path: root/net/xfrm/xfrm_user.c
2008-01-28[IPSEC]: Make x->lastused an unsigned longHerbert Xu
Currently x->lastused is u64 which means that it cannot be read/written atomically on all architectures. David Miller observed that the value stored in it is only an unsigned long which is always atomic. So based on his suggestion this patch changes the internal representation from u64 to unsigned long while the user-interface still refers to it as u64. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-08[XFRM]: xfrm_algo_clone() allocates too much memoryEric Dumazet
alg_key_len is the length in bits of the key, not in bytes. Best way to fix this is to move alg_len() function from net/xfrm/xfrm_user.c to include/net/xfrm.h, and to use it in xfrm_algo_clone() alg_len() is renamed to xfrm_alg_len() because of its global exposition. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-26[IPSEC]: Temporarily remove locks around copying of non-atomic fieldsHerbert Xu
The change 050f009e16f908932070313c1745d09dc69fd62b [IPSEC]: Lock state when copying non-atomic fields to user-space caused a regression. Ingo Molnar reports that it causes a potential dead-lock found by the lock validator as it tries to take x->lock within xfrm_state_lock while numerous other sites take the locks in opposite order. For 2.6.24, the best fix is to simply remove the added locks as that puts us back in the same state as we've been in for years. For later kernels a proper fix would be to reverse the locking order for every xfrm state user such that if x->lock is taken together with xfrm_state_lock then it is to be taken within it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[NET]: make netlink user -> kernel interface synchroniousDenis V. Lunev
This patch make processing netlink user -> kernel messages synchronious. This change was inspired by the talk with Alexey Kuznetsov about current netlink messages processing. He says that he was badly wrong when introduced asynchronious user -> kernel communication. The call netlink_unicast is the only path to send message to the kernel netlink socket. But, unfortunately, it is also used to send data to the user. Before this change the user message has been attached to the socket queue and sk->sk_data_ready was called. The process has been blocked until all pending messages were processed. The bad thing is that this processing may occur in the arbitrary process context. This patch changes nlk->data_ready callback to get 1 skb and force packet processing right in the netlink_unicast. Kernel -> user path in netlink_unicast remains untouched. EINTR processing for in netlink_run_queue was changed. It forces rtnl_lock drop, but the process remains in the cycle until the message will be fully processed. So, there is no need to use this kludges now. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Lock state when copying non-atomic fields to user-spaceHerbert Xu
This patch adds locking so that when we're copying non-atomic fields such as life-time or coaddr to user-space we don't get a partial result. For af_key I've changed every instance of pfkey_xfrm_state2msg apart from expiration notification to include the keys and life-times. This is in-line with XFRM behaviour. The actual cases affected are: * pfkey_getspi: No change as we don't have any keys to copy. * key_notify_sa: + ADD/UPD: This wouldn't work otherwise. + DEL: It can't hurt. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] user: Move attribute copying code into copy_to_user_state_extraHerbert Xu
Here's a good example of code duplication leading to code rot. The notification patch did its own netlink message creation for xfrm states. It duplicated code that was already in dump_one_state. Guess what, the next time (and the time after) when someone updated dump_one_state the notification path got zilch. This patch moves that code from dump_one_state to copy_to_user_state_extra and uses it in xfrm_notify_sa too. Unfortunately whoever updates this still needs to update xfrm_sa_len since the notification path wants to know the exact size for allocation. At least I've added a comment saying so and if someone still forgest, we'll have a WARN_ON telling us so. I also changed the security size calculation to use xfrm_user_sec_ctx since that's what we actually put into the skb. However it makes no practical difference since it has the same size as xfrm_sec_ctx. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move common code into xfrm_alloc_spiHerbert Xu
This patch moves some common code that conceptually belongs to the xfrm core from af_key/xfrm_user into xfrm_alloc_spi. In particular, the spin lock on the state is now taken inside xfrm_alloc_spi. Previously it also protected the construction of the response PF_KEY/XFRM messages to user-space. This is inconsistent as other identical constructions are not protected by the state lock. This is bad because they in fact should be protected but only in certain spots (so as not to hold the lock for too long which may cause packet drops). The SPI byte order conversion has also been moved. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETLINK]: Avoid pointer in netlink_run_queueHerbert Xu
I was looking at Patrick's fix to inet_diag and it occured to me that we're using a pointer argument to return values unnecessarily in netlink_run_queue. Changing it to return the value will allow the