commit c2c77ec83bdad17fb688557b5b3fdc36661dd1c6 upstream.
Added very simple check that req buffer has enough space to
fit configuration parameters. Shall be enough to reject packets
with configuration size more than req buffer.
Crash trace below
[ 6069.659393] Unable to handle kernel paging request at virtual address 02000205
[ 6069.673034] Internal error: Oops: 805 [#1] PREEMPT
[ 6069.727172] PC is at l2cap_add_conf_opt+0x70/0xf0 [l2cap]
[ 6069.732604] LR is at l2cap_recv_frame+0x1350/0x2e78 [l2cap]
[ 6070.030303] Backtrace:
[ 6070.032806] [<bf1c2880>] (l2cap_add_conf_opt+0x0/0xf0 [l2cap]) from
[<bf1c6624>] (l2cap_recv_frame+0x1350/0x2e78 [l2cap])
[ 6070.043823] r8:dc5d3100 r7:df2a91d6 r6:00000001 r5:df2a8000 r4:00000200
[ 6070.050659] [<bf1c52d4>] (l2cap_recv_frame+0x0/0x2e78 [l2cap]) from
[<bf1c8408>] (l2cap_recv_acldata+0x2bc/0x350 [l2cap])
[ 6070.061798] [<bf1c814c>] (l2cap_recv_acldata+0x0/0x350 [l2cap]) from
[<bf0037a4>] (hci_rx_task+0x244/0x478 [bluetooth])
[ 6070.072631] r6:dc647700 r5:00000001 r4:df2ab740
[ 6070.077362] [<bf003560>] (hci_rx_task+0x0/0x478 [bluetooth]) from
[<c006b9fc>] (tasklet_action+0x78/0xd8)
[ 6070.087005] [<c006b984>] (tasklet_action+0x0/0xd8) from [<c006c160>]
Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com>
Acked-by: Gustavo F. Padovan <gustavo@padovan.org>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 101545f6fef4a0a3ea8daf0b5b880df2c6a92a69 upstream.
When creating a high number of Bluetooth sockets (L2CAP, SCO
and RFCOMM) it is possible to scribble repeatedly on arbitrary
pages of memory. Ensure that the content of these sysfs files is
always less than one page. Even if this means truncating. The
files in question are scheduled to be moved over to debugfs in
the future anyway.
Based on initial patches from Neil Brown and Linus Torvalds
Reported-by: Neil Brown <neilb@suse.de>
[ Upstream commit 28b2774a0d5852236dab77a4147b8b88548110f1 ]
Commit 4957faad (TCPCT part 1g: Responder Cookie => Initiator), part
of TCP_COOKIE_TRANSACTION implementation, forgot to correctly size
synack skb in case user data must be included.
Many thanks to Mika Pentillä for spotting this error.
Reported-by: Penttillä Mika <mika.penttila@ixonos.com>
[ Upstream commit b634f87522dff87712df8bda2a6c9061954d552a ]
Fixes kernel bugzilla #15541
[ Upstream commit 6830c25b7d08fbbd922959425193791bc42079f2 ]
A packet is marked as lost in case packets == 0, although nothing should be done.
This results in a too early retransmitted packet during recovery in some cases.
This small patch fixes this issue by returning immediately.
Signed-off-by: Lennart Schulte <lennart.schulte@nets.rwth-aachen.de>
Signed-off-by: Arnd Hannemann <hannemann@nets.rwth-aachen.de>
[ Upstream commit 0641e4fbf2f824faee00ea74c459a088d94905fd ]
When doing "ifenslave -d bond0 eth0", there is chance to get NULL
dereference in netif_receive_skb(), because dev->master suddenly becomes
NULL after we tested it.
We should use ACCESS_ONCE() to avoid this (or rcu_dereference())
[ Upstream commit 37b7ef7203240b3aba577bb1ff6765fe15225976 ]
This patch fixes a bug that allows to lose events when reliable
event delivery mode is used, ie. if NETLINK_BROADCAST_SEND_ERROR
and NETLINK_RECV_NO_ENOBUFS socket options are set.
[ Upstream commit 1a50307ba1826e4da0024e64b245ce4eadf7688a ]
Currently, ENOBUFS errors are reported to the socket via
netlink_set_err() even if NETLINK_RECV_NO_ENOBUFS is set. However,
that should not happen. This fixes this problem and it changes the
prototype of netlink_set_err() to return the number of sockets that
have set the NETLINK_RECV_NO_ENOBUFS socket option. This return
value is used in the next patch in these bugfix series.
