path: root/net
2015-09-22openvswitch: Zero flows on allocation.Jesse Gross
When support for megaflows was introduced, OVS needed to start installing flows with a mask applied to them. Since masking is an expensive operation, OVS also had an optimization that would only take the parts of the flow keys that were covered by a non-zero mask. The values stored in the remaining pieces should not matter because they are masked out. While this works fine for the purposes of matching (which must always look at the mask), serialization to netlink can be problematic. Since the flow and the mask are serialized separately, the uninitialized portions of the flow can be encoded with whatever values happen to be present. In terms of functionality, this has little effect since these fields will be masked out by definition. However, it leaks kernel memory to userspace, which is a potential security vulnerability. It is also possible that other code paths could look at the masked key and get uninitialized data, although this does not currently appear to be an issue in practice. This removes the mask optimization for flows that are being installed. This was always intended to be the case as the mask optimizations were really targetting per-packet flow operations. Fixes: 03f0d916 ("openvswitch: Mega flow implementation") Signed-off-by: Jesse Gross <jesse@nicira.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-21inet: fix races in reqsk_queue_hash_req()Eric Dumazet
Before allowing lockless LISTEN processing, we need to make sure to arm the SYN_RECV timer before the req socket is visible in hash tables. Also, req->rsk_hash should be written before we set rsk_refcnt to a non zero value. Fixes: fa76ce7328b2 ("inet: get rid of central tcp/dccp listener timer") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Ying Cai <ycai@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-21tcp/dccp: fix timewait races in timer handlingEric Dumazet
When creating a timewait socket, we need to arm the timer before allowing other cpus to find it. The signal allowing cpus to find the socket is setting tw_refcnt to non zero value. As we set tw_refcnt in __inet_twsk_hashdance(), we therefore need to call inet_twsk_schedule() first. This also means we need to remove tw_refcnt changes from inet_twsk_schedule() and let the caller handle it. Note that because we use mod_timer_pinned(), we have the guarantee the timer wont expire before we set tw_refcnt as we run in BH context. To make things more readable I introduced inet_twsk_reschedule() helper. When rearming the timer, we can use mod_timer_pending() to make sure we do not rearm a canceled timer. Note: This bug can possibly trigger if packets of a flow can hit multiple cpus. This does not normally happen, unless flow steering is broken somehow. This explains this bug was spotted ~5 months after its introduction. A similar fix is needed for SYN_RECV sockets in reqsk_queue_hash_req(), but will be provided in a separate patch for proper tracking. Fixes: 789f558cfb36 ("tcp/dccp: get rid of central timewait timer") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Ying Cai <ycai@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-20netlink: Fix autobind race condition that leads to zero port IDHerbert Xu
The commit c0bb07df7d981e4091432754e30c9c720e2c0c78 ("netlink: Reset portid after netlink_insert failure") introduced a race condition where if two threads try to autobind the same socket one of them may end up with a zero port ID. This led to kernel deadlocks that were observed by multiple people. This patch reverts that commit and instead fixes it by introducing a separte rhash_portid variable so that the real portid is only set after the socket has been successfully hashed. Fixes: c0bb07df7d98 ("netlink: Reset portid after netlink_insert failure") Reported-by: Tejun Heo <tj@kernel.org> Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-20iptunnel: make rx/tx bytes counters consistentNicolas Dichtel
This was already done a long time ago in commit 64194c31a0b6 ("inet: Make tunnel RX/TX byte counters more consistent") but tx path was broken (at least since 3.10). Before the patch the gre header was included on tx. After the patch: $ ping -c1 192.168.0.121 ; ip -s l ls dev gre1 PING 192.168.0.121 (192.168.0.121) 56(84) bytes of data. 64 bytes from 192.168.0.121: icmp_req=1 ttl=64 time=2.95 ms --- 192.168.0.121 ping statistics --- 1 packets transmitted, 1 received, 0% packet loss, time 0ms rtt min/avg/max/mdev = 2.955/2.955/2.955/0.000 ms 7: gre1@NONE: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1468 qdisc noqueue state UNKNOWN mode DEFAULT group default link/gre 10.16.0.249 peer 10.16.0.121 RX: bytes packets errors dropped overrun mcast 84 1 0 0 0 0 TX: bytes packets errors dropped carrier collsns 84 1 0 0 0 0 Reported-by: Julien Meunier <julien.meunier@6wind.com> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== Netfilter fixes for net The following patch contains Netfilter fixes for your net tree, they are: 1) nf_log_unregister() should only set to NULL the logger that is being unregistered, instead of everything else. Patch from Florian Westphal. 2) Fix a crash when accessing physoutdev from PREROUTING in br_netfilter. This is partially reverting the patch to shrink nf_bridge_info to 32 bytes. Also from Florian. 3) Use existing match/target extensions in the internal nft_compat extension lists when the extension is family unspecific (ie. NFPROTO_UNSPEC). 4) Wait for rcu grace period before leaving nf_log_unregister(). ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-20tipc: reinitialize pointer after skb linearizeErik Hugne
The msg pointer into header may change after skb linearization. We must reinitialize it after calling skb_linearize to prevent operating on a freed or invalid pointer. Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Reported-by: Tamás Végh <tamas.vegh@ericsson.com> Acked-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-20net: Fix behaviour of unreachable, blackhole and prohibit routesNikola Forró
Man page of ip-route(8) says following about route types: unreachable - these destinations are unreachable. Packets are dis‐ carded and the ICMP message host unreachable is generated. The local senders get an EHOSTUNREACH error. blackhole - these destinations are unreachable. Packets are dis‐ carded silently. The local senders get an EINVAL error. prohibit - these destinations are unreachable. Packets are discarded and the ICMP message communication administratively prohibited is generated. The local senders get an EACCES error. In the inet6 address family, this was correct, except the local senders got ENETUNREACH error instead of EHOSTUNREACH in case of unreachable route. In the inet address family, all three route types generated ICMP message net unreachable, and the local senders got ENETUNREACH error. In both address families all three route types now behave consistently with documentation. Signed-off-by: Nikola Forró <nforro@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17tcp_cubic: do not set epoch_start in the futureEric Dumazet
