path: root/net
2011-06-20batman-adv: Reduce usage of charSven Eckelmann
char was used in different places to store information without really using the characteristics of that data type or by ignoring the fact that char has not a well defined signedness. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-06-20batman-adv: count_real_packets() in batman-adv assumes char is signedDavid Howells
count_real_packets() in batman-adv assumes char is signed, and returns -1 through it: net/batman-adv/routing.c: In function 'receive_bat_packet': net/batman-adv/routing.c:739: warning: comparison is always false due to limited range of data type Use int instead. Signed-off-by: David Howells <dhowells@redhat.com> [sven@narfation.org: Rebase on top of current version] Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-06-20batman-adv: Keep interface_tx as local functionSven Eckelmann
interface_tx is not used outside of soft-interface.c and thus doesn't need to be declared inside soft-interface.h Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-06-20batman-adv: Move compare_orig to originator.cSven Eckelmann
compare_orig is only used in context of orig_node which is managed inside originator.c. It is not necessary to keep that function inside the header originator.h. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-06-09batman-adv: use NO_FLAGS define instead of hard-coding 0Marek Lindner
The definition NO_FLAGS was introduced to make the code more readable and shall be used to initialize flag fields. Signed-off-by: Marek Lindner <lindner_marek@yahoo.de> Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-06-09batman-adv: Use enums for related constantsSven Eckelmann
CodingStyle "Chapter 12: Macros, Enums and RTL" recommends to use enums for several related constants. Internal states can be used without defining the actual value, but all values which are visible to the outside must be defined as before. Normal values are assigned as usual and flags are defined by shifts of a bit. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-06-09batman-adv: Rewrite debugfs kobj_to_* helpers as functionsSven Eckelmann
CodingStyle "Chapter 12: Macros, Enums and RTL" highly recommends to use functions instead of macros were possible. This ensures type safety and prevents shadowing of other variables. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-06-09batman-adv: Fix signedness problem in parse_gw_bandwidthSven Eckelmann
strict_strtoul as used in parse_gw_bandwidth is defined for unsigned long and strict_strtol should be used instead for long. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-06-09batman-adv: Don't return value in void functionSven Eckelmann
gw_node_delete is defined with "void" as return type, but still tries to return a value. The called function gw_node_delete is also return as void and thus doesn't provide a value for us. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-06-09batman-adv: accept delayed rebroadcasts to avoid bogus routing under heavy loadDaniele Furlan
When a link is saturated (re)broadcasts of OGMs are delayed. Under heavy load this delay may exceed the orig interval which leads to OGMs being dropped (the code would only accept an OGM rebroadcast if it arrived before the next OGM was broadcasted). With this patch batman-adv will also accept delayed OGMs in order to avoid a bogus influence on the routing metric. Signed-off-by: Daniele Furlan <daniele.furlan@gmail.com> Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-05-30batman-adv: Ensure that we really have route changes in update_routeSven Eckelmann
The debug output of update_route has tests for "route deleted" and "route added". All other situations are handled as "route changed". This is not true because neigh_node and curr_router could be both NULL. The function is not called in this situation, but the code might be interpreted wrong when reading it without this test. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-05-30batman-adv: a multiline comment should precede the variable it is describingAntonio Quartulli
This comment has been wrongly put after the variable it refers to and was also bad indented Signed-off-by: Antonio Quartulli <ordex@autistici.org> Acked-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-05-30batman-adv: use is_broadcast_ether_addr() instead of compare_eth(.., brd_addr)Antonio Quartulli
Instead of comparing mac addresses with the broadcast address by means of compare_eth(), the is_broadcast_ether_addr() kernel function has to be used. Signed-off-by: Antonio Quartulli <ordex@autistici.org> Acked-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-05-30batman-adv: Check type of x and y in seq_(before|after)Sven Eckelmann
