path: root/net
2015-09-24switchdev: move transaction phase enum under transaction structureJiri Pirko
Before it disappears completely, move transaction phase enum under transaction structure and make attr/obj structures a bit cleaner. Signed-off-by: Jiri Pirko <jiri@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-24switchdev: introduce transaction item queue for attr_set and obj_addJiri Pirko
Now, the memory allocation in prepare/commit state is done separatelly in each driver (rocker). Introduce the similar mechanism in generic switchdev code, in form of queue. That can be used not only for memory allocations, but also for different items. Abort item destruction is handled as well. Signed-off-by: Jiri Pirko <jiri@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-24switchdev: rename "trans" to "trans_ph".Jiri Pirko
This is temporary, name "trans" will be used for something else and "trans_ph" will eventually disappear. Signed-off-by: Jiri Pirko <jiri@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-24tcp: factorize sk_txhash initEric Dumazet
Neal suggested to move sk_txhash init into tcp_create_openreq_child(), called both from IPv4 and IPv6. This opportunity was missed in commit 58d607d3e52f ("tcp: provide skb->hash to synack packets") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-24ipv6: remove unused neigh parameter from ndisc functionsJiri Benc
Since commit 12fd84f4383b1 ("ipv6: Remove unused neigh argument for icmp6_dst_alloc() and its callers."), the neigh parameter of ndisc_send_na and ndisc_send_ns is unused. CC: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Jiri Benc <jbenc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-24genetlink: simplify genl_notifyJiri Benc
The genl_notify function has too many arguments for no real reason - all callers use genl_info to get them anyway. Just pass the genl_info down to genl_notify. Signed-off-by: Jiri Benc <jbenc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-23bridge: don't age externally added FDB entriesSiva Mannem
Signed-off-by: Siva Mannem <siva.mannem.lnx@gmail.com> Signed-off-by: Scott Feldman <sfeldma@gmail.com> Acked-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Acked-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Premkumar Jonnala <pjonnala@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-23bridge: define some min/max/default ageing time constantsScott Feldman
Signed-off-by: Scott Feldman <sfeldma@gmail.com> Acked-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-23cls_bpf: further limit exec opcodes subsetDaniel Borkmann
Jamal suggested to further limit the currently allowed subset of opcodes that may be used by a direct action return code as the intention is not to replace the full action engine, but rather to have a minimal set that can be used in the fast-path on things like ingress for some features that cls_bpf supports. Classifiers can, of course, still be chained together that have direct action mode with those that have a full exec pass. For more complex scenarios that go beyond this minimal set here, the full tcf_exts_exec() path must be used. Suggested-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-23cls_bpf: make binding to classid optionalDaniel Borkmann
The binding to a particular classid was so far always mandatory for cls_bpf, but it doesn't need to be. Therefore, lift this restriction as similarly done in other classifiers. Only a couple of qdiscs make use of class from the tcf_result, others don't strictly care, so let the user choose his needs (those that read out class can handle situations where it could be NULL). An explicit check for tcf_unbind_filter() is also not needed here, as the previous r->class was 0, so the xchg() will return that and therefore a callback to the qdisc's unbind_tcf() is skipped. Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-23cls_bpf: also dump TCA_BPF_FLAGSDaniel Borkmann
In commit 43388da42a49 ("cls_bpf: introduce integrated actions") we have added TCA_BPF_FLAGS. We can also retrieve this information from the prog, dump it back to user space as well. It's useful in tc when displaying/dumping filter info. Also, remove tp from cls_bpf_prog_from_efd(), came in as a conflict from a rebase and it's unused here (later work may add it along with a real user). Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-23sched, bpf: let stack handle !IFF_UP devs on bpf_clone_redirectDaniel Borkmann