Tracking idle time in bictcp_cwnd_event() is imprecise, as epoch_start is normally set at ACK processing time, not at send time. Doing a proper fix would need to add an additional state variable, and does not seem worth the trouble, given CUBIC bug has been there forever before Jana noticed it. Let's simply not set epoch_start in the future, otherwise bictcp_update() could overflow and CUBIC would again grow cwnd too fast. This was detected thanks to a packetdrill test Neal wrote that was flaky before applying this fix. Fixes: 30927520dbae ("tcp_cubic: better follow cubic curve after idle period") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Cc: Jana Iyengar <jri@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17Merge branch 'for-upstream' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth Johan Hedberg says: ==================== pull request: bluetooth 2015-09-17 Here's one important patch for the 4.3-rc series that fixes an issue with Bluetooth LE encryption failing because of a too early check for the SMP context. Please let me know if there are any issues pulling. Thanks. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17atm: deal with setting entry before mkip was calledSasha Levin
If we didn't call ATMARP_MKIP before ATMARP_ENCAP the VCC descriptor is non-existant and we'll end up dereferencing a NULL ptr: [1033173.491930] kasan: GPF could be caused by NULL-ptr deref or user memory accessirq event stamp: 123386 [1033173.493678] general protection fault: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC KASAN [1033173.493689] Modules linked in: [1033173.493697] CPU: 9 PID: 23815 Comm: trinity-c64 Not tainted 4.2.0-next-20150911-sasha-00043-g353d875-dirty #2545 [1033173.493706] task: ffff8800630c4000 ti: ffff880063110000 task.ti: ffff880063110000 [1033173.493823] RIP: clip_ioctl (net/atm/clip.c:320 net/atm/clip.c:689) [1033173.493826] RSP: 0018:ffff880063117a88 EFLAGS: 00010203 [1033173.493828] RAX: dffffc0000000000 RBX: 0000000000000000 RCX: 000000000000000c [1033173.493830] RDX: 0000000000000002 RSI: ffffffffb3f10720 RDI: 0000000000000014 [1033173.493832] RBP: ffff880063117b80 R08: ffff88047574d9a4 R09: 0000000000000000 [1033173.493834] R10: 0000000000000000 R11: 0000000000000000 R12: 1ffff1000c622f53 [1033173.493836] R13: ffff8800cb905500 R14: ffff8808d6da2000 R15: 00000000fffffdfd [1033173.493840] FS: 00007fa56b92d700(0000) GS:ffff880478000000(0000) knlGS:0000000000000000 [1033173.493843] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [1033173.493845] CR2: 0000000000000000 CR3: 00000000630e8000 CR4: 00000000000006a0 [1033173.493855] Stack: [1033173.493862] ffffffffb0b60444 000000000000eaea 0000000041b58ab3 ffffffffb3c3ce32 [1033173.493867] ffffffffb0b6f3e0 ffffffffb0b60444 ffffffffb5ea2e50 1ffff1000c622f5e [1033173.493873] ffff8800630c4cd8 00000000000ee09a ffffffffb3ec4888 ffffffffb5ea2de8 [1033173.493874] Call Trace: [1033173.494108] do_vcc_ioctl (net/atm/ioctl.c:170) [1033173.494113] vcc_ioctl (net/atm/ioctl.c:189) [1033173.494116] svc_ioctl (net/atm/svc.c:605) [1033173.494200] sock_do_ioctl (net/socket.c:874) [1033173.494204] sock_ioctl (net/socket.c:958) [1033173.494244] do_vfs_ioctl (fs/ioctl.c:43 fs/ioctl.c:607) [1033173.494290] SyS_ioctl (fs/ioctl.c:622 fs/ioctl.c:613) [1033173.494295] entry_SYSCALL_64_fastpath (arch/x86/entry/entry_64.S:186) [1033173.494362] Code: fa 48 c1 ea 03 80 3c 02 00 0f 85 50 09 00 00 49 8b 9e 60 06 00 00 48 b8 00 00 00 00 00 fc ff df 48 8d 7b 14 48 89 fa 48 c1 ea 03 <0f> b6 04 02 48 89 fa 83 e2 07 38 d0 7f 08 84 c0 0f 85 14 09 00 All code ======== 0: fa cli 1: 48 c1 ea 03 shr $0x3,%rdx 5: 80 3c 02 00 cmpb $0x0,(%rdx,%rax,1) 9: 0f 85 50 09 00 00 jne 0x95f f: 49 8b 9e 60 06 00 00 mov 0x660(%r14),%rbx 16: 48 b8 00 00 00 00 00 movabs $0xdffffc0000000000,%rax 1d: fc ff df 20: 48 8d 7b 14 lea 0x14(%rbx),%rdi 24: 48 89 fa mov %rdi,%rdx 27: 48 c1 ea 03 shr $0x3,%rdx 2b:* 0f b6 04 02 movzbl (%rdx,%rax,1),%eax <-- trapping instruction 2f: 48 89 fa mov %rdi,%rdx 32: 83 e2 07 and $0x7,%edx 35: 38 d0 cmp %dl,%al 37: 7f 08 jg 0x41 39: 84 c0 test %al,%al 3b: 0f 85 14 09 00 00 jne 0x955 Code starting with the faulting instruction =========================================== 0: 0f b6 04 02 movzbl (%rdx,%rax,1),%eax 4: 48 89 fa mov %rdi,%rdx 7: 83 e2 07 and $0x7,%edx a: 38 d0 cmp %dl,%al c: 7f 08 jg 0x16 e: 84 c0 test %al,%al 10: 0f 85 14 09 00 00 jne 0x92a [1033173.494366] RIP clip_ioctl (net/atm/clip.c:320 net/atm/clip.c:689) [1033173.494368] RSP <ffff880063117a88> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17ipv6: ip6_fragment: fix headroom tests and skb leakFlorian Westphal
David Woodhouse reports skb_under_panic when we try to push ethernet header to fragmented ipv6 skbs: skbuff: skb_under_panic: text:c1277f1e len:1294 put:14 head:dec98000 data:dec97ffc tail:0xdec9850a end:0xdec98f40 dev:br-lan [..] ip6_finish_output2+0x196/0x4da David further debugged this: [..] offending fragments were arriving here with skb_headroom(skb)==10. Which is reasonable, being the Solos ADSL card's header of 8 bytes followed by 2 bytes of PPP frame type. The problem is that if netfilter ipv6 defragmentation is used, skb_cow() in ip6_forward will only see reassembled skb. Therefore, headroom is overestimated by 8 bytes (we pulled fragment header) and we don't check the skbs in the frag_list either. We can't do these checks in netfilter defrag since outdev isn't known yet. Furthermore, existing tests in ip6_fragment did not consider the fragment or ipv6 header size when checking headroom of the fraglist skbs. While at it, also fix a skb leak on memory allocation -- ip6_fragment must consume the skb. I tested this e1000 driver hacked to not allocate additional headroom (we end up in slowpath, since LL_RESERVED_SPACE is 16). If 2 bytes of headroom are allocated, fastpath is taken (14 byte ethernet header was pulled, so 16 byte headroom available in all fragments). Reported-by: David Woodhouse <dwmw2@infradead.org> Diagnosed-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Florian Westphal <fw@strlen.de> Tested-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17net: Fix vti use case with oif in dst lookupsDavid Ahern
Steffen reported that the recent change to add oif to dst lookups breaks the VTI use case. The problem is that with the oif set in the flow struct the comparison to the nh_oif is triggered. Fix by splitting the FLOWI_FLAG_VRFSRC into 2 flags -- one that triggers the vrf device cache bypass (FLOWI_FLAG_VRFSRC) and another telling the lookup to not compare nh oif (FLOWI_FLAG_SKIP_NH_OIF). Fixes: 42a7b32b73d6 ("xfrm: Add oif to dst lookups") Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17openvswitch: Fix IPv6 exthdr handling with ct helpers.Joe Stringer
Static code analysis reveals the following bug: net/openvswitch/conntrack.c:281 ovs_ct_helper() warn: unsigned 'protoff' is never less than zero. This signedness bug breaks error handling for IPv6 extension headers when using conntrack helpers. Fix the error by using a local signed variable. Fixes: cae3a2627520: "openvswitch: Allow attaching helpers to ct action" Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Joe Stringer <joestringer@nicira.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17ipv6: include NLM_F_REPLACE in route replace notificationsRoopa Prabhu
This patch adds NLM_F_REPLACE flag to ipv6 route replace notifications. This makes nlm_flags in ipv6 replace notifications consistent with ipv4. Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com> Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Reviewed-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17netfilter: nf_log: wait for rcu grace after logger unregistrationPablo Neira Ayuso
The nf_log_unregister() function needs to call synchronize_rcu() to make sure that the objects are not dereferenced anymore on module removal. Fixes: 5962815a6a56 ("netfilter: nf_log: use an array of loggers instead of list") Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-17Bluetooth: Delay check for conn->smp in smp_conn_security()Johan Hedberg