seq_before and seq_after depend on the fact that both sequence numbers have the same type and thus the same bitwidth. We can ensure that by compile time checking using a compare between the pointer to the temporary buffers which were created using the typeof of both parameters. For example gcc would create a warning like "warning: comparison of distinct pointer types lacks a cast". Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-05-30batman-adv: move smallest_signed_int(), seq_before() and seq_after() into main.hAntonio Quartulli
smallest_signed_int(), seq_before() and seq_after() are very useful functions that help to handle comparisons between sequence numbers. However they were only defined in vis.c. With this patch every batman-adv function will be able to use them. Signed-off-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-05-30batman-adv: Use rcu_dereference_protected by update-sideSven Eckelmann
Usually rcu_dereference isn't necessary in situations were the RCU-protected data structure cannot change, but sparse and lockdep still need a similar functionality for analysis. rcu_dereference_protected implements the reduced version which should be used to support the dynamic and static analysis. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-05-30batman-adv: Calculate sizeof using variable insead of typesSven Eckelmann
Documentation/CodingStyle recommends to use the form p = kmalloc(sizeof(*p), ...); to calculate the size of a struct and not the version where the struct name is spelled out to prevent bugs when the type of p changes. This also seems appropriate for manipulation of buffers when they are directly associated with p. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-05-30batman-adv: Remove casts from type x to type xSven Eckelmann
Casting from pointer like 'struct orig_node*' to 'struct orig_node *' doesn't provide any additional functionality and can be savely removed. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-05-30batman-adv: Remove explicit casts cast from void* for storeSven Eckelmann
It is not necessary to cast a void* to the pointer type when we just store it and don't want to do pointer arithmetic before the actual assignment. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-05-30batman-adv: Only use int up and down gw representationSven Eckelmann
It is not save to provide memory for an int and then cast the pointer to it to long*. It is better to standardize the up and down gateway bandwith representation to simple ints and only use long inside conversation routines. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-05-30batman-adv: Add const type qualifier for pointersSven Eckelmann
batman-adv uses pointers which are marked as const and should not violate that type qualifier by passing it to functions which force a cast to the non-const version. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-05-30batman-adv: Don't do pointer arithmetic with void*Sven Eckelmann
The size of void is currently set by gcc to 1, but is not well defined in general. Therefore it is more advisable to cast it to char* before doing pointer arithmetic. Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-05-30batman-adv: Remove comparising < 0 for unsigned typeSven Eckelmann
2011-05-30batman-adv: Print jiffies as unsigned longSven Eckelmann
2011-05-30batman-adv: Annotate functions with format stringsSven Eckelmann
2011-05-30batman-adv: Use kzalloc rather than kmalloc followed by memset with 0Sven Eckelmann
2011-05-30batman-adv: move neigh_node->if_incoming->if_status check in find_router()Antonio Quartulli
Every time that find_router() is invoked, if_status has to be compared with IF_ACTIVE. Moving this comparison inside find_router() will avoid to write it each time. Signed-off-by: Antonio Quartulli <ordex@autistici.org> Signed-off-by: Sven Eckelmann <sven@narfation.org>
2011-05-29Merge branch 'pnfs-submit' of git://git.open-osd.org/linux-open-osdLinus Torvalds
* 'pnfs-submit' of git://git.open-osd.org/linux-open-osd: (32 commits) pnfs-obj: pg_test check for max_io_size NFSv4.1: define nfs_generic_pg_test NFSv4.1: use pnfs_generic_pg_test directly by layout driver NFSv4.1: change pg_test return type to bool NFSv4.1: unify pnfs_pageio_init functions pnfs-obj: objlayout_encode_layoutcommit implementation pnfs: encode_layoutcommit pnfs-obj: report errors and .encode_layoutreturn Implementation. pnfs: encode_layoutreturn pnfs: layoutret_on_setattr pnfs: layoutreturn pnfs-obj: osd raid engine read/write implementation pnfs: support for non-rpc layout drivers pnfs-obj: define per-inode private structure pnfs: alloc and free layout_hdr layoutdriver methods pnfs-obj: objio_osd device information retrieval and caching pnfs-obj: decode layout, alloc/free lseg pnfs-obj: pnfs_osd XDR client implementation pnfs-obj: pnfs_osd XDR definitions pnfs-obj: objlayoutdriver module skeleton ...
