there.
When a new dst is used to send a frame, neigh_resolve_output() tries to
associate an struct hh_cache to this dst, calling neigh_hh_init() with
the neigh rwlock write locked.
Most of the time, hh_cache is already known and linked into neighbour,
so we find it and increment its refcount.
This patch changes the logic so that we call neigh_hh_init() with
neighbour lock read locked only, so that fast path can be run in
parallel by concurrent cpus.
This brings part of the speedup we got with commit c7d4426a98a5f
(introduce DST_NOCACHE flag) for non cached dsts, even for cached ones,
removing one of the contention point that routers hit on multiqueue
enabled machines.
Further improvements would need to use a seqlock instead of an rwlock to
protect neigh->ha[], to not dirty neigh too often and remove two atomic
ops.
While parsing the GetValuebyClass command frame, we could potentially write
passed the skb->data pointer.
Reported-by: Ilja Van Sprundel <ivansprundel@ioactive.com>
Signed-off-by: Samuel Ortiz <samuel@sortiz.org>
The code intends to lock the irnet_socket, so adding a mutex to it allows
for a complet BKL removal.
Most of the times, lock_kernel() was pointless or could simply be replaced
by lock_sock().
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
The rx->count reference is used to track reference counts to the
number of rx-queue kobjects created for the device. This patch
eliminates initialization of the counter in netif_alloc_rx_queues
and instead increments the counter each time a kobject is created.
This is now symmetric with the decrement that is done when an object is
released.
Signed-off-by: Tom Herbert <therbert@google.com>
There are a bunch of issues that need to be fixed, including:
- GFP_KERNEL allocations from atomic context
(and GFP_ATOMIC in process context),
- abuse of the setsockopt() call convention,
- unprotected/unlocked static variables...
IMHO, we will need to alter the userspace ABI when we fix it. So mark
the configuration option as EXPERIMENTAL for the time being (or should
it be BROKEN instead?).
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com>
The current code works like this:
int garbage, status;
socklen_t len = sizeof(status);
/* enable pipe */
setsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &garbage, sizeof(garbage));
/* disable pipe */
setsockopt(fd, SOL_PNPIPE, PNPIPE_DISABLE, &garbage, sizeof(garbage));
/* get status */
getsockopt(fd, SOL_PNPIPE, PNPIPE_INQ, &status, &len);
...which does not follow the usual socket option pattern. This patch
merges all three "options" into a single gettable&settable option,
before Linux 2.6.37 gets out:
int status;
/* enable pipe */
status = 1;
setsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &status, sizeof(status));
/* disable pipe */
status = 0;
/* get status */
getsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &status, &len);
This also fixes the error code from EFAULT to ENOTCONN.
Cc: Kumar Sanghvi <kumar.sanghvi@stericsson.com>
As it currently is, the new code path is not compatible with existing
Nokia modems. This would break existing userspace for Nokia modem, such
as the existing oFono ISI driver.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
Documentation/feature-removal-schedule.txt
drivers/net/wireless/ipw2x00/ipw2200.c
Commit "fib: RCU conversion of fib_lookup()" removed rcu_read_lock() from
__mkroute_output but left a couple of calls to rcu_read_unlock() in there.
This causes lockdep to complain that the rcu_read_unlock() call in
__ip_route_output_key causes a lock inbalance and quickly crashes the
kernel. The below fixes this for me.
Signed-off-by: Dimitris Michailidis <dm@chelsio.com>
Calling ETHTOOL_GRXCLSRLALL with a large rule_cnt will allocate kernel
heap without clearing it. For the one driver (niu) that implements it,
it will leave the unused portion of heap unchanged and copy the full
contents back to userspace.
Synchronise the comment with the preceding implementation change.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
There's no need for the WDS peer address
to not be const, so make it const.
Bill Jordan's patch to allow setting the WDS
peer crossed with my patch removing all the
boilerplate code in nl80211, and consequently
he didn't make use of it yet. Fix that.
The recent scan overhaul broke locking
because now we can jump to code that
attempts to unlock, while we don't have
the mutex held. Fix this by holding the
mutex around all the relevant code.
Reported-by: Ben Greear <greearb@candelatech.com>
This reverts commit 5ed3bc7288487bd4f891f420a07319e0b538b4fe.
It turns-out that not all drivers are calling ieee80211_tx_status from a
compatible context. Revert this for now and try again later...
