path: root/net
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27sctp: convert to idr_alloc()Tejun Heo
Convert to the much saner new idr interface. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Cc: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27mac80211: convert to idr_alloc()Tejun Heo
Convert to the much saner new idr interface. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27net/9p: convert to idr_alloc()Tejun Heo
Convert to the much saner new idr interface. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) ping_err() ICMP error handler looks at wrong ICMP header, from Li Wei. 2) TCP socket hash function on ipv6 is too weak, from Eric Dumazet. 3) netif_set_xps_queue() forgets to drop mutex on errors, fix from Alexander Duyck. 4) sum_frag_mem_limit() can deadlock due to lack of BH disabling, fix from Eric Dumazet. 5) TCP SYN data is miscalculated in tcp_send_syn_data(), because the amount of TCP option space was not taken into account properly in this code path. Fix from yuchung Cheng. 6) MLX4 driver allocates device queues with the wrong size, from Kleber Sacilotto. 7) sock_diag can access past the end of the sock_diag_handlers[] array, from Mathias Krause. 8) vlan_set_encap_proto() makes incorrect assumptions about where skb->data points, rework the logic so that it works regardless of where skb->data happens to be. From Jesse Gross. 9) Fix gianfar build failure with NET_POLL enabled, from Paul Gortmaker. 10) Fix Ipv4 ID setting and checksum calculations in GRE driver, from Pravin B Shelar. 11) bgmac driver does: int i; for (i = 0; ...; ...) { ... for (i = 0; ...; ...) { effectively corrupting the outer loop index, use a seperate variable for the inner loops. From Rafał Miłecki. 12) Fix suspend bugs in smsc95xx driver, from Ming Lei. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (35 commits) usbnet: smsc95xx: rename FEATURE_AUTOSUSPEND usbnet: smsc95xx: fix broken runtime suspend usbnet: smsc95xx: fix suspend failure bgmac: fix indexing of 2nd level loops b43: Fix lockdep splat on module unload Revert "ip_gre: propogate target device GSO capability to the tunnel device" IP_GRE: Fix GRE_CSUM case. VXLAN: Use tunnel_ip_select_ident() for tunnel IP-Identification. IP_GRE: Fix IP-Identification. net/pasemi: Fix missing coding style vmxnet3: fix ethtool ring buffer size setting vmxnet3: make local function static bnx2x: remove dead code and make local funcs static gianfar: fix compile fail for NET_POLL=y due to struct packing vlan: adjust vlan_set_encap_proto() for its callers sock_diag: Simplify sock_diag_handlers[] handling in __sock_diag_rcv_msg sock_diag: Fix out-of-bounds access to sock_diag_handlers[] vxlan: remove depends on CONFIG_EXPERIMENTAL mlx4_en: fix allocation of CPU affinity reverse-map mlx4_en: fix allocation of device tx_cq ...
2013-02-26Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull infiniband update from Roland Dreier: "Main batch of InfiniBand/RDMA changes for 3.9: - SRP error handling fixes from Bart Van Assche - Implementation of memory windows for mlx4 from Shani Michaeli - Lots of cxgb4 HW driver fixes from Vipul Pandya - Make iSER work for virtual functions, other fixes from Or Gerlitz - Fix for bug in qib HW driver from Mike Marciniszyn - IPoIB fixes from me, Itai Garbi, Shlomo Pongratz, Yan Burman - Various cleanups and warning fixes from Julia Lawall, Paul Bolle, Wei Yongjun" * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (41 commits) IB/mlx4: Advertise MW support IB/mlx4: Support memory window binding mlx4: Implement memory windows allocation and deallocation mlx4_core: Enable memory windows in {INIT, QUERY}_HCA mlx4_core: Disable memory windows for virtual functions IPoIB: Free ipoib neigh on path record failure so path rec queries are retried IB/srp: Fail I/O requests if the transport is offline IB/srp: Avoid endless SCSI error handling loop IB/srp: Avoid sending a task management function needlessly IB/srp: Track connection state properly IB/mlx4: Remove redundant NULL check before kfree IB/mlx4: Fix compiler warning about uninitialized 'vlan' variable IB/mlx4: Convert is_xxx variables in build_mlx_header() to bool IB/iser: Enable iser when FMRs are not supported IB/iser: Avoid error prints on EAGAIN registration failures IB/iser: Use proper define for the commands per LUN value advertised to SCSI ML IB/uverbs: Implement memory windows support in uverbs IB/core: Add "type 2" memory windows support mlx4_core: Propagate MR deregistration failures to caller mlx4_core: Rename MPT-related functions to have mpt_ prefix ...