Similarly as already the case in bpf_redirect()/skb_do_redirect() pair, let the stack deal with devs that are !IFF_UP. dev_forward_skb() as well as dev_queue_xmit() will free the skb and increment drop counter internally in such cases, so we can spare the condition in bpf_clone_redirect(). Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-23ipv6 Use get_hash_from_flowi6 for rt6 hashTom Herbert
In rt6_info_hash_nhsfn replace the custom hashing over flowi6 that is using xor with a call to common function get_hash_from_flowi6. Signed-off-by: Tom Herbert <tom@herbertland.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nf-nextDavid S. Miller
Pablo Neira Ayuso says: ==================== Netfilter/IPVS updates for net-next The following patchset contains Netfilter/IPVS updates for your net-next tree in this 4.4 development cycle, they are: 1) Schedule ICMP traffic to IPVS instances, this introduces a new schedule_icmp proc knob to enable/disable it. By default is off to retain the old behaviour. Patchset from Alex Gartrell. I'm also including what Alex originally said for the record: "The configuration of ipvs at Facebook is relatively straightforward. All ipvs instances bgp advertise a set of VIPs and the network prefers the nearest one or uses ECMP in the event of a tie. For the uninitiated, ECMP deterministically and statelessly load balances by hashing the packet (usually a 5-tuple of protocol, saddr, daddr, sport, and dport) and using that number as an index (basic hash table type logic). The problem is that ICMP packets (which contain really important information like whether or not an MTU has been exceeded) will get a different hash value and may end up at a different ipvs instance. With no information about where to route these packets, they are dropped, creating ICMP black holes and breaking Path MTU discovery. Suddenly, my mom's pictures can't load and I'm fielding midday calls that I want nothing to do with. To address this, this patch set introduces the ability to schedule icmp packets which is gated by a sysctl net.ipv4.vs.schedule_icmp. If set to 0, the old behavior is maintained -- otherwise ICMP packets are scheduled." 2) Add another proc entry to ignore tunneled packets to avoid routing loops from IPVS, also from Alex. 3) Fifteen patches from Eric Biederman to: * Stop passing nf_hook_ops as parameter to the hook and use the state hook object instead all around the netfilter code, so only the private data pointer is passed to the registered hook function. * Now that we've got state->net, propagate the netns pointer to netfilter hook clients to avoid its computation over and over again. A good example of how this has been simplified is the former TEE target (now nf_dup infrastructure) since it has killed the ugly pick_net() function. There's another round of netns updates from Eric Biederman making the line. To avoid the patchbomb again to almost all the networking mailing list (that is 84 patches) I'd suggest we send you a pull request with no patches or let me know if you prefer a better way. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-21tcp: send loss probe after 1s if no RTT availableYuchung Cheng
This patch makes TLP to use 1 sec timer by default when RTT is not available due to SYN/ACK retransmission or SYN cookies. Prior to this change, the lack of RTT prevents TLP so the first data packets sent can only be recovered by fast recovery or RTO. If the fast recovery fails to trigger the RTO is 3 second when SYN/ACK is retransmitted. With this patch we can trigger fast recovery in 1sec instead. Note that we need to check Fast Open more properly. A Fast Open connection could be (accepted then) closed before it receives the final ACK of 3WHS so the state is FIN_WAIT_1. Without the new check, TLP will retransmit FIN instead of SYN/ACK. Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Nandita Dukkipati <nanditad@google.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-21tcp: usec resolution SYN/ACK RTTYuchung Cheng
