Eliminate an argument in a print statement that has no corresponding
format specification.
Signed-off-by: Allan Stephens <allan.stephens@windriver.com>
Eliminate a field of the TIPC port structure that is populated,
but never referenced.
Aviod these link-time errors when IPV6=m, XT_TEE=y:
net/built-in.o: In function `tee_tg_route6':
xt_TEE.c:(.text+0x45ca5): undefined reference to `ip6_route_output'
net/built-in.o: In function `tee_tg6':
xt_TEE.c:(.text+0x45d79): undefined reference to `ip6_local_out'
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Documentation/feature-removal-schedule.txt
drivers/net/wireless/ath/ar9170/usb.c
drivers/scsi/iscsi_tcp.c
net/ipv4/ipmr.c
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
drivers/net/wireless/ath/ar9170/main.c
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
net: Fix FDDI and TR config checks in ipv4 arp and LLC.
IPv4: unresolved multicast route cleanup
mac80211: remove association work when processing deauth request
ar9170: wait for asynchronous firmware loading
ipv4: udp: fix short packet and bad checksum logging
phy: Fix initialization in micrel driver.
sctp: Fix a race between ICMP protocol unreachable and connect()
veth: Dont kfree_skb() after dev_forward_skb()
IPv6: fix IPV6_RECVERR handling of locally-generated errors
net/gianfar: drop recycled skbs on MTU change
iwlwifi: work around passive scan issue
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
Restore the rcu_dereference() calls in conntrack/expectation notifier
and logger registration/unregistration, but use the _protected variant,
which will be required by the upcoming __rcu annotations.
Based on patch by Eric Dumazet <eric.dumazet@gmail.com>
net/bridge/br_device.c
net/bridge/br_forward.c
[ INFO: suspicious rcu_dereference_check() usage. ]
include/net/netfilter/nf_conntrack_l3proto.h:92 invoked rcu_dereference_check()
without protection!
rcu_scheduler_active = 1, debug_locks = 0
2 locks held by iptables/3197:
#0: (sk_lock-AF_INET){+.+.+.}, at: [<ffffffff8149bd8c>]
ip_setsockopt+0x7c/0xa0
#1: (&xt[i].mutex){+.+.+.}, at: [<ffffffff8148a5fe>]
xt_find_table_lock+0x3e/0x110
stack backtrace:
Pid: 3197, comm: iptables Not tainted 2.6.34-rc4 #2
Call Trace:
[<ffffffff8105e2e8>] lockdep_rcu_dereference+0xb8/0xc0
[<ffffffff8147fb3b>] nf_ct_l3proto_module_put+0x6b/0x70
[<ffffffff8148d891>] state_mt_destroy+0x11/0x20
[<ffffffff814d3baf>] cleanup_match+0x2f/0x50
[<ffffffff814d3c63>] cleanup_entry+0x33/0x90
[<ffffffff814d5653>] ? __do_replace+0x1a3/0x210
[<ffffffff814d564c>] __do_replace+0x19c/0x210
[<ffffffff814d651a>] do_ipt_set_ctl+0x16a/0x1b0
[<ffffffff8147a610>] nf_sockopt+0x60/0xa0
The __nf_ct_l3proto_find() call doesn't actually need rcu read side
protection since the caller holds a reference to the protocol. Use
rcu_read_lock() anyways to avoid the warning.
Kernel bugzilla #15781: https://bugzilla.kernel.org/show_bug.cgi?id=15781
Reported-by: Christian Casteyde <casteyde.christian@free.fr>
Need to check both CONFIG_FOO and CONFIG_FOO_MODULE
Fixes the expiration timer for unresolved multicast route entries.
In case new multicast routing requests come in faster than the
expiration timeout occurs (e.g. zap through multicast TV streams), the
timer is prevented from being called at time for already existing entries.
As the single timer is resetted to default whenever a new entry is made,
the timeout for existing unresolved entires are missed and/or not
updated. As a consequence new requests are denied when the limit of
unresolved entries has been reached because old entries live longer than
they are supposed to.
The solution is to reset the timer only for the first unresolved entry
in the multicast routing cache. All other timers are already set and
updated correctly within the timer function itself by now.
Signed-off by: Andreas Meissner <andreas.meissner@sphairon.com>
There were some left-overs that used sk->sk_sleep instead of the new
sk_sleep() helper.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Use strict_strtoul as suggested by checkpatch.pl for more strict input
checking.
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Instead of having a global workqueue for all controllers, it makes
more sense to have a workqueue per controller.
On the receipt of an RR(P=1) under RemoteBusy set to TRUE(on the RECV
state table) we have to call sendIorRRorRNR(F=1) and just after set
RemoteBusy to False. This leads to a freeze in the sending process since
it's not allowed send data with RemoteBusy set to true and no one
call SendPending-I-Frames after set RemoteBusy to false(The last action
for that event).
