path: root/net
2010-12-02tcp: Add timewait recycling bits to ipv6 connect code.David S. Miller
This will also improve handling of ipv6 tcp socket request backlog when syncookies are not enabled. When backlog becomes very deep, last quarter of backlog is limited to validated destinations. Previously only ipv4 implemented this logic, but now ipv6 does too. Now we are only one step away from enabling timewait recycling for ipv6, and that step is simply filling in the implementation of tcp_v6_get_peer() and tcp_v6_tw_get_peer(). Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02ipv6: Create inet6_csk_route_req().David S. Miller
Brother of ipv4's inet_csk_route_req(). Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-01timewait_sock: Create and use getpeer op.David S. Miller
The only thing AF-specific about remembering the timestamp for a time-wait TCP socket is getting the peer. Abstract that behind a new timewait_sock_ops vector. Support for real IPV6 sockets is not filled in yet, but curiously this makes timewait recycling start to work for v4-mapped ipv6 sockets. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-01inetpeer: Kill use of inet_peer_address_t typedef.David S. Miller
They are verboten these days. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-01ipip: add module alias for tunl0 tunnel devicestephen hemminger
If ipip is built as a module the 'ip tunnel add' command would fail because the ipip module was not being autoloaded. Adding an alias for the tunl0 device name cause dev_load() to autoload it when needed. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-01gre: add module alias for gre0 tunnel devicestephen hemminger
If gre is built as a module the 'ip tunnel add' command would fail because the ip_gre module was not being autoloaded. Adding an alias for the gre0 device name cause dev_load() to autoload it when needed. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-01gre: minor cleanupsstephen hemminger
Use strcpy() rather the sprintf() for the case where name is getting generated. Fix indentation. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-01net sched: use xps information for qdisc NUMA affinityEric Dumazet
Allocate qdisc memory according to NUMA properties of cpus included in xps map. To be effective, qdisc should be (re)setup after changes of /sys/class/net/eth<n>/queues/tx-<n>/xps_cpus I added a numa_node field in struct netdev_queue, containing NUMA node if all cpus included in xps_cpus share same node, else -1. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Cc: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-30inet: Turn ->remember_stamp into ->get_peer in connection AF ops.David S. Miller
Then we can make a completely generic tcp_remember_stamp() that uses ->get_peer() as a helper, minimizing the AF specific code and minimizing the eventual code duplication when we implement the ipv6 side of TW recycling. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-30ipv6: Add infrastructure to bind inet_peer objects to routes.David S. Miller
They are only allowed on cached ipv6 routes. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-30inetpeer: Add v6 peers tree, abstract root properly.David S. Miller
Add the ipv6 peer tree instance, and adapt remaining direct references to 'v4_peers' as needed. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-30inetpeer: Abstract address comparisons.David S. Miller
Now v4 and v6 addresses will both work properly. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-30inetpeer: Make inet_getpeer() take an inet_peer_adress_t pointer.David S. Miller
And make an inet_getpeer_v4() helper, update callers. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-30inetpeer: Introduce inet_peer_address_t.David S. Miller
Currently only the v4 aspect is used, but this will change. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-30inetpeer: Abstract out the tree root accesses.David S. Miller
Instead of directly accessing "peer", change to code to operate using a "struct inet_peer_base *" pointer. This will facilitate the addition of a seperate tree for ipv6 peer entries. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2010-11-29xps: add __rcu annotationsEric Dumazet
Avoid sparse warnings : add __rcu annotations and use rcu_dereference_protected() where necessary. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29xps: NUMA allocations for per cpu dataEric Dumazet
store_xps_map() allocates maps that are used by single cpu, it makes sense to use NUMA allocations. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28xps: Add CONFIG_XPSTom Herbert
This patch adds XPS_CONFIG option to enable and disable XPS. This is done in the same manner as RPS_CONFIG. This is also fixes build failure in XPS code when SMP is not enabled. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28ipv6: Prepare the tree for un-inlined jhash.Jozsef Kadlecsik
