Add new nl80211 event notifications (and a new multicast group, "mlme")
for informing user space about received and processed Authentication,
(Re)Association Response, Deauthentication, and Disassociation frames in
station and IBSS modes (i.e., MLME SAP interface primitives
MLME-AUTHENTICATE.confirm, MLME-ASSOCIATE.confirm,
MLME-REASSOCIATE.confirm, MLME-DEAUTHENTICATE.indicate, and
MLME-DISASSOCIATE.indication). The event data is encapsulated as the 802.11
management frame since we already have the frame in that format and it
includes all the needed information.
This is the initial step in providing MLME SAP interface for
authentication and association with nl80211. In other words, kernel code
will act as the MLME and a user space application can control it as the
SME.
Signed-off-by: Jouni Malinen <j@w1.fi>
We must not clear the previous BSSID when roaming to another AP within
the same ESS for reassociation to be used properly. It is fine to
clear this when the SSID changes, so let's move the code into
ieee80211_sta_set_ssid().
Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com>
ieee80211_tx_h_check_assoc() was dropping everything else than probe
requests during software scan. So the nullfunc frame with the power save
bit was dropped and AP never received it. This meant that AP never
buffered any frames for the station during software scan.
Fix this by allowing to transmit both probe request and nullfunc frames
during software scan. Tested with stlc45xx.
Signed-off-by: Kalle Valo <kalle.valo@nokia.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
When I added scanning to cfg80211, we got a lock dependency like this:
rtnl --> cfg80211_mtx
nl80211, on the other hand, has the reverse lock dependency:
cfg80211_mtx --> rtnl
which clearly is a bad idea. This patch reworks nl80211 to take these
two locks in the other order to fix the possible, and easily
triggerable, deadlock.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
When the driver has been notified with a STA_REMOVE, it tears down
the internal ADDBA state. On resume, trying to initiate aggregation would
fail because mac80211 has not cleared the operational state for that <TID,STA>.
This can be fixed by tearing down the existing sessions on a suspend.
Also, the driver can initiate a new BA session when suspend is in progress.
This is fixed by marking the station as being in suspend state and
denying ADDBA requests for such STAs.
Signed-off-by: Sujith <Sujith.Manoharan@atheros.com>
To avoid concurrent manipulations of the sta list (which shouldn't
be possible at this point, but anyway) we need to hold the sta_lock
around iterating the list.
At the same time, we do not need to iterate the list at all if
the driver doesn't want to be notified.
Acked-by: Bob Copeland <me@bobcopeland.com>
This makes nl80211 export the supported commands (command groups)
per wiphy so userspace has an idea what it can do -- this will be
required reading for userspace when we introduce auth/assoc /or/
connect for older hardware that cannot separate auth and assoc.
SIOCSIWENCODE too
Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com>
Radiotap was updated to include a "bad PLCP" flag and standardise
the "bad FCS" flag in the "flags" rather than "RX flags" field,
this patch updates Linux to that standard.
Even though userland probably cannot submit packets, there might
still be some coming, and that's no good when the driver doesn't
expect them. Stop the queues across suspend/resume.
The last warning can never trigger, and the explicit AP_VLAN
check is pointless if we move the config_interface check down,
in practice config_interface is required anyway.
If a scan is queued in STA mode while the interface is in state direct
probe, authenticate or associate the scan is delayed until the interface
enters disabled or associated state. But in case of direct probe-,
authentication- or association- timeout sta_work will not be scheduled
anymore (without external trigger) and thus the pending scan is not
executed and prevents a new scan from being triggered (-EBUSY).
Fix this by queueing the sta work again after direct probe-, authentication-
and association- timeout.
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
This inline is useless and actually makes the code _longer_
rather than shorter.
The scan capability added to cfg80211/nl80211 introduced a
dependency on nl80211 by cfg80211. We can thus no longer have
just cfg80211 without nl80211. Specifically, cfg80211_scan_done()
calls nl80211_send_scan_aborted() or nl80211_send_scan_done().