[ Upstream commit 73852e8151b7d7a529fbe019ab6d2d0c02d8f3f2 ]
Under NET_DMA, data transfer can grind to a halt when userland issues a
large read on a socket with a high RCVLOWAT (i.e., 512 KB for both).
This appears to be because the NET_DMA design queues up lots of memcpy
operations, but doesn't issue or wait for them (and thus free the
associated skbs) until it is time for tcp_recvmesg() to return.
The socket hangs when its TCP window goes to zero before enough data is
available to satisfy the read.
Periodically issue asynchronous memcpy operations, and free skbs for ones
that have completed, to prevent sockets from going into zero-window mode.
Signed-off-by: Steven J. Magnani <steve@digidescorp.com>
[ Upstream commit 54c1a859efd9fd6cda05bc700315ba2519c14eba ]
This is ipv6 variant of the commit 5e016cbf6.. ("ipv4: Don't drop
redirected route cache entry unless PTMU actually expired")
by Guenter Roeck <guenter.roeck@ericsson.com>.
Remove cache route entry in ipv6_negative_advice() only if
the timer is expired.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[ Upstream commit 5e016cbf6cffd4a53b7922e0c91b775399d7fe47 ]
TCP sessions over IPv4 can get stuck if routers between endpoints
do not fragment packets but implement PMTU instead, and we are using
those routers because of an ICMP redirect.
Setup is as follows
MTU1 MTU2 MTU1
A--------B------C------D
with MTU1 > MTU2. A and D are endpoints, B and C are routers. B and C
implement PMTU and drop packets larger than MTU2 (for example because
DF is set on all packets). TCP sessions are initiated between A and D.
There is packet loss between A and D, causing frequent TCP
retransmits.
After the number of retransmits on a TCP session reaches tcp_retries1,
tcp calls dst_negative_advice() prior to each retransmit. This results
in route cache entries for the peer to be deleted in
ipv4_negative_advice() if the Path MTU is set.
If the outstanding data on an affected TCP session is larger than
MTU2, packets sent from the endpoints will be dropped by B or C, and
ICMP NEEDFRAG will be returned. A and D receive NEEDFRAG messages and
update PMTU.
Before the next retransmit, tcp will again call dst_negative_advice(),
causing the route cache entry (with correct PMTU) to be deleted. The
retransmitted packet will be larger than MTU2, causing it to be
dropped again.
This sequence repeats until the TCP session aborts or is terminated.
Problem is fixed by removing redirected route cache entries in
ipv4_negative_advice() only if the PMTU is expired.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
[ Upstream commit d11a4dc18bf41719c9f0d7ed494d295dd2973b92 ]
Xfrm_dst keeps a reference to ipv4 rtable entries on each
cached bundle. The only way to renew xfrm_dst when the underlying
route has changed, is to implement dst_check for this. This is
what ipv6 side does too.
The problems started after 87c1e12b5eeb7b30b4b41291bef8e0b41fc3dde9
("ipsec: Fix bogus bundle flowi") which fixed a bug causing xfrm_dst
to not get reused, until that all lookups always generated new
xfrm_dst with new route reference and path mtu worked. But after the
fix, the old routes started to get reused even after they were expired
causing pmtu to break (well it would occationally work if the rtable
gc had run recently and marked the route obsolete causing dst_check to
get called).
Signed-off-by: Timo Teras <timo.teras@iki.fi>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
[ Upstream commit 87c1e12b5eeb7b30b4b41291bef8e0b41fc3dde9 ]
When I merged the bundle creation code, I introduced a bogus
flowi value in the bundle. Instead of getting from the caller,
it was instead set to the flow in the route object, which is
totally different.
The end result is that the bundles we created never match, and
we instead end up with an ever growing bundle list.
Thanks to Jamal for find this problem.
Reported-by: Jamal Hadi Salim <hadi@cyberus.ca>
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
Acked-by: Jamal Hadi Salim <hadi@cyberus.ca>
[ Upstream commit 243aad830e8a4cdda261626fbaeddde16b08d04a ]
Taking route's header_len into account, and updating gre device
needed_headroom will give better hints on upper bound of required
headroom. This is useful if the gre traffic is xfrm'ed.
[ Upstream commit a3a858ff18a72a8d388e31ab0d98f7e944841a62 ]
sk_add_backlog -> __sk_add_backlog
sk_add_backlog_limited -> sk_add_backlog
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
[ Upstream commit 2499849ee8f513e795b9f2c19a42d6356e4943a4 ]
Make x25 adapt to the limited socket backlog change.
Cc: Andrew Hendry <andrew.hendry@gmail.com>
[ Upstream commit 53eecb1be5ae499d399d2923933937a9ea1a284f ]
Make tipc adapt to the limited socket backlog change.
