path: root/net
2010-04-27bridge: multicast router list manipulationstephen hemminger
I prefer that the hlist be only accessed through the hlist macro objects. Explicit twiddling of links (especially with RCU) exposes the code to future bugs. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27bridge: use is_multicast_ether_addrstephen hemminger
Use existing inline function. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e100.c drivers/net/e1000e/netdev.c
2010-04-27bridge: Fix build of ipv6 multicast code.David S. Miller
Based upon a report from Stephen Rothwell: -------------------- net/bridge/br_multicast.c: In function 'br_ip6_multicast_alloc_query': net/bridge/br_multicast.c:469: error: implicit declaration of function 'csum_ipv6_magic' Introduced by commit 08b202b6726459626c73ecfa08fcdc8c3efc76c2 ("bridge br_multicast: IPv6 MLD support") from the net tree. csum_ipv6_magic is declared in net/ip6_checksum.h ... -------------------- Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-26bridge br_multicast: Ensure to initialize BR_INPUT_SKB_CB(skb)->mrouters_only.YOSHIFUJI Hideaki / 吉藤英明
Even with commit 32dec5dd0233ebffa9cae25ce7ba6daeb7df4467 ("bridge br_multicast: Don't refer to BR_INPUT_SKB_CB(skb)->mrouters_only without IGMP snooping."), BR_INPUT_SKB_CB(skb)->mrouters_only is not appropriately initialized if IGMP/MLD snooping support is compiled and disabled, so we can see garbage. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
Even with commit 32dec5dd0233ebffa9cae25ce7ba6daeb7df4467 ("bridge br_multicast: Don't refer to BR_INPUT_SKB_CB(skb)->mrouters_only without IGMP snooping."), BR_INPUT_SKB_CB(skb)->mrouters_only is not appropriately initialized if IGMP snooping support is compiled and disabled, so we can see garbage. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-26ieee802154: Fix oops during ieee802154_sock_ioctlStefan Schmidt
Trying to run izlisten (from lowpan-tools tests) on a device that does not exists I got the oops below. The problem is that we are using get_dev_by_name without checking if we really get a device back. We don't in this case and writing to dev->type generates this oops. [Oops code removed by Dmitry Eremin-Solenikov] If possible this patch should be applied to the current -rc fixes branch. Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org> Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-26net: use sk_sleep()Eric Dumazet
Commit aa395145 (net: sk_sleep() helper) missed three files in the conversion. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-26phonet: use phonet_pernet instead of directly net_genericJiri Pirko
As in for example pppoe introduce phonet_pernet and use it instead of calling net_generic directly. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-25ipv6: Fix inet6_csk_bind_conflict()Eric Dumazet
Commit fda48a0d7a84 (tcp: bind() fix when many ports are bound) introduced a bug on IPV6 part. We should not call ipv6_addr_any(inet6_rcv_saddr(sk2)) but ipv6_addr_any(inet6_rcv_saddr(sk)) because sk2 can be IPV4, while sk is IPV6. Reported-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-25netns: rename unregister_pernet_subsys parameterJiri Pirko
Stay consistent with other functions and with comment also and name pernet_operations parameter properly. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-24rps: optimize rps_get_cpu()Changli Gao
optimize rps_get_cpu(). don't initialize ports when we can get the ports. one memory access for ports than two. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-23Merge branch 'net-next-2.6_20100423a/br/br_multicast_v3' of ↵David S. Miller
git://git.linux-ipv6.org/gitroot/yoshfuji/linux-2.6-next
2010-04-23IPv6: Complete IPV6_DONTFRAG supportBrian Haley