Currently SYN/ACK RTT is measured in jiffies. For LAN the SYN/ACK RTT is often measured as 0ms or sometimes 1ms, which would affect RTT estimation and min RTT samping used by some congestion control. This patch improves SYN/ACK RTT to be usec resolution if platform supports it. While the timestamping of SYN/ACK is done in request sock, the RTT measurement is carefully arranged to avoid storing another u64 timestamp in tcp_sock. For regular handshake w/o SYNACK retransmission, the RTT is sampled right after the child socket is created and right before the request sock is released (tcp_check_req() in tcp_minisocks.c) For Fast Open the child socket is already created when SYN/ACK was sent, the RTT is sampled in tcp_rcv_state_process() after processing the final ACK an right before the request socket is released. If the SYN/ACK was retransmistted or SYN-cookie was used, we rely on TCP timestamps to measure the RTT. The sample is taken at the same place in tcp_rcv_state_process() after the timestamp values are validated in tcp_validate_incoming(). Note that we do not store TS echo value in request_sock for SYN-cookies, because the value is already stored in tp->rx_opt used by tcp_ack_update_rtt(). One side benefit is that the RTT measurement now happens before initializing congestion control (of the passive side). Therefore the congestion control can use the SYN/ACK RTT. Signed-off-by: Yuchung Cheng <ycheng@google.com> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-21s390/iucv: do not use arrays as argumentUrsula Braun
The iucv code uses arrays as arguments. Even though this does not really cause a problem, it could be misleading, since the compiler turns array arguments into just a pointer argument. To be more precise this patch changes the array arguments into pointers. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-21Merge branch 'for-upstream' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next Johan Hedberg says: ==================== pull request: bluetooth-next 2015-09-18 Here's the first bluetooth-next pull request for the 4.4 kernel: - ieee802154 cleanups & fixes - debugfs support for the at86rf230 driver - Support for quirky (seemingly counterfeit) CSR Bluetooth controllers - Power management and device config improvements for Intel controllers - Fix for devices with incorrect advertising data length - Fix for closing HCI user channel socket Please let me know if there are any issues pulling. Thanks. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-20rxrpc: Replace get_seconds with ktime_get_secondsKsenija Stanojevic
Replace time_t type and get_seconds function which are not y2038 safe on 32-bit systems. Function ktime_get_seconds use monotonic instead of real time and therefore will not cause overflow. Signed-off-by: Ksenija Stanojevic <ksenija.stanojevic@gmail.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-18netfilter: Use nf_ct_net instead of dev_net(out) in nf_nat_masquerade_ipv6Eric W. Biederman
Use nf_ct_net(ct) instead of guessing that the netdevice out can reliably report the network namespace the conntrack operation is happening in. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-18netfilter: Pass net into nf_xfrm_me_harderEric W. Biederman
Instead of calling dev_net on a likley looking network device pass state->net into nf_xfrm_me_harder. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-18netfilter: Pass priv instead of nf_hook_ops to netfilter hooksEric W. Biederman
Only pass the void *priv parameter out of the nf_hook_ops. That is all any of the functions are interested now, and by limiting what is passed it becomes simpler to change implementation details. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-18ipvs: Read hooknum from state rather than ops->hooknumEric W. Biederman
This should be more cache efficient as state is more likely to be in core, and the netfilter core will stop passing in ops soon. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-18netfilter: nf_conntrack: Add a struct net parameter to l4_pkt_to_tupleEric W. Biederman
