path: root/net
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[SOCK]: Introduce sk_receive_skbArnaldo Carvalho de Melo
Its common enough to to justify that, TCP still can't use it as it has the prequeueing stuff, still to be made generic in the not so distant future :-) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: restructure sock_aio_{read,write} / sock_{readv,writev}Christoph Hellwig
Mid-term I plan to restructure the file_operations so that we don't need to have all these duplicate aio and vectored versions. This patch is a small step in that direction but also a worthwile cleanup on it's own: (1) introduce a alloc_sock_iocb helper that encapsulates allocating a proper sock_iocb (2) add do_sock_read and do_sock_write helpers for common read/write code Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: Fix sock_init() return value.David S. Miller
It needs to return zero now that it is an initcall. Also, net/nonet.c no longer needs a dummy sock_init(). Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[PKTGEN]: Deinitialise static variables.Jaco Kroon
static variables should not be explicitly initialised to 0. This causes them to be placed in .data instead of .bss. This patch de-initialises 3 static variables in net/core/pktgen.c. There are approximately 800 more such variables in the source tree (2.6.15rc5). If there is more interrest I'd be willing to track down the rest of these as well and de-initialise them as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: Small cleanup to socket initializationAndi Kleen
sock_init can be done as a core_initcall instead of calling it directly in init/main.c Also I removed an out of date #ifdef. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[SCTP]: Add support for SCTP_DELAYED_ACK_TIME socket option.Frank Filz
Signed-off-by: Frank Filz <ffilz@us.ibm.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[SCTP]: Update SCTP_PEER_ADDR_PARAMS socket option to the latest api draft.Frank Filz
This patch adds support to set/get heartbeat interval, maximum number of retransmissions, pathmtu, sackdelay time for a particular transport/ association/socket as per the latest SCTP sockets api draft11. Signed-off-by: Frank Filz <ffilz@us.ibm.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV4] fib_trie: Add credits.Robert Olsson
Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TCP] cubic: use Newton-RaphsonStephen Hemminger
Replace cube root algorithim with a faster version using Newton-Raphson. Surprisingly, doing the scaled div64_64 is faster than a true 64 bit division on 64 bit CPU's. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TCP] cubic: precompute constantsStephen Hemminger
Revised version of patch to pre-compute values for TCP cubic. * d32,d64 replaced with descriptive names * cube_factor replaces srtt[scaled by count] / HZ * ((1 << (10+2*BICTCP_HZ)) / bic_scale) * beta_scale replaces 8*(BICTCP_BETA_SCALE+beta)/3/(BICTCP_BETA_SCALE-beta); Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[PKT_SCHED] netem: packet corruption optionStephen Hemminger
Here is a new feature for netem in 2.6.16. It adds the ability to randomly corrupt packets with netem. A version was done by Hagen Paul Pfeifer, but I redid it to handle the cases of backwards compatibility with netlink interface and presence of hardware checksum offload. It is useful for testing hardware offload in devices. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[BRIDGE]: add version numberStephen Hemminger
Add version info to bridge module. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[BRIDGE]: limited ethtool supportStephen Hemminger
Add limited ethtool support to bridge to allow disabling features. Note: if underlying device does not support a feature (like checksum offload), then the bridge device won't inherit it. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[BRIDGE]: filter packets in learning stateStephen Hemminger
While in the learning state, run filters but drop the result. This prevents us from acquiring bad fdb entries in learning state. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[BRIDGE]: handle speed detection after carrier changesStephen Hemminger
Speed of a interface may not be available until carrier is detected in the case of autonegotiation. To get the correct value we need to recheck speed after carrier event. But the check needs to be done in a context that is similar to normal ethtool interface (can sleep). Also, delay check for 1ms to try avoid any carrier bounce transitions. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[BRIDGE]: allow setting hardware address of bridge pseudo-devStephen Hemminger
