* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
BKL: introduce CONFIG_BKL.
dabusb: remove the BKL
sunrpc: remove the big kernel lock
init/main.c: remove BKL notations
blktrace: remove the big kernel lock
rtmutex-tester: make it build without BKL
dvb-core: kill the big kernel lock
dvb/bt8xx: kill the big kernel lock
tlclk: remove big kernel lock
fix rawctl compat ioctls breakage on amd64 and itanic
uml: kill big kernel lock
parisc: remove big kernel lock
cris: autoconvert trivial BKL users
alpha: kill big kernel lock
isapnp: BKL removal
s390/block: kill the big kernel lock
hpet: kill BKL, add compat_ioctl
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (29 commits)
sched: Export account_system_vtime()
sched: Call tick_check_idle before __irq_enter
sched: Remove irq time from available CPU power
sched: Do not account irq time to current task
x86: Add IRQ_TIME_ACCOUNTING
sched: Add IRQ_TIME_ACCOUNTING, finer accounting of irq time
sched: Add a PF flag for ksoftirqd identification
sched: Consolidate account_system_vtime extern declaration
sched: Fix softirq time accounting
sched: Drop group_capacity to 1 only if local group has extra capacity
sched: Force balancing on newidle balance if local group has capacity
sched: Set group_imb only a task can be pulled from the busiest cpu
sched: Do not consider SCHED_IDLE tasks to be cache hot
sched: Drop all load weight manipulation for RT tasks
sched: Create special class for stop/migrate work
sched: Unindent labels
sched: Comment updates: fix default latency and granularity numbers
tracing/sched: Add sched_pi_setprio tracepoint
sched: Give CPU bound RT tasks preference
sched: Try not to migrate higher priority RT tasks
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (163 commits)
tracing: Fix compile issue for trace_sched_wakeup.c
[S390] hardirq: remove pointless header file includes
[IA64] Move local_softirq_pending() definition
perf, powerpc: Fix power_pmu_event_init to not use event->ctx
ftrace: Remove recursion between recordmcount and scripts/mod/empty
jump_label: Add COND_STMT(), reducer wrappery
perf: Optimize sw events
perf: Use jump_labels to optimize the scheduler hooks
jump_label: Add atomic_t interface
jump_label: Use more consistent naming
perf, hw_breakpoint: Fix crash in hw_breakpoint creation
perf: Find task before event alloc
perf: Fix task refcount bugs
perf: Fix group moving
irq_work: Add generic hardirq context callbacks
perf_events: Fix transaction recovery in group_sched_in()
perf_events: Fix bogus AMD64 generic TLB events
perf_events: Fix bogus context time tracking
tracing: Remove parent recording in latency tracer graph options
tracing: Use one prologue for the preempt irqs off tracer function tracers
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (52 commits)
sched: fix RCU lockdep splat from task_group()
rcu: using ACCESS_ONCE() to observe the jiffies_stall/rnp->qsmask value
sched: suppress RCU lockdep splat in task_fork_fair
net: suppress RCU lockdep false positive in sock_update_classid
rcu: move check from rcu_dereference_bh to rcu_read_lock_bh_held
rcu: Add advice to PROVE_RCU_REPEATEDLY kernel config parameter
rcu: Add tracing data to support queueing models
rcu: fix sparse errors in rcutorture.c
rcu: only one evaluation of arg in rcu_dereference_check() unless sparse
kernel: Remove undead ifdef CONFIG_DEBUG_LOCK_ALLOC
rcu: fix _oddness handling of verbose stall warnings
rcu: performance fixes to TINY_PREEMPT_RCU callback checking
rcu: upgrade stallwarn.txt documentation for CPU-bound RT processes
vhost: add __rcu annotations
rcu: add comment stating that list_empty() applies to RCU-protected lists
rcu: apply TINY_PREEMPT_RCU read-side speedup to TREE_PREEMPT_RCU
rcu: combine duplicate code, courtesy of CONFIG_PREEMPT_RCU
rcu: Upgrade srcu_read_lock() docbook about SRCU grace periods
rcu: document ways of stalling updates in low-memory situations
rcu: repair code-duplication FIXMEs
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (26 commits)
selinux: include vmalloc.h for vmalloc_user
secmark: fix config problem when CONFIG_NF_CONNTRACK_SECMARK is not set
selinux: implement mmap on /selinux/policy
SELinux: allow userspace to read policy back out of the kernel
SELinux: drop useless (and incorrect) AVTAB_MAX_SIZE
SELinux: deterministic ordering of range transition rules
kernel: roundup should only reference arguments once
kernel: rounddown helper function
secmark: export secctx, drop secmark in procfs
conntrack: export lsm context rather than internal secid via netlink
security: secid_to_secctx returns len when data is NULL
secmark: make secmark object handling generic
secmark: do not return early if there was no error
AppArmor: Ensure the size of the copy is < the buffer allocated to hold it
TOMOYO: Print URL information before panic().
