path: root/net
2006-12-11[DCCP] ccid3: Fixup some type conversions related to rttsArnaldo Carvalho de Melo
Spotted by David Miller when compiling on sparc64, I reproduced it here on parisc64, that are the only platforms to define __kernel_suseconds_t as an 'int', all the others, x86_64 and x86 included typedef it as a 'long', but from the definition of suseconds_t it should just be an 'int' on platforms where it is >= 32bits, it would not require all the castings from suseconds_t to (int) when printking variables of this type, that are not needed on parisc64 and sparc64. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: BUG-FIX - conversion errorsGerrit Renker
This fixes conversion errors which arose by not properly type-casting from u32 to __u64. Fixed by explicitly casting each type which is not __u64, or by performing operation after assignment. The patch further adds missing debug information to track the current value of X_recv. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Reorder packet history source fileGerrit Renker
No code change at all. This reorders the source file to follow the same order as the corresponding header file. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Reorder packet history header fileGerrit Renker
No code change at all. To make the header file easier to read, the following ordering is established among the declarations: * hist_new * hist_delete * hist_entry_new * hist_head * hist_find_entry * hist_add_entry * hist_entry_delete * hist_purge Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Make debug output consistentGerrit Renker
This patch does not alter any algorithm, just the debug message format: * s#%s, sk=%p#%s(%p)#g * when a statename is present, it now uses %s(%p, state=%s) * when only function entry is debugged, it adds an `- entry' Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Perform history operations only after packet has been sentGerrit Renker
This migrates all packet history operations into the routine ccid3_hc_tx_packet_sent, thereby removing synchronization problems that occur when, as before, the operations are spread over multiple routines. The following minor simplifications are also applied: * several simplifications now follow from this change - several tests are now no longer required * removal of one unnecessary variable (dp) Justification: Currently packet history operations span two different routines, one of which is likely to pass through several iterations of sleeping and awakening. The first routine, ccid3_hc_tx_send_packet, allocates an entry and sets a few fields. The remaining fields are filled in when the second routine (which is not within a sleeping context), ccid3_hc_tx_packet_sent, is called. This has several strong drawbacks: * it is not necessary to split history operations - all fields can be filled in by the second routine * the first routine is called multiple times, until a packet can be sent, and sleeps meanwhile - this causes a lot of difficulties with regard to keeping the list consistent * since both routines do not have a producer-consumer like synchronization, it is very difficult to maintain data across calls to these routines * the fact that the routines are called in different contexts (sleeping, not sleeping) adds further problems Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: TX history - remove unused fieldGerrit Renker
This removes the `dccphtx_ccval' field since it is nowhere used in the code and in fact not necessary for the accounting. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Shift window counter computationGerrit Renker
This puts the window counter computation [RFC 4342, 8.1] into a separate function which is called whenever a new packet is ready for immediate transmission in ccid3_hc_tx_send_packet. Justification: The window counter update was previously computed after the packet was sent. This has two drawbacks, both fixed by this patch: 1) re-compute another timestamp almost directly after the packet was sent (expensive), 2) the CCVal for the window counter is needed at the instant the packet is sent. Further details: The initialisation of the window counter is left in the state NO_SENT, as before. The algorithm will do nothing if either RTT is initialised to 0 (which is ok) or if the RTT value remains below 4 microseconds (which is almost pathological). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Sanity-check RTT samplesGerrit Renker
CCID3 performance depends much on the accuracy of RTT samples. If RTT samples grow too large, performance can be catastrophically poor. To limit the amount of possible damage in such cases, the patch * introduces an upper limit which identifies a maximum `sane' RTT value; * uses a macro to enforce this upper limit. Using a macro was given preference, since it is necessary to identify the calling function in the warning message. Since exceeding this threshold identifies a critical condition, DCCP_CRIT is used and not DCCP_WARN. Many thanks to Ian McDonald for collaboration on this issue. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Initialise RTT valuesGerrit Renker
In both the sender and the receiver it is possible that the stored RTT value is accessed before an actual RTT estimate has been computed. This patch * initialises the sender RTT to 0 - the sender always accesses the RTT in ccid3_hc_tx_packet_sent - the RTT is further needed for the window counter algorithm * replaces the receiver initialisation of 5msec with 0 - which has the same effect and removes an `XXX' - the RTT value is needed in ccid3_hc_rx_packet_recv as rtt_prev Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid: Deprecate ccid_hc_tx_insert_optionsGerrit Renker