Some people are using bridging to hide multiple machines from an ISP that restricts by MAC address. So in that case allow the bridge mac address to be set to any of the existing interfaces. I don't want to allow any arbitrary value and confuse STP. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[AF_UNIX]: Use spinlock for unix_table_lockDavid S. Miller
This lock is actually taken mostly as a writer, so using a rwlock actually just makes performance worse especially on chips like the Intel P4. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IP_SOCKGLUE]: Remove most of the tcp specific callsArnaldo Carvalho de Melo
As DCCP needs to be called in the same spots. Now we have a member in inet_sock (is_icsk), set at sock creation time from struct inet_protosw->flags (if INET_PROTOSW_ICSK is set, like for TCP and DCCP) to see if a struct sock instance is a inet_connection_sock for places like the ones in ip_sockglue.c (v4 and v6) where we previously were looking if sk_type was SOCK_STREAM, that is insufficient because we now use the same code for DCCP, that has sk_type SOCK_DCCP. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET6]: Generalise tcp_v6_hash_connectArnaldo Carvalho de Melo
Renaming it to inet6_hash_connect, making it possible to ditch dccp_v6_hash_connect and share the same code with TCP instead. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET]: Generalise tcp_v4_hash_connectArnaldo Carvalho de Melo
Renaming it to inet_hash_connect, making it possible to ditch dccp_v4_hash_connect and share the same code with TCP instead. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TWSK]: Introduce struct timewait_sock_opsArnaldo Carvalho de Melo
So that we can share several timewait sockets related functions and make the timewait mini sockets infrastructure closer to the request mini sockets one. Next changesets will take advantage of this, moving more code out of TCP and DCCP v4 and v6 to common infrastructure. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[DCCP]: Use reqsk_free in dccp_v4_conn_requestArnaldo Carvalho de Melo
Now we have the destructor (dccp_v4_reqsk_destructor) in our request_sock_ops vtable. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[DCCP]: Introduce DCCPv6Arnaldo Carvalho de Melo
Still needs mucho polishing, specially in the checksum code, but works just fine, inet_diag/iproute2 and all 8) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Export ipv6_opt_acceptedArnaldo Carvalho de Melo
It was already non-TCP specific, will be used by DCCPv6. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[DCCP]: Prepare the AF agnostic core for the introduction of DCCPv6Arnaldo Carvalho de Melo
Basically exports a similar set of functions as the one exported by the non-AF specific TCP code. In the process moved some non-AF specific code from dccp_v4_connect to dccp_connect_init and moved the checksum verification from dccp_invalid_packet to dccp_v4_rcv, so as to use it in dccp_v6_rcv too. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[DCCP]: Just rename dccp_v4_prot to dccp_protArnaldo Carvalho de Melo
To match TCP equivalent. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Export some symbols for DCCPv6Arnaldo Carvalho de Melo
2006-01-03[IPV6]: Introduce inet6_timewait_sockArnaldo Carvalho de Melo
Out of tcp6_timewait_sock, that now is just an aggregation of inet_timewait_sock and inet6_timewait_sock, using tw_ipv6_offset in struct inet_timewait_sock, that is common to the IPv6 transport protocols that use timewait sockets, like DCCP and TCP. tw_ipv6_offset plays the struct inet_sock pinfo6 role, i.e. for the generic code to find the IPv6 area in a timewait sock. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Generalise some functionsArnaldo Carvalho de Melo
Using sk->sk_protocol instead of IPPROTO_TCP. Will be used by DCCPv6 in the next changesets. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[AF_UNIX]: Remove superfluous reference counting in unix_stream_sendmsgBenjamin LaHaise
AF_UNIX stream socket performance on P4 CPUs tends to suffer due to a lot of pipeline flushes from atomic operations. The patch below removes the sock_hold() and sock_put() in unix_stream_sendmsg(). This should be safe as the socket still holds a reference to its peer which is only released after the file descriptor's final user invokes unix_release_sock(). The only consideration is that we must add a memory barrier before setting the peer initially. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: Avoid atomic xchg() for non-error caseBenjamin LaHaise
It also looks like there were 2 places where the test on sk_err was missing from the event wait logic (in sk_stream_wait_connect and sk_stream_wait_memory), while the rest of the sock_error() users look to be doing the right thing. This version of the patch fixes those, and cleans up a few places that were testing ->sk_err directly. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPVS]: remove dead codeRoberto Nibali