security: remove unused parameter from security_task_setscheduler()
tpm: change 'tpm_suspend_pcr' to be module parameter
selinux: fix up style problem on /selinux/status
selinux: change to new flag variable
selinux: really fix dependency causing parallel compile failure.
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (22 commits)
ceph: do not carry i_lock for readdir from dcache
fs/ceph/xattr.c: Use kmemdup
rbd: passing wrong variable to bvec_kunmap_irq()
rbd: null vs ERR_PTR
ceph: fix num_pages_free accounting in pagelist
ceph: add CEPH_MDS_OP_SETDIRLAYOUT and associated ioctl.
ceph: don't crash when passed bad mount options
ceph: fix debugfs warnings
block: rbd: removing unnecessary test
block: rbd: fixed may leaks
ceph: switch from BKL to lock_flocks()
ceph: preallocate flock state without locks held
ceph: add pagelist_reserve, pagelist_truncate, pagelist_set_cursor
ceph: use mapping->nrpages to determine if mapping is empty
ceph: only invalidate on check_caps if we actually have pages
ceph: do not hide .snap in root directory
rbd: introduce rados block device (rbd), based on libceph
ceph: factor out libceph from Ceph file system
ceph-rbd: osdc support for osd call and rollback operations
ceph: messenger and osdc changes for rbd
With all the patches we have queued in the BKL removal tree, only a
few dozen modules are left that actually rely on the BKL, and even
there are lots of low-hanging fruit. We need to decide what to do
about them, this patch illustrates one of the options:
Every user of the BKL is marked as 'depends on BKL' in Kconfig,
and the CONFIG_BKL becomes a user-visible option. If it gets
disabled, no BKL using module can be built any more and the BKL
code itself is compiled out.
The one exception is file locking, which is practically always
enabled and does a 'select BKL' instead. This effectively forces
CONFIG_BKL to be enabled until we have solved the fs/lockd
mess and can apply the patch that removes the BKL from fs/locks.c.
When CONFIG_NF_CONNTRACK_SECMARK is not set we accidentally attempt to use
the secmark fielf of struct nf_conn. Problem is when that config isn't set
the field doesn't exist. whoops. Wrap the incorrect usage in the config.
Signed-off-by: Eric Paris <eparis@redhat.com>
Signed-off-by: James Morris <jmorris@namei.org>
The current secmark code exports a secmark= field which just indicates if
there is special labeling on a packet or not. We drop this field as it
isn't particularly useful and instead export a new field secctx= which is
the actual human readable text label.
Acked-by: Patrick McHardy <kaber@trash.net>
The conntrack code can export the internal secid to userspace. These are
dynamic, can change on lsm changes, and have no meaning in userspace. We
should instead be sending lsm contexts to userspace instead. This patch sends
the secctx (rather than secid) to userspace over the netlink socket. We use a
new field CTA_SECCTX and stop using the the old CTA_SECMARK field since it did
not send particularly useful information.
Reviewed-by: Paul Moore <paul.moore@hp.com>
Right now secmark has lots of direct selinux calls. Use all LSM calls and
remove all SELinux specific knowledge. The only SELinux specific knowledge
we leave is the mode. The only point is to make sure that other LSMs at
least test this generic code before they assume it works. (They may also
have to make changes if they do not represent labels as strings)
Acked-by: Paul Moore <paul.moore@hp.com>
Commit 4a5a5c73 attempted to pass decent error messages back to userspace for
netfilter errors. In xt_SECMARK.c however the patch screwed up and returned
on 0 (aka no error) early and didn't finish setting up secmark. This results
in a kernel BUG if you use SECMARK.
Decrement the free page counter when removing a page from the free_list.
Signed-off-by: Sage Weil <sage@newdream.net>
This only happened when parse_extra_token was not passed
to ceph_parse_option() (hence, only happened in rbd).
Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net>
These facilitate preallocation of pages so that we can encode into the pagelist
in an atomic context.
Signed-off-by: Greg Farnum <gregf@hq.newdream.net>
The rados block device (rbd), based on osdblk, creates a block device
that is backed by objects stored in the Ceph distributed object storage
cluster. Each device consists of a single metadata object and data
striped over many data objects.
The rbd driver supports read-only snapshots.
This factors out protocol and low-level storage parts of ceph into a
separate libceph module living in net/ceph and include/linux/ceph. This
is mostly a matter of moving files around. However, a few key pieces
of the interface change as well:
- ceph_client becomes ceph_fs_client and ceph_client, where the latter
captures the mon and osd clients, and the fs_client gets the mds client
and file system specific pieces.
- Mount option parsing and debugfs setup is correspondingly broken into
two pieces.
- The mon client gets a generic handler callback for otherwise unknown
messages (mds map, in this case).
- The basic supported/required feature bits can be expanded (and are by
ceph_fs_client).
No functional change, aside from some subtle error handling cases that got
cleaned up in the refactoring process.
The sunrpc cache_ioctl function does not need the big kernel lock
because it uses its own queue_lock already.
rpc_pipe_ioctl apparently should be using i_lock like the other
operations on the pipe file descriptor do.
Peter Zijlstra found a bug in the way softirq time is accounted in
VIRT_CPU_ACCOUNTING on this thread:
http://lkml.indiana.edu/hypermail//linux/kernel/1009.2/01366.html
The problem is, softirq processing uses local_bh_disable internally. There
is no way, later in the flow, to differentiate between whether softirq is
being processed or is it just that bh has been disabled. So, a hardirq when bh
is disabled results in time being wrongly accounted as softirq.
Looking at the code a bit more, the problem exists in !VIRT_CPU_ACCOUNTING
as well. As account_system_time() in normal tick based accouting also uses
softirq_count, which will be set even when not in softirq with bh disabled.
Peter also suggested solution of using 2*SOFTIRQ_OFFSET as irq count
for local_bh_{disable,enable} and using just SOFTIRQ_OFFSET while softirq
processing. The patch below does that and adds API in_serving_softirq() which
returns whether we are currently processing softirq or not.
Also changes one of the usages of softirq_count in net/sched/cls_cgroup.c
to in_serving_softirq.
Looks like many usages of in_softirq really want in_serving_softirq. Those
changes can be made individually on a case by case basis.
Signed-off-by: Venkatesh Pallipadi <venki@google.com>
LKML-Reference: <1286237003-12406-2-git-send-email-venki@google.com>
Don't try to "optimize" rds_page_copy_user() by using kmap_atomic() and
the unsafe atomic user mode accessor functions. It's actually slower
than the straightforward code on any reasonable modern CPU.
Back when the code was written (although probably not by the time it was
actually merged, though), 32-bit x86 may have been the dominant
architecture. And there kmap_atomic() can be a lot faster than kmap()
(unless you have very good locality, in which case the virtual address
caching by kmap() can overcome all the downsides).
But these days, x86-64 may not be more populous, but it's getting there
(and if you care about performance, it's definitely already there -
you'd have upgraded your CPU's already in the last few years). And on
x86-64, the non-kmap_atomic() version is faster, simply because the code
is simpler and doesn't have the "re-try page fault" case.
People with old hardware are not likely to care about RDS anyway, and
the optimization for the 32-bit case is simply buggy, since it doesn't
verify the user addresses properly.
Reported-by: Dan Rosenberg <drosenberg@vsecurity.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Cc: stable@kernel.org
Several other ethtool functions leave heap uncleared (potentially) by
drivers. Some interfaces appear safe (eeprom, etc), in that the sizes
are well controlled. In some situations (e.g. unchecked error conditions),
the heap will remain unchanged in areas before copying back to userspace.
Note that these are less of an issue since these all require CAP_NET_ADMIN.
Signed-off-by: Kees Cook <kees.cook@canonical.com>
Acked-by: Ben Hutchings <bhutchings@solarflare.com>
Stanse found that mpc_push frees skb and then it dereferences it. It
is a typo, new_skb should be dereferenced there.
Calling ETHTOOL_GRXCLSRLALL with a large rule_cnt will allocate kernel
heap without clearing it. For the one driver (niu) that implements it,
it will leave the unused portion of heap unchanged and copy the full
contents back to userspace.
arch/x86/kernel/module.c
Merge reason: Resolve the conflict, pick up fixes.