Finally add support to detect a local IPV6_DONTFRAG event and return the relevant data to the user if they've enabled IPV6_RECVPATHMTU on the socket. The next recvmsg() will return no data, but have an IPV6_PATHMTU as ancillary data. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-23IPv6: Add dontfrag argument to relevant functionsBrian Haley
Add dontfrag argument to relevant functions for IPV6_DONTFRAG support, as well as allowing the value to be passed-in via ancillary cmsg data. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-23IPv6: data structure changes for new socket optionsBrian Haley
Add underlying data structure changes and basic setsockopt() and getsockopt() support for IPV6_RECVPATHMTU, IPV6_PATHMTU, and IPV6_DONTFRAG. IPV6_PATHMTU is actually fully functional at this point. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-23l2tp_eth: fix memory allocationJiri Pirko
Since .size is set properly in "struct pernet_operations l2tp_eth_net_ops", allocating space for "struct l2tp_eth_net" by hand is not correct, even causes memory leakage. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-23l2tp: fix memory allocationJiri Pirko
Since .size is set properly in "struct pernet_operations l2tp_net_ops", allocating space for "struct l2tp_net" by hand is not correct, even causes memory leakage. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-23Merge branch 'master' into for-davemJohn W. Linville
Conflicts: drivers/net/wireless/ath/ath9k/phy.c drivers/net/wireless/iwlwifi/iwl-6000.c drivers/net/wireless/iwlwifi/iwl-debugfs.c
2010-04-23bridge br_multicast: IPv6 MLD support.YOSHIFUJI Hideaki
2010-04-23bridge br_multicast: Make functions less ipv4 dependent.YOSHIFUJI Hideaki
Introduce struct br_ip{} to store ip address and protocol and make functions more generic so that we can support both IPv4 and IPv6 with less pain. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2010-04-23ipv6 mcast: Introduce include/net/mld.h for MLD definitions.YOSHIFUJI Hideaki
2010-04-22tcp: bind() fix when many ports are boundEric Dumazet
Port autoselection done by kernel only works when number of bound sockets is under a threshold (typically 30000). When this threshold is over, we must check if there is a conflict before exiting first loop in inet_csk_get_port() Change inet_csk_bind_conflict() to forbid two reuse-enabled sockets to bind on same (address,port) tuple (with a non ANY address) Same change for inet6_csk_bind_conflict() Reported-by: Gaspar Chilingarov <gasparch@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22X25: Add if_x25.h and x25 to device identifiersAndrew Hendry
V2 Feedback from John Hughes. - Add header for userspace implementations such as xot/xoe to use - Use explicit values for interface stability - No changes to driver patches V1 - Use identifiers instead of magic numbers for X25 layer 3 to device interface. - Also fixed checkpatch notes on updated code. [ Add new user header to include/linux/Kbuild -DaveM ] Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22net: Socket filter ancilliary data access for skb->dev->typePaul LeoNerd Evans
Add an SKF_AD_HATYPE field to the packet ancilliary data area, giving access to skb->dev->type, as reported in the sll_hatype field. When capturing packets on a PF_PACKET/SOCK_RAW socket bound to all interfaces, there doesn't appear to be a way for the filter program to actually find out the underlying hardware type the packet was captured on. This patch adds such ability. This patch also handles the case where skb->dev can be NULL, such as on netlink sockets. Signed-off-by: Paul Evans <leonerd@leonerd.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22tcp: fix outsegs stat for TSO segmentsTom Herbert
Account for TSO segments of an skb in TCP_MIB_OUTSEGS counter. Without doing this, the counter can be off by orders of magnitude from the actual number of segments sent. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22rdma: potential ERR_PTR dereferenceDan Carpenter