2011-05-29Merge branch 'for-2.6.40' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.40' of git://linux-nfs.org/~bfields/linux: (22 commits) nfsd: make local functions static NFSD: Remove unused variable from nfsd4_decode_bind_conn_to_session() NFSD: Check status from nfsd4_map_bcts_dir() NFSD: Remove setting unused variable in nfsd_vfs_read() nfsd41: error out on repeated RECLAIM_COMPLETE nfsd41: compare request's opcnt with session's maxops at nfsd4_sequence nfsd v4.1 lOCKT clientid field must be ignored nfsd41: add flag checking for create_session nfsd41: make sure nfs server process OPEN with EXCLUSIVE4_1 correctly nfsd4: fix wrongsec handling for PUTFH + op cases nfsd4: make fh_verify responsibility of nfsd_lookup_dentry caller nfsd4: introduce OPDESC helper nfsd4: allow fh_verify caller to skip pseudoflavor checks nfsd: distinguish functions of NFSD_MAY_* flags svcrpc: complete svsk processing on cb receive failure svcrpc: take advantage of tcp autotuning SUNRPC: Don't wait for full record to receive tcp data svcrpc: copy cb reply instead of pages svcrpc: close connection if client sends short packet svcrpc: note network-order types in svc_process_calldir ...
2011-05-29Merge branch 'nfs-for-2.6.40' of ↵Linus Torvalds
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 * 'nfs-for-2.6.40' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: SUNRPC: Support for RPC over AF_LOCAL transports SUNRPC: Remove obsolete comment SUNRPC: Use AF_LOCAL for rpcbind upcalls SUNRPC: Clean up use of curly braces in switch cases NFS: Revert NFSROOT default mount options SUNRPC: Rename xs_encode_tcp_fragment_header() nfs,rcu: convert call_rcu(nfs_free_delegation_callback) to kfree_rcu() nfs41: Correct offset for LAYOUTCOMMIT NFS: nfs_update_inode: print current and new inode size in debug output NFSv4.1: Fix the handling of NFS4ERR_SEQ_MISORDERED errors NFSv4: Handle expired stateids when the lease is still valid SUNRPC: Deal with the lack of a SYN_SENT sk->sk_state_change callback...
2011-05-29SUNRPC: introduce xdr_init_decode_pagesBenny Halevy
Initialize xdr_stream and xdr_buf using an array of page pointers and length of buffer. Signed-off-by: Benny Halevy <bhalevy@panasas.com>
2011-05-27SUNRPC: Support for RPC over AF_LOCAL transportsChuck Lever
TI-RPC introduces the capability of performing RPC over AF_LOCAL sockets. It uses this mainly for registering and unregistering local RPC services securely with the local rpcbind, but we could also conceivably use it as a generic upcall mechanism. This patch provides a client-side only implementation for the moment. We might also consider a server-side implementation to provide AF_LOCAL access to NLM (for statd downcalls, and such like). Autobinding is not supported on kernel AF_LOCAL transports at this time. Kernel ULPs must specify the pathname of the remote endpoint when an AF_LOCAL transport is created. rpcbind supports registering services available via AF_LOCAL, so the kernel could handle it with some adjustment to ->rpcbind and ->set_port. But we don't need this feature for doing upcalls via well-known named sockets. This has not been tested with ULPs that move a substantial amount of data. Thus, I can't attest to how robust the write_space and congestion management logic is. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-27SUNRPC: Remove obsolete commentChuck Lever
Clean up. The documenting comment at the top of net/sunrpc/clnt.c is out of date. We adopted BSD's RTO estimation mechanism years ago. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-27SUNRPC: Use AF_LOCAL for rpcbind upcallsChuck Lever
As libtirpc does in user space, have our registration API try using an AF_LOCAL transport first when registering and unregistering. This means we don't chew up privileged ports, and our registration is bound to an "owner" (the effective uid of the process on the sending end of the transport). Only that "owner" may unregister the service. The kernel could probe rpcbind via an rpcbind query to determine whether rpcbind has an AF_LOCAL service. For simplicity, we use the same technique that libtirpc uses: simply fail over to network loopback if creating an AF_LOCAL transport to the well-known rpcbind service socket fails. This means we open-code the pathname of the rpcbind socket in the kernel. For now we have to do that anyway because the kernel's RPC over AF_LOCAL implementation does not support autobind. That may be undesirable in the long term. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-27SUNRPC: Clean up use of curly braces in switch casesChuck Lever