Cc: Jon Maloy <jon.maloy@ericsson.com>
Cc: Allan Stephens <allan.stephens@windriver.com>
Acked-by: Allan Stephens <allan.stephens@windriver.com>
[ Upstream commit 50b1a782f845140f4138f14a1ce8a4a6dd0cc82f ]
Make sctp adapt to the limited socket backlog change.
Cc: Vlad Yasevich <vladislav.yasevich@hp.com>
Cc: Sridhar Samudrala <sri@us.ibm.com>
[ Upstream commit 79545b681961d7001c1f4c3eb9ffb87bed4485db ]
Make llc adapt to the limited socket backlog change.
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit 55349790d7cbf0d381873a7ece1dcafcffd4aaa9 ]
Make udp adapt to the limited socket backlog change.
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: "Pekka Savola (ipv6)" <pekkas@netcore.fi>
Cc: Patrick McHardy <kaber@trash.net>
[ Upstream commit 6b03a53a5ab7ccf2d5d69f96cf1c739c4d2a8fb9 ]
Make tcp adapt to the limited socket backlog change.
[ Upstream commit 8eae939f1400326b06d0c9afe53d2a484a326871 ]
We got system OOM while running some UDP netperf testing on the loopback
device. The case is multiple senders sent stream UDP packets to a single
receiver via loopback on local host. Of course, the receiver is not able
to handle all the packets in time. But we surprisingly found that these
packets were not discarded due to the receiver's sk->sk_rcvbuf limit.
Instead, they are kept queuing to sk->sk_backlog and finally ate up all
the memory. We believe this is a secure hole that a none privileged user
can crash the system.
The root cause for this problem is, when the receiver is doing
__release_sock() (i.e. after userspace recv, kernel udp_recvmsg ->
skb_free_datagram_locked -> release_sock), it moves skbs from backlog to
sk_receive_queue with the softirq enabled. In the above case, multiple
busy senders will almost make it an endless loop. The skbs in the
backlog end up eat all the system memory.
The issue is not only for UDP. Any protocols using socket backlog is
potentially affected. The patch adds limit for socket backlog so that
the backlog size cannot be expanded endlessly.
Reported-by: Alex Shi <alex.shi@intel.com>
[ Upstream commit 858a18a6a2f74e8f0e5b2e9671d4b74694aba708 ]
route: Fix caught BUG_ON during rt_secret_rebuild_oneshot()
Call rt_secret_rebuild can cause BUG_ON(timer_pending(&net->ipv4.rt_secret_timer)) in
add_timer as there is not any synchronization for call rt_secret_rebuild_oneshot()
for the same net namespace.
Also this issue affects to rt_secret_reschedule().
Thus use mod_timer enstead.
Signed-off-by: Vitaliy Gusev <vgusev@openvz.org>
commit 375177bf35efc08e1bd37bbda4cc0c8cc4db8500 upstream.
Even if the null data frame is not acked by the AP, mac80211
goes into power save. This might lead to loss of frames
from the AP.
Prevent this by restarting dynamic_ps_timer when ack is not
received for null data frames.
Cc: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Vivek Natarajan <vnatarajan@atheros.com>
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
commit ef1691504c83ba3eb636c0cfd3ed33f7a6d0b4ee upstream.
Commit 8ccb92ad (netfilter: xt_recent: fix false match) fixed supposedly
false matches in rules using a zero hit_count. As it turns out there is
nothing false about these matches and people are actually using entries
with a hit_count of zero to make rules dependant on addresses inserted
manually through /proc.
Since this slipped past the eyes of three reviewers, instead of
reverting the commit in question, this patch explicitly checks
for a hit_count of zero to make the intentions more clear.
Reported-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
Tested-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
commit f1f0abe192a72e75d7c59972e30784d043fd8d73 upstream.
__rpc_lookup_create() can return ERR_PTR(-ENOMEM).
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit cdead7cf12896c0e50a8be2e52de52c364603095 upstream.
The function alloc_enc_pages() currently fails to release the pointer
rqstp->rq_enc_pages in the error path.
Acked-by: J. Bruce Fields <bfields@citi.umich.edu>
commit 301e99ce4a2f42a317129230fd42e6cd874c64b0 upstream.
One the changes in commit d7979ae4a "svc: Move close processing to a
single place" is:
err_delete:
- svc_delete_socket(svsk);
+ set_bit(SK_CLOSE, &svsk->sk_flags);
return -EAGAIN;
This is insufficient. The recvfrom methods must always call
svc_xprt_received on completion so that the socket gets re-queued if
there is any more work to do. This particular path did not make that
call because it actually destroyed the svsk, making requeue pointless.