As gre does not have the srckey in the packet gre_pkt_to_tuple needs to perform a lookup in it's per network namespace tables. Pass in the proper network namespace to all pkt_to_tuple implementations to ensure gre (and any similar protocols) can get this right. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-18act_connmark: Remember the struct net instead of guessing it.Eric W. Biederman
Stop guessing the struct net instead of remember it. Guessing is just silly and will be problematic in the future when I implement routes between network namespaces. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-18netfilter: Pass net to nf_dup_ipv4 and nf_dup_ipv6Eric W. Biederman
This allows them to stop guessing the network namespace with pick_net. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-18netfilter: nf_tables: Use pkt->net instead of computing net from the passed ↵Eric W. Biederman
net_devices Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-18netfilter: x_tables: Use par->net instead of computing from the passed net ↵Eric W. Biederman
2015-09-18netfilter: x_tables: Pass struct net in xt_action_paramEric W. Biederman
As xt_action_param lives on the stack this does not bloat any persistent data structures. This is a first step in making netfilter code that needs to know which network namespace it is executing in simpler. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-18netfilter: nf_tables: kill nft_pktinfo.opsEric W. Biederman
- Add nft_pktinfo.pf to replace ops->pf - Add nft_pktinfo.hook to replace ops->hooknum This simplifies the code, makes it more readable, and likely reduces cache line misses. Maintainability is enhanced as the details of nft_hook_ops are of no concern to the recpients of nft_pktinfo. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-18inet netfilter: Prefer state->hook to ops->hooknumEric W. Biederman
The values of nf_hook_state.hook and nf_hook_ops.hooknum must be the same by definition. We are more likely to access the fields in nf_hook_state over the fields in nf_hook_ops so with a little luck this results in fewer cache line misses, and slightly more consistent code. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-18inet netfilter: Remove hook from ip6t_do_table, arp_do_table, ipt_do_tableEric W. Biederman
The values of ops->hooknum and state->hook are guaraneted to be equal making the hook argument to ip6t_do_table, arp_do_table, and ipt_do_table is unnecessary. Remove the unnecessary hook argument. In the callers use state->hook instead of ops->hooknum for clarity and to reduce the number of cachelines the callers touch. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-18netfilter: ebtables: Simplify the arguments to ebt_do_tableEric W. Biederman
Nearly everything thing of interest to ebt_do_table is already present in nf_hook_state. Simplify ebt_do_table by just passing in the skb, nf_hook_state, and the table. This make the code easier to read and maintenance easier. To support this create an nf_hook_state on the stack in ebt_broute (the only caller without a nf_hook_state already available). This new nf_hook_state adds no new computations to ebt_broute, but does use a few more bytes of stack. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-18Merge tag 'ipvs-for-v4.4' of ↵Pablo Neira Ayuso
https://git.kernel.org/pub/scm/linux/kernel/git/horms/ipvs-next Simon Horman says: ==================== IPVS Updates for v4.4 please consider these IPVS Updates for v4.4. The updates include the following from Alex Gartrell: * Scheduling of ICMP * Sysctl to ignore tunneled packets; and hence some packet-looping scenarios ==================== Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-09-18Bluetooth: Fix reporting incorrect EIR in device found mgmt eventSzymon Janc