In the original code, the "goto out" calls "rdma_destroy_id(cm_id);" That isn't needed here and would cause problems because "cm_id" is an ERR_PTR. The new code just returns directly. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22rtnetlink: potential ERR_PTR dereferenceDan Carpenter
In the original code, if rtnl_create_link() returned an ERR_PTR then that would get passed to rtnl_configure_link() which dereferences it. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22IPv6: Generic TTL Security Mechanism (final version)Stephen Hemminger
This patch adds IPv6 support for RFC5082 Generalized TTL Security Mechanism. Not to users of mapped address; the IPV6 and IPV4 socket options are seperate. The server does have to deal with both IPv4 and IPv6 socket options and the client has to handle the different for each family. On client: int ttl = 255; getaddrinfo(argv[1], argv[2], &hint, &result); for (rp = result; rp != NULL; rp = rp->ai_next) { s = socket(rp->ai_family, rp->ai_socktype, rp->ai_protocol); if (s < 0) continue; if (rp->ai_family == AF_INET) { setsockopt(s, IPPROTO_IP, IP_TTL, &ttl, sizeof(ttl)); } else if (rp->ai_family == AF_INET6) { setsockopt(s, IPPROTO_IPV6, IPV6_UNICAST_HOPS, &ttl, sizeof(ttl))) } if (connect(s, rp->ai_addr, rp->ai_addrlen) == 0) { ... On server: int minttl = 255 - maxhops; getaddrinfo(NULL, port, &hints, &result); for (rp = result; rp != NULL; rp = rp->ai_next) { s = socket(rp->ai_family, rp->ai_socktype, rp->ai_protocol); if (s < 0) continue; if (rp->ai_family == AF_INET6) setsockopt(s, IPPROTO_IPV6, IPV6_MINHOPCOUNT, &minttl, sizeof(minttl)); setsockopt(s, IPPROTO_IP, IP_MINTTL, &minttl, sizeof(minttl)); if (bind(s, rp->ai_addr, rp->ai_addrlen) == 0) break ... Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22net: Orphan and de-dst skbs earlier in xmit path.David S. Miller
This way GSO packets don't get handled differently. With help from Eric Dumazet. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com>
2010-04-22rps: immediate send IPI in process_backlog()Eric Dumazet
If some skb are queued to our backlog, we are delaying IPI sending at the end of net_rx_action(), increasing latencies. This defeats the queueing, since we want to quickly dispatch packets to the pool of worker cpus, then eventually deeply process our packets. It's better to send IPI before processing our packets in upper layers, from process_backlog(). Change the _and_disable_irq suffix to _and_enable_irq(), since we enable local irq in net_rps_action(), sorry for the confusion. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21net: ipv6 bind to device issueJiri Olsa
The issue raises when having 2 NICs both assigned the same IPv6 global address. If a sender binds to a particular NIC (SO_BINDTODEVICE), the outgoing traffic is being sent via the first found. The bonded device is thus not taken into an account during the routing. From the ip6_route_output function: If the binding address is multicast, linklocal or loopback, the RT6_LOOKUP_F_IFACE bit is set, but not for global address. So binding global address will neglect SO_BINDTODEVICE-binded device, because the fib6_rule_lookup function path won't check for the flowi::oif field and take first route that fits. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Scott Otto <scott.otto@alcatel-lucent.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21ethernet: print protocol in host byte orderJohannes Berg
Eric's recent patch added __force, but this place would seem to require actually doing a byte order conversion so the printk is consistent across architectures. Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21net: Introduce skb_orphan_try()Eric Dumazet
At this point, skb->destructor is not the original one (stored in DEV_GSO_CB(skb)->destructor) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21ipv6: allow to send packet after receiving ICMPv6 Too Big message with MTU ↵Shan Wei
