Receive background scan period as part of connect
command and pass the same to the driver.
Signed-off-by: Bala Shanmugam <bkamatch@qca.qualcomm.com>
smatch was complaining:
CHECK net/mac80211/mesh_pathtbl.c
net/mac80211/mesh_pathtbl.c:562 mesh_path_add() error: double lock
'bottom_half:'
net/mac80211/mesh_pathtbl.c:580 mesh_path_add() error: double unlock
'bottom_half:'
net/mac80211/mesh_pathtbl.c:589 mesh_path_add() error: double unlock
'bottom_half:'
net/mac80211/mesh_pathtbl.c:691 mpp_path_add() error: double lock
'bottom_half:'
net/mac80211/mesh_pathtbl.c:707 mpp_path_add() error: double unlock
'bottom_half:'
net/mac80211/mesh_pathtbl.c:716 mpp_path_add() error: double unlock
'bottom_half:'
net/mac80211/mesh_pathtbl.c:814 mesh_path_flush_by_nexthop() error:
double lock 'bottom_half:'
net/mac80211/mesh_pathtbl.c:819 mesh_path_flush_by_nexthop() error:
double unlock 'bottom_half:'
net/mac80211/mesh_pathtbl.c:887 mesh_path_del() error: double lock
'bottom_half:'
net/mac80211/mesh_pathtbl.c:901 mesh_path_del() error: double unlock
'bottom_half:'
So don't lock / unlock with _bh() while bottom halves are already
disabled.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Thomas Pedersen <thomas@cozybit.com>
The patch "{nl,cfg,mac}80211: Implement RSSI threshold for mesh peering"
has a potential null pointer dereferencing problem. Thanks to Dan Carpenter
for pointing out. This patch will fix the issue.
Signed-off-by: Ashok Nagarajan <ashok@cozybit.com>
mac80211 is lenient with respect to reception of corrupted beacons.
Even if the frame is corrupted as a whole, the available IE elements
are still passed back and accepted, sometimes replacing legitimate
data. It is unknown to what extent this "feature" is made use of,
but it is clear that in some cases, this is detrimental. One such
case is reported in http://crosbug.com/26832 where an AP corrupts
its beacons but not its probe responses.
One approach would be to completely reject frames with invaid data
(for example, if the last tag extends beyond the end of the enclosing
PDU). The enclosed approach is much more conservative: we simply
prevent later IEs from overwriting the state from previous ones.
This approach hopes that there might be some salient data in the
IE stream before the corruption, and seeks to at least prevent that
data from being overwritten. This approach will fix the case above.
Further, we flag element structures that contain data we think might
be corrupted, so that as we fill the mac80211 BSS structure, we try
not to replace data from an un-corrupted probe response with that
of a corrupted beacon, for example.
Short of any statistics gathering in the various forms of AP breakage,
it's not possible to ascertain the side effects of more stringent
discarding of data.
Signed-off-by: Paul Stewart <pstew@chromium.org>
Cc: Sam Leffler <sleffler@chromium.org>
Cc: Eliad Peller <eliad@wizery.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
The socket local pointer needs to be set to NULL when the adapter is
removed or the MAC goes down.
If the socket release code is called after such an event, the socket
reference count still needs to be decreased in order for the socket to
eventually be freed.
When calling nfc_dep_link_up, we implicitely are in initiator mode.
Which means we also can provide the general bytes as a function argument,
as all drivers will eventually request them.
We just don't do anything with it when parsing the general bytes.
We handle it from the CONNECT reception code.
The parent socket (the bound one) could be freed before its children, so
we should unlink the children without trying to reach it through the parent.
Based on the receiver MIU, we have to fragment the frame to be
transmitted.
We use the maximum values for the LLCP Maximum Information Unit and Receive
Window Size.
In order to acknowledge an I frame, we have to either queue pending local
I frames or queue a receiver ready frame.
This one will be called from the I frame command sending.
For user space to know if a device is up or down.
Signed-off-by: Javier Cardona <javier@cozybit.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
Airtime link metric estimation was broken in HT mesh, use
cfg80211_calculate_bitrate to get the right rate value.
Also factor out tx rate copying from sta_set_sinfo().
Add the signal strength (in dBm only for now) to
frames that are received via nl80211's various
frame APIs.