There are several actions that smp_conn_security() might make that do not require a valid SMP context (conn->smp pointer). One of these actions is to encrypt the link with an existing LTK. If the SMP context wasn't initialized properly we should still allow the independent actions to be done, i.e. the check for the context should only be done at the last possible moment. Reported-by: Chuck Ebbert <cebbert.lkml@gmail.com> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Cc: stable@vger.kernel.org # 4.0+
2015-09-15dccp: drop null test before destroy functionsJulia Lawall
Remove unneeded NULL test. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x; @@ -if (x != NULL) \(kmem_cache_destroy\|mempool_destroy\|dma_pool_destroy\)(x); @@ expression x; @@ -if (x != NULL) { \(kmem_cache_destroy\|mempool_destroy\|dma_pool_destroy\)(x); x = NULL; -} // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-15net: core: drop null test before destroy functionsJulia Lawall
Remove unneeded NULL test. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x; @@ -if (x != NULL) { \(kmem_cache_destroy\|mempool_destroy\|dma_pool_destroy\)(x); x = NULL; -} // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-15openvswitch: Fix mask generation for nested attributes.Jesse Gross
Masks were added to OVS flows in a way that was backwards compatible with userspace programs that did not generate masks. As a result, it is possible that we may receive flows that do not have a mask and we need to synthesize one. Generating a mask requires iterating over attributes and descending into nested attributes. For each level we need to know the size to generate the correct mask. We do this with a linked table of attribute types. Although the logic to handle these nested attributes was there in concept, there are a number of bugs in practice. Examples include incomplete links between tables, variable length attributes being treated as nested and missing sanity checks. Signed-off-by: Jesse Gross <jesse@nicira.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-15rtnetlink: catch -EOPNOTSUPP errors from ndo_bridge_getlinkRoopa Prabhu
problem reported: kernel 4.1.3 ------------ # bridge vlan port vlan ids eth0 1 PVID Egress Untagged 90 91 92 93 94 95 96 97 98 99 100 vmbr0 1 PVID Egress Untagged 94 kernel 4.2 ----------- # bridge vlan port vlan ids ndo_bridge_getlink can return -EOPNOTSUPP when an interfaces ndo_bridge_getlink op is set to switchdev_port_bridge_getlink and CONFIG_SWITCHDEV is not defined. This today can happen to bond, rocker and team devices. This patch adds -EOPNOTSUPP checks after calls to ndo_bridge_getlink. Fixes: 85fdb956726ff2a ("switchdev: cut over to new switchdev_port_bridge_getlink") Reported-by: Alexandre DERUMIER <aderumier@odiso.com> Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-15ipv6: Replace spinlock with seqlock and rcu in ip6_tunnelMartin KaFai Lau
This patch uses a seqlock to ensure consistency between idst->dst and idst->cookie. It also makes dst freeing from fib tree to undergo a rcu grace period. Signed-off-by: Martin KaFai Lau <kafai@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-15ipv6: Avoid double dst_freeMartin KaFai Lau
It is a prep work to get dst freeing from fib tree undergo a rcu grace period. The following is a common paradigm: if (ip6_del_rt(rt)) dst_free(rt) which means, if rt cannot be deleted from the fib tree, dst_free(rt) now. 1. We don't know the ip6_del_rt(rt) failure is because it was not managed by fib tree (e.g. DST_NOCACHE) or it had already been removed from the fib tree. 2. If rt had been managed by the fib tree, ip6_del_rt(rt) failure means dst_free(rt) has been called already. A second dst_free(rt) is not always obviously safe. The rt may have been destroyed already. 3. If rt is a DST_NOCACHE, dst_free(rt) should not be called. 4. It is a stopper to make dst freeing from fib tree undergo a rcu grace period. This patch is to use a DST_NOCACHE flag to indicate a rt is not managed by the fib tree. Signed-off-by: Martin KaFai Lau <kafai@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-15ipv6: Fix dst_entry refcnt bugs in ip6_tunnelMartin KaFai Lau
Problems in the current dst_entry cache in the ip6_tunnel: 1. ip6_tnl_dst_set is racy. There is no lock to protect it: - One major problem is that the dst refcnt gets messed up. F.e. the same dst_cache can be released multiple times and then triggering the infamous dst refcnt < 0 warning message. - Another issue is the inconsistency between dst_cache and dst_cookie. It can be reproduced by adding and removing the ip6gre tunnel while running a super_netperf TCP_CRR test. 2. ip6_tnl_dst_get does not take the dst refcnt before returning the dst. This patch: 1. Create a percpu dst_entry cache in ip6_tnl 2. Use a spinlock to protect the dst_cache operations 3. ip6_tnl_dst_get always takes the dst refcnt before returning Signed-off-by: Martin KaFai Lau <kafai@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-15ipv6: Rename the dst_cache helper functions in ip6_tunnelMartin KaFai Lau
It is a prep work to fix the dst_entry refcnt bugs in ip6_tunnel. This patch rename: 1. ip6_tnl_dst_check() to ip6_tnl_dst_get() to better reflect that it will take a dst refcnt in the next patch. 2. ip6_tnl_dst_store() to ip6_tnl_dst_set() to have a more conventional name matching with ip6_tnl_dst_get(). Signed-off-by: Martin KaFai Lau <kafai@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-15ipv6: Refactor common ip6gre_tunnel_init codesMartin KaFai Lau
It is a prep work to fix the dst_entry refcnt bugs in ip6_tunnel. This patch refactors some common init codes used by both ip6gre_tunnel_init and ip6gre_tap_init. Signed-off-by: Martin KaFai Lau <kafai@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-14netfilter: nft_compat: skip family comparison in case of NFPROTO_UNSPECPablo Neira Ayuso
Fix lookup of existing match/target structures in the corresponding list by skipping the family check if NFPROTO_UNSPEC is used. This is resulting in the allocation and insertion of one match/target structure for each use of them. So this not only bloats memory consumption but also severely affects the time to reload the ruleset from the iptables-compat utility. After this patch, iptables-compat-restore and iptables-compat take almost the same time to reload large rulesets. Fixes: 0ca743a55991 ("netfilter: nf_tables: add compatibility layer for x_tables") Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-14netfilter: nf_log: don't zap all loggers on unregisterFlorian Westphal
like nf_log_unset, nf_log_unregister must not reset the list of loggers. Otherwise, a call to nf_log_unregister() will render loggers of other nf protocols unusable: iptables -A INPUT -j LOG modprobe nf_log_arp ; rmmod nf_log_arp iptables -A INPUT -j LOG iptables: No chain/target/match by that name Fixes: 30e0c6a6be ("netfilter: nf_log: prepare net namespace support for loggers") Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-11openvswitch: Fix dependency on IPv6 defrag.Joe Stringer
When NF_CONNTRACK is built-in, NF_DEFRAG_IPV6 is a module, and OPENVSWITCH is built-in, the following build error would occur: net/built-in.o: In function `ovs_ct_execute': (.text+0x10f587): undefined reference to `nf_ct_frag6_gather' Fixes: 7f8a436eaa2c ("openvswitch: Add conntrack action") Reported-by: Jim Davis <jim.epost@gmail.com> Signed-off-by: Joe Stringer <joestringer@nicira.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-11bridge: fix igmpv3 / mldv2 report parsingLinus Lüssing