Some remote devices (ie Gigaset G-Tag) misbehave with ADV data length. This can lead to incorrect EIR format in device found event when ADV_DATA and SCAN_RSP are merged (terminator field before SCAN_RSP part). Fix this by inspecting ADV_DATA and correct its length if terminator is found. > HCI Event: LE Meta Event (0x3e) plen 42 [hci0] 32.172182 LE Advertising Report (0x02) Num reports: 1 Event type: Connectable undirected - ADV_IND (0x00) Address type: Public (0x00) Address: 7C:2F:80:94:97:5A (Gigaset Communications GmbH) Data length: 30 Flags: 0x06 LE General Discoverable Mode BR/EDR Not Supported Company: Gigaset Communications GmbH (384) Data: 021512348094975abbc5 16-bit Service UUIDs (partial): 1 entry Battery Service (0x180f) RSSI: -65 dBm (0xbf) > HCI Event: LE Meta Event (0x3e) plen 27 [hci0] 32.172191 LE Advertising Report (0x02) Num reports: 1 Event type: Scan response - SCAN_RSP (0x04) Address type: Public (0x00) Address: 7C:2F:80:94:97:5A (Gigaset Communications GmbH) Data length: 15 Name (complete): Gigaset G-tag RSSI: -59 dBm (0xc5) Note "Data length: 30" in ADV_DATA which results in 9 extra zero bytes after Battery Service UUID. Terminator field present in the middle of EIR in Device Found event resulted in userspace stop parsing EIR and skipping device name. @ Device Found: 7C:2F:80:94:97:5A (1) rssi -59 flags 0x0000 02 01 06 0d ff 80 01 02 15 12 34 80 94 97 5a bb ..........4...Z. c5 03 02 0f 18 00 00 00 00 00 00 00 00 00 0e 09 ................ 47 69 67 61 73 65 74 20 47 2d 74 61 67 Gigaset G-tag With this fix EIR with merged ADV_DATA and SCAN_RSP in device found event is properly formatted: @ Device Found: 7C:2F:80:94:97:5A (1) rssi -59 flags 0x0000 02 01 06 0d ff 80 01 02 15 12 34 80 94 97 5a bb ..........4...Z. c5 03 02 0f 18 0e 09 47 69 67 61 73 65 74 20 47 .......Gigaset G 2d 74 61 67 -tag Signed-off-by: Szymon Janc <ext.szymon.janc@tieto.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2015-09-18Bluetooth: Add BT_ERR_RATELIMITEDSzymon Janc
This patch adds ratelimited version of the BT_ERR macro. Signed-off-by: Szymon Janc <ext.szymon.janc@tieto.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2015-09-17sch_dsmark: improve memory localityEric Dumazet
Memory placement in sch_dsmark is silly : Better place mask/value in the same cache line. Also, we can embed small arrays in the first cache line and remove a potential cache miss. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17net: Initialize table in fib resultDavid Ahern
Sergey, Richard and Fabio reported an oops in ip_route_input_noref. e.g., from Richard: [ 0.877040] BUG: unable to handle kernel NULL pointer dereference at 0000000000000056 [ 0.877597] IP: [<ffffffff8155b5e2>] ip_route_input_noref+0x1a2/0xb00 [ 0.877597] PGD 3fa14067 PUD 3fa6e067 PMD 0 [ 0.877597] Oops: 0000 [#1] SMP [ 0.877597] Modules linked in: virtio_net virtio_pci virtio_ring virtio [ 0.877597] CPU: 1 PID: 119 Comm: ifconfig Not tainted 4.2.0+ #1 [ 0.877597] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 [ 0.877597] task: ffff88003fab0bc0 ti: ffff88003faa8000 task.ti: ffff88003faa8000 [ 0.877597] RIP: 0010:[<ffffffff8155b5e2>] [<ffffffff8155b5e2>] ip_route_input_noref+0x1a2/0xb00 [ 0.877597] RSP: 0018:ffff88003ed03ba0 EFLAGS: 00010202 [ 0.877597] RAX: 0000000000000046 RBX: 00000000ffffff8f RCX: 0000000000000020 [ 0.877597] RDX: ffff88003fab50b8 RSI: 0000000000000200 RDI: ffffffff8152b4b8 [ 0.877597] RBP: ffff88003ed03c50 R08: 0000000000000000 R09: 0000000000000000 [ 0.877597] R10: 0000000000000000 R11: 0000000000000000 R12: ffff88003fab6f00 [ 0.877597] R13: ffff88003fab5000 R14: 0000000000000000 R15: ffffffff81cb5600 [ 0.877597] FS: 00007f6de5751700(0000) GS:ffff88003ed00000(0000) knlGS:0000000000000000 [ 0.877597] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 0.877597] CR2: 0000000000000056 CR3: 000000003fa6d000 CR4: 00000000000006e0 [ 0.877597] Stack: [ 0.877597] 0000000000000000 0000000000000046 ffff88003fffa600 ffff88003ed03be0 [ 0.877597] ffff88003f9e2c00 697da8c0017da8c0 ffff880000000000 000000000007fd00 [ 0.877597] 0000000000000000 0000000000000046 0000000000000000 0000000400000000 [ 0.877597] Call Trace: [ 0.877597] <IRQ> [ 0.877597] [<ffffffff812bfa1f>] ? cpumask_next_and+0x2f/0x40 [ 0.877597] [<ffffffff8158e13c>] arp_process+0x39c/0x690 [ 0.877597] [<ffffffff8158e57e>] arp_rcv+0x13e/0x170 [ 0.877597] [<ffffffff8151feec>] __netif_receive_skb_core+0x60c/0xa00 [ 0.877597] [<ffffffff81515795>] ? __build_skb+0x25/0x100 [ 0.877597] [<ffffffff81515795>] ? __build_skb+0x25/0x100 [ 0.877597] [<ffffffff81521ff6>] __netif_receive_skb+0x16/0x70 [ 0.877597] [<ffffffff81522078>] netif_receive_skb_internal+0x28/0x90 [ 0.877597] [<ffffffff8152288f>] napi_gro_receive+0x7f/0xd0 [ 0.877597] [<ffffffffa0017906>] virtnet_receive+0x256/0x910 [virtio_net] [ 0.877597] [<ffffffffa0017fd8>] virtnet_poll+0x18/0x80 [virtio_net] [ 0.877597] [<ffffffff815234cd>] net_rx_action+0x1dd/0x2f0 [ 0.877597] [<ffffffff81053228>] __do_softirq+0x98/0x260 [ 0.877597] [<ffffffff8164969c>] do_softirq_own_stack+0x1c/0x30 The root cause is use of res.table uninitialized. Thanks to Nikolay for noticing the uninitialized use amongst the maze of gotos. As Nikolay pointed out the second initialization is not required to fix the oops, but rather to fix a related problem where a valid lookup should be invalidated before creating the rth entry. Fixes: b7503e0cdb5d ("net: Add FIB table id to rtable") Reported-by: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Reported-by: Richard Alpe <richard.alpe@ericsson.com> Reported-by: Fabio Estevam <festevam@gmail.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: David Ahern <dsa@cumulusnetworks.com> Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17bpf: add bpf_redirect() helperAlexei Starovoitov
Existing bpf_clone_redirect() helper clones skb before redirecting it to RX or TX of destination netdev. Introduce bpf_redirect() helper that does that without cloning. Benchmarked with two hosts using 10G ixgbe NICs. One host is doing line rate pktgen. Another host is configured as: $ tc qdisc add dev $dev ingress $ tc filter add dev $dev root pref 10 u32 match u32 0 0 flowid 1:2 \ action bpf run object-file tcbpf1_kern.o section clone_redirect_xmit drop so it receives the packet on $dev and immediately xmits it on $dev + 1 The section 'clone_redirect_xmit' in tcbpf1_kern.o file has the program that does bpf_clone_redirect() and performance is 2.0 Mpps $ tc filter add dev $dev root pref 10 u32 match u32 0 0 flowid 1:2 \ action bpf run object-file tcbpf1_kern.o section redirect_xmit drop which is using bpf_redirect() - 2.4 Mpps and using cls_bpf with integrated actions as: $ tc filter add dev $dev root pref 10 \ bpf run object-file tcbpf1_kern.o section redirect_xmit integ_act classid 1 performance is 2.5 Mpps To summarize: u32+act_bpf using clone_redirect - 2.0 Mpps u32+act_bpf using redirect - 2.4 Mpps cls_bpf using redirect - 2.5 Mpps For comparison linux bridge in this setup is doing 2.1 Mpps and ixgbe rx + drop in ip_rcv - 7.8 Mpps Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17cls_bpf: introduce integrated actionsDaniel Borkmann
Often cls_bpf classifier is used with single action drop attached. Optimize this use case and let cls_bpf return both classid and action. For backwards compatibility reasons enable this feature under TCA_BPF_FLAG_ACT_DIRECT flag. Then more interesting programs like the following are easier to write: int cls_bpf_prog(struct __sk_buff *skb) { /* classify arp, ip, ipv6 into different traffic classes * and drop all other packets */ switch (skb->protocol) { case htons(ETH_P_ARP): skb->tc_classid = 1; break; case htons(ETH_P_IP): skb->tc_classid = 2; break; case htons(ETH_P_IPV6): skb->tc_classid = 3; break; default: return TC_ACT_SHOT; } return TC_ACT_OK; } Joint work with Daniel Borkmann. Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17net: only check perm protocol when register protoJunwei Zhang
The permanent protocol nodes are at the head of the list, So only need check all these nodes. No matter the new node is permanent or not, insert the new node after the last permanent protocol node, If the new node conflicts with existing permanent node, return error. Signed-off-by: Martin Zhang <martinbj2008@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17tcp: provide skb->hash to synack packetsEric Dumazet
In commit b73c3d0e4f0e ("net: Save TX flow hash in sock and set in skbuf on xmit"), Tom provided a l4 hash to most outgoing TCP packets. We'd like to provide one as well for SYNACK packets, so that all packets of a given flow share same txhash, to later enable bonding driver to also use skb->hash to perform slave selection. Note that a SYNACK retransmit shuffles the tx hash, as Tom did in commit 265f94ff54d62 ("net: Recompute sk_txhash on negative routing advice") for established sockets. This has nice effect making TCP flows resilient to some kind of black holes, even at connection establish phase. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Tom Herbert <tom@herbertland.com> Cc: Mahesh Bandewar <maheshb@google.com> Acked-by: Tom Herbert <tom@herbertland.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17netfilter: Add blank lines in callers of netfilter hooksEric W. Biederman