When the svc_delete_socket was change to just set a bit, we should have
added a call to svc_xprt_received,
This is the problem that b0401d7253 attempted to fix, incorrectly.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
commit 1b644b6e6f6160ae35ce4b52c2ca89ed3e356e18 upstream.
This reverts commit b0401d725334a94d57335790b8ac2404144748ee, which
moved svc_delete_xprt() outside of XPT_BUSY, and allowed it to be called
after svc_xpt_recived(), removing its last reference and destroying it
after it had already been queued for future processing.
commit f5822754ea006563e1bf0a1f43faaad49c0d8bb2 upstream.
This reverts commit b292cf9ce70d221c3f04ff62db5ab13d9a249ca8. The
commit that it attempted to patch up,
b0401d725334a94d57335790b8ac2404144748ee, was fundamentally wrong, and
will also be reverted.
commit 4fa004373133ece3d9b1c0a7e243b0e53760b165 upstream.
Handling HT configuration changes involved setting the channel
with the new HT parameters and then issuing a rate_update()
notification to the driver.
This behavior changed after the off-channel changes. Now, the channel
is not updated with the new HT params in enable_ht() - instead, it
is now done when the scan work terminates. This results in the driver
depending on stale information, defaulting to non-HT mode always.
Fix this by passing the new channel type to the driver.
Signed-off-by: Sujith <Sujith.Manoharan@atheros.com>
commit 9fcfe0c83c3b04a759cde6b8c5f961237f17808b upstream.
This can, for instance, happen if the user specifies a link local IPv6
address.
commit ab1b18f70a007ea6caeb007d269abb75b131a410 upstream.
The 'struct svc_deferred_req's on the xpt_deferred queue do not
own a reference to the owning xprt. This is seen in svc_revisit
which is where things are added to this queue. dr->xprt is set to
NULL and the reference to the xprt it put.
So when this list is cleaned up in svc_delete_xprt, we mustn't
put the reference.
Also, replace the 'for' with a 'while' which is arguably
simpler and more likely to compile efficiently.
Cc: Tom Tucker <tom@opengridcomputing.com>
Signed-off-by: NeilBrown <neilb@suse.de>
commit 3f0e0b220f80075ce15483b20458192c0ac27426 upstream.
If frames are transmitted on 4-addr ap vlan interfaces with no station,
they end up being transmitted unencrypted, even if the ap interface
uses WPA. This patch add some sanity checking to make sure that this
does not happen.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit 8ccb92ad41cb311e52ad1b1fe77992c7f47a3b63 upstream.
A rule with a zero hit_count will always match.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit 2c08522e5d2f0af2d6f05be558946dcbf8173683 upstream.
e->index overflows e->stamps[] every ip_pkt_list_tot packets.
Consider the case when ip_pkt_list_tot==1; the first packet received is stored
in e->stamps[0] and e->index is initialized to 1. The next received packet
timestamp is then stored at e->stamps[1] in recent_entry_update(),
a buffer overflow because the maximum e->stamps[] index is 0.
commit 76dadd76c265a0cdb5a76aa4eef03fcc9639b388 upstream.
We use scm_send and scm_recv on both unix domain and
netlink sockets, but only unix domain sockets support
everything required for file descriptor passing,
so error if someone attempts to pass file descriptors
over netlink sockets.
commit e15276a4b220c54db665cf46a92bd9ceb9aeb052 upstream.
The current mac80211 implementation enables power save if there
is no Tx traffic for a specific timeout. Hence, PS is triggered
even if there is a continuous Rx only traffic(like UDP) going on.
This makes the drivers to wait on the tim bit in the next beacon
to awake which leads to redundant sleep-wake cycles.
Fix this by restarting the dynamic ps timer on receiving every
data packet.
commit 3dc1de0bf23816ed557ac8addf680cd5ee57e805 upstream.
Make addba_resp_timer aware the HT_AGG_STATE_REQ_STOP_BA_MSK mask
so that when ___ieee80211_stop_tx_ba_session() is issued the timer
will quit. Otherwise when suspend happens before the timer expired,
the timer handler will be called immediately after resume and
messes up driver status.
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Traffic (tcp) doesnot start on a vlan interface when gro is enabled.
Even the tcp handshake was not taking place.
This is because, the eth_type_trans call before the netif_receive_skb
in napi_gro_finish() resets the skb->dev to napi->dev from the previously
set vlan netdev interface. This causes the ip_route_input to drop the
incoming packet considering it as a packet coming from a martian source.
I could repro this on 2.6.32.7 (stable) and 2.6.33-rc7.