2013-02-26Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: "This is fairly big pull by my standards as I had missed last merge window. So we have the support for device tree for slave-dmaengine, large updates to dw_dmac driver from Andy for reusing on different architectures. Along with this we have fixes on bunch of the drivers" Fix up trivial conflicts, usually due to #include line movement next to each other. * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (111 commits) Revert "ARM: SPEAr13xx: Pass DW DMAC platform data from DT" ARM: dts: pl330: Add #dma-cells for generic dma binding support DMA: PL330: Register the DMA controller with the generic DMA helpers DMA: PL330: Add xlate function DMA: PL330: Add new pl330 filter for DT case. dma: tegra20-apb-dma: remove unnecessary assignment edma: do not waste memory for dma_mask dma: coh901318: set residue only if dma is in progress dma: coh901318: avoid unbalanced locking dmaengine.h: remove redundant else keyword dma: of-dma: protect list write operation by spin_lock dmaengine: ste_dma40: do not remove descriptors for cyclic transfers dma: of-dma.c: fix memory leakage dw_dmac: apply default dma_mask if needed dmaengine: ioat - fix spare sparse complain dmaengine: move drivers/of/dma.c -> drivers/dma/of-dma.c ioatdma: fix race between updating ioat->head and IOAT_COMPLETION_PENDING dw_dmac: add support for Lynxpoint DMA controllers dw_dmac: return proper residue value dw_dmac: fill individual length of descriptor ...
2013-02-26get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zeroAl Viro
2013-02-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace and namespace infrastructure changes from Eric W Biederman: "This set of changes starts with a few small enhnacements to the user namespace. reboot support, allowing more arbitrary mappings, and support for mounting devpts, ramfs, tmpfs, and mqueuefs as just the user namespace root. I do my best to document that if you care about limiting your unprivileged users that when you have the user namespace support enabled you will need to enable memory control groups. There is a minor bug fix to prevent overflowing the stack if someone creates way too many user namespaces. The bulk of the changes are a continuation of the kuid/kgid push down work through the filesystems. These changes make using uids and gids typesafe which ensures that these filesystems are safe to use when multiple user namespaces are in use. The filesystems converted for 3.9 are ceph, 9p, afs, ocfs2, gfs2, ncpfs, nfs, nfsd, and cifs. The changes for these filesystems were a little more involved so I split the changes into smaller hopefully obviously correct changes. XFS is the only filesystem that remains. I was hoping I could get that in this release so that user namespace support would be enabled with an allyesconfig or an allmodconfig but it looks like the xfs changes need another couple of days before it they are ready." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (93 commits) cifs: Enable building with user namespaces enabled. cifs: Convert struct cifs_ses to use a kuid_t and a kgid_t cifs: Convert struct cifs_sb_info to use kuids and kgids cifs: Modify struct smb_vol to use kuids and kgids cifs: Convert struct cifsFileInfo to use a kuid cifs: Convert struct cifs_fattr to use kuid and kgids cifs: Convert struct tcon_link to use a kuid. cifs: Modify struct cifs_unix_set_info_args to hold a kuid_t and a kgid_t cifs: Convert from a kuid before printing current_fsuid cifs: Use kuids and kgids SID to uid/gid mapping cifs: Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID to keyring_alloc cifs: Use BUILD_BUG_ON to validate uids and gids are the same size cifs: Override unmappable incoming uids and gids nfsd: Enable building with user namespaces enabled. nfsd: Properly compare and initialize kuids and kgids nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids nfsd: Modify nfsd4_cb_sec to use kuids and kgids nfsd: Handle kuids and kgids in the nfs4acl to posix_acl conversion nfsd: Convert nfsxdr to use kuids and kgids nfsd: Convert nfs3xdr to use kuids and kgids ...