jhash is widely used in the kernel and because the functions are inlined, the cost in size is significant. Also, the new jhash functions are slightly larger than the previous ones so better un-inline. As a preparation step, the calls to the internal macros are replaced with the plain jhash function calls. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28X25 remove bkl in call user data length ioctlandrew hendry
Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28X25 remove bkl from causediag ioctlsandrew hendry
2010-11-28X25 remove bkl from calluserdata ioctlsandrew hendry
2010-11-28X25 remove bkl in facility ioctlsandrew hendry
2010-11-28X25 remove bkl in subscription ioctlsandrew hendry
2010-11-288021q: vlan device is lockless do not transfer real_num_{tx|rx}_queuesJohn Fastabend
Now that the vlan device is lockless and single queue do not transfer the real num queues. This is causing a BUG_ON to occur. kernel BUG at net/8021q/vlan.c:345! Call Trace: [<ffffffff813fd6e8>] ? fib_rules_event+0x28/0x1b0 [<ffffffff814ad2b5>] notifier_call_chain+0x55/0x80 [<ffffffff81089156>] raw_notifier_call_chain+0x16/0x20 [<ffffffff813e5af7>] call_netdevice_notifiers+0x37/0x70 [<ffffffff813e6756>] netdev_features_change+0x16/0x20 [<ffffffffa02995be>] ixgbe_fcoe_enable+0xae/0x100 [ixgbe] [<ffffffffa01da06a>] vlan_dev_fcoe_enable+0x2a/0x30 [8021q] [<ffffffffa02d08c3>] fcoe_create+0x163/0x630 [fcoe] [<ffffffff811244d5>] ? mmap_region+0x255/0x5a0 [<ffffffff81080ef0>] param_attr_store+0x50/0x80 [<ffffffff810809b6>] module_attr_store+0x26/0x30 [<ffffffff811b9db2>] sysfs_write_file+0xf2/0x180 [<ffffffff8114fc88>] vfs_write+0xc8/0x190 [<ffffffff81150621>] sys_write+0x51/0x90 [<ffffffff8100c0b2>] system_call_fastpath+0x16/0x1b Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28net: add netif_tx_queue_frozen_or_stoppedEric Dumazet
When testing struct netdev_queue state against FROZEN bit, we also test XOFF bit. We can test both bits at once and save some cycles. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28ipv6: kill two unused macro definitionShan Wei
1. IPV6_TLV_TEL_DST_SIZE This has not been using for several years since created. 2. RT6_INFO_LEN commit 33120b30 kill all RT6_INFO_LEN's references, but only this definition remained. commit 33120b30cc3b8665204d4fcde7288638b0dd04d5 Author: Alexey Dobriyan <adobriyan@sw.ru> Date: Tue Nov 6 05:27:11 2007 -0800 [IPV6]: Convert /proc/net/ipv6_route to seq_file interface Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28net: add some KERN_CONT markers to continuation linesUwe Kleine-König
Cc: netdev@vger.kernel.org Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-27rtnl: make link af-specific updates atomicThomas Graf
As David pointed out correctly, updates to af-specific attributes are currently not atomic. If multiple changes are requested and one of them fails, previous updates may have been applied already leaving the link behind in a undefined state. This patch splits the function parse_link_af() into two functions validate_link_af() and set_link_at(). validate_link_af() is placed to validate_linkmsg() check for errors as early as possible before any changes to the link have been made. set_link_af() is called to commit the changes later. This method is not fail proof, while it is currently sufficient to make set_link_af() inerrable and thus 100% atomic, the validation function method will not be able to detect all error scenarios in the future, there will likely always be errors depending on states which are f.e. not protected by rtnl_mutex and thus may change between validation and setting. Also, instead of silently ignoring unknown address families and config blocks for address families which did not register a set function the errors EAFNOSUPPORT respectively EOPNOSUPPORT are returned to avoid comitting 4 out of 5 update requests without notifying the user. Signed-off-by: Thomas Graf <tgraf@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2010-11-24mac80211: implement packet loss notificationJohannes Berg
For drivers that have accurate TX status reporting we can report the number of consecutive lost packets to userspace using the new cfg80211 CQM event. The threshold is fixed right now, this may need to be improved in the future. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24cfg80211: allow using CQM event to notify packet lossJohannes Berg
This adds the ability for drivers to use CQM events to notify about packet loss for specific stations (which could be the AP for the managed mode case). Since the threshold might be determined by the driver (it isn't passed in right now) it will be passed out of the driver to userspace in the event. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24mac80211: avoid aggregation for VO trafficLuis R. Rodriguez