In code review it was noticed that I had failed to add some blank lines in places where they are customarily used. Taking a second look at the code I have to agree blank lines would be nice so I have added them here. Reported-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17netfilter: Pass net into okfnEric W. Biederman
This is immediately motivated by the bridge code that chains functions that call into netfilter. Without passing net into the okfns the bridge code would need to guess about the best expression for the network namespace to process packets in. As net is frequently one of the first things computed in continuation functions after netfilter has done it's job passing in the desired network namespace is in many cases a code simplification. To support this change the function dst_output_okfn is introduced to simplify passing dst_output as an okfn. For the moment dst_output_okfn just silently drops the struct net. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17netfilter: Use nf_hook_state.netEric W. Biederman
Instead of saying "net = dev_net(state->in?state->in:state->out)" just say "state->net". As that information is now availabe, much less confusing and much less error prone. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17netfilter: Pass struct net into the netfilter hooksEric W. Biederman
Pass a network namespace parameter into the netfilter hooks. At the call site of the netfilter hooks the path a packet is taking through the network stack is well known which allows the network namespace to be easily and reliabily. This allows the replacement of magic code like "dev_net(state->in?:state->out)" that appears at the start of most netfilter hooks with "state->net". In almost all cases the network namespace passed in is derived from the first network device passed in, guaranteeing those paths will not see any changes in practice. The exceptions are: xfrm/xfrm_output.c:xfrm_output_resume() xs_net(skb_dst(skb)->xfrm) ipvs/ip_vs_xmit.c:ip_vs_nat_send_or_cont() ip_vs_conn_net(cp) ipvs/ip_vs_xmit.c:ip_vs_send_or_cont() ip_vs_conn_net(cp) ipv4/raw.c:raw_send_hdrinc() sock_net(sk) ipv6/ip6_output.c:ip6_xmit() sock_net(sk) ipv6/ndisc.c:ndisc_send_skb() dev_net(skb->dev) not dev_net(dst->dev) ipv6/raw.c:raw6_send_hdrinc() sock_net(sk) br_netfilter_hooks.c:br_nf_pre_routing_finish() dev_net(skb->dev) before skb->dev is set to nf_bridge->physindev In all cases these exceptions seem to be a better expression for the network namespace the packet is being processed in then the historic "dev_net(in?in:out)". I am documenting them in case something odd pops up and someone starts trying to track down what happened. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17bridge: Add br_netif_receive_skb remove netif_receive_skb_skEric W. Biederman
netif_receive_skb_sk is only called once in the bridge code, replace it with a bridge specific function that calls netif_receive_skb. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17bridge: Cache net in br_nf_pre_routing_finishEric W. Biederman
This is prep work for passing net to the netfilter hooks. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17bridge: Pass net into br_nf_push_frag_xmitEric W. Biederman
When struct net starts being passed through the ipv4 and ipv6 fragment routines br_nf_push_frag_xmit will need to take a net parameter. Prepare br_nf_push_frag_xmit before that is needed and introduce br_nf_push_frag_xmit_sk for the call sites that still need the old calling conventions. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-17bridge: Pass net into br_nf_ip_fragmentEric W. Biederman
This is a prep work for passing struct net through ip_do_fragment and later the netfilter okfn. Doing this independently makes the later code changes clearer. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