2013-02-25Revert "ip_gre: propogate target device GSO capability to the tunnel device"Pravin B Shelar
This reverts commit eb6b9a8cad65e820b145547844b108117cece3a0. Above commit limits GSO capability of gre device to just TSO, but software GRE-GSO is capable of handling all GSO capabilities. This patch also fixes following panic which reverted commit introduced:- BUG: unable to handle kernel NULL pointer dereference at 00000000000000a2 IP: [<ffffffffa0680fd1>] ipgre_tunnel_bind_dev+0x161/0x1f0 [ip_gre] PGD 42bc19067 PUD 42bca9067 PMD 0 Oops: 0000 [#1] SMP Pid: 2636, comm: ip Tainted: GF 3.8.0+ #83 Dell Inc. PowerEdge R620/0KCKR5 RIP: 0010:[<ffffffffa0680fd1>] [<ffffffffa0680fd1>] ipgre_tunnel_bind_dev+0x161/0x1f0 [ip_gre] RSP: 0018:ffff88042bfcb708 EFLAGS: 00010246 RAX: 00000000000005b6 RBX: ffff88042d2fa000 RCX: 0000000000000044 RDX: 0000000000000018 RSI: 0000000000000078 RDI: 0000000000000060 RBP: ffff88042bfcb748 R08: 0000000000000018 R09: 000000000000000c R10: 0000000000000020 R11: 000000000101010a R12: ffff88042d2fa800 R13: 0000000000000000 R14: ffff88042d2fa800 R15: ffff88042cd7f650 FS: 00007fa784f55700(0000) GS:ffff88043fd20000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000000000a2 CR3: 000000042d8b9000 CR4: 00000000000407e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process ip (pid: 2636, threadinfo ffff88042bfca000, task ffff88042d142a80) Stack: 0000000100000000 002f000000000000 0a01010100000000 000000000b010101 ffff88042d2fa800 ffff88042d2fa000 ffff88042bfcb858 ffff88042f418c00 ffff88042bfcb798 ffffffffa068199a ffff88042bfcb798 ffff88042d2fa830 Call Trace: [<ffffffffa068199a>] ipgre_newlink+0xca/0x160 [ip_gre] [<ffffffff8143b692>] rtnl_newlink+0x532/0x5f0 [<ffffffff8143b2fc>] ? rtnl_newlink+0x19c/0x5f0 [<ffffffff81438978>] rtnetlink_rcv_msg+0x2c8/0x340 [<ffffffff814386b0>] ? rtnetlink_rcv+0x40/0x40 [<ffffffff814560f9>] netlink_rcv_skb+0xa9/0xd0 [<ffffffff81438695>] rtnetlink_rcv+0x25/0x40 [<ffffffff81455ddc>] netlink_unicast+0x1ac/0x230 [<ffffffff81456a45>] netlink_sendmsg+0x265/0x380 [<ffffffff814138c0>] sock_sendmsg+0xb0/0xe0 [<ffffffff8141141e>] ? move_addr_to_kernel+0x4e/0x90 [<ffffffff81420445>] ? verify_iovec+0x85/0xf0 [<ffffffff81414ffd>] __sys_sendmsg+0x3fd/0x420 [<ffffffff8114b701>] ? handle_mm_fault+0x251/0x3b0 [<ffffffff8114f39f>] ? vma_link+0xcf/0xe0 [<ffffffff81415239>] sys_sendmsg+0x49/0x90 [<ffffffff814ffd19>] system_call_fastpath+0x16/0x1b CC: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Acked-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-25IP_GRE: Fix GRE_CSUM case.Pravin B Shelar
commit "ip_gre: allow CSUM capable devices to handle packets" aa0e51cdda005cd37e2, broke GRE_CSUM case. GRE_CSUM needs checksum computed for inner packet. Therefore csum-calculation can not be offloaded if tunnel device requires GRE_CSUM. Following patch fixes it by computing inner packet checksum for GRE_CSUM type, for all other type of GRE devices csum is offloaded. CC: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Acked-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-25IP_GRE: Fix IP-Identification.Pravin B Shelar
GRE-GSO generates ip fragments with id 0,2,3,4... for every GSO packet, which is not correct. Following patch fixes it by setting ip-header id unique id of fragments are allowed. As Eric Dumazet suggested it is optimized by using inner ip-header whenever inner packet is ipv4. Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-23net: change type of virtio_chan->p9_max_pagesZhang Yanfei
This member of struct virtio_chan is calculated from nr_free_buffer_pages so change its type to unsigned long in case of overflow. Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: David Miller <davem@davemloft.net> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23net/core: apply pm_runtime_set_memalloc_noio on network devicesMing Lei
Deadlock might be caused by allocating memory with GFP_KERNEL in runtime_resume and runtime_suspend callback of network devices in iSCSI situation, so mark network devices and its ancestor as 'memalloc_noio' with the introduced pm_runtime_set_memalloc_noio(). Signed-off-by: Ming Lei <ming.lei@canonical.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David Decotigny <david.decotigny@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jens Axboe <axboe@kernel.dk> Cc: Minchan Kim <minchan@kernel.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Oliver Neukum <oneukum@suse.de> Cc: Jiri Kosina <jiri.kosina@suse.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-23sock_diag: Simplify sock_diag_handlers[] handling in __sock_diag_rcv_msgMathias Krause
The sock_diag_lock_handler() and sock_diag_unlock_handler() actually make the code less readable. Get rid of them and make the lock usage and access to sock_diag_handlers[] clear on the first sight. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-23sock_diag: Fix out-of-bounds access to sock_diag_handlers[]Mathias Krause
