path: root/net
2006-01-06SUNRPC: rpc_execute should not return task->tk_status;Trond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06SUNRPC: Get rid of some unused exportsTrond Myklebust
2006-01-06NFSv4: stateful NFSv4 RPC call interfaceTrond Myklebust
The NFSv4 model requires us to complete all RPC calls that might establish state on the server whether or not the user wants to interrupt it. We may also need to schedule new work (including new RPC calls) in order to cancel the new state. The asynchronous RPC model will allow us to ensure that RPC calls always complete, but in order to allow for "synchronous" RPC, we want to add the ability to wait for completion. The waits are, of course, interruptible. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06SUNRPC: Further cleanupsTrond Myklebust
2006-01-06RPC: Clean up RPC task structureTrond Myklebust
Shrink the RPC task structure. Instead of storing separate pointers for task->tk_exit and task->tk_release, put them in a structure. Also pass the user data pointer as a parameter instead of passing it via task->tk_calldata. This enables us to nest callbacks. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06SUNRPC: Yet more RPC cleanupsTrond Myklebust
2006-01-06[PATCH] Keep nfsd from exiting when seeing recv() errorsOlaf Kirch
I submitted this one previously - svc_tcp_recvfrom currently returns any errors to the caller, including ECONNRESET and the like. This is something svc_recv isn't able to deal with: len = svsk->sk_recvfrom(rqstp); [...] if (len == 0 || len == -EAGAIN) { [...] return -EAGAIN; } [...] return len; The nfsd main loop will exit when it sees an error code other than EAGAIN. The following patch fixes this problem svc_recv is not equipped to deal with error codes other than EAGAIN, and will propagate anything else (such as ECONNRESET) up to nfsd, causing it to exit. Signed-off-by: Olaf Kirch <okir@suse.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] knfsd: fix hash function for IP addresses on 64bit little-endian ↵NeilBrown
machines. The hash.h hash_long function, when used on a 64 bit machine, ignores many of the middle-order bits. (The prime chosen it too bit-sparse). IP addresses for clients of an NFS server are very likely to differ only in the low-order bits. As addresses are stored in network-byte-order, these bits become middle-order bits in a little-endian 64bit 'long', and so do not contribute to the hash. Thus you can have the situation where all clients appear on one hash chain. So, until hash_long is fixed (or maybe forever), us a hash function that works well on IP addresses - xor the bytes together. Thanks to "Iozone" <capps@iozone.org> for identifying this problem. Cc: "Iozone" <capps@iozone.org> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-05[NET]: Change 1500 to ETH_DATA_LEN in some filesKris Katterjohn
These patches add the header linux/if_ether.h and change 1500 to ETH_DATA_LEN in some files. Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[IPVS]: Another file needs linux/interrupt.hAndrew Morton
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: Use HOPLIMIT metric as TTL of TCP reset sent by REJECTYasuyuki Kozakai
HOPLIMIT metric is appropriate to TCP reset sent by REJECT target than hard-coded max TTL. Thanks to David S. Miller for hint. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: nf_conntrack_l3proto_ipv4.c needs net/route.hPatrick McHardy
CC [M] net/ipv4/netfilter/nf_conntrack_l3proto_ipv4.o net/ipv4/netfilter/nf_conntrack_l3proto_ipv4.c: In function 'ipv4_refrag': net/ipv4/netfilter/nf_conntrack_l3proto_ipv4.c:198: error: dereferencing pointer to incomplete type make[3]: *** [net/ipv4/netfilter/nf_conntrack_l3proto_ipv4.o] Error 1 Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: Export ip6_masked_addrcmp, don't pass IPv6 addresses on stackPatrick McHardy
2006-01-05[NETFILTER]: make ipv6_find_hdr() find transport protocol headerPatrick McHardy
The original ipv6_find_hdr() finds the specified header in IPv6 packets. This makes it possible to get transport header so that we can kill similar loop in ip6_match_packet(). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: Call POST_ROUTING hook before fragmentationPatrick McHardy
Call POST_ROUTING hook before fragmentation to get rid of the okfn use in ip_refrag and save the useless fragmentation/defragmentation step when NAT is used. The patch introduces one user-visible change, the POSTROUTING chain in the mangle table gets entire packets, not fragments, which should simplify use of the MARK and CLASSIFY targets for queueing as a nice side-effect. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: Remove okfn usage in ip_vs_core.cPatrick McHardy
okfn should only be used from different contexts to avoid deep call chains, i.e. by nf_queue. Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: ctnetlink: Fix dumping of helper namePatrick McHardy
Properly dump the helper name instead of internal kernel data. Based on patch by Marcus Sundberg <marcus@ingate.com>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: Fix module_param types and permissionsPatrick McHardy
Fix netfilter module_param types and permissions. Also fix an off-by-one in the ipt_ULOG nlbufsiz < 128k check. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: Filter dumped entries based on the layer 3 protocol numberPablo Neira Ayuso
Dump entries of a given Layer 3 protocol number. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: Add ctnetlink port for nf_conntrackPablo Neira Ayuso
2006-01-05[NETFILTER]: ctnetlink: remove unused variablePablo Neira Ayuso
2006-01-05[NETFILTER]: ctnetlink: fix conntrack mark racePablo Neira Ayuso
Set conntrack mark before it is in hashes. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: ctnetlink: ctnetlink_event cleanupPablo Neira Ayuso
Cleanup: Use 'else if' instead of a ugly 'goto' statement. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: ctnetlink: use u_int32_t instead of unsigned intPablo Neira Ayuso
2006-01-05[NETFILTER]: ctnetlink: propagate ctnetlink_dump_tuples_proto return value backPablo Neira Ayuso
2006-01-05[NETFILTER]: ctnetlink: Add sanity checkings for ICMPYasuyuki Kozakai
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: ctnetlink: remove bogus checks in ICMP protocol at dumpingPablo Neira Ayuso
2006-01-05[NETFILTER]: Decrease number of pointer derefs in nf_conntrack_core.cJesper Juhl
Benefits of the patch: - Fewer pointer dereferences should make the code slightly faster. - Size of generated code is smaller - improved readability Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-05[NETFILTER]: Decrease number of pointer derefs in nfnetlink_queue.cJesper Juhl
2006-01-05[IPVS]: Fix compilationAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
Trivial manual merge fixup for usb_find_interface clashes.