> [ INFO: suspicious rcu_dereference_check() usage. ]
> include/linux/cgroup.h:542 invoked rcu_dereference_check() without protection!
> other info that might help us debug this:
> rcu_scheduler_active = 1, debug_locks = 0
> 1 lock held by swapper/1:
> #0: (net_mutex){+.+.+.}, at: [<ffffffff813e9010>]
> register_pernet_subsys+0x1f/0x47
> stack backtrace:
> Pid: 1, comm: swapper Not tainted 2.6.35.4-28.fc14.x86_64 #1
> Call Trace:
> [<ffffffff8107bd3a>] lockdep_rcu_dereference+0xaa/0xb3
> [<ffffffff813e04b9>] sock_update_classid+0x7c/0xa2
> [<ffffffff813e054a>] sk_alloc+0x6b/0x77
> [<ffffffff8140b281>] __netlink_create+0x37/0xab
> [<ffffffff813f941c>] ? rtnetlink_rcv+0x0/0x2d
> [<ffffffff8140cee1>] netlink_kernel_create+0x74/0x19d
> [<ffffffff8149c3ca>] ? __mutex_lock_common+0x339/0x35b
> [<ffffffff813f7e9c>] rtnetlink_net_init+0x2e/0x48
> [<ffffffff813e8d7a>] ops_init+0xe9/0xff
> [<ffffffff813e8f0d>] register_pernet_operations+0xab/0x130
> [<ffffffff813e901f>] register_pernet_subsys+0x2e/0x47
> [<ffffffff81db7bca>] rtnetlink_init+0x53/0x102
> [<ffffffff81db835c>] netlink_proto_init+0x126/0x143
> [<ffffffff81db8236>] ? netlink_proto_init+0x0/0x143
> [<ffffffff810021b8>] do_one_initcall+0x72/0x186
> [<ffffffff81d78ebc>] kernel_init+0x23b/0x2c9
> [<ffffffff8100aae4>] kernel_thread_helper+0x4/0x10
> [<ffffffff8149e2d0>] ? restore_args+0x0/0x30
> [<ffffffff81d78c81>] ? kernel_init+0x0/0x2c9
> [<ffffffff8100aae0>] ? kernel_thread_helper+0x0/0x10
The sock_update_classid() function calls task_cls_classid(current),
but the calling task cannot go away, so there is no danger of
the associated structures disappearing. Insert an RCU read-side
critical section to suppress the false positive.
Reported-by: Subrata Modak <subrata@linux.vnet.ibm.com>
This reverts commit 5ed3bc7288487bd4f891f420a07319e0b538b4fe.
It turns-out that not all drivers are calling ieee80211_tx_status from a
compatible context. Revert this for now and try again later...
git://git.kernel.org/pub/scm/linux/kernel/git/padovan/bluetooth-2.6
Merge reason: Update from -rc3 to -rc7.
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/rcu
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
We never delete the addBA response timer, which
is typically fine, but if the station it belongs
to is deleted very quickly after starting the BA
session, before the peer had a chance to reply,
the timer may fire after the station struct has
been freed already. Therefore, we need to delete
the timer in a suitable spot -- best when the
session is being stopped (which will happen even
then) in which case the delete will be a no-op
most of the time.
I've reproduced the scenario and tested the fix.
This fixes the crash reported at
http://mid.gmane.org/4CAB6F96.6090701@candelatech.com
Reported-by: Ben Greear <greearb@candelatech.com>
caif_connect() might dereference a netdevice after dev_put() it.
It also doesnt check dev_get_by_index() return value and could
dereference a NULL pointer.
Fix it, using RCU to avoid taking a reference.
CC: Sjur Braendeland <sjur.brandeland@stericsson.com>
skb_headroom() is unsigned so "skb_headroom(skb) + toff" is also
unsigned and can't be less than zero. This test was added in 66d50d25:
"u32: negative offset fix" It was supposed to fix a regression.
L2CAP doesn't permit change like MTU, FCS, TxWindow values while the
connection is alive, we can only set that before the
connection/configuration process. That can lead to bugs in the L2CAP
operation.