Userland can send a netlink message requesting SOCK_DIAG_BY_FAMILY with a family greater or equal then AF_MAX -- the array size of sock_diag_handlers[]. The current code does not test for this condition therefore is vulnerable to an out-of-bound access opening doors for a privilege escalation. Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-22fs: Preserve error code in get_empty_filp(), part 2Anatol Pomozov
Allocating a file structure in function get_empty_filp() might fail because of several reasons: - not enough memory for file structures - operation is not allowed - user is over its limit Currently the function returns NULL in all cases and we loose the exact reason of the error. All callers of get_empty_filp() assume that the function can fail with ENFILE only. Return error through pointer. Change all callers to preserve this error code. [AV: cleaned up a bit, carved the get_empty_filp() part out into a separate commit (things remaining here deal with alloc_file()), removed pipe(2) behaviour change] Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22new helper: file_inode(file)Al Viro
2013-02-22tcp: fix SYN-data space mis-accountingYuchung Cheng
In fast open the sender unncessarily reduces the space available for data in SYN by 12 bytes. This is because in the sender incorrectly reserves space for TS option twice in tcp_send_syn_data(): tcp_mtu_to_mss() already accounts for TS option space. But it further reserves MAX_TCP_OPTION_SPACE when computing the payload space. Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-22sock: only define socket limit if mem cgroup configuredstephen hemminger
The mem cgroup socket limit is only used if the config option is enabled. Found with sparse Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-22net: Fix locking bug in netif_set_xps_queueAlexander Duyck
Smatch found a locking bug in netif_set_xps_queue in which we were not releasing the lock in the case of an allocation failure. This change corrects that so that we release the xps_map_mutex before returning -ENOMEM in the case of an allocation failure. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-22ipv4: fix error handling in icmp_protocol.Li Wei
Now we handle icmp errors in each transport protocol's err_handler, for icmp protocols, that is ping_err. Since this handler only care of those icmp errors triggered by echo request, errors triggered by echo reply(which sent by kernel) are sliently ignored. So wrap ping_err() with icmp_err() to deal with those icmp errors. Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 update from Martin Schwidefsky: "The most prominent change in this patch set is the software dirty bit patch for s390. It removes __HAVE_ARCH_PAGE_TEST_AND_CLEAR_DIRTY and the page_test_and_clear_dirty primitive which makes the common memory management code a bit less obscure. Heiko fixed most of the PCI related fallout, more often than not missing GENERIC_HARDIRQS dependencies. Notable is one of the 3270 patches which adds an export to tty_io to be able to resize a tty. The rest is the usual bunch of cleanups and bug fixes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (42 commits) s390/module: Add missing R_390_NONE relocation type drivers/gpio: add missing GENERIC_HARDIRQ dependency drivers/input: add couple of missing GENERIC_HARDIRQS dependencies s390/cleanup: rename SPP to LPP s390/mm: implement software dirty bits s390/mm: Fix crst upgrade of mmap with MAP_FIXED s390/linker skript: discard exit.data at runtime drivers/media: add missing GENERIC_HARDIRQS dependency s390/bpf,jit: add vlan tag support drivers/net,AT91RM9200: add missing GENERIC_HARDIRQS dependency iucv: fix kernel panic at reboot s390/Kconfig: sort list of arch selected config options phylib: remove !S390 dependeny from Kconfig uio: remove !S390 dependency from Kconfig dasd: fix sysfs cleanup in dasd_generic_remove s390/pci: fix hotplug module init s390/pci: cleanup clp page allocation s390/pci: cleanup clp inline assembly s390/perf: cpum_cf: fallback to software sampling events s390/mm: provide PAGE_SHARED define ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Assorted tiny fixes queued in trivial tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits) DocBook: update EXPORT_SYMBOL entry to point at export.h Documentation: update top level 00-INDEX file with new additions ARM: at91/ide: remove unsused at91-ide Kconfig entry percpu_counter.h: comment code for better readability x86, efi: fix comment typo in head_32.S IB: cxgb3: delay freeing mem untill entirely done with it net: mvneta: remove unneeded version.h include time: x86: report_lost_ticks doesn't exist any more pcmcia: avoid static analysis complaint about use-after-free fs/jfs: Fix typo in comment : 'how may' -> 'how many' of: add missing documentation for of_platform_populate() btrfs: remove unnecessary cur_trans set before goto loop in join_transaction sound: soc: Fix typo in sound/codecs treewide: Fix typo in various drivers btrfs: fix comment typos Update ibmvscsi module name in Kconfig. powerpc: fix typo (utilties -> utilities) of: fix spelling mistake in comment h8300: Fix home page URL in h8300/README xtensa: Fix home page URL in Kconfig ...