This patch removes dead code. I don't see the reason to keep this cruft around, besides cluttering the nice and functionally working code. Signed-off-by: Roberto Nibali <ratz@drugphish.ch> Signed-off-by: Horms <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[UDP]: udp_checksum_init return valueStephen Hemminger
Since udp_checksum_init always returns 0 there is no point in having it return a value. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IP]: Simplify and consolidate MSG_PEEK error handlingHerbert Xu
When a packet is obtained from skb_recv_datagram with MSG_PEEK enabled it is left on the socket receive queue. This means that when we detect a checksum error we have to be careful when trying to free the packet as someone could have dequeued it in the time being. Currently this delicate logic is duplicated three times between UDPv4, UDPv6 and RAWv6. This patch moves them into a one place and simplifies the code somewhat. This is based on a suggestion by Eric Dumazet. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[DCCP]: Introduce dccp_ipv4_af_opsArnaldo Carvalho de Melo
And make the core DCCP code AF agnostic, just like TCP, now its time to work on net/dccp/ipv6.c, we are close to the end! Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[ICSK]: Move v4_addr2sockaddr from TCP to icskArnaldo Carvalho de Melo
Renaming it to inet_csk_addr2sockaddr. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[ICSK]: Rename struct tcp_func to struct inet_connection_sock_af_opsArnaldo Carvalho de Melo
And move it to struct inet_connection_sock. DCCP will use it in the upcoming changesets. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Introduce inet6_rsk()Arnaldo Carvalho de Melo
And inet6_rsk_offset in inet_request_sock, for the same reasons as inet_sock's pinfo6 member. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Generalise tcp_v6_search_req & tcp_v6_synq_addArnaldo Carvalho de Melo
More work is needed tho to introduce inet6_request_sock from tcp6_request_sock, in the same layout considerations as ipv6_pinfo in inet_sock, next changeset will do that. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[ICSK]: make inet_csk_reqsk_queue_hash_add timeout arg unsigned longArnaldo Carvalho de Melo
2006-01-03[IPV6]: Generalise __tcp_v6_hash, renaming it to __inet6_hashArnaldo Carvalho de Melo
2006-01-03[IPV6]: Reuse inet_csk_get_port in tcp_v6_get_portArnaldo Carvalho de Melo
2006-01-03[IPV4]: Safer reassemblyHerbert Xu
Another spin of Herbert Xu's "safer ip reassembly" patch for 2.6.16. (The original patch is here: http://marc.theaimsgroup.com/?l=linux-netdev&m=112281936522415&w=2 and my only contribution is to have tested it.) This patch (optionally) does additional checks before accepting IP fragments, which can greatly reduce the possibility of reassembling fragments which originated from different IP datagrams. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arthur Kepner <akepner@sgi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NETFILTER] ebtables: Support nf_log API from ebt_log and ebt_ulogBart De Schuymer
This makes ebt_log and ebt_ulog use the new nf_log api. This enables the bridging packet filter to log packets e.g. via nfnetlink_log. Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NETFILTER] ip_tables: NUMA-aware allocationEric Dumazet
Part of a performance problem with ip_tables is that memory allocation is not NUMA aware, but 'only' SMP aware (ie each CPU normally touch separate cache lines) Even with small iptables rules, the cost of this misplacement can be high on common workloads. Instead of using one vmalloc() area (located in the node of the iptables process), we now allocate an area for each possible CPU, using vmalloc_node() so that memory should be allocated in the CPU's node if possible. Port to arp_tables and ip6_tables by Harald Welte. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TCP] BIC: CUBIC window growth (2.0)Stephen Hemminger
Replace existing BIC version 1.1 with new version 2.0. The main change is to replace the window growth function with a cubic function as described in: http://www.csc.ncsu.edu/faculty/rhee/export/bitcp/cubic-paper.pdf Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TCP] BIC: spelling and whitespaceStephen Hemminger
2006-01-03[TCP] BIC: remove low utilization code.Stephen Hemminger
The latest BICTCP patch at: http://www.csc.ncsu.edu:8080/faculty/rhee/export/bitcp/index_files/Page546.htm disables the low_utilization feature of BICTCP because it doesn't work in some cases. This patch removes it. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