With the newly introduced helper functions the skb pulling is hidden in the checksumming function - and undone before returning to the caller. The IGMPv3 and MLDv2 report parsing functions in the bridge still assumed that the skb is pointing to the beginning of the IGMP/MLD message while it is now kept at the beginning of the IPv4/6 header, breaking the message parsing and creating packet loss. Fixing this by taking the offset between IP and IGMP/MLD header into account, too. Fixes: 9afd85c9e455 ("net: Export IGMP/MLD message validation code") Reported-by: Tobias Powalowski <tobias.powalowski@googlemail.com> Tested-by: Tobias Powalowski <tobias.powalowski@googlemail.com> Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-11sctp: fix race on protocol/netns initializationMarcelo Ricardo Leitner
Consider sctp module is unloaded and is being requested because an user is creating a sctp socket. During initialization, sctp will add the new protocol type and then initialize pernet subsys: status = sctp_v4_protosw_init(); if (status) goto err_protosw_init; status = sctp_v6_protosw_init(); if (status) goto err_v6_protosw_init; status = register_pernet_subsys(&sctp_net_ops); The problem is that after those calls to sctp_v{4,6}_protosw_init(), it is possible for userspace to create SCTP sockets like if the module is already fully loaded. If that happens, one of the possible effects is that we will have readers for net->sctp.local_addr_list list earlier than expected and sctp_net_init() does not take precautions while dealing with that list, leading to a potential panic but not limited to that, as sctp_sock_init() will copy a bunch of blank/partially initialized values from net->sctp. The race happens like this: CPU 0 | CPU 1 socket() | __sock_create | socket() inet_create | __sock_create list_for_each_entry_rcu( | answer, &inetsw[sock->type], | list) { | inet_create /* no hits */ | if (unlikely(err)) { | ... | request_module() | /* socket creation is blocked | * the module is fully loaded | */ | sctp_init | sctp_v4_protosw_init | inet_register_protosw | list_add_rcu(&p->list, | last_perm); | | list_for_each_entry_rcu( | answer, &inetsw[sock->type], sctp_v6_protosw_init | list) { | /* hit, so assumes protocol | * is already loaded | */ | /* socket creation continues | * before netns is initialized | */ register_pernet_subsys | Simply inverting the initialization order between register_pernet_subsys() and sctp_v4_protosw_init() is not possible because register_pernet_subsys() will create a control sctp socket, so the protocol must be already visible by then. Deferring the socket creation to a work-queue is not good specially because we loose the ability to handle its errors. So, as suggested by Vlad, the fix is to split netns initialization in two moments: defaults and control socket, so that the defaults are already loaded by when we register the protocol, while control socket initialization is kept at the same moment it is today. Fixes: 4db67e808640 ("sctp: Make the address lists per network namespace") Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-11ebpf: emit correct src_reg for conditional jumpsTycho Andersen
Instead of always emitting BPF_REG_X, let's emit BPF_REG_X only when the source actually is BPF_X. This causes programs generated by the classic converter to not be importable via bpf(), as the eBPF verifier checks that the src_reg is correct or 0. While not a problem yet, this will be a problem when BPF_PROG_DUMP lands, and we can potentially dump and re-import programs generated by the converter. Signed-off-by: Tycho Andersen <tycho.andersen@canonical.com> CC: Alexei Starovoitov <ast@kernel.org> CC: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-11netlink, mmap: transform mmap skb into full skb on tapsDaniel Borkmann
Ken-ichirou reported that running netlink in mmap mode for receive in combination with nlmon will throw a NULL pointer dereference in __kfree_skb() on nlmon_xmit(), in my case I can also trigger an "unable to handle kernel paging request". The problem is the skb_clone() in __netlink_deliver_tap_skb() for skbs that are mmaped. I.e. the cloned skb doesn't have a destructor, whereas the mmap netlink skb has it pointed to netlink_skb_destructor(), set in the handler netlink_ring_setup_skb(). There, skb->head is being set to NULL, so that in such cases, __kfree_skb() doesn't perform a skb_release_data() via skb_release_all(), where skb->head is possibly being freed through kfree(head) into slab allocator, although netlink mmap skb->head points to the mmap buffer. Similarly, the same has to be done also for large netlink skbs where the data area is vmalloced. Therefore, as discussed, make a copy for these rather rare cases for now. This fixes the issue on my and Ken-ichirou's test-cases. Reference: http://thread.gmane.org/gmane.linux.network/371129 Fixes: bcbde0d449ed ("net: netlink: virtual tap device management") Reported-by: Ken-ichirou MATSUZAWA <chamaken@gmail.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Tested-by: Ken-ichirou MATSUZAWA <chamaken@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix out-of-bounds array access in netfilter ipset, from Jozsef Kadlecsik. 2) Use correct free operation on netfilter conntrack templates, from Daniel Borkmann. 3) Fix route leak in SCTP, from Marcelo Ricardo Leitner. 4) Fix sizeof(pointer) in mac80211, from Thierry Reding. 5) Fix cache pointer comparison in ip6mr leading to missed unlock of mrt_lock. From Richard Laing. 6) rds_conn_lookup() needs to consider network namespace in key comparison, from Sowmini Varadhan. 7) Fix deadlock in TIPC code wrt broadcast link wakeups, from Kolmakov Dmitriy. 8) Fix fd leaks in bpf syscall, from Daniel Borkmann. 9) Fix error recovery when installing ipv6 multipath routes, we would delete the old route before we would know if we could fully commit to the new set of nexthops. Fix from Roopa Prabhu. 10) Fix run-time suspend problems in r8152, from Hayes Wang. 11) In fec, don't program the MAC address into the chip when the clocks are gated off. From Fugang Duan. 12) Fix poll behavior for netlink sockets when using rx ring mmap, from Daniel Borkmann. 13) Don't allocate memory with GFP_KERNEL from get_stats64 in r8169 driver, from Corinna Vinschen. 14) In TCP Cubic congestion control, handle idle periods better where we are application limited, in order to keep cwnd from growing out of control. From Eric Dumzet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits) tcp_cubic: better follow cubic curve after idle period tcp: generate CA_EVENT_TX_START on data frames xen-netfront: respect user provided max_queues xen-netback: respect user provided max_queues r8169: Fix sleeping function called during get_stats64, v2 ether: add IEEE 1722 ethertype - TSN netlink, mmap: fix edge-case leakages in nf queue zero-copy netlink, mmap: don't walk rx ring on poll if receive queue non-empty cxgb4: changes for new firmware 1.14.4.0 net: fec: add netif status check before set mac address r8152: fix the runtime suspend issues r8152: split DRIVER_VERSION ipv6: fix ifnullfree.cocci warnings add microchip LAN88xx phy driver stmmac: fix check for phydev being open net: qlcnic: delete redundant memsets net: mv643xx_eth: use kzalloc net: jme: use kzalloc() instead of kmalloc+memset net: cavium: liquidio: use kzalloc in setup_glist() net: ipv6: use common fib_default_rule_pref ...