2013-02-21Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge misc patches from Andrew Morton: - Florian has vanished so I appear to have become fbdev maintainer again :( - Joel and Mark are distracted to welcome to the new OCFS2 maintainer - The backlight queue - Small core kernel changes - lib/ updates - The rtc queue - Various random bits * akpm: (164 commits) rtc: rtc-davinci: use devm_*() functions rtc: rtc-max8997: use devm_request_threaded_irq() rtc: rtc-max8907: use devm_request_threaded_irq() rtc: rtc-da9052: use devm_request_threaded_irq() rtc: rtc-wm831x: use devm_request_threaded_irq() rtc: rtc-tps80031: use devm_request_threaded_irq() rtc: rtc-lp8788: use devm_request_threaded_irq() rtc: rtc-coh901331: use devm_clk_get() rtc: rtc-vt8500: use devm_*() functions rtc: rtc-tps6586x: use devm_request_threaded_irq() rtc: rtc-imxdi: use devm_clk_get() rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug() rtc: rtc-pcf8583: use dev_warn() instead of printk() rtc: rtc-sun4v: use pr_warn() instead of printk() rtc: rtc-vr41xx: use dev_info() instead of printk() rtc: rtc-rs5c313: use pr_err() instead of printk() rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug() rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug() rtc: rtc-ds2404: use dev_err() instead of printk() rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk() ...
2013-02-21sun.com documentation fixesChristian Kujau
After I came across a help text for SUNGEM mentioning a broken sun.com URL, I felt like fixing those up, as they are now pointing to oracle.com URLs. Signed-off-by: Christian Kujau <lists@nerdbynature.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21ipv6: use a stronger hash for tcpEric Dumazet
It looks like its possible to open thousands of TCP IPv6 sessions on a server, all landing in a single slot of TCP hash table. Incoming packets have to lookup sockets in a very long list. We should hash all bits from foreign IPv6 addresses, using a salt and hash mix, not a simple XOR. inet6_ehashfn() can also separately use the ports, instead of xoring them. Reported-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-21Merge tag 'tty-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial patches from Greg Kroah-Hartman: "Here's the big tty/serial driver patches for 3.9-rc1. More tty port rework and fixes from Jiri here, as well as lots of individual serial driver updates and fixes. All of these have been in the linux-next tree for a while." * tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits) tty: mxser: improve error handling in mxser_probe() and mxser_module_init() serial: imx: fix uninitialized variable warning serial: tegra: assume CONFIG_OF TTY: do not update atime/mtime on read/write lguest: select CONFIG_TTY to build properly. ARM defconfigs: add missing inclusions of linux/platform_device.h fb/exynos: include platform_device.h ARM: sa1100/assabet: include platform_device.h directly serial: imx: Fix recursive locking bug pps: Fix build breakage from decoupling pps from tty tty: Remove ancient hardpps() pps: Additional cleanups in uart_handle_dcd_change pps: Move timestamp read into PPS code proper pps: Don't crash the machine when exiting will do pps: Fix a use-after free bug when unregistering a source. pps: Use pps_lookup_dev to reduce ldisc coupling pps: Add pps_lookup_dev() function tty: serial: uartlite: Support uartlite on big and little endian systems tty: serial: uartlite: Fix sparse and checkpatch warnings serial/arc-uart: Miscll DT related updates (Grant's review comments) ... Fix up trivial conflicts, mostly just due to the TTY config option clashing with the EXPERIMENTAL removal.