The function ccid3_hc_tx_insert_options only does a redundant no-op, as the operation DCCP_SKB_CB(skb)->dccpd_ccval = hctx->ccid3hctx_last_win_count; is already performed _unconditionally_ in ccid3_hc_tx_send_packet. Since there is further no current need for this function, it is removed entirely. Since furthermore, there is actually no present need for the entire interface function ccid_hc_tx_insert_options, it was decided to remove it also, to clean up the interface. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP]: Warn when discarding packet due to internal errorsGerrit Renker
This adds a (debug) warning message which is triggered whenever a packet is discarded due to send failure. It also adds a conditional, so that an interruption during dccp_wait_for_ccid is not treated as a `BUG': the rationale is that interruptions are external, whereas bug warnings are concerned with the internals. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP]: Only deliver to the CCID rx side in chargeGerrit Renker
This is an optimisation to reduce CPU load. The received feedback is now only directed to the active CCID component, without requiring processing also by the inactive one. As a consequence, a similar test in ccid3.c is now redundant and is also removed. Justification: Currently DCCP works as a unidirectional service, i.e. a listening server is not at the same time a connecting client. As far as I can see, several modifications are necessary until that becomes possible. At the present time, received feedback is both fed to the rx/tx CCID modules. In unidirectional service, only one of these is active at any one time. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP]: Simplify TFRC calculationGerrit Renker
In migrating towards using the newer functions scaled_div/scaled_div32 for TFRC computations mapped from floating-point onto integer arithmetic, this completes the last stage of modifications. In particular, the overflow case for computing X_calc is circumvented by * breaking the computation into two stages * the first stage, res = (s*1E6)/R, cannot overflow due to use of u64 * in the second stage, res = (res*1E6)/f, overflow on u32 is avoided due to (i) returning UINT_MAX in this case (which is logically appropriate) and (ii) issuing a warning message into the system log (since very likely there is a problem somewhere else with the parameters) Lastly, all such scaling operations are now exported into tfrc.h, since actually this form of scaled computation is specific to TFRC and not to CCID3. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP]: Debug timeval operationsGerrit Renker
Problem: Most target types in the CCID3 code are u32, so subtle conversion errors can occur if signed time calculations yield negative results: the original values are lost in the conversion to unsigned, calculation errors go undetected. This patch therefore * sets all critical time types from unsigned to suseconds_t * avoids comparison between signed/unsigned via type-casting * provides ample warning messages in case time calculations are negative These warning messages can be removed at a later stage when the code has undergone more testing. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Simplify calculation for reverse lookup of pGerrit Renker
This simplifies the calculation of a value p for a given fval when the first loss interval is computed (RFC 3448, 6.3.1). It makes use of the two new functions scaled_div/scaled_div32 to provide overflow protection. Additionally, protection against divide-by-zero is extended - in this case the function will return the maximally possible value of p=100%. Background: The maximum fval, f(100%), is approximately 244, i.e. the scaled value of fval should never exceed 244E6, which fits easily into u32. The problem is the scaling by 10^6, since additionally R(TT) is in microseconds. This is resolved by breaking the division into two stages: the first stage computes fval=(s*10^6)/R, stores that into u64; the second stage computes fval = (fval*10^6)/X_recv and complains if overflow is reached for u32. This case is safe since the TFRC reverse-lookup routine then returns p=100%. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Replace scaled division operationsGerrit Renker
This replaces the remaining uses of usecs_div with scaled_div32, which internally uses 64bit division and produces a warning on overflow. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Finer-grained resolution of sending ratesGerrit Renker
This patch * resolves a bug where packets smaller than 32/64 bytes resulted in sending rates of 0 * supports all sending rates from 1/64 bytes/second up to 4Gbyte/second * simplifies the present overflow problems in calculations Current sending rate X and the cached value X_recv of the receiver-estimated sending rate are both scaled by 64 (2^6) in order to * cope with low sending rates (minimally 1 byte/second) * allow upgrading to use a packets-per-second implementation of CCID 3 * avoid calculation errors due to integer arithmetic cut-off The patch implements a revised strategy from http://www.mail-archive.com/dccp@vger.kernel.org/msg01040.html The only difference with regard to that strategy is that t_ipi is already used in the calculation of the nofeedback timeout, which saves one division. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Fix two bugs in sending rate computationGerrit Renker
This fixes 1) a bug in the recomputation of the sending rate by the nofeedback timer when no feedback at all has so far been sent by the receiver: min_t was used instead of max_t, which is wrong (cf. RFC 3448, p. 10); 2) an error in the computation of larger initial windows: instead of min(... max()) (cf. RFC 4342, 5.), the code had used max(... max()). Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Two optimisations for sending rate recomputationGerrit Renker