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
vlan: dont drop packets from unknown vlans in promiscuous mode
Phonet: Correct header retrieval after pskb_may_pull
um: Proper Fix for f25c80a4: remove duplicate structure field initialization
ip_gre: Fix dependencies wrt. ipv6.
net-2.6: SYN retransmits: Add new parameter to retransmits_timed_out()
iwl3945: queue the right work if the scan needs to be aborted
mac80211: fix use-after-free
The sctp_asoc_get_hmac() function iterates through a peer's hmac_ids
array and attempts to ensure that only a supported hmac entry is
returned. The current code fails to do this properly - if the last id
in the array is out of range (greater than SCTP_AUTH_HMAC_ID_MAX), the
id integer remains set after exiting the loop, and the address of an
out-of-bounds entry will be returned and subsequently used in the parent
function, causing potentially ugly memory corruption. This patch resets
the id integer to 0 on encountering an invalid id so that NULL will be
returned after finishing the loop if no valid ids are found.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Two user-controlled allocations in SCTP are subsequently dereferenced as
sockaddr structs, without checking if the dereferenced struct members fall
beyond the end of the allocated chunk. There doesn't appear to be any
information leakage here based on how these members are used and
additional checking, but it's still worth fixing.
[akpm@linux-foundation.org: remove unfashionable newlines, fix gmail tab->space conversion]
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
A recent patch to allow IGMPv2 responses to IGMPv3 queries
bypasses length checks for valid query lengths, incorrectly
resets the v2_seen timer, and does not support IGMPv1.
The following patch responds with a v2 report as required
by IGMPv2 while correcting the other problems introduced
by the patch.
Signed-Off-By: David L Stevens <dlstevens@us.ibm.com>
This reverts commit e81963b180ac502fda0326edf059b1e29cdef1a2.
LRO is now deprecated in favour of GRO, and only a few drivers use it,
so it is desirable to build it as a module in distribution kernels.
The original change to prevent building it as a module was made in an
attempt to avoid the case where some dependents are set to y and some
to m, and INET_LRO can be set to m rather than y. However, the
Kconfig system will reliably set INET_LRO=y in this case.
This patch fixes the condition (3rd arg) passed to sk_wait_event() in
sk_stream_wait_memory(). The incorrect check in sk_stream_wait_memory()
causes the following soft lockup in tcp_sendmsg() when the global tcp
memory pool has exhausted.
>>> snip <<<
localhost kernel: BUG: soft lockup - CPU#3 stuck for 11s! [sshd:6429]
localhost kernel: CPU 3:
localhost kernel: RIP: 0010:[sk_stream_wait_memory+0xcd/0x200] [sk_stream_wait_memory+0xcd/0x200] sk_stream_wait_memory+0xcd/0x200
localhost kernel:
localhost kernel: Call Trace:
localhost kernel: [sk_stream_wait_memory+0x1b1/0x200] sk_stream_wait_memory+0x1b1/0x200
localhost kernel: [<ffffffff802557c0>] autoremove_wake_function+0x0/0x40
localhost kernel: [ipv6:tcp_sendmsg+0x6e6/0xe90] tcp_sendmsg+0x6e6/0xce0
localhost kernel: [sock_aio_write+0x126/0x140] sock_aio_write+0x126/0x140
localhost kernel: [xfs:do_sync_write+0xf1/0x130] do_sync_write+0xf1/0x130
localhost kernel: [hrtimer_start+0xe3/0x170] hrtimer_start+0xe3/0x170
localhost kernel: [vfs_write+0x185/0x190] vfs_write+0x185/0x190
localhost kernel: [sys_write+0x50/0x90] sys_write+0x50/0x90
localhost kernel: [system_call+0x7e/0x83] system_call+0x7e/0x83
>>> snip <<<
What is happening is, that the sk_wait_event() condition passed from
sk_stream_wait_memory() evaluates to true for the case of tcp global memory
exhaustion. This is because both sk_stream_memory_free() and vm_wait are true
which causes sk_wait_event() to *not* call schedule_timeout().
Hence sk_stream_wait_memory() returns immediately to the caller w/o sleeping.
This causes the caller to again try allocation, which again fails and again
calls sk_stream_wait_memory(), and so on.
[ Bug introduced by commit c1cbe4b7ad0bc4b1d98ea708a3fecb7362aa4088
("[NET]: Avoid atomic xchg() for non-error case") -DaveM ]
Signed-off-by: Nagendra Singh Tomar <tomer_iisc@yahoo.com>
Signed-off-by: Maciej Żenczykowski <maze@google.com>
Roger Luethi noticed packets for unknown VLANs getting silently dropped
even in promiscuous mode.