Actually sendIorRRorRNR() calls SendPending-I-Frames but at that moment
RemoteBusy is still True and we cannot send any frame, after, no one
calls SendPending-I-Frames again and the sending process stops.
The solution here is to set RemoteBusy to false inside
SendPending-I-Frames just before call SendPending-I-Frames. That will
make SendPending-I-Frames able to send frames. This solution is similar
to what RR(P=0)(F=0) on the RECV table and RR(P=1) on the SREJ_SENT
table do.
Actually doesn't make any sense call SendPending-I-Frames if we can send
any frame, i. e., RemoteBusy is True.
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
The checks should be done before the the memcpy to avoid buffer
overflow.
Reported-by: João Paulo Rechi Vita <jprvita@profusion.mobi>
l2cap_ertm_send() can be called both from user context and bottom half
context. The socket locks for that contexts are different, the user
context uses a mutex(which can sleep) and the second one uses a
spinlock_bh. That creates a race condition when we have interruptions on
both contexts at the same time.
The better way to solve this is to add a new spinlock to lock
l2cap_ertm_send() and the vars it access. The other solution was to defer
l2cap_ertm_send() with a workqueue, but we the sending process already
has one defer on the hci layer. It's not a good idea add another one.
The patch refactor the code to create l2cap_retransmit_frames(), then we
encapulate the lock of l2cap_ertm_send() for some call. It also changes
l2cap_retransmit_frame() to l2cap_retransmit_one_frame() to avoid
confusion
Reviewed-by: João Paulo Rechi Vita <jprvita@profusion.mobi>
To guarantee that all packets we sent were received we need to wait for
theirs ack before shutdown the socket.
Supports Local Busy condition handling through a waitqueue that wake ups
each 200ms and try to push the packets to the upper layer. If it can
push all the queue then it leaves the Local Busy state.
The patch modifies the behaviour of l2cap_ertm_reassembly_sdu() to
support retry of the push operation.
Add checks for invalid tx_seq and fixes the duplicated tx_seq check.
Signed-off-by: João Paulo Rechi Vita <jprvita@profusion.mobi>
Acked-by: Gustavo F. Padovan <padovan@profusion.mobi>
There is a plenty of situation where ERTM shall close the channel, this
commit treats the cases regarding Invalid Frame Detection.
It create one reassembly SDU function for ERTM and other for Streaming
Mode to make the Invalid Frame Detection handling less complex.
Make the code flow cleaner and changes the function to void.
It also fixes a potential NULL dereference with skb.
hci_send_acl can't fail, so we can make it void. This patch changes
that and all the funcions that use hci_send_acl().
That change exposed a bug on sending connectionless data. We were not
reporting the lenght send back to the user space.
A spin_lock_init() call was missing. :)
F-bit set should be processed only if we are in the WAIT_F state.
Trivial clean up.
That action is not specified by the ERTM spec, so removing it.
We can set the SAR bits in the control field directly.
The code was reusing the control var without its reinitialization.
Add this check to getsockopt makes possible to fail early instead of
waiting until listen / connect.
if enable_ertm is true and we have SOCK_STREAM the default mode will be
ERTM, otherwise Basic Mode.
The L2CAP Extended Features are still unstable and under development,
so we are adding them under the EXPERIMENTAL flag to get more feedback
on them. L2CAP Extended Features includes the Enhanced Retransmission
and Streaming Modes, Frame Check Sequence (FCS), and Segmentation and
Reassemby (SAR).
When the I-frame received is the expected, i.e., its tx_seq is equal to
expected_tx_seq and we are under a SREJ, we can just add it to the tail
of the list. Doing that we change the complexity from O(n) to O(1).
l2cap_drop_acked_frames() was droping not sent packets, causing them to
be not transmitted.
The code was crashing due to a invalid access to hci_conn after the
channel disconnect.
If there is no frames to retransmit l2cap was crashing the kernel, now
we check if the queue is empty first.
With the sockopt extension we can set a per-channel MaxTx value.
Very useful for testing purposes.
[jprvita@profusion.mobi: improved parameter description]
Now that we can set the txWindow we need to change the acknowledgement
procedure to ack after each (pi->txWindow/6 + 1). The plus 1 is to avoid
the zero value.
It also renames pi->num_to_ack to a better name: pi->num_acked.
Now we can set/get Transmission Window size via sockopt.
As specified by Bluetooth 3.0 spec we shall send an acknowledgment using
the Send-Ack() after clear the SREJ list.
If the SDU size is greater than the MTU something is wrong, so report
an error.
[jprvita@profusion.mobi: set err to appropriate errno value]
Fix a possible problem with Big Endian machines.
We were accepting values bigger than we can accept. This was leading
ERTM to drop packets because of wrong FCS checks.
On Enhanced Retransmission Mode and Streaming Mode a entity can send, on
a successful Conf RSP, new values for the RFC fields. For example, the
entity can send txWindow and MPS values less than the value received on
a Conf REQ.
Tx Window value shall not be used with Streaming Mode and the receiver
of the config Request shall ignore its value.