2015-09-10tcp_cubic: better follow cubic curve after idle periodEric Dumazet
Jana Iyengar found an interesting issue on CUBIC : The epoch is only updated/reset initially and when experiencing losses. The delta "t" of now - epoch_start can be arbitrary large after app idle as well as the bic_target. Consequentially the slope (inverse of ca->cnt) would be really large, and eventually ca->cnt would be lower-bounded in the end to 2 to have delayed-ACK slow-start behavior. This particularly shows up when slow_start_after_idle is disabled as a dangerous cwnd inflation (1.5 x RTT) after few seconds of idle time. Jana initial fix was to reset epoch_start if app limited, but Neal pointed out it would ask the CUBIC algorithm to recalculate the curve so that we again start growing steeply upward from where cwnd is now (as CUBIC does just after a loss). Ideally we'd want the cwnd growth curve to be the same shape, just shifted later in time by the amount of the idle period. Reported-by: Jana Iyengar <jri@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Sangtae Ha <sangtae.ha@gmail.com> Cc: Lawrence Brakmo <lawrence@brakmo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-10tcp: generate CA_EVENT_TX_START on data framesNeal Cardwell
Issuing a CC TX_START event on control frames like pure ACK is a waste of time, as a CC should not care. Following patch needs this change, as we want CUBIC to properly track idle time at a low cost, with a single TX_START being generated. Yuchung might slightly refine the condition triggering TX_START on a followup patch. Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Cc: Jana Iyengar <jri@google.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Sangtae Ha <sangtae.ha@gmail.com> Cc: Lawrence Brakmo <lawrence@brakmo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-09netlink, mmap: fix edge-case leakages in nf queue zero-copyDaniel Borkmann
When netlink mmap on receive side is the consumer of nf queue data, it can happen that in some edge cases, we write skb shared info into the user space mmap buffer: Assume a possible rx ring frame size of only 4096, and the network skb, which is being zero-copied into the netlink skb, contains page frags with an overall skb->len larger than the linear part of the netlink skb. skb_zerocopy(), which is generic and thus not aware of the fact that shared info cannot be accessed for such skbs then tries to write and fill frags, thus leaking kernel data/pointers and in some corner cases possibly writing out of bounds of the mmap area (when filling the last slot in the ring buffer this way). I.e. the ring buffer slot is then of status NL_MMAP_STATUS_VALID, has an advertised length larger than 4096, where the linear part is visible at the slot beginning, and the leaked sizeof(struct skb_shared_info) has been written to the beginning of the next slot (also corrupting the struct nl_mmap_hdr slot header incl. status etc), since skb->end points to skb->data + ring->frame_size - NL_MMAP_HDRLEN. The fix adds and lets __netlink_alloc_skb() take the actual needed linear room for the network skb + meta data into account. It's completely irrelevant for non-mmaped netlink sockets, but in case mmap sockets are used, it can be decided whether the available skb_tailroom() is really large enough for the buffer, or whether it needs to internally fallback to a normal alloc_skb(). >From nf queue side, the information whether the destination port is an mmap RX ring is not really available without extra port-to-socket lookup, thus it can only be determined in lower layers i.e. when __netlink_alloc_skb() is called that checks internally for this. I chose to add the extra ldiff parameter as mmap will then still work: We have data_len and hlen in nfqnl_build_packet_message(), data_len is the full length (capped at queue->copy_range) for skb_zerocopy() and hlen some possible part of data_len that needs to be copied; the rem_len variable indicates the needed remaining linear mmap space. The only other workaround in nf queue internally would be after allocation time by f.e. cap'ing the data_len to the skb_tailroom() iff we deal with an mmap skb, but that would 1) expose the fact that we use a mmap skb to upper layers, and 2) trim the skb where we otherwise could just have moved the full skb into the normal receive queue. After the patch, in my test case the ring slot doesn't fit and therefore shows NL_MMAP_STATUS_COPY, where a full skb carries all the data and thus needs to be picked up via recv(). Fixes: 3ab1f683bf8b ("nfnetlink: add support for memory mapped netlink") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-09netlink, mmap: don't walk rx ring on poll if receive queue non-emptyDaniel Borkmann
In case of netlink mmap, there can be situations where received frames have to be placed into the normal receive queue. The ring buffer indicates this through NL_MMAP_STATUS_COPY, so the user is asked to pick them up via recvmsg(2) syscall, and to put the slot back to NL_MMAP_STATUS_UNUSED. Commit 0ef707700f1c ("netlink: rx mmap: fix POLLIN condition") changed polling, so that we walk in the worst case the whole ring through the new netlink_has_valid_frame(), for example, when the ring would have no NL_MMAP_STATUS_VALID, but at least one NL_MMAP_STATUS_COPY frame. Since we do a datagram_poll() already earlier to pick up a mask that could possibly contain POLLIN | POLLRDNORM already (due to NL_MMAP_STATUS_COPY), we can skip checking the rx ring entirely. In case the kernel is compiled with !CONFIG_NETLINK_MMAP, then all this is irrelevant anyway as netlink_poll() is just defined as datagram_poll(). Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-09ipv6: fix ifnullfree.cocci warningsWu Fengguang
net/ipv6/route.c:2946:3-8: WARNING: NULL check before freeing functions like kfree, debugfs_remove, debugfs_remove_recursive or usb_free_urb is not needed. Maybe consider reorganizing relevant code to avoid passing NULL values. NULL check before some freeing functions is not needed. Based on checkpatch warning "kfree(NULL) is safe this check is probably not required" and kfreeaddr.cocci by Julia Lawall. Generated by: scripts/coccinelle/free/ifnullfree.cocci CC: Roopa Prabhu <roopa@cumulusnetworks.com> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-09net: ipv6: use common fib_default_rule_prefPhil Sutter