Check for promiscuous mode in __vlan_hwaccel_rx() and vlan_gro_common()
before drops.
As suggested by Patrick, mark such packets to have skb->pkt_type set to
PACKET_OTHERHOST to make sure they are dropped by IP stack.
Reported-by: Roger Luethi <rl@hellgate.ch>
CC: Patrick McHardy <kaber@trash.net>
This reverts commit 8cb8e6f1684be13b51f8429b15f39c140326b327.
That commit introduced a regression with the Bluetooth Profile Tuning
Suite(PTS), Reverting this make sure that L2CAP is in a qualificable
state.
When receiving a rfcomm connection with the old dund deamon a
inconsistent lock state happens. That's because interrupts were already
disabled by l2cap_conn_start() when rfcomm_sk_state_change() try to lock
the spin_lock.
As result we may have a inconsistent lock state for l2cap_conn_start()
after rfcomm_sk_state_change() calls bh_lock_sock() and disable interrupts
as well.
[ 2833.151999]
[ 2833.151999] =================================
[ 2833.151999] [ INFO: inconsistent lock state ]
[ 2833.151999] 2.6.36-rc3 #2
[ 2833.151999] ---------------------------------
[ 2833.151999] inconsistent {IN-SOFTIRQ-W} -> {SOFTIRQ-ON-W} usage.
[ 2833.151999] krfcommd/2306 [HC0[0]:SC0[0]:HE1:SE1] takes:
[ 2833.151999] (slock-AF_BLUETOOTH){+.?...}, at: [<ffffffffa00bcb56>] rfcomm_sk_state_change+0x46/0x170 [rfcomm]
[ 2833.151999] {IN-SOFTIRQ-W} state was registered at:
[ 2833.151999] [<ffffffff81094346>] __lock_acquire+0x5b6/0x1560
[ 2833.151999] [<ffffffff8109534a>] lock_acquire+0x5a/0x70
[ 2833.151999] [<ffffffff81392b6c>] _raw_spin_lock+0x2c/0x40
[ 2833.151999] [<ffffffffa00a5092>] l2cap_conn_start+0x92/0x640 [l2cap]
[ 2833.151999] [<ffffffffa00a6a3f>] l2cap_sig_channel+0x6bf/0x1320 [l2cap]
[ 2833.151999] [<ffffffffa00a9173>] l2cap_recv_frame+0x133/0x770 [l2cap]
[ 2833.151999] [<ffffffffa00a997b>] l2cap_recv_acldata+0x1cb/0x390 [l2cap]
[ 2833.151999] [<ffffffffa000db4b>] hci_rx_task+0x2ab/0x450 [bluetooth]
[ 2833.151999] [<ffffffff8106b22b>] tasklet_action+0xcb/0xe0
[ 2833.151999] [<ffffffff8106b91e>] __do_softirq+0xae/0x150
[ 2833.151999] [<ffffffff8102bc0c>] call_softirq+0x1c/0x30
[ 2833.151999] [<ffffffff8102ddb5>] do_softirq+0x75/0xb0
[ 2833.151999] [<ffffffff8106b56d>] irq_exit+0x8d/0xa0
[ 2833.151999] [<ffffffff8104484b>] smp_apic_timer_interrupt+0x6b/0xa0
[ 2833.151999] [<ffffffff8102b6d3>] apic_timer_interrupt+0x13/0x20
[ 2833.151999] [<ffffffff81029dfa>] cpu_idle+0x5a/0xb0
[ 2833.151999] [<ffffffff81381ded>] rest_init+0xad/0xc0
[ 2833.151999] [<ffffffff817ebc4d>] start_kernel+0x2dd/0x2e8
[ 2833.151999] [<ffffffff817eb2e6>] x86_64_start_reservations+0xf6/0xfa
[ 2833.151999] [<ffffffff817eb3ce>] x86_64_start_kernel+0xe4/0xeb
[ 2833.151999] irq event stamp: 731
[ 2833.151999] hardirqs last enabled at (731): [<ffffffff8106b762>] local_bh_enable_ip+0x82/0xe0
[ 2833.151999] hardirqs last disabled at (729): [<ffffffff8106b93e>] __do_softirq+0xce/0x150
[ 2833.151999] softirqs last enabled at (730): [<ffffffff8106b96e>] __do_softirq+0xfe/0x150
[ 2833.151999] softirqs last disabled at (711): [<ffffffff8102bc0c>] call_softirq+0x1c/0x30
[ 2833.151999]