Now we remove the option for user to select nl80211. It will always
be compiled if user selects cfg80211.
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
Don't call ieee80211_sta_find_ibss() directly, like it's done in STA
mode, so that the commit() call is more harmless respectively has
less site-effects.
Signed-off-by: Alina Friedrichsen <x-alina@gmx.net>
Otherwise we can wrap the sizes and end up sending garbage.
Closes #10423
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Its past 2.2 ...
spin_lock() should be spin_unlock() in xfrm_state_walk_done().
caused by:
commit 12a169e7d8f4b1c95252d8b04ed0f1033ed7cfe2
"ipsec: Put dumpers on the dump list"
Reported-by: Marc Milgram <mmilgram@redhat.com>
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
Commit 778d80be52699596bf70e0eb0761cf5e1e46088d
(ipv6: Add disable_ipv6 sysctl to disable IPv6 operaion on specific interface)
seems to have introduced a leak of sk_buff's for ipv6 traffic,
at least in some configurations where idev is NULL, or when ipv6
is disabled via sysctl.
The problem is that if the first condition of the if-statement
returns non-NULL, it returns an skb with only one reference,
and when the other conditions apply, execution jumps to the "out"
label, which does not call kfree_skb for it.
To plug this leak, change to use the "drop" label instead.
(this relies on it being ok to call kfree_skb on NULL)
This also allows us to avoid calling rcu_read_unlock here,
and removes the only user of the "out" label.
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
When I fixed the GRO crash in the legacy receive path I used
napi_complete to replace __napi_complete. Unfortunately they're
not the same when NETPOLL is enabled, which may result in us
not calling __napi_complete at all.
What's more, we really do need to keep the __napi_complete call
within the IRQ-off section since in theory an IRQ can occur in
between and fill up the backlog to the maximum, causing us to
lock up.
Since we can't seem to find a fix that works properly right now,
this patch reverts all the GRO support from the netif_rx path.
* 'bkl-removal' of git://git.lwn.net/linux-2.6:
Rationalize fasync return values
Move FASYNC bit handling to f_op->fasync()
Use f_lock to protect f_flags
Rename struct file->f_ep_lock
drivers/net/wimax/i2400m/usb-notif.c
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (61 commits)
Dynamic debug: fix pr_fmt() build error
Dynamic debug: allow simple quoting of words
dynamic debug: update docs
dynamic debug: combine dprintk and dynamic printk
sysfs: fix some bin_vm_ops errors
kobject: don't block for each kobject_uevent
sysfs: only allow one scheduled removal callback per kobj
Driver core: Fix device_move() vs. dpm list ordering, v2
Driver core: some cleanup on drivers/base/sys.c
Driver core: implement uevent suppress in kobject
vcs: hook sysfs devices into object lifetime instead of "binding"
driver core: fix passing platform_data
driver core: move platform_data into platform_device
sysfs: don't block indefinitely for unmapped files.
driver core: move knode_bus into private structure
driver core: move knode_driver into private structure
driver core: move klist_children into private structure
driver core: create a private portion of struct device
driver core: remove polling for driver_probe_done(v5)
sysfs: reference sysfs_dirent from sysfs inodes
Fixed conflicts in drivers/sh/maple/maple.c manually
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (29 commits)
crypto: sha512-s390 - Add missing block size
hwrng: timeriomem - Breaks an allyesconfig build on s390:
nlattr: Fix build error with NET off
crypto: testmgr - add zlib test
crypto: zlib - New zlib crypto module, using pcomp
crypto: testmgr - Add support for the pcomp interface
crypto: compress - Add pcomp interface
netlink: Move netlink attribute parsing support to lib
crypto: Fix dead links
hwrng: timeriomem - New driver
crypto: chainiv - Use kcrypto_wq instead of keventd_wq
crypto: cryptd - Per-CPU thread implementation based on kcrypto_wq
crypto: api - Use dedicated workqueue for crypto subsystem
crypto: testmgr - Test skciphers with no IVs
crypto: aead - Avoid infinite loop when nivaead fails selftest
crypto: skcipher - Avoid infinite loop when cipher fails selftest
crypto: api - Fix crypto_alloc_tfm/create_create_tfm return convention
crypto: api - crypto_alg_mod_lookup either tested or untested
crypto: amcc - Add crypt4xx driver
crypto: ansi_cprng - Add maintainer
On a box with most of the optional Netfilter switches turned off some
of the NLAs are never send, e. g. secmark, mark or the conntrack
byte/packet counters. As a worst case scenario this may possibly
still lead to ctnetlink skbs being reallocated in netlink_trim()
later, loosing all the nice effects from the previous patches.