This performs two optimisations for the recomputation of the sending rate. 1) Currently the target sending rate X_calc is recalculated whenever a) the nofeedback timer expires, or b) a feedback packet is received. In the (a) case, recomputing X_calc is redundant, since * the parameters p and RTT do not change in between the reception of feedback packets; * the parameter X_recv is either modified from received feedback or via the nofeedback timer; * a test (`p == 0') in the nofeedback timer avoids using a stale/undefined value of X_calc if p was previously 0. 2) The nofeedback timer now only recomputes a timestamp when p == 0. This is according to step (4) of [RFC 3448, 4.3] and avoids unnecessarily determining a timestamp. A debug statement about not updating X is also removed - it helps very little in debugging and just clutters the logs. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP] ccid3: Check against too large pGerrit Renker
This patch follows a suggestion by Ian McDonald and ensures that in the current code the value of p can not exceed 100%. Such a value is illegal and would consequently cause a bug condition in tfrc_calc_x(). The receiver case is also tested, and a warning message is added. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[DCCP]: Remove timeo from output.cIan McDonald
It simplifies waiting for the CCID module to signal that a packet is ready to be sent. Other simplifications flow on from this such as removing constants. As a result of this EAGAIN is not returned any more by dccp_wait_for_ccid (which would otherwise lead to unnecessarily discarding the packet in dccp_write_xmit). Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-11[NETPOLL]: Make sure TX lock is taken with BH disabled.Andrew Morton
Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-10[PATCH] sysctl: remove unused "context" paramAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andi Kleen <ak@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: David Howells <dhowells@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] workstruct: fix ieee80211-softmac compile problemDavid Howells
Fix ieee80211-softmac compile problem where it's using schedule_work() on a delayed_work struct. Signed-off-by: David Howells <dhowells@redhat.com> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[NET_SCHED] sch_htb: turn intermediate classes into leavesJarek Poplawski
- turn intermediate classes into leaves again when their last child is deleted (struct htb_class changed) Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[NET_SCHED] sch_cbq: deactivating when grafting, purging etc.Jarek Poplawski
- deactivating of active classes when q.qlen drops to zero (cbq_drop) - a redundant instruction removed from cbq_deactivate_class PS: probably htb_deactivate in htb_delete and cbq_deactivate_class in cbq_delete are also redundant now. Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[NETPOLL]: make arp replies through netpoll use mac address of senderNeil Horman
Back in 2.4 arp requests that were recevied by netpoll were processed in netconsole_receive_skb, where they were responded to using the src mac of the request sender. In the 2.6 kernel arp_reply is responsible for this function, but instead of using the src mac address of the incomming request, the stored mac address that was registered for the netconsole application is used. While this is usually ok, it can lead to failures in netpoll in some situations (specifically situations where a network may have two gateways, as arp requests from one may be responded to using the mac address of the other). This patch reverts the behavior to what we had in 2.4, in which all arp requests are sent back using the src address of the request sender. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Chris Lalancette <clalance@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[AX.25]: Fix default address and broadcast address initialization.Ralf Baechle
Only the callsign but not the SSID part of an AX.25 address is ASCII based but Linux by initializes the SSID which should be just a 4-bit number from ASCII anyway. Fix that and convert the code to use a shared constant for both default addresses. While at it, use the same style for null_ax25_address also. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[AX.25]: Constify ax25 utility functionsRalf Baechle
2006-12-08[NET]: Convert hh_lock to seqlock.Stephen Hemminger
The hard header cache is in the main output path, so using seqlock instead of reader/writer lock should reduce overhead. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] tty: switch to ktermios and new frameworkAlan Cox
This is the core of the switch to the new framework. I've split it from the driver patches which are mostly search/replace and would encourage people to give this one a good hard stare. The references to BOTHER and ISHIFT are the termios values that must be defined by a platform once it wants to turn on "new style" ioctl support. The code patches here ensure that providing 1. The termios overlays the ktermios in memory 2. The only new kernel only fields are c_ispeed/c_ospeed (or none) the existing behaviour is retained. This is true for the patches at this point in time. Future patches will define BOTHER, ISHIFT and enable newer termios structures for each architecture, and once they are all done some of the ifdefs also vanish. [akpm@osdl.org: warning fix] [akpm@osdl.org: IRDA fix] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert unixJosef Sipek
2006-12-08[PATCH] struct path: convert sunrpcJosef Sipek
2006-12-08[PATCH] struct path: convert netlinkJosef Sipek
2006-12-08[PATCH] struct path: convert netfilterJosef Sipek
2006-12-08[PATCH] struct path: convert netJosef Sipek
2006-12-08[PATCH] struct path: convert atmJosef Sipek
2006-12-07Merge branch 'master' of /home/trondmy/kernel/linux-2.6/ into merge_linusTrond Myklebust
Conflicts: include/linux/sunrpc/xprt.h net/sunrpc/xprtsock.c Fix up conflicts with the workqueue changes.