2013-02-21ipv4: fix a bug in ping_err().Li Wei
We should get 'type' and 'code' from the outer ICMP header. Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-21IB/core: Add "type 2" memory windows supportShani Michaeli
This patch enhances the IB core support for Memory Windows (MWs). MWs allow an application to have better/flexible control over remote access to memory. Two types of MWs are supported, with the second type having two flavors: Type 1 - associated with PD only Type 2A - associated with QPN only Type 2B - associated with PD and QPN Applications can allocate a MW once, and then repeatedly bind the MW to different ranges in MRs that are associated to the same PD. Type 1 windows are bound through a verb, while type 2 windows are bound by posting a work request. The 32-bit memory key is composed of a 24-bit index and an 8-bit key. The key is changed with each bind, thus allowing more control over the peer's use of the memory key. The changes introduced are the following: * add memory window type enum and a corresponding parameter to ib_alloc_mw. * type 2 memory window bind work request support. * create a struct that contains the common part of the bind verb struct ibv_mw_bind and the bind work request into a single struct. * add the ib_inc_rkey helper function to advance the tag part of an rkey. Consumer interface details: * new device capability flags IB_DEVICE_MEM_WINDOW_TYPE_2A and IB_DEVICE_MEM_WINDOW_TYPE_2B are added to indicate device support for these features. Devices can set either IB_DEVICE_MEM_WINDOW_TYPE_2A or IB_DEVICE_MEM_WINDOW_TYPE_2B if it supports type 2A or type 2B memory windows. It can set neither to indicate it doesn't support type 2 windows at all. * modify existing provides and consumers code to the new param of ib_alloc_mw and the ib_mw_bind_info structure Signed-off-by: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Shani Michaeli <shanim@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-02-21Merge tag 'nfs-for-3.9-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: - Fix an Oops in the pNFS layoutget code - Fix a number of NFSv4 and v4.1 state recovery deadlocks and hangs due to the interaction of the session drain lock and state management locks. - Remove task->tk_xprt, which was hiding a lot of RCU dereferencing bugs - Fix a long standing NFSv3 posix lock recovery bug. - Revert commit 324d003b0cd8 ("NFS: add nfs_sb_deactive_async to avoid deadlock"). It turned out that the root cause of the deadlock was due to interactions with the workqueues that have now been resolved. * tag 'nfs-for-3.9-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (22 commits) NLM: Ensure that we resend all pending blocking locks after a reclaim umount oops when remove blocklayoutdriver first sunrpc: silence build warning in gss_fill_context nfs: remove kfree() redundant null checks NFSv4.1: Don't decode skipped layoutgets NFSv4.1: Fix bulk recall and destroy of layouts NFSv4.1: Fix an ABBA locking issue with session and state serialisation NFSv4: Fix a reboot recovery race when opening a file NFSv4: Ensure delegation recall and byte range lock removal don't conflict NFSv4: Fix up the return values of nfs4_open_delegation_recall NFSv4.1: Don't lose locks when a server reboots during delegation return NFSv4.1: Prevent deadlocks between state recovery and file locking NFSv4: Allow the state manager to mark an open_owner as being recovered SUNRPC: Add missing static declaration to _gss_mech_get_by_name Revert "NFS: add nfs_sb_deactive_async to avoid deadlock" SUNRPC: Nuke the tk_xprt macro SUNRPC: Avoid RCU dereferences in the transport bind and connect code SUNRPC: Fix an RCU dereference in xprt_reserve SUNRPC: Pass pointers to struct rpc_xprt to the congestion window SUNRPC: Fix an RCU dereference in xs_local_rpcbind ...
2013-02-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking update from David Miller: 1) Checkpoint/restarted TCP sockets now can properly propagate the TCP timestamp offset. From Andrey Vagin. 2) VMWARE VM VSOCK layer, from Andy King. 3) Much improved support for virtual functions and SR-IOV in bnx2x, from Ariel ELior. 4) All protocols on ipv4 and ipv6 are now network namespace aware, and all the compatability checks for initial-namespace-only protocols is removed. Thanks to Tom Parkin for helping deal with the last major holdout, L2TP. 5) IPV6 support in netpoll and network namespace support in pktgen, from Cong Wang. 6) Multiple Registration Protocol (MRP) and Multiple VLAN Registration Protocol (MVRP) support, from David Ward. 7) Compute packet lengths more accurately in the packet scheduler, from Eric Dumazet. 8) Use per-task page fragment allocator in skb_append_datato_frags(), also from Eric Dumazet. 9) Add support for connection tracking labels in netfilter, from Florian Westphal. 10) Fix default multicast group joining on ipv6, and add anti-spoofing checks to 6to4 and 6rd. From Hannes Frederic Sowa. 11) Make ipv4/ipv6 fragmentation memory limits more reasonable in modern times, rearrange inet frag datastructures for better cacheline locality, and move more operations outside of locking. From Jesper Dangaard Brouer. 12) Instead of strict master <--> slave relationships, allow arbitrary scenerios with "upper device lists". From Jiri Pirko. 