This switches IPv6 policy routing to use the shared fib_default_rule_pref() function of IPv4 and DECnet. It is also used in multicast routing for IPv4 as well as IPv6. The motivation for this patch is a complaint about iproute2 behaving inconsistent between IPv4 and IPv6 when adding policy rules: Formerly, IPv6 rules were assigned a fixed priority of 0x3FFF whereas for IPv4 the assigned priority value was decreased with each rule added. Since then all users of the default_pref field have been converted to assign the generic function fib_default_rule_pref(), fib_nl_newrule() may just use it directly instead. Therefore get rid of the function pointer altogether and make fib_default_rule_pref() static, as it's not used outside fib_rules.c anymore. Signed-off-by: Phil Sutter <phil@nwl.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-09ipv6: fix multipath route replace error recoveryRoopa Prabhu
Problem: The ecmp route replace support for ipv6 in the kernel, deletes the existing ecmp route too early, ie when it installs the first nexthop. If there is an error in installing the subsequent nexthops, its too late to recover the already deleted existing route leaving the fib in an inconsistent state. This patch reduces the possibility of this by doing the following: a) Changes the existing multipath route add code to a two stage process: build rt6_infos + insert them ip6_route_add rt6_info creation code is moved into ip6_route_info_create. b) This ensures that most errors are caught during building rt6_infos and we fail early c) Separates multipath add and del code. Because add needs the special two stage mode in a) and delete essentially does not care. d) In any event if the code fails during inserting a route again, a warning is printed (This should be unlikely) Before the patch: $ip -6 route show 3000:1000:1000:1000::2 via fe80::202:ff:fe00:b dev swp49s0 metric 1024 3000:1000:1000:1000::2 via fe80::202:ff:fe00:d dev swp49s1 metric 1024 3000:1000:1000:1000::2 via fe80::202:ff:fe00:f dev swp49s2 metric 1024 /* Try replacing the route with a duplicate nexthop */ $ip -6 route change 3000:1000:1000:1000::2/128 nexthop via fe80::202:ff:fe00:b dev swp49s0 nexthop via fe80::202:ff:fe00:d dev swp49s1 nexthop via fe80::202:ff:fe00:d dev swp49s1 RTNETLINK answers: File exists $ip -6 route show /* previously added ecmp route 3000:1000:1000:1000::2 dissappears from * kernel */ After the patch: $ip -6 route show 3000:1000:1000:1000::2 via fe80::202:ff:fe00:b dev swp49s0 metric 1024 3000:1000:1000:1000::2 via fe80::202:ff:fe00:d dev swp49s1 metric 1024 3000:1000:1000:1000::2 via fe80::202:ff:fe00:f dev swp49s2 metric 1024 /* Try replacing the route with a duplicate nexthop */ $ip -6 route change 3000:1000:1000:1000::2/128 nexthop via fe80::202:ff:fe00:b dev swp49s0 nexthop via fe80::202:ff:fe00:d dev swp49s1 nexthop via fe80::202:ff:fe00:d dev swp49s1 RTNETLINK answers: File exists $ip -6 route show 3000:1000:1000:1000::2 via fe80::202:ff:fe00:b dev swp49s0 metric 1024 3000:1000:1000:1000::2 via fe80::202:ff:fe00:d dev swp49s1 metric 1024 3000:1000:1000:1000::2 via fe80::202:ff:fe00:f dev swp49s2 metric 1024 Fixes: 27596472473a ("ipv6: fix ECMP route replacement") Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com> Reviewed-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-09RDS: verify the underlying transport exists before creating a connectionSasha Levin
There was no verification that an underlying transport exists when creating a connection, this would cause dereferencing a NULL ptr. It might happen on sockets that weren't properly bound before attempting to send a message, which will cause a NULL ptr deref: [135546.047719] kasan: GPF could be caused by NULL-ptr deref or user memory accessgeneral protection fault: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC KASAN [135546.051270] Modules linked in: [135546.051781] CPU: 4 PID: 15650 Comm: trinity-c4 Not tainted 4.2.0-next-20150902-sasha-00041-gbaa1222-dirty #2527 [135546.053217] task: ffff8800835bc000 ti: ffff8800bc708000 task.ti: ffff8800bc708000 [135546.054291] RIP: __rds_conn_create (net/rds/connection.c:194) [135546.055666] RSP: 0018:ffff8800bc70fab0 EFLAGS: 00010202 [135546.056457] RAX: dffffc0000000000 RBX: 0000000000000f2c RCX: ffff8800835bc000 [135546.057494] RDX: 0000000000000007 RSI: ffff8800835bccd8 RDI: 0000000000000038 [135546.058530] RBP: ffff8800bc70fb18 R08: 0000000000000001 R09: 0000000000000000 [135546.059556] R10: ffffed014d7a3a23 R11: ffffed014d7a3a21 R12: 0000000000000000 [135546.060614] R13: 0000000000000001 R14: ffff8801ec3d0000 R15: 0000000000000000 [135546.061668] FS: 00007faad4ffb700(0000) GS:ffff880252000000(0000) knlGS:0000000000000000 [135546.062836] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [135546.063682] CR2: 000000000000846a CR3: 000000009d137000 CR4: 00000000000006a0 [135546.064723] Stack: [135546.065048] ffffffffafe2055c ffffffffafe23fc1 ffffed00493097bf ffff8801ec3d0008 [135546.066247] 0000000000000000 00000000000000d0 0000000000000000 ac194a24c0586342 [135546.067438] 1ffff100178e1f78 ffff880320581b00 ffff8800bc70fdd0 ffff880320581b00 [135546.068629] Call Trace: [135546.069028] ? __rds_conn_create (include/linux/rcupdate.h:856 net/rds/connection.c:134) [135546.069989] ? rds_message_copy_from_user (net/rds/message.c:298) [135546.071021] rds_conn_create_outgoing (net/rds/connection.c:278) [135546.071981] rds_sendmsg (net/rds/send.c:1058) [135546.072858] ? perf_trace_lock (include/trace/events/lock.h:38) [135546.073744] ? lockdep_init (kernel/locking/lockdep.c:3298) [135546.074577] ? rds_send_drop_to (net/rds/send.c:976) [135546.075508] ? __might_fault (./arch/x86/include/asm/current.h:14 mm/memory.c:3795) [135546.076349] ? __might_fault (mm/memory.c:3795) [135546.077179] ? rds_send_drop_to (net/rds/send.c:976) [135546.078114] sock_sendmsg (net/socket.c:611 net/socket.c:620) [135546.078856] SYSC_sendto (net/socket.c:1657) [135546.079596] ? SYSC_connect (net/socket.c:1628) [135546.080510] ? trace_dump_stack (kernel/trace/trace.c:1926) [135546.081397] ? ring_buffer_unlock_commit (kernel/trace/ring_buffer.c:2479 kernel/trace/ring_buffer.c:2558 kernel/trace/ring_buffer.c:2674) [135546.082390] ? trace_buffer_unlock_commit (kernel/trace/trace.c:1749) [135546.083410] ? trace_event_raw_event_sys_enter (include/trace/events/syscalls.h:16) [135546.084481] ? do_audit_syscall_entry (include/trace/events/syscalls.h:16) [135546.085438] ? trace_buffer_unlock_commit (kernel/trace/trace.c:1749) [135546.085515] rds_ib_laddr_check(): addr 36.74.25.172 ret -99 node type -1 Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-09Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull inifiniband/rdma updates from Doug Ledford: "This is a fairly sizeable set of changes. I've put them through a decent amount of testing prior to sending the pull request due to that. There are still a few fixups that I know are coming, but I wanted to go ahead and get the big, sizable chunk into your hands sooner rather than waiting for those last few fixups. Of note is the fact that this creates what is intended to be a temporary area in the drivers/staging tree specifically for some cleanups and additions that are coming for the RDMA stack. We deprecated two drivers (ipath and amso1100) and are waiting to hear back if we can deprecate another one (ehca). We also put Intel's new hfi1 driver into this area because it needs to be refactored and a transfer library created out of the factored out code, and then it and the qib driver and the soft-roce driver should all be modified to use that library. I expect drivers/staging/rdma to be around for three or four kernel releases and then to go away as all of the work is completed and final deletions of deprecated drivers are done. Summary of changes for 4.3: - Create drivers/staging/rdma - Move amso1100 driver to staging/rdma and schedule for deletion - Move ipath driver to staging/rdma and schedule for deletion - Add hfi1 driver to staging/rdma and set TODO for move to regular tree - Initial support for namespaces to be used on RDMA devices - Add RoCE GID table handling to the RDMA core caching code - Infrastructure to support handling of devices with differing read and write scatter gather capabilities - Various iSER updates - Kill off unsafe usage of global mr registrations - Update SRP driver - Misc mlx4 driver updates - Support for the mr_alloc verb - Support for a netlink interface between kernel and user space cache daemon to speed path record queries and route resolution - Ininitial support for safe hot removal of verbs devices" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (136 commits) IB/ipoib: Suppress warning for send only join failures IB/ipoib: Clean up send-only multicast joins IB/srp: Fix possible protection fault IB/core: Move SM class defines from ib_mad.h to ib_smi.h IB/core: Remove unnecessary defines from ib_mad.h IB/hfi1: Add PSM2 user space header to header_install IB/hfi1: Add CSRs for CONFIG_SDMA_VERBOSITY mlx5: Fix incorrect wc pkey_index assignment for GSI messages IB/mlx5: avoid destroying a NULL mr in reg_user_mr error flow IB/uverbs: reject invalid or unknown opcodes IB/cxgb4: Fix if statement in pick_local_ip6adddrs IB/sa: Fix rdma netlink message flags IB/ucma: HW Device hot-removal support IB/mlx4_ib: Disassociate support IB/uverbs: Enable device removal when there are active user space applications IB/uverbs: Explicitly pass ib_dev to uverbs commands IB/uverbs: Fix race between ib_uverbs_open and remove_one IB/uverbs: Fix reference counting usage of event files IB/core: Make ib_dealloc_pd return void IB/srp: Create an insecure all physical rkey only if needed ...
2015-09-08net: tipc: fix stall during bclink wakeup procedureKolmakov Dmitriy
If an attempt to wake up users of broadcast link is made when there is no enough place in send queue than it may hang up inside the tipc_sk_rcv() function since the loop breaks only after the wake up queue becomes empty. This can lead to complete CPU stall with the following message generated by RCU: INFO: rcu_sched self-detected stall on CPU { 0} (t=2101 jiffies g=54225 c=54224 q=11465) Task dump for CPU 0: tpch R running task 0 39949 39948 0x0000000a ffffffff818536c0 ffff88181fa037a0 ffffffff8106a4be 0000000000000000 ffffffff818536c0 ffff88181fa037c0 ffffffff8106d8a8 ffff88181fa03800 0000000000000001 ffff88181fa037f0 ffffffff81094a50 ffff88181fa15680 Call Trace: <IRQ> [<ffffffff8106a4be>] sched_show_task+0xae/0x120 [<ffffffff8106d8a8>] dump_cpu_task+0x38/0x40 [<ffffffff81094a50>] rcu_dump_cpu_stacks+0x90/0xd0 [<ffffffff81097c3b>] rcu_check_callbacks+0x3eb/0x6e0 [<ffffffff8106e53f>] ? account_system_time+0x7f/0x170 [<ffffffff81099e64>] update_process_times+0x34/0x60 [<ffffffff810a84d1>] tick_sched_handle.isra.18+0x31/0x40 [<ffffffff810a851c>] tick_sched_timer+0x3c/0x70 [<ffffffff8109a43d>] __run_hrtimer.isra.34+0x3d/0xc0 [<ffffffff8109aa95>] hrtimer_interrupt+0xc5/0x1e0 [<ffffffff81030d52>] ? native_smp_send_reschedule+0x42/0x60 [<ffffffff81032f04>] local_apic_timer_interrupt+0x34/0x60 [<ffffffff810335bc>] smp_apic_timer_interrupt+0x3c/0x60 [<ffffffff8165a3fb>] apic_timer_interrupt+0x6b/0x70 [<ffffffff81659129>] ? _raw_spin_unlock_irqrestore+0x9/0x10 [<ffffffff8107eb9f>] __wake_up_sync_key+0x4f/0x60 [<ffffffffa313ddd1>] tipc_write_space+0x31/0x40 [tipc] [<ffffffffa313dadf>] filter_rcv+0x31f/0x520 [tipc] [<ffffffffa313d699>] ? tipc_sk_lookup+0xc9/0x110 [tipc] [<ffffffff81659259>] ? _raw_spin_lock_bh+0x19/0x30 [<ffffffffa314122c>] tipc_sk_rcv+0x2dc/0x3e0 [tipc] [<ffffffffa312e7ff>] tipc_bclink_wakeup_users+0x2f/0x40 [tipc] [<ffffffffa313ce26>] tipc_node_unlock+0x186/0x190 [tipc] [<ffffffff81597c1c>] ? kfree_skb+0x2c/0x40 [<ffffffffa313475c>] tipc_rcv+0x2ac/0x8c0 [tipc] [<ffffffffa312ff58>] tipc_l2_rcv_msg+0x38/0x50 [tipc] [<ffffffff815a76d3>] __netif_receive_skb_core+0x5a3/0x950 [<ffffffff815a98d3>] __netif_receive_skb+0x13/0x60 [<ffffffff815a993e>] netif_receive_skb_internal+0x1e/0x90 [<ffffffff815aa138>] napi_gro_receive+0x78/0xa0 [<ffffffffa07f93f4>] tg3_poll_work+0xc54/0xf40 [tg3] [<ffffffff81597c8c>] ? consume_skb+0x2c/0x40 [<ffffffffa07f9721>] tg3_poll_msix+0x41/0x160 [tg3] [<ffffffff815ab0f2>] net_rx_action+0xe2/0x290 [<ffffffff8104b92a>] __do_softirq+0xda/0x1f0 [<ffffffff8104bc26>] irq_exit+0x76/0xa0 [<ffffffff81004355>] do_IRQ+0x55/0xf0 [<ffffffff8165a12b>] common_interrupt+0x6b/0x6b <EOI> The issue occurs only when tipc_sk_rcv() is used to wake up postponed senders: tipc_bclink_wakeup_users() // wakeupq - is a queue which consists of special // messages with SOCK_WAKEUP type. tipc_sk_rcv(wakeupq) ... while (skb_queue_len(inputq)) { filter_rcv(skb) // Here the type of message is checked // and if it is SOCK_WAKEUP then // it tries to wake up a sender. tipc_write_space(sk) wake_up_interruptible_sync_poll() } After the sender thread is woke up it can gather control and perform an attempt to send a message. But if there is no enough place in send queue it will call link_schedule_user() function which puts a message of type SOCK_WAKEUP to the wakeup queue and put the sender to sleep. Thus the size of the queue actually is not changed and the while() loop never exits. The approach I proposed is to wake up only senders for which there is enough place in send queue so the described issue can't occur. Moreover the same approach is already used to wake up senders on unicast links. I have got into the issue on our product code but to reproduce the issue I changed a benchmark test application (from tipcutils/demos/benchmark) to perform the following scenario: 1. Run 64 instances of test application (nodes). It can be done on the one physical machine. 