This should help with latency issues which can happen when using aggregation. Cc: Felix Fietkau <nbd@openwrt.org> Cc: Matt Smith <matt.smith@atheros.com> Cc: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24mac80211: reduce the number of retries for nullfunc probingFelix Fietkau
Since nullfunc frames are transmitted as unicast frames, they're more reliable than the broadcast probe requests, so we need fewer retries to figure out whether the AP is really gone. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24mac80211: use nullfunc instead of probe request for connection monitoringFelix Fietkau
nullfunc frames are better for connection monitoring, because probe requests are answered even if the AP has already dropped the connection, whereas nullfunc frames from an unassociated station will trigger a disassoc/deauth frame from the AP (WLAN_REASON_CLASS3_FRAME_FROM_NONASSOC_STA), which allows the station to reconnect immediately instead of waiting until it attempts to transmit the next unicast frame. This only works on hardware with reliable tx ACK reporting, any other hardware needs to fall back to the probe request method. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24cfg80211/mac80211: improve ad-hoc multicast rate handlingFelix Fietkau
- store the multicast rate as an index instead of the rate value (reduces cpu overhead in a hotpath) - validate the rate values (must match a bitrate in at least one sband) Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24mac80211: probe the AP when resumingFelix Fietkau
Check the connection by probing the AP (either using nullfunc or a probe request). If nullfunc probing is supported and the assoc is no longer valid, the AP will send a disassoc/deauth immediately. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24mac80211: calculate beacon loss time accuratelyFelix Fietkau
Instead of using a fixed 2 second timeout, calculate beacon loss interval from the advertised beacon interval and a frame count. With this beacon loss happens after N (default 7) consecutive frames are missed which for a typical setup (100TU beacon interval) is ~700ms (or ~1/3 previous). Signed-off-by: Sam Leffler <sleffler@chromium.org> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24mac80211: restart beacon miss timer on system resume from suspendFelix Fietkau
Signed-off-by: Paul Stewart <pstew@google.com> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24net/wireless: Use pr_<level> and netdev_<level>Joe Perches
No change in output for pr_<level> prefixes. netdev_<level> output is different, arguably improved. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24Revert "nl80211/mac80211: Report signal average"John W. Linville
This reverts commit 86107fd170bc379869250eb7e1bd393a3a70e8ae. This patch inadvertantly changed the userland ABI. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24xps: Transmit Packet SteeringTom Herbert
This patch implements transmit packet steering (XPS) for multiqueue devices. XPS selects a transmit queue during packet transmission based on configuration. This is done by mapping the CPU transmitting the packet to a queue. This is the transmit side analogue to RPS-- where RPS is selecting a CPU based on receive queue, XPS selects a queue based on the CPU (previously there was an XPS patch from Eric Dumazet, but that might more appropriately be called transmit completion steering). Each transmit queue can be associated with a number of CPUs which will use the queue to send packets. This is configured as a CPU mask on a per queue basis in: /sys/class/net/eth<n>/queues/tx-<n>/xps_cpus The mappings are stored per device in an inverted data structure that maps CPUs to queues. In the netdevice structure this is an array of num_possible_cpu structures where each structure holds and array of queue_indexes for queues which that CPU can use. The benefits of XPS are improved locality in the per queue data structures. Also, transmit completions are more likely to be done nearer to the sending thread, so this should promote locality back to the socket on free (e.g. UDP). The benefits of XPS are dependent on cache hierarchy, application load, and other factors. XPS would nominally be configured so that a queue would only be shared by CPUs which are sharing a cache, the degenerative configuration woud be that each CPU has it's own queue. Below are some benchmark results which show the potential benfit of this patch. The netperf test has 500 instances of netperf TCP_RR test with 1 byte req. and resp. bnx2x on 16 core AMD XPS (16 queues, 1 TX queue per CPU) 1234K at 100% CPU No XPS (16 queues) 996K at 100% CPU Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24xps: Improvements in TX queue selectionTom Herbert