I try to solve that (at least partly) by correctly #ifdef'ing the
NLAs in the computation.
Signed-off-by: Holger Eitzenberger <holger@eitzenberger.org>
Signed-off-by: Rami Rosen <ramirose@gmail.com>
This patch renames the ebt_ulog nf_logger from "ulog" to "ebt_ulog" to
be in sync with other modules naming. As this name was currently only
used for informational purpose, the renaming should be harmless.
Signed-off-by: Eric Leblond <eric@inl.fr>
The ebt_ulog module does not follow the fixed convention about function
return. Loading the module is triggering the following message:
sys_init_module: 'ebt_ulog'->init suspiciously returned 1, it should follow 0/-E convention
sys_init_module: loading module anyway...
Pid: 2334, comm: modprobe Not tainted 2.6.29-rc5edenwall0-00883-g199e57b #146
Call Trace:
[<c0441b81>] ? printk+0xf/0x16
[<c02311af>] sys_init_module+0x107/0x186
[<c0202cfa>] syscall_call+0x7/0xb
The following patch fixes the return treatment in ebt_ulog_init()
function.
This patch fixes the declaration of the logger structure in ebt_log
and ebt_ulog: I forgot to remove the const option from their declaration
in the commit ca735b3aaa945626ba65a3e51145bfe4ecd9e222 ("netfilter:
use a linked list of loggers").
Pointed-out-by: Stephen Rothwell <sfr@canb.auug.org.au>
This fixes an crash when empty bond device is added to a bridge.
If an interface with invalid ethernet address (all zero) is added
to a bridge, then bridge code detects it when setting up the forward
databas entry. But the error unwind is broken, the bridge port object
can get freed twice: once when ref count went to zeo, and once by kfree.
Since object is never really accessible, just free it.
Usefull for all protocols which do not add additional data, such
as GRE or UDPlite.
Try to allocate a Netlink skb roughly the size of the actual
message, with the help from the l3 and l4 protocol helpers.
This is all to prevent a reallocation in netlink_trim() later.
The overhead of allocating the right-sized skb is rather small, with
ctnetlink_alloc_skb() actually being inlined away on my x86_64 box.
The size of the per-proto space is determined at registration time of
the protocol helper.
Use "hlist_nulls" infrastructure we added in 2.6.29 for RCUification of UDP & TCP.
This permits an easy conversion from call_rcu() based hash lists to a
SLAB_DESTROY_BY_RCU one.
Avoiding call_rcu() delay at nf_conn freeing time has numerous gains.
First, it doesnt fill RCU queues (up to 10000 elements per cpu).
This reduces OOM possibility, if queued elements are not taken into account
This reduces latency problems when RCU queue size hits hilimit and triggers
emergency mode.
- It allows fast reuse of just freed elements, permitting better use of
CPU cache.
- We delete rcu_head from "struct nf_conn", shrinking size of this structure
by 8 or 16 bytes.
This patch only takes care of "struct nf_conn".
call_rcu() is still used for less critical conntrack parts, that may
be converted later if necessary.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Commit e1b4b9f ([NETFILTER]: {ip,ip6,arp}_tables: fix exponential worst-case
search for loops) introduced a regression in the loop detection algorithm,
causing sporadic incorrectly detected loops.