2006-12-07Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (43 commits) [wireless] zd1211rw: workqueue-related build fixes [netdrvr] netxen: workqueue-related build fixes [PATCH] sky2: sparse warnings [PATCH] skge: fix sparse warnings [PATCH] myri10ge: write as 2 32-byte blocks in myri10ge_submit_8rx [PATCH] sky2: receive queue watermark tweak [PATCH] sky2: beter ram buffer partitioning [PATCH] sky2: add comments to PCI ids [PATCH] sky2: add PCI for 88ec033 [PATCH] AT91RM9200 Ethernet: Use dev_alloc_skb() [PATCH] AT91RM9200 Ethernet: Add netpoll / netconsole support [PATCH] AT91RM9200 Ethernet: Move check_timer variable and use mod_timer() [PATCH] AT91RM9200 Ethernet: Remove 'at91_dev' and use netdev_priv() [PATCH] ipw2200: Fix debug output endian issue [PATCH] ipw2200: Fix a typo [PATCH] ipw2200: Update version stamp to 1.2.0 [PATCH] ipw2200: Add IEEE80211_RADIOTAP_TSFT for promiscuous mode [PATCH] softmac: fix unbalanced mutex_lock/unlock in ieee80211softmac_wx_set_mlme [PATCH] softmac: Fixed handling of deassociation from AP [PATCH] ipw2200: replace kmalloc+memset with kcalloc ...
2006-12-07Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (48 commits) [NETFILTER]: Fix non-ANSI func. decl. [TG3]: Identify Serdes devices more clearly. [TG3]: Use msleep. [TG3]: Use netif_msg_*. [TG3]: Allow partial speed advertisement. [TG3]: Add TG3_FLG2_IS_NIC flag. [TG3]: Add 5787F device ID. [TG3]: Fix Phy loopback. [WANROUTER]: Kill kmalloc debugging code. [TCP] inet_twdr_hangman: Delete unnecessary memory barrier(). [NET]: Memory barrier cleanups [IPSEC]: Fix inetpeer leak in ipv4 xfrm dst entries. audit: disable ipsec auditing when CONFIG_AUDITSYSCALL=n audit: Add auditing to ipsec [IRDA] irlan: Fix compile warning when CONFIG_PROC_FS=n [IrDA]: Incorrect TTP header reservation [IrDA]: PXA FIR code device model conversion [GENETLINK]: Fix misplaced command flags. [NETLIK]: Add a pointer to the Generic Netlink wiki page. [IPV6] RAW: Don't release unlocked sock. ...
2006-12-07[PATCH] net: don't insert socket dentries into dentry_hashtableEric Dumazet
We currently insert socket dentries into the global dentry hashtable. This is suboptimal because there is currently no way these entries can be used for a lookup(). (/proc/xxx/fd/xxx uses a different mechanism). Inserting them in dentry hashtable slows dcache lookups. To let __dpath() still work correctly (ie not adding a " (deleted)") after dentry name, we do : - Right after d_alloc(), pretend they are hashed by clearing the DCACHE_UNHASHED bit. - Call d_instantiate() instead of d_add() : dentry is not inserted in hash table. __dpath() & friends work as intended during dentry lifetime. - At dismantle time, once dput() must clear the dentry, setting again DCACHE_UNHASHED bit inside the custom d_delete() function provided by socket code, so that dput() can just kill_it. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] hotplug CPU: clean up hotcpu_notifier() useIngo Molnar
There was lots of #ifdef noise in the kernel due to hotcpu_notifier(fn, prio) not correctly marking 'fn' as used in the !HOTPLUG_CPU case, and thus generating compiler warnings of unused symbols, hence forcing people to add #ifdefs. the compiler can skip truly unused functions just fine: text data bss dec hex filename 1624412 728710 3674856 6027978 5bfaca vmlinux.before 1624412 728710 3674856 6027978 5bfaca vmlinux.after [akpm@osdl.org: topology.c fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] lockdep: name some old style locksPeter Zijlstra
Name some of the remaning 'old_style_spin_init' locks Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] lockdep: annotate nfs/nfsd in-kernel socketsPeter Zijlstra
Stick NFS sockets in their own class to avoid some lockdep warnings. NFS sockets are never exposed to user-space, and will hence not trigger certain code paths that would otherwise pose deadlock scenarios. [akpm@osdl.org: cleanups] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Steven Dickson <SteveD@redhat.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> [ Fixed patch corruption by quilt, pointed out by Peter Zijlstra ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