field less than IPV6_MIN_MTU According to RFC2460, PMTU is set to the IPv6 Minimum Link MTU (1280) and a fragment header should always be included after a node receiving Too Big message reporting PMTU is less than the IPv6 Minimum Link MTU. After receiving a ICMPv6 Too Big message reporting PMTU is less than the IPv6 Minimum Link MTU, sctp *can't* send any data/control chunk that total length including IPv6 head and IPv6 extend head is less than IPV6_MIN_MTU(1280 bytes). The failure occured in p6_fragment(), about reason see following(take SHUTDOWN chunk for example): sctp_packet_transmit (SHUTDOWN chunk, len=16 byte) |------sctp_v6_xmit (local_df=0) |------ip6_xmit |------ip6_output (dst_allfrag is ture) |------ip6_fragment In ip6_fragment(), for local_df=0, drops the the packet and returns EMSGSIZE. The patch fixes it with adding check length of skb->len. In this case, Ipv6 not to fragment upper protocol data, just only add a fragment header before it. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21X25 fix dead unaccepted socketsandrew hendry
1, An X25 program binds and listens 2, calls arrive waiting to be accepted 3, Program exits without accepting 4, Sockets time out but don't get correctly cleaned up 5, cat /proc/net/x25/socket shows the dead sockets with bad inode fields. This line borrowed from AX25 sets the dying socket so the timers clean up later. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21xfrm6: ensure to use the same dev when building a bundleNicolas Dichtel
When building a bundle, we set dst.dev and rt6.rt6i_idev. We must ensure to set the same device for both fields. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21fasync: RCU and fine grained lockingEric Dumazet
kill_fasync() uses a central rwlock, candidate for RCU conversion, to avoid cache line ping pongs on SMP. fasync_remove_entry() and fasync_add_entry() can disable IRQS on a short section instead during whole list scan. Use a spinlock per fasync_struct to synchronize kill_fasync_rcu() and fasync_{remove|add}_entry(). This spinlock is IRQ safe, so sock_fasync() doesnt need its own implementation and can use fasync_helper(), to reduce code size and complexity. We can remove __kill_fasync() direct use in net/socket.c, and rename it to kill_fasync_rcu(). Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21tcp: Mark v6 response packets as CHECKSUM_PARTIALDavid S. Miller
Otherwise we only get the checksum right for data-less TCP responses. Noticed by Herbert Xu. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21tcp: Fix ipv6 checksumming on response packets for real.David S. Miller
Commit 6651ffc8e8bdd5fb4b7d1867c6cfebb4f309512c ("ipv6: Fix tcp_v6_send_response transport header setting.") fixed one half of why ipv6 tcp response checksums were invalid, but it's not the whole story. If we're going to use CHECKSUM_PARTIAL for these things (which we are since commit 2e8e18ef52e7dd1af0a3bd1f7d990a1d0b249586 "tcp: Set CHECKSUM_UNNECESSARY in tcp_init_nondata_skb"), we can't be setting buff->csum as we always have been here in tcp_v6_send_response. We need to leave it at zero. Kill that line and checksums are good again. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-6000.c net/core/dev.c
2010-04-21net: Fix an RCU warning in dev_pick_tx()David Howells