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-2.6
Do not set num_rx_queues in netif_set_real_num_rx_queues() some
drivers will increase the real_num_rx_queues later due to a feature
changes or available interrupts increasing. By setting num_rx_queues
here this ends up creating a cap on the number of rx queues
available.
For example the ixgbe driver sets the max number of queues it intends
to use ever then sets the current number in use with the
netif_set_num_{rx|tx}_queues calls. With the current implementation
the number of rx queues gets limited so when a feature such as DCB
or FCoE is enabled the queues are no longer available.
kobjects will only be allocated for real_num_rx_queues so the waste
in memory is minimal.
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
Remove dead code and make some functions static.
Compile tested only.
This looks like a simple typo that has gone unnoticed for some time. The
impact is relatively low but it's clearly wrong.
Signed-off-by: John Heffner <johnwheffner@gmail.com>
drivers/net/pcmcia/pcnet_cs.c
net/caif/caif_socket.c
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
This is the second step for neighbour RCU conversion.
(first was commit d6bf7817 : RCU conversion of neigh hash table)
neigh_lookup() becomes lockless, but still take a reference on found
neighbour. (no more read_lock()/read_unlock() on tbl->lock)
struct neighbour gets an additional rcu_head field and is freed after an
RCU grace period.
Future work would need to eventually not take a reference on neighbour
for temporary dst (DST_NOCACHE), but this would need dst->_neighbour to
use a noref bit like we did for skb->_dst.
net/mac80211/scan.c: In function ‘ieee80211_scan_cancel’:
net/mac80211/scan.c:794: warning: ‘finish’ may be used uninitialized in this function
When multiple interfaces are actively trying
to associate with the same BSS, they may both
find that the BSS isn't there and then try to
unlink it. This can cause errors since the
unlinking code can't currently deal with items
that have already been unlinked.
Normally this doesn't happen as most people
don't try to use multiple station interfaces
that associate at the same time too.
Fix this by using the list entry as a flag to
see if the item is still on a list.
Tested-by: Hun-Kyi Wynn <hkwynn@candelatech.com>
This information is already available in mac80211, we just need to export it
via cfg80211 and nl80211.
Signed-off-by: Bruno Randolf <br1@einfach.org>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
We nulify local->scan_req on failure in __ieee80211_start_scan, so
__ieee80211_scan_completed will not call cfg80211_scan_done. Fix that.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
When performing hw scan and not abort it, __ieee80211_scan_completed()
is currently called from scan work, so does not need to reschedule work
to call drv_hw_scan().
This is partial revert and fix for commit
85f72bc839705294b32b6c16b491c0422f0a71b3 "mac80211: only cancel
software-based scans on suspend"
When cfg80211 request the scan and mac80211 perform some management work,
we defer the scan request. We do not canceling such requests when calling
ieee80211_scan_cancel(), because of SCAN_SW_SCANNING bit check just
before the call. So fix that problem.
Another problem, which commit 85f72bc839705294b32b6c16b491c0422f0a71b3
tries to solve, is we can not cancel HW scan. Hence patch make
ieee80211_scan_cancel() ignore HW scan (see code comments). Keeping
local->mtx lock assures that the deferred scan will not become
"working" HW scan.
We are taking local->mtx inside __ieee80211_scan_completed(), but just
before call to that function we drop the lock. Dropping/taking lock is not
good, because can lead to hard to understand race conditions.
Patch split scan_completed() code into two functions, first must be called
with local->mtx taken and second without it.
Use goto instruction to call __ieee80211_scan_completed only ones in
ieee80211_scan_work. This is prepare for the next patch.
Yikes! The error return keeps a netdev reference
and the rdev mutex locked, fix that!
This adds API to allow adding per-station GTKs,
updates mac80211 to support it, and also allows
drivers to remove a key from hwaccel again when
this may be necessary due to multiple GTKs.
When roaming while we have active BA session,
we can end up transmitting delBA frames to
the old AP while we're already on the new AP's
channel, which can cause warnings.
Simply avoid sending those frames, but still
tear down the internal session state, since
they are not really necessary anyway as we
will implicitly disassociate when sending the
association to the new AP.
Acked-by: Luis R. Rodriguez <lrodriguez@atheros.com>
We never delete the addBA response timer, which
is typically fine, but if the station it belongs
to is deleted very quickly after starting the BA
session, before the peer had a chance to reply,
the timer may fire after the station struct has
been freed already. Therefore, we need to delete
the timer in a suitable spot -- best when the
session is being stopped (which will happen even
then) in which case the delete will be a no-op
most of the time.