Acked-by: Kalle Valo <kvalo@qca.qualcomm.com>
When associating and particularly when disassociating
there's no need to notify the driver about changes
with multiple calls to bss_info_changed, we should
combine the QoS enabling/disabling into the same call
as otherwise the driver could get confused about QoS
suddenly getting disabled while connected.
There's no need to hardcode a subset of the
radiotap header for cooked monitor receive,
we can just reuse the normal monitor mode
radiotap code. This simplifies the code and
extends the information available on cooked
monitor interfaces.
This patch adds an attribute, NL80211_ATTR_INACTIVITY_TIMEOUT,
to set the inactivity timeout which can be used to remove the
station in AP mode. This can be passed in NL80211_CMD_START_AP
and used by the drivers which have AP MLME in firmware but
don't support get_station() properly. To disable inactivity
timer in userspace, wpa_s for example, there is a new flag,
NL80211_FEATURE_INACTIVITY_TIMER, in nl80211_feature_flags
through which drivers can register their capability to use
the inactivity timeout to free the stations.
Signed-off-by: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com>
RANN, PREP and PERR propagation should happen only if the
dot11MeshForwarding is true. Besides, data frame should not be
forwarded if dot11MeshForwarding is false. This redundant checking
is necessary to avoid the broadcasted ARP breaking the non-forwarding
rule.
Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@gmail.com>
For A-MPDU rx it makes sense to only process the signal strength once per
aggregate instead of once per subframe. Additonally, some hardware (e.g.
Atheros) only provides valid signal strength information for the last
subframe.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Because of the constant size and guaranteed 16 bit alignment, the inline
compare_ether_addr function is much cheaper than calling memcmp.
Several MAC address comparison functions assume 16 bit alignment for pointers
passed to them. Since the addition of the control_port field, alignment
for the IBSS bssid was off by one, causing a severe performance hit on
architectures without efficient unaligned access (e.g. MIPS).
Mesh peer links are established only if average rssi of the peer
candidate satisfies the threshold. This is not in 802.11s specification
but was requested by David Fulgham, an open80211s user. This is a way to avoid
marginal peer links with stations that are barely within range.
This patch adds a new mesh configuration parameter, mesh_rssi_threshold. This
feature is supported only for hardwares that report signal in dBm.
According to Section Y.7.4 Actions on receipt of proactive RANN, an individually
addressed PREQ should be generated towards the neighbor peer mesh STA indicated
in the RANN Sender Address field in the forwarding information.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
This renames the IEEE80211_TX_CTL_POLL_RESPONSE
TX flag to IEEE80211_TX_CTL_NO_PS_BUFFER and also
uses it for non-bufferable MMPDUs (all MMPDUs but
deauth, disassoc and action frames.)
Previously, mac80211 would let the MMPDU through
but not set the flag so drivers supporting some
hardware aids for avoiding the PS races would
then reject the frame.
The association sequence looks (roughly) like
this now:
* set BSSID
* set station to EXIST state
* send auth
* set station to AUTH state
* send assoc
* set station to ASSOC state
* set BSS info to associated
In contrast, the deauth/disassoc sequence is
the other way around:
* clear BSSID/BSS info state
* remove station
* send deauth/disassoc
(in some cases the last two steps are reversed.)
This patch encodes the entire sequence in the
ieee80211_set_disassoc() function and changes
it to be like this, for good measure with an
explicit flush:
* flush
* remove station
At least iwlwifi gets confused with the other
sequence in P2P mode and complains that it
wasn't able to flush the queues.
When ieee80211_set_disassoc() is called with the
tx argument set to true, it will send DelBA out
to the peer. This isn't useful or necessary in a
few cases where we do it today, those being when
we lost the connection or when the supplicant
explicitly asked us to not tell the AP.
Instead of calling cfg80211 in ieee80211_send_deauth_disassoc()
pass out the frame and call it from the caller. That saves the
SKB allocation if we don't actually want to send the frame and
enables us to make the ordering smarter in the future.
In "cfg80211: no cookies in cfg80211_send_XXX()"
Holger Schurig removed the cookies in the calls
from mac80211 to cfg80211, but the ones in the
other direction were left in. Remove them now.
That's a lot longer than open-coding it and
doesn't really add value, so just remove it.
The comment for sta_info_flush() states
"Returns the number of removed STA entries"
but that isn't actually true. Consequently,
the warning when a station is still around
on interface removal can never trigger and
this delayed finding the timer issue the
previous patch fixed. Fix the return value
here to make that warning useful again.