With this fix, the traffic starts and the test runs fine on both vlan
and non-vlan interfaces.
CC: Herbert Xu <herbert@gondor.apana.org.au>
CC: Patrick McHardy <kaber@trash.net>
Signed-off-by: Ajit Khaparde <ajitk@serverengines.com>
The wireless sysfs methods like the rest of the networking sysfs
methods are removed with the rtnl_lock held and block until
the existing methods stop executing. So use rtnl_trylock
and restart_syscall so that the code continues to work.
Yuck. It turns out that when we restart sysctls we were restarting
with the values already changed. Which unfortunately meant that
the second time through we thought there was no change and skipped
all kinds of work, despite the fact that there was indeed a change.
I have fixed this the simplest way possible by restoring the changed
values when we restart the sysctl write.
One of my coworkers spotted this bug when after disabling forwarding
on an interface pings were still forwarded.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (22 commits)
be2net: set proper value to version field in req hdr
xfrm: Fix xfrm_state_clone leak
ipcomp: Avoid duplicate calls to ipcomp_destroy
ethtool: allow non-admin user to read GRO settings.
ixgbe: fix WOL register setup for 82599
ixgbe: Fix - Do not allow Rx FC on 82598 at 1G due to errata
sfc: Fix SFE4002 initialisation
mac80211: fix handling of null-rate control in rate_control_get_rate
inet: Remove bogus IGMPv3 report handling
iwlwifi: fix AMSDU Rx after paged Rx patch
tcp: fix ICMP-RTO war
via-velocity: Fix races on shared interrupts
via-velocity: Take spinlock on set coalesce
via-velocity: Remove unused IRQ status parameter from rx_srv and tx_srv
rtl8187: Add new device ID
iwmc3200wifi: Test of wrong pointer after kzalloc in iwm_mlme_update_bss_table()
ath9k: Fix sequence numbers for PAE frames
mac80211: fix deferred hardware scan requests
iwlwifi: Fix to set correct ht configuration
mac80211: Fix probe request filtering in IBSS mode
xfrm_state_clone calls kfree instead of xfrm_state_put to free
a failed state. Depending on the state of the failed state, it
can cause leaks to things like module references.
All states should be freed by xfrm_state_put past the point of
xfrm_init_state.
When ipcomp_tunnel_attach fails we will call ipcomp_destroy twice.
This may lead to double-frees on certain structures.
As there is no reason to explicitly call ipcomp_destroy, this patch
removes it from ipcomp*.c and lets the standard xfrm_state destruction
take place.
This is based on the discovery and patch by Alexey Dobriyan.
Tested-by: Alexey Dobriyan <adobriyan@gmail.com>
Looks like an oversight in GRO design.
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6
For hardware with IEEE80211_HW_HAS_RATE_CONTROL the rate controller is not
initialized. However, calling functions such as ieee80211_beacon_get result
in the rate_control_get_rate function getting called, which is accessing
(in this case uninitialized) rate control structures unconditionally.
Fix by exiting the function before setting the rates for HW with
IEEE80211_HW_HAS_RATE_CONTROL set. The initialization of the ieee80211_tx_info
struct is intentionally still executed.
Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com>
Reviewed-by: Kalle Valo <kalle.valo@nokia.com>
Cc: stable@kernel.org
Currently we treat IGMPv3 reports as if it were an IGMPv2/v1 report.
This is broken as IGMPv3 reports are formatted differently. So we
end up suppressing a bogus multicast group (which should be harmless
as long as the leading reserved field is zero).
In fact, IGMPv3 does not allow membership report suppression so
we should simply ignore IGMPv3 membership reports as a host.
This patch does exactly that. I kept the case statement for it
so people won't accidentally add it back thinking that we overlooked
this case.
Make sure, that TCP has a nonzero RTT estimation after three-way
handshake. Currently, a listening TCP has a value of 0 for srtt,
rttvar and rto right after the three-way handshake is completed
with TCP timestamps disabled.
This will lead to corrupt RTO recalculation and retransmission
flood when RTO is recalculated on backoff reversion as introduced
in "Revert RTO on ICMP destination unreachable"
(f1ecd5d9e7366609d640ff4040304ea197fbc618).
This behaviour can be provoked by connecting to a server which
"responds first" (like SMTP) and rejecting every packet after
the handshake with dest-unreachable, which will lead to softirq
load on the server (up to 30% per socket in some tests).
Thanks to Ilpo Jarvinen for providing debug patches and to
Denys Fedoryshchenko for reporting and testing.
Changes since v3: Removed bad characters in patchfile.
Reported-by: Denys Fedoryshchenko <denys@visp.net.lb>
Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de>