Fix the following RCU warning in dev_pick_tx(): =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- net/core/dev.c:1993 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 2 locks held by swapper/0: #0: (&idev->mc_ifc_timer){+.-...}, at: [<ffffffff81039e65>] run_timer_softirq+0x17b/0x278 #1: (rcu_read_lock_bh){.+....}, at: [<ffffffff812ea3eb>] dev_queue_xmit+0x14e/0x4dc stack backtrace: Pid: 0, comm: swapper Not tainted 2.6.34-rc5-cachefs #4 Call Trace: <IRQ> [<ffffffff810516c4>] lockdep_rcu_dereference+0xaa/0xb2 [<ffffffff812ea4f6>] dev_queue_xmit+0x259/0x4dc [<ffffffff812ea3eb>] ? dev_queue_xmit+0x14e/0x4dc [<ffffffff81052324>] ? trace_hardirqs_on+0xd/0xf [<ffffffff81035362>] ? local_bh_enable_ip+0xbc/0xc1 [<ffffffff812f0954>] neigh_resolve_output+0x24b/0x27c [<ffffffff8134f673>] ip6_output_finish+0x7c/0xb4 [<ffffffff81350c34>] ip6_output2+0x256/0x261 [<ffffffff81052324>] ? trace_hardirqs_on+0xd/0xf [<ffffffff813517fb>] ip6_output+0xbbc/0xbcb [<ffffffff8135bc5d>] ? fib6_force_start_gc+0x2b/0x2d [<ffffffff81368acb>] mld_sendpack+0x273/0x39d [<ffffffff81368858>] ? mld_sendpack+0x0/0x39d [<ffffffff81052099>] ? mark_held_locks+0x52/0x70 [<ffffffff813692fc>] mld_ifc_timer_expire+0x24f/0x288 [<ffffffff81039ed6>] run_timer_softirq+0x1ec/0x278 [<ffffffff81039e65>] ? run_timer_softirq+0x17b/0x278 [<ffffffff813690ad>] ? mld_ifc_timer_expire+0x0/0x288 [<ffffffff81035531>] ? __do_softirq+0x69/0x140 [<ffffffff8103556a>] __do_softirq+0xa2/0x140 [<ffffffff81002e0c>] call_softirq+0x1c/0x28 [<ffffffff81004b54>] do_softirq+0x38/0x80 [<ffffffff81034f06>] irq_exit+0x45/0x47 [<ffffffff810177c3>] smp_apic_timer_interrupt+0x88/0x96 [<ffffffff810028d3>] apic_timer_interrupt+0x13/0x20 <EOI> [<ffffffff810488dd>] ? __atomic_notifier_call_chain+0x0/0x86 [<ffffffff810096bf>] ? mwait_idle+0x6e/0x78 [<ffffffff810096b6>] ? mwait_idle+0x65/0x78 [<ffffffff810011cb>] cpu_idle+0x4d/0x83 [<ffffffff81380b05>] rest_init+0xb9/0xc0 [<ffffffff81380a4c>] ? rest_init+0x0/0xc0 [<ffffffff8168dcf0>] start_kernel+0x392/0x39d [<ffffffff8168d2a3>] x86_64_start_reservations+0xb3/0xb7 [<ffffffff8168d38b>] x86_64_start_kernel+0xe4/0xeb An rcu_dereference() should be an rcu_dereference_bh(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-04-21ipv6: Fix tcp_v6_send_response transport header setting.Herbert Xu
My recent patch to remove the open-coded checksum sequence in tcp_v6_send_response broke it as we did not set the transport header pointer on the new packet. Actually, there is code there trying to set the transport header properly, but it sets it for the wrong skb ('skb' instead of 'buff'). This bug was introduced by commit a8fdf2b331b38d61fb5f11f3aec4a4f9fb2dedcb ("ipv6: Fix tcp_v6_send_response(): it didn't set skb transport header") Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: Remove two unnecessary exports (skbuff).Rami Rosen
There is no need to export skb_under_panic() and skb_over_panic() in skbuff.c, since these methods are used only in skbuff.c ; this patch removes these two exports. It also marks these functions as 'static' and removeS the extern declarations of them from include/linux/skbuff.h Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: Fix various endianness glitchesEric Dumazet
Sparse can help us find endianness bugs, but we need to make some cleanups to be able to more easily spot real bugs. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20bridge: add a missing ntohs()Eric Dumazet
grec_nsrcs is in network order, we should convert to host horder in br_multicast_igmp3_report() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20Merge branch 'master' of ↵David S. Miller
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20mac80211: Fix ieee80211_sta_conn_mon_timer with hw connection monitoringJuuso Oikarinen
When IEEE80211_HW_CONNECTION_MONITOR is configured by the driver, starting of ieee80211_sta_conn_mon_timer should be prevented, as it is then not needed. This is currently partially the case. As it seems, when a probe-response is received from the AP the timer is still restarted, thus restarting the host based connection keep-alive mechanism. These probe-responses happen at least when scanning while associated. Fix this by preventing starting of the ieee80211_sta_conn_mon_timer in the ieee80211_rx_mgmt_probe_resp function. Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