Clean up. Preferred style is not to use curly braces around switch cases. I'm about to add another case that needs a third type cast. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-27SUNRPC: Rename xs_encode_tcp_fragment_header()Chuck Lever
Clean up: Use a more generic name for xs_encode_tcp_fragment_header(); it's appropriate to use for all stream transport types. We're about to add new stream transport. Also, move it to a place where it is more easily shared amongst the various send_request methods. And finally, replace the "htonl" macro invocation with its modern equivalent. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-27SUNRPC: Deal with the lack of a SYN_SENT sk->sk_state_change callback...Trond Myklebust
The TCP connection state code depends on the state_change() callback being called when the SYN_SENT state is set. However the networking layer doesn't actually call us back in that case. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@kernel.org
2011-05-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: Kill ratelimit.h dependency in linux/net.h net: Add linux/sysctl.h includes where needed. net: Kill ether_table[] declaration. inetpeer: fix race in unused_list manipulations atm: expose ATM device index in sysfs IPVS: bug in ip_vs_ftp, same list heaad used in all netns. bug.h: Move ratelimit warn interfaces to ratelimit.h bonding: cleanup module option descriptions net:8021q:vlan.c Fix pr_info to just give the vlan fullname and version. net: davinci_emac: fix dev_err use at probe can: convert to %pK for kptr_restrict support net: fix ETHTOOL_SFEATURES compatibility with old ethtool_ops.set_flags netfilter: Fix several warnings in compat_mtw_from_user(). netfilter: ipset: fix ip_set_flush return code netfilter: ipset: remove unused variable from type_pf_tdel() netfilter: ipset: Use proper timeout value to jiffies conversion
2011-05-27net: Kill ratelimit.h dependency in linux/net.hDavid S. Miller
Ingo Molnar noticed that we have this unnecessary ratelimit.h dependency in linux/net.h, which hid compilation problems from people doing builds only with CONFIG_NET enabled. Move this stuff out to a seperate net/net_ratelimit.h file and include that in the only two places where this thing is needed. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu>
2011-05-27inetpeer: fix race in unused_list manipulationsEric Dumazet
Several crashes in cleanup_once() were reported in recent kernels. Commit d6cc1d642de9 (inetpeer: various changes) added a race in unlink_from_unused(). One way to avoid taking unused_peers.lock before doing the list_empty() test is to catch 0->1 refcnt transitions, using full barrier atomic operations variants (atomic_cmpxchg() and atomic_inc_return()) instead of previous atomic_inc() and atomic_add_unless() variants. We then call unlink_from_unused() only for the owner of the 0->1 transition. Add a new atomic_add_unless_return() static helper With help from Arun Sharma. Refs: https://bugzilla.kernel.org/show_bug.cgi?id=32772 Reported-by: Arun Sharma <asharma@fb.com> Reported-by: Maximilian Engelhardt <maxi@daemonizer.de> Reported-by: Yann Dupont <Yann.Dupont@univ-nantes.fr> Reported-by: Denys Fedoryshchenko <denys@visp.net.lb> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-27Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] mm: add ZONE_DMA to 31-bit config again [S390] mm: add page fault retry handling [S390] mm: handle kernel caused page fault oom situations [S390] delay: implement ndelay [S390] topology,sched: fix cpu_coregroup_mask/cpu_book_mask definitions [S390] hwsampler: allow cpu hotplug [S390] uaccess: turn __access_ok() into a define [S390] irq: merge irq.c and s390_ext.c [S390] irq: fix service signal external interrupt handling [S390] pfault: always enable service signal interrupt