When removing an interface while it is in the
process of authenticating or associating, we
leak the auth_data or assoc_data, and leave
the timer pending. The timer then crashes the
system when it fires as its data is gone.
Fix this by explicitly deleting all the data
when the interface is removed. This uncovered
another bug -- this problem should have been
detected by the sta_info_flush() warning but
that function doesn't ever return non-zero,
I'll fix that in a separate patch.
Reported-by: Hieu Nguyen <hieux.c.nguyen@intel.com>
Use interface data from sta instead of invalid pointer
to list head in calls to drv_sta_state.
Signed-off-by: Jakub Kicinski <kubakici@wp.pl>
Eliad reports that if a scan finishes in the
middle of processing associated (however it
happens), the interface can go idle. This is
because we set assoc_data to NULL before we
set associated. Change the order so any idle
check will find either one of them.
Doing this requires duplicating the TX sync
processing, but I already have a patch to
delete that completely and will submit that
as soon as my driver changes to no longer
require it are submitted.
Reported-by: Eliad Peller <eliad@wizery.com>
Tested-by: Eliad Peller <eliad@wizery.com>
Some files implicitly get this via mesh.h
which itself doesn't need it, so move the
inclusion into the right files. Some other
files don't need it at all but include it,
so remove it from there.
ieee80211_restart_sta_timer() takes care for enqueueing
monitor_work if needed, so no need to do it again.
Signed-off-by: Eliad Peller <eliad@wizery.com>
Devices that monitor the connection in the hw don't need
the monitor work in the driver.
The AP/GO mode API isn't very clearly defined, it
has "set beacon" and "new beacon" etc.
Modify the API to the following:
* start AP -- all settings
* change beacon -- new beacon data
* stop AP -- stop AP mode operation
This also reflects in the nl80211 API, rename
the commands there correspondingly (but keep
the old names for compatibility.)
Overall, this makes it much clearer what's going
on in the API.
Kalle developed the ath6kl changes, I created
the rest of the patch.
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
nothing needs to be done for monitor/AP_VLAN mode on calling
ieee80211_bss_info_change_notify -> drv_bss_info_changed with the change
flag 'BSS_CHANGED_IDLE'. 'wl1271' seems to use BSS_CHANGED_IDLE only for
STA and IBSS mode. further the non-idle state of the monitor mode is
taken care by the 'count' variable which counts non-idle interfaces.
ieee80211_idle_off(local, "in use") will be called.
this fixes the following WARNING when we have initially STA mode
(network manager running) and not associated, and change it to monitor
mode with network manager disabled and bringing up the monitor mode.
this changes the idle state from 'true' (STA unassociated) to 'false'
(MONITOR mode)
exposed by the commit 405385f8ce7a2ed8f82e216d88b5282142e1288b
"mac80211: set bss_conf.idle when vif is connected"
WARNING: net/mac80211/main.c:212
ieee80211_bss_info_change_notify+0x1cf/0x330 [mac80211]()
Hardware name: 64756D6
Pid: 3835, comm: ifconfig Tainted: G O
3.3.0-rc3-wl #9
Call Trace:
[<c0133b02>] warn_slowpath_common+0x72/0xa0
[<fc8e8c3f>] ?
[<fc8e8c3f>] ?
[<c0133b52>] warn_slowpath_null+0x22/0x30
[<fc8e8c3f>]
[<fc8f9de3>] __ieee80211_recalc_idle+0x113/0x430
[mac80211]
[<fc8fabc6>] ieee80211_do_open+0x156/0x7e0 [mac80211]
[<fc8f8a25>] ?
ieee80211_check_concurrent_iface+0x25/0x180 [mac80211]
[<c015dd9f>] ? raw_notifier_call_chain+0x1f/0x30
[<fc8fb290>] ieee80211_open+0x40/0x80 [mac80211]
[<c05894f6>] __dev_open+0x96/0xe0
[<c068fba5>] ? _raw_spin_unlock_bh+0x35/0x40
[<c05881d9>] __dev_change_flags+0x109/0x170
[<c0589423>] dev_change_flags+0x23/0x60
[<c05f3770>] devinet_ioctl+0x6a0/0x770
ieee80211 phy0: device no longer idle - in use
Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com>