When a chain has already been visited during the check, it is treated as
having a standard target containing a RETURN verdict directly at the
beginning in order to not check it again. The real target of the first
rule is then incorrectly treated as STANDARD target and checked not to
contain invalid verdicts.
Fix by making sure the rule does actually contain a standard target.
Based on patch by Francis Dupont <Francis_Dupont@isc.org>
This is necessary in order to have an upper bound for Netlink
message calculation, which is not a problem at all, as there
are no helpers with a longer name.
It calculates the max. length of a Netlink policy, which is usefull
for allocating Netlink buffers roughly the size of the actual
message.
There is added a single callback for the l3 proto helper. The two
callbacks for the l4 protos are necessary because of the general
structure of a ctnetlink event, which is in short:
CTA_TUPLE_ORIG
<l3/l4-proto-attributes>
CTA_TUPLE_REPLY
CTA_ID
CTA_PROTOINFO
<l4-proto-attributes>
CTA_TUPLE_MASTER
Therefore the formular is
size := sizeof(generic-nlas) + 3 * sizeof(tuple_nlas) + sizeof(protoinfo_nlas)
Some of the NLAs are optional, e. g. CTA_TUPLE_MASTER, which is only
set if it's an expected connection. But the number of optional NLAs is
small enough to prevent netlink_trim() from reallocating if calculated
properly.
We use same not trivial helper function in four places. We can factorize it.
Using hlist_add_head() in nf_conntrack_set_hashsize() is quite dangerous.
Without any barrier, one CPU could see a loop while doing its lookup.
Its true new table cannot be seen by another cpu, but previous table is still
readable.
net/netfilter/xt_LED.c:40: error: field netfilter_led_trigger has incomplete type
net/netfilter/xt_LED.c: In function led_timeout_callback:
net/netfilter/xt_LED.c:78: warning: unused variable ledinternal
net/netfilter/xt_LED.c: In function led_tg_check:
net/netfilter/xt_LED.c:102: error: implicit declaration of function led_trigger_register
net/netfilter/xt_LED.c: In function led_tg_destroy:
net/netfilter/xt_LED.c:135: error: implicit declaration of function led_trigger_unregister
Fix by adding a dependency on LED_TRIGGERS.
Reported-by: Sachin Sant <sachinp@in.ibm.com>
Tested-by: Subrata Modak <tosubrata@gmail.com>
The ipv6 version of bind_conflict code calls ipv6_rcv_saddr_equal()
which at times wrongly identified intersections between addresses.
It particularly broke down under a few instances and caused erroneous
bind conflicts.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Binding to a v4-mapped address on an AF_INET6 socket should
produce the same result as binding to an IPv4 address on
AF_INET socket. The two are interchangable as v4-mapped
address is really a portability aid.
The IPv4 wildcard (0.0.0.0) address does not intersect
in any way with explicit IPv6 addresses. These two should
be permitted, but the IPv4 conflict code checks the ipv6only
bit as part of the test. Since binding to an explicit IPv6
address restricts the socket to only that IPv6 address, the
side-effect is that the socket behaves as v6-only. By
explicitely setting ipv6only in this case, allows the 2 binds
to succeed.
A socket marked v6-only, can not receive or send traffic to v4-mapped
addresses. Thus allowing binding to v4-mapped address on such a
socket makes no sense.
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
This patch combines Greg Bank's dprintk() work with the existing dynamic
printk patchset, we are now calling it 'dynamic debug'.
The new feature of this patchset is a richer /debugfs control file interface,
(an example output from my system is at the bottom), which allows fined grained
control over the the debug output. The output can be controlled by function,
file, module, format string, and line number.
for example, enabled all debug messages in module 'nf_conntrack':
echo -n 'module nf_conntrack +p' > /mnt/debugfs/dynamic_debug/control
to disable them:
echo -n 'module nf_conntrack -p' > /mnt/debugfs/dynamic_debug/control
A further explanation can be found in the documentation patch.
Signed-off-by: Greg Banks <gnb@sgi.com>
Signed-off-by: Jason Baron <jbaron@redhat.com>