2011-05-27atm: expose ATM device index in sysfsDan Williams
It's currently exposed only through /proc which, besides requiring screen-scraping, doesn't allow userspace to distinguish between two identical ATM adapters with different ATM indexes. The ATM device index is required when using PPPoATM on a system with multiple ATM adapters. Signed-off-by: Dan Williams <dcbw@redhat.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: David Woodhouse <dwmw2@infradead.org> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-27Merge branch 'pablo/nf-2.6-updates' of git://1984.lsi.us.es/net-2.6David S. Miller
2011-05-27IPVS: bug in ip_vs_ftp, same list heaad used in all netns.Hans Schillstrom
When ip_vs was adapted to netns the ftp application was not adapted in a correct way. However this is a fix to avoid kernel errors. In the long term another solution might be chosen. I.e the ports that the ftp appl, uses should be per netns. Signed-off-by: Hans Schillstrom <hans.schillstrom@ericsson.com> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-05-26Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: gfs2: Drop __TIME__ usage isdn/diva: Drop __TIME__ usage atm: Drop __TIME__ usage dlm: Drop __TIME__ usage wan/pc300: Drop __TIME__ usage parport: Drop __TIME__ usage hdlcdrv: Drop __TIME__ usage baycom: Drop __TIME__ usage pmcraid: Drop __DATE__ usage edac: Drop __DATE__ usage rio: Drop __DATE__ usage scsi/wd33c93: Drop __TIME__ usage scsi/in2000: Drop __TIME__ usage aacraid: Drop __TIME__ usage media/cx231xx: Drop __TIME__ usage media/radio-maxiradio: Drop __TIME__ usage nozomi: Drop __TIME__ usage cyclades: Drop __TIME__ usage
2011-05-26Merge branches 'core-fixes-for-linus' and 'irq-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: seqlock: Get rid of SEQLOCK_UNLOCKED * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: irq: Remove smp_affinity_list when unregister irq proc
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/cma: Save PID of ID's owner RDMA/cma: Add support for netlink statistics export RDMA/cma: Pass QP type into rdma_create_id() RDMA: Update exported headers list RDMA/cma: Export enum cma_state in <rdma/rdma_cm.h> RDMA/nes: Add a check for strict_strtoul() RDMA/cxgb3: Don't post zero-byte read if endpoint is going away RDMA/cxgb4: Use completion objects for event blocking IB/srp: Fix integer -> pointer cast warnings IB: Add devnode methods to cm_class and umad_class IB/mad: Return EPROTONOSUPPORT when an RDMA device lacks the QP required IB/uverbs: Add devnode method to set path/mode RDMA/ucma: Add .nodename/.mode to tell userspace where to create device node RDMA: Add netlink infrastructure RDMA: Add error handling to ib_core_init()
2011-05-26bug.h: Move ratelimit warn interfaces to ratelimit.hDavid S. Miller
As reported by Ingo Molnar, we still have configuration combinations where use of the WARN_RATELIMIT interfaces break the build because dependencies don't get met. Instead of going down the long road of trying to make it so that ratelimit.h can get included by kernel.h or asm-generic/bug.h, just move the interface into ratelimit.h and make users have to include that. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Randy Dunlap <randy.dunlap@oracle.com>
2011-05-26net:8021q:vlan.c Fix pr_info to just give the vlan fullname and version.Justin Mattock
The below patch removes vlan_buggyright and vlan_copyright from vlan_proto_init, so that it prints out just the fullname of vlan and the version number. before: [ 30.438203] 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com> [ 30.441542] All bugs added by David S. Miller <davem@redhat.com> after: [ 31.513910] 802.1Q VLAN Support v1.8 Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> CC: Joe Perches <joe@perches.com> CC: David S. Miller <davem@davemloft.net> CC: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-26can: convert to %pK for kptr_restrict supportOliver Hartkopp
As these pointers have been printed without using %p they were missed in the big network kptr_restrict conversion patch %p -> %pK from Dan Rosenberg. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