2. Each application connects to all other using TIPC sockets in RDM mode. 3. When setup is done all nodes start simultaneously send broadcast messages. 4. Everything hangs up. The issue is reproducible only when a congestion on broadcast link occurs. For example, when there are only 8 nodes it works fine since congestion doesn't occur. Send queue limit is 40 in my case (I use a critical importance level) and when 64 nodes send a message at the same moment a congestion occurs every time. Signed-off-by: Dmitry S Kolmakov <kolmakov.dmitriy@huawei.com> Reviewed-by: Jon Maloy <jon.maloy@ericsson.com> Acked-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-08net: bridge: remove unnecessary switchdev includeVivien Didelot
Remove the unnecessary switchdev.h include from br_netlink.c. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Acked-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-08net: bridge: check __vlan_vid_del for errorVivien Didelot
Since __vlan_del can return an error code, change its inner function __vlan_vid_del to return an eventual error from switchdev_port_obj_del. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Acked-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-07Merge tag 'nfs-for-4.3-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates from Trond Myklebust: "Highlights include: Stable patches: - Fix atomicity of pNFS commit list updates - Fix NFSv4 handling of open(O_CREAT|O_EXCL|O_RDONLY) - nfs_set_pgio_error sometimes misses errors - Fix a thinko in xs_connect() - Fix borkage in _same_data_server_addrs_locked() - Fix a NULL pointer dereference of migration recovery ops for v4.2 client - Don't let the ctime override attribute barriers. - Revert "NFSv4: Remove incorrect check in can_open_delegated()" - Ensure flexfiles pNFS driver updates the inode after write finishes - flexfiles must not pollute the attribute cache with attrbutes from the DS - Fix a protocol error in layoutreturn - Fix a protocol issue with NFSv4.1 CLOSE stateids Bugfixes + cleanups - pNFS blocks bugfixes from Christoph - Various cleanups from Anna - More fixes for delegation corner cases - Don't fsync twice for O_SYNC/IS_SYNC files - Fix pNFS and flexfiles layoutstats bugs - pnfs/flexfiles: avoid duplicate tracking of mirror data - pnfs: Fix layoutget/layoutreturn/return-on-close serialisation issues - pnfs/flexfiles: error handling retries a layoutget before fallback to MDS Features: - Full support for the OPEN NFS4_CREATE_EXCLUSIVE4_1 mode from Kinglong - More RDMA client transport improvements from Chuck - Removal of the deprecated ib_reg_phys_mr() and ib_rereg_phys_mr() verbs from the SUNRPC, Lustre and core infiniband tree. - Optimise away the close-to-open getattr if there is no cached data" * tag 'nfs-for-4.3-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (108 commits) NFSv4: Respect the server imposed limit on how many changes we may cache NFSv4: Express delegation limit in units of pages Revert "NFS: Make close(2) asynchronous when closing NFS O_DIRECT files" NFS: Optimise away the close-to-open getattr if there is no cached data NFSv4.1/flexfiles: Clean up ff_layout_write_done_cb/ff_layout_commit_done_cb NFSv4.1/flexfiles: Mark the layout for return in ff_layout_io_track_ds_error() nfs: Remove unneeded checking of the return value from scnprintf nfs: Fix truncated client owner id without proto type NFSv4.1/flexfiles: Mark layout for return if the mirrors are invalid NFSv4.1/flexfiles: RW layouts are valid only if all mirrors are valid NFSv4.1/flexfiles: Fix incorrect usage of pnfs_generic_mark_devid_invalid() NFSv4.1/flexfiles: Fix freeing of mirrors NFSv4.1/pNFS: Don't request a minimal read layout beyond the end of file NFSv4.1/pnfs: Handle LAYOUTGET return values correctly NFSv4.1/pnfs: Don't ask for a read layout for an empty file. NFSv4.1: Fix a protocol issue with CLOSE stateids NFSv4.1/flexfiles: Don't mark the entire deviceid as bad for file errors SUNRPC: Prevent SYN+SYNACK+RST storms SUNRPC: xs_reset_transport must mark the connection as disconnected NFSv4.1/pnfs: Ensure layoutreturn reserves space for the opaque payload ...
2015-09-06openvswitch: Remove conntrack Kconfig option.Joe Stringer
There's no particular desire to have conntrack action support in Open vSwitch as an independently configurable bit, rather just to ensure there is not a hard dependency. This exposed option doesn't accurately reflect the conntrack dependency when enabled, so simplify this by removing the option. Compile the support if NF_CONNTRACK is enabled. Fixes: 7f8a436eaa2c ("openvswitch: Add conntrack action") Signed-off-by: Joe Stringer <joestringer@nicira.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-06Merge tag 'mac80211-for-davem-2015-09-04' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211 Johannes Berg says: ==================== For the first round of fixes, we have this: * fix for the sizeof() pointer type issue * a fix for regulatory getting into a restore loop * a fix for rfkill global 'all' state, it needs to be stored everywhere to apply correctly to new rfkill instances * properly refuse CQM RSSI when it cannot actually be used * protect HT TDLS traffic properly in non-HT networks * don't incorrectly advertise 80 MHz support when not allowed ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-05RDS: rds_conn_lookup() should factor in the struct net for a matchSowmini Varadhan
Only return a conn if the rds_conn_net(conn) matches the struct net passed to rds_conn_lookup(). Fixes: 467fa15356ac ("RDS-TCP: Support multiple RDS-TCP listen endpoints, one per netns.") Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