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2006-01-04Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2006-01-04[PATCH] net: swich device attribute creation to default attrsKay Sievers
Recent udev versions don't longer cover bad sysfs timing with built-in logic. Explicit rules are required to do that. For net devices, the following is needed: ACTION=="add", SUBSYSTEM=="net", WAIT_FOR_SYSFS="address" to handle access to net device properties from an event handler without races. This patch changes the main net attributes to be created by the driver core, which is done _before_ the event is sent out and will not require the stat() loop of the WAIT_FOR_SYSFS key. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] driver core: replace "hotplug" by "uevent"Kay Sievers
Leave the overloaded "hotplug" word to susbsystems which are handling real devices. The driver core does not "plug" anything, it just exports the state to userspace and generates events. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[TCP] tcp_vegas: Fix slow startThomas Young
Vegas' slow start was only adding one MSS per RTT rather than one for every ack. Slow start behavior should now match Reno. Signed-off-by: Thomas Young <tyo@ee.mu.oz.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-04[NET]: More instruction checks fornet/core/filter.cKris Katterjohn
2006-01-04[NETFILTER]: Use macro for spinlock_t/rwlock_t initializations/definition.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-04[IPV6]: Use macro for rwlock_t initialization.YOSHIFUJI Hideaki
2006-01-04[ECONET]: Use macro for spinlock_t definition.YOSHIFUJI Hideaki
2006-01-04[IPVS]: Add missing include <linux/net.h>Arnaldo Carvalho de Melo
CC [M] net/ipv4/ipvs/ip_vs_conn.o /pub/scm/linux/kernel/git/acme/net-2.6/net/ipv4/ipvs/ip_vs_conn.c: In function 'ip_vs_conn_new': /pub/scm/linux/kernel/git/acme/net-2.6/net/ipv4/ipvs/ip_vs_conn.c:606: warning: implicit declaration of function 'net_ratelimit' /pub/scm/linux/kernel/git/acme/net-2.6/net/ipv4/ipvs/ip_vs_conn.c: In function 'ip_vs_random_dropentry': /pub/scm/linux/kernel/git/acme/net-2.6/net/ipv4/ipvs/ip_vs_conn.c:810: warning: implicit declaration of function 'net_random' Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-01-04[TCP]: syn_flood_warning is only needed if CONFIG_SYN_COOKIES is selectedArnaldo Carvalho de Melo
CC net/ipv4/tcp_ipv4.o /pub/scm/linux/kernel/git/acme/net-2.6/net/ipv4/tcp_ipv4.c:665: warning: 'syn_flood_warning' defined but not used Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-01-04[DCCP] ackvec: use u8 for the buf offsetsArnaldo Carvalho de Melo
2006-01-04[DCCP] ackvec: Fix spelling of "throw"Andrea Bittau
Signed-off-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-01-03[TCP]: less inline'sStephen Hemminger
TCP inline usage cleanup: * get rid of inline in several places * replace __inline__ with inline where possible * move functions used in one file out of tcp.h * let compiler decide on used once cases On x86_64: text data bss dec hex filename 3594701 648348 567400 4810449 4966d1 vmlinux.orig 3593133 648580 567400 4809113 496199 vmlinux On sparc64: text data bss dec hex filename 2538278 406152 530392 3474822 350586 vmlinux.ORIG 2536382 406384 530392 3473158 34ff06 vmlinux Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IEEE80211] ipw2200: Simplify multicast checks.Stephen Hemminger
From: Stephen Hemminger <shemminger@osdl.org> is_multicast_ether_addr() accepts broadcast too, so the is_broadcast_ether_addr() calls are redundant. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV4] fib_trie: build fixStephen Hemminger
Need this to fix build of fib_trie in net-2.6.16 (rebased) tree. The code needs the new inet_make_mask inline. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[BRIDGE]: Fix faulty check in br_stp_recalculate_bridge_id()Stephen Hemminger
One of the conversions from memcmp to compare_ether_addr is incorrect. We need to do relative comparison to determine min MAC address to use in bridge id. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[DCCP]: Notify CCID only after ACK vectors have been processed.Andrea Bittau
The CCID should be notified of packet reception only when a packet is valid. Therefore, the ACK vector needs to be processed before notifying the CCID. Also, the CCID might need information provided by the ACK vector. Signed-off-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[DCCP]: Send an ACK vector when ACKing a response packetAndrea Bittau
If ACK vectors are used, each packet with an ACK should contain an ACK vector. The only exception currently is response packets. It probably is not a good idea to store ACK vector state before the connection is completed (to help protect from syn floods). Signed-off-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