In dev_pick_tx, don't do work in calculating queue index or setting the index in the sock unless the device has more than one queue. This allows the sock to be set only with a queue index of a multi-queue device which is desirable if device are stacked like in a tunnel. We also allow the mapping of a socket to queue to be changed. To maintain in order packet transmission a flag (ooo_okay) has been added to the sk_buff structure. If a transport layer sets this flag on a packet, the transmit queue can be changed for the socket. Presumably, the transport would set this if there was no possbility of creating OOO packets (for instance, there are no packets in flight for the socket). This patch includes the modification in TCP output for setting this flag. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24scm: lower SCM_MAX_FDEric Dumazet
Lower SCM_MAX_FD from 255 to 253 so that allocations for scm_fp_list are halved. (commit f8d570a4 added two pointers in this structure) scm_fp_dup() should not copy whole structure (and trigger kmemcheck warnings), but only the used part. While we are at it, only allocate needed size. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-24ipv6: mcast: RCU conversionEric Dumazet
ipv6_sk_mc_lock rwlock becomes a spinlock. readers (inet6_mc_check()) now takes rcu_read_lock() instead of read lock. Writers dont need to disable BH anymore. struct ipv6_mc_socklist objects are reclaimed after one RCU grace period. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-22mac80211: Disable hw crypto for GTKs on AP VLAN interfacesHelmut Schaa
When using AP VLAN interfaces, each VLAN interface should be in its own broadcast domain. Hostapd achieves this by assigning different GTKs to different AP VLAN interfaces. However, mac80211 drivers are not aware of AP VLAN interfaces and as such mac80211 sends the GTK to the driver in the context of the base AP mode interface. This causes problems when multiple AP VLAN interfaces are used since the driver will use the same key slot for the different GTKs (there's no way for the driver to distinguish the different GTKs from different AP VLAN interfaces). Thus, only the clients associated to one AP VLAN interface (the one that was created last) can actually use broadcast traffic. Fix this by not programming any GTKs for AP VLAN interfaces into the hw but fall back to using software crypto. The GTK for the underlying AP interface is still sent to the driver. That means, broadcast traffic to stations associated to an AP VLAN interface is encrypted in software whereas broadcast traffic to stations associated to the non-VLAN AP interface is encrypted in hardware. Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22cfg80211: Fix regulatory bug with multiple cards and delaysLuis R. Rodriguez
When two cards are connected with the same regulatory domain if CRDA had a delayed response then cfg80211's own set regulatory domain would still be the world regulatory domain. There was a bug on cfg80211's logic such that it assumed that once you pegged a request as the last request it was already the currently set regulatory domain. This would mean we would race setting a stale regulatory domain to secondary cards which had the same regulatory domain since the alpha2 would match. We fix this by processing each regulatory request atomically, and only move on to the next one once we get it fully processed. In the case CRDA is not present we will simply world roam. This issue is only present when you have a slow system and the CRDA processing is delayed. Because of this it is not a known regression. Without this fix when a delay is present with CRDA the second card would end up with an intersected regulatory domain and not allow it to use the channels it really is designed for. When two cards with two different regulatory domains were inserted you'd end up rejecting the second card's regulatory domain request. This fails with mac80211_hswim's regtest=2 (two requests, same alpha2) and regtest=3 (two requests, different alpha2) module parameter options. This was reproduced and tested against mac80211_hwsim using this CRDA delayer: #!/bin/bash echo $COUNTRY >> /tmp/log sleep 2 /sbin/crda.orig And these regulatory tests: modprobe mac80211_hwsim regtest=2 modprobe mac80211_hwsim regtest=3 Reported-by: Mark Mentovai <mark@moxienet.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Tested-by: Mark Mentovai <mark@moxienet.com> Tested-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22cfg80211: move mutex locking to reg_process_pending_hints()Luis R. Rodriguez
This will be required in the next patch and it makes the next patch easier to review. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Tested-by: Mark Mentovai <mark@moxienet.com> Tested-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