13) Improve rate limiting accuracy in TBF and act_police, also from Jiri Pirko. 14) Add a BPF filter netfilter match target, from Willem de Bruijn. 15) Orphan and delete a bunch of pre-historic networking drivers from Paul Gortmaker. 16) Add TSO support for GRE tunnels, from Pravin B SHelar. Although this still needs some minor bug fixing before it's %100 correct in all cases. 17) Handle unresolved IPSEC states like ARP, with a resolution packet queue. From Steffen Klassert. 18) Remove TCP Appropriate Byte Count support (ABC), from Stephen Hemminger. This was long overdue. 19) Support SO_REUSEPORT, from Tom Herbert. 20) Allow locking a socket BPF filter, so that it cannot change after a process drops capabilities. 21) Add VLAN filtering to bridge, from Vlad Yasevich. 22) Bring ipv6 on-par with ipv4 and do not cache neighbour entries in the ipv6 routes, from YOSHIFUJI Hideaki. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1538 commits) ipv6: fix race condition regarding dst->expires and dst->from. net: fix a wrong assignment in skb_split() ip_gre: remove an extra dst_release() ppp: set qdisc_tx_busylock to avoid LOCKDEP splat atl1c: restore buffer state net: fix a build failure when !CONFIG_PROC_FS net: ipv4: fix waring -Wunused-variable net: proc: fix build failed when procfs is not configured Revert "xen: netback: remove redundant xenvif_put" net: move procfs code to net/core/net-procfs.c qmi_wwan, cdc-ether: add ADU960S bonding: set sysfs device_type to 'bond' bonding: fix bond_release_all inconsistencies b44: use netdev_alloc_skb_ip_align() xen: netback: remove redundant xenvif_put net: fec: Do a sanity check on the gpio number ip_gre: propogate target device GSO capability to the tunnel device ip_gre: allow CSUM capable devices to handle packets bonding: Fix initialize after use for 3ad machine state spinlock bonding: Fix race condition between bond_enslave() and bond_3ad_update_lacp_rate() ...
2013-02-20ipv6: fix race condition regarding dst->expires and dst->from.YOSHIFUJI Hideaki / 吉藤英明
Eric Dumazet wrote: | Some strange crashes happen in rt6_check_expired(), with access | to random addresses. | | At first glance, it looks like the RTF_EXPIRES and | stuff added in commit 1716a96101c49186b | (ipv6: fix problem with expired dst cache) | are racy : same dst could be manipulated at the same time | on different cpus. | | At some point, our stack believes rt->dst.from contains a dst pointer, | while its really a jiffie value (as rt->dst.expires shares the same area | of memory) | | rt6_update_expires() should be fixed, or am I missing something ? | | CC Neil because of https://bugzilla.redhat.com/show_bug.cgi?id=892060 Because we do not have any locks for dst_entry, we cannot change essential structure in the entry; e.g., we cannot change reference to other entity. To fix this issue, split 'from' and 'expires' field in dst_entry out of union. Once it is 'from' is assigned in the constructor, keep the reference until the very last stage of the life time of the object. Of course, it is unsafe to change 'from', so make rt6_set_from simple just for fresh entries. Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Reported-by: Neil Horman <nhorman@tuxdriver.com> CC: Gao Feng <gaofeng@cn.fujitsu.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Reviewed-by: Eric Dumazet <edumazet@google.com> Reported-by: Steinar H. Gunderson <sesse@google.com> Reviewed-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-20net: fix a wrong assignment in skb_split()Amerigo Wang
commit c9af6db4c11ccc6c3e7f1 (net: Fix possible wrong checksum generation) has a suspicous piece: - skb_shinfo(skb1)->gso_type = skb_shinfo(skb)->gso_type; - + skb_shinfo(skb)->tx_flags = skb_shinfo(skb1)->tx_flags & SKBTX_SHARED_FRAG; skb1 is the new skb, therefore should be on the left side of the assignment. This patch fixes it. Cc: Pravin B Shelar <pshelar@nicira.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-19Merge branch 'for-3.9-cleanups' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq Pull workqueue [delayed_]work_pending() cleanups from Tejun Heo: "This is part of on-going cleanups to remove / minimize usages of workqueue interfaces which are deprecated and/or misleading. This round drops a number of usages of [delayed_]work_pending(), which are dangerous as they lack any form of synchronization and thus often lead to buggy / unnecessary code. There are a couple legitimate use cases in kernel. Hopefully, they can be converted and [delayed_]work_pending() can be removed completely. Even if not, removing most of misuses should make it more difficult to find examples of misuses and thus slow down growth of them. These changes are independent from other workqueue changes." * 'for-3.9-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: wimax/i2400m: fix i2400m->wake_tx_skb handling kprobes: fix wait_for_kprobe_optimizer() ipw2x00: simplify scan_event handling video/exynos: don't use [delayed_]work_pending() tty/max3100: don't use [delayed_]work_pending() x86/mce: don't use [delayed_]work_pending() rfkill: don't use [delayed_]work_pending() wl1251: don't use [delayed_]work_pending() thinkpad_acpi: don't use [delayed_]work_pending() mwifiex: don't use [delayed_]work_pending() sja1000: don't use [delayed_]work_pending()