I've reproduced the scenario and tested the fix.
This fixes the crash reported at
http://mid.gmane.org/4CAB6F96.6090701@candelatech.com
fib_lookup() converted to be called in RCU protected context, no
reference taken and released on a contended cache line (fib_clntref)
fib_table_lookup() and fib_semantic_match() get an additional parameter.
struct fib_info gets an rcu_head field, and is freed after an rcu grace
period.
Stress test :
(Sending 160.000.000 UDP frames on same neighbour,
IP route cache disabled, dual E5540 @2.53GHz,
32bit kernel, FIB_HASH) (about same results for FIB_TRIE)
Before patch :
real 1m31.199s
user 0m13.761s
sys 23m24.780s
After patch:
real 1m5.375s
user 0m14.997s
sys 15m50.115s
Before patch Profile :
13044.00 15.4% __ip_route_output_key vmlinux
8438.00 10.0% dst_destroy vmlinux
5983.00 7.1% fib_semantic_match vmlinux
5410.00 6.4% fib_rules_lookup vmlinux
4803.00 5.7% neigh_lookup vmlinux
4420.00 5.2% _raw_spin_lock vmlinux
3883.00 4.6% rt_set_nexthop vmlinux
3261.00 3.9% _raw_read_lock vmlinux
2794.00 3.3% fib_table_lookup vmlinux
2374.00 2.8% neigh_resolve_output vmlinux
2153.00 2.5% dst_alloc vmlinux
1502.00 1.8% _raw_read_lock_bh vmlinux
1484.00 1.8% kmem_cache_alloc vmlinux
1407.00 1.7% eth_header vmlinux
1406.00 1.7% ipv4_dst_destroy vmlinux
1298.00 1.5% __copy_from_user_ll vmlinux
1174.00 1.4% dev_queue_xmit vmlinux
1000.00 1.2% ip_output vmlinux
After patch Profile :
13712.00 15.8% dst_destroy vmlinux
8548.00 9.9% __ip_route_output_key vmlinux
7017.00 8.1% neigh_lookup vmlinux
4554.00 5.3% fib_semantic_match vmlinux
4067.00 4.7% _raw_read_lock vmlinux
3491.00 4.0% dst_alloc vmlinux
3186.00 3.7% neigh_resolve_output vmlinux
3103.00 3.6% fib_table_lookup vmlinux
2098.00 2.4% _raw_read_lock_bh vmlinux
2081.00 2.4% kmem_cache_alloc vmlinux
2013.00 2.3% _raw_spin_lock vmlinux
1763.00 2.0% __copy_from_user_ll vmlinux
1763.00 2.0% ip_output vmlinux
1761.00 2.0% ipv4_dst_destroy vmlinux
1631.00 1.9% eth_header vmlinux
1440.00 1.7% _raw_read_unlock_bh vmlinux
Reference results, if IP route cache is enabled :
real 0m29.718s
user 0m10.845s
sys 7m37.341s
25213.00 29.5% __ip_route_output_key vmlinux
9011.00 10.5% dst_release vmlinux
4817.00 5.6% ip_push_pending_frames vmlinux
4232.00 5.0% ip_finish_output vmlinux
3940.00 4.6% udp_sendmsg vmlinux
3730.00 4.4% __copy_from_user_ll vmlinux
3716.00 4.4% ip_route_output_flow vmlinux
2451.00 2.9% __xfrm_lookup vmlinux
2221.00 2.6% ip_append_data vmlinux
1718.00 2.0% _raw_spin_lock_bh vmlinux
1655.00 1.9% __alloc_skb vmlinux
1572.00 1.8% sock_wfree vmlinux
1345.00 1.6% kfree vmlinux
caif_connect() might dereference a netdevice after dev_put() it.
It also doesnt check dev_get_by_index() return value and could
dereference a NULL pointer.
Fix it, using RCU to avoid taking a reference.
CC: Sjur Braendeland <sjur.brandeland@stericsson.com>
The IGMP specs states that if the system receives a
membership report, it shouldn't send another for the
next minute. However, if a link failure happens right
after that, the backup slave and the switch connected
to this slave will not know about the multicast and
the traffic will hang for about a minute.
This patch fixes it to rejoin multicast groups immediately
after a failover restoring the multicast traffic.
Signed-off-by: Flavio Leitner <fleitner@redhat.com>