[ 2833.151999] other info that might help us debug this:
[ 2833.151999] 2 locks held by krfcommd/2306:
[ 2833.151999] #0: (rfcomm_mutex){+.+.+.}, at: [<ffffffffa00bb744>] rfcomm_run+0x174/0xb20 [rfcomm]
[ 2833.151999] #1: (&(&d->lock)->rlock){+.+...}, at: [<ffffffffa00b9223>] rfcomm_dlc_accept+0x53/0x100 [rfcomm]
[ 2833.151999]
[ 2833.151999] stack backtrace:
[ 2833.151999] Pid: 2306, comm: krfcommd Tainted: G W 2.6.36-rc3 #2
[ 2833.151999] Call Trace:
[ 2833.151999] [<ffffffff810928e1>] print_usage_bug+0x171/0x180
[ 2833.151999] [<ffffffff810936c3>] mark_lock+0x333/0x400
[ 2833.151999] [<ffffffff810943ca>] __lock_acquire+0x63a/0x1560
[ 2833.151999] [<ffffffff810948b5>] ? __lock_acquire+0xb25/0x1560
[ 2833.151999] [<ffffffffa00bcb56>] ? rfcomm_sk_state_change+0x46/0x170 [rfcomm]
[ 2833.151999] [<ffffffffa00bcb56>] rfcomm_sk_state_change+0x46/0x170 [rfcomm]
[ 2833.151999] [<ffffffffa00b9239>] rfcomm_dlc_accept+0x69/0x100 [rfcomm]
[ 2833.151999] [<ffffffffa00b9a49>] rfcomm_check_accept+0x59/0xd0 [rfcomm]
[ 2833.151999] [<ffffffffa00bacab>] rfcomm_recv_frame+0x9fb/0x1320 [rfcomm]
[ 2833.151999] [<ffffffff813932bb>] ? _raw_spin_unlock_irqrestore+0x3b/0x60
[ 2833.151999] [<ffffffff81093acd>] ? trace_hardirqs_on_caller+0x13d/0x180
[ 2833.151999] [<ffffffff81093b1d>] ? trace_hardirqs_on+0xd/0x10
[ 2833.151999] [<ffffffffa00bb7f1>] rfcomm_run+0x221/0xb20 [rfcomm]
[ 2833.151999] [<ffffffff813905e7>] ? schedule+0x287/0x780
[ 2833.151999] [<ffffffffa00bb5d0>] ? rfcomm_run+0x0/0xb20 [rfcomm]
[ 2833.151999] [<ffffffff81081026>] kthread+0x96/0xa0
[ 2833.151999] [<ffffffff8102bb14>] kernel_thread_helper+0x4/0x10
[ 2833.151999] [<ffffffff813936bc>] ? restore_args+0x0/0x30
[ 2833.151999] [<ffffffff81080f90>] ? kthread+0x0/0xa0
[ 2833.151999] [<ffffffff8102bb10>] ? kernel_thread_helper+0x0/0x10
As we don't have any error control on the Streaming mode, i.e., we don't
need to keep a copy of the skb for later resending we don't need to
call skb_clone() on it.
Then we can go one further here, and dequeue the skb before sending it,
that also means we don't need to look to sk->sk_send_head anymore.
The patch saves memory and time when sending Streaming mode data, so
it is good to mainline.
When receiving L2CAP negative configuration response with respect
to MTU parameter we modify wrong field. MTU here means proposed
value of MTU that the remote device intends to transmit. So for local
L2CAP socket it is pi->imtu.
Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com>
Acked-by: Ville Tervo <ville.tervo@nokia.com>
This fixes a bug which caused the FCS setting to show L2CAP_FCS_CRC16
with L2CAP modes other than ERTM or streaming. At present, this only
affects the FCS value shown with getsockopt() for basic mode.
Signed-off-by: Mat Martineau <mathewm@codeaurora.org>
Retrieve the header after doing pskb_may_pull since, pskb_may_pull
could change the buffer structure.
This is based on the comment given by Eric Dumazet on Phonet
Pipe controller patch for a similar problem.
Signed-off-by: Kumar Sanghvi <kumar.sanghvi@stericsson.com>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com>