2013-02-19Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next John W. Linville says: ==================== One last batch of stragglers intended for 3.9... For the iwlwifi pull, Johannes says: "I hadn't expected to ask you to pull iwlwifi-next again, but I have a number of fixes most of which I'd also send in after rc1, so here it is. The first commit is a merge error between mac80211-next and iwlwifi-next; in addition I have fixes for P2P scanning and MVM driver MAC (virtual interface) management from Ilan, a CT-kill (critical temperature) fix from Eytan, and myself fixed three different little but annoying bugs in the MVM driver. The only ones I might not send for -rc1 are Emmanuel's debug patch, but OTOH it should help greatly if there are any issues, and my own time event debugging patch that I used to find the race condition but we decided to keep it for the future." For the mac80211 pull, Johannes says: "Like iwlwifi-next, this would almost be suitable for rc1. I have a fix for station management on non-TDLS drivers, a CAB queue crash fix for mesh, a fix for an annoying (but harmless) warning, a tracing fix and a documentation fix. Other than that, only a few mesh cleanups." Along with that is a fix for memory corruption in rtlwifi, an orinoco_usb fix to avoid allocating a DMA buffer on the stack, an a hostap fix to return -ENOMEM instead of -1 after a memory allocation failure. The remaining bits implement 802.11ac support for the mwifiex driver -- I think that is still worth getting into 3.9. Please let me know if there are problems! ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-19ip_gre: remove an extra dst_release()Eric Dumazet
commit 68c331631143 (v4 GRE: Add TCP segmentation offload for GRE) introduced a bug in error path. dst is attached to skb, so will be released when skb is freed. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Pravin B Shelar <pshelar@nicira.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-19Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
2013-02-19net: fix a build failure when !CONFIG_PROC_FSCong Wang
When !CONFIG_PROC_FS dev_mcast_init() is not defined, actually we can just merge dev_mcast_init() into dev_proc_init(). Reported-by: Gao feng <gaofeng@cn.fujitsu.com> Cc: Gao feng <gaofeng@cn.fujitsu.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-19net: ipv4: fix waring -Wunused-variableGao feng
the vars ip_rt_gc_timeout is used only when CONFIG_SYSCTL is selected. move these vars into CONFIG_SYSCTL. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-19net: move procfs code to net/core/net-procfs.cCong Wang
Similar to net/core/net-sysfs.c, group procfs code to a single unit. Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-19ip_gre: propogate target device GSO capability to the tunnel deviceDmitry Kravkov
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-19ip_gre: allow CSUM capable devices to handle packetsDmitry Kravkov
If device is not able to handle checksumming it will be handled in dev_xmit Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18Merge branch 'master' of git://1984.lsi.us.es/nf-nextDavid S. Miller
Pablo Neira Ayuso says: ==================== The following patchset contain updates for your net-next tree, they are: * Fix (for just added) connlabel dependencies, from Florian Westphal. * Add aliasing support for conntrack, thus users can either use -m state or -m conntrack from iptables while using the same kernel module, from Jozsef Kadlecsik. * Some code refactoring for the CT target to merge common code in revision 0 and 1, from myself. * Add aliasing support for CT, based on patch from Jozsef Kadlecsik. * Add one mutex per nfnetlink subsystem, from myself. * Improved logging for packets that are dropped by helpers, from myself. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net into netDavid S. Miller
Pull in 'net' to take in the bug fixes that didn't make it into 3.8-final. Also, deal with the semantic conflict of the change made to net/ipv6/xfrm6_policy.c A missing rt6->n neighbour release was added to 'net', but in 'net-next' we no longer cache the neighbour entries in the ipv6 routes so that change is not appropriate there. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-19netfilter: nf_ct_helper: better logging for dropped packetsPablo Neira Ayuso
Connection tracking helpers have to drop packets under exceptional situations. Currently, the user gets the following logging message in case that happens: nf_ct_%s: dropping packet ... However, depending on the helper, there are different reasons why a packet can be dropped. This patch modifies the existing code to provide more specific error message in the scope of each helper to help users to debug the reason why the packet has been dropped, ie: nf_ct_%s: dropping packet: reason ... Thanks to Joe Perches for many formatting suggestions. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-02-18ipv6: fix a sparse warningEric Dumazet
net/ipv6/reassembly.c:82:72: warning: incorrect type in argument 3 (different base types) net/ipv6/reassembly.c:82:72: expected unsigned int [unsigned] [usertype] c net/ipv6/reassembly.c:82:72: got restricted __be32 [usertype] id Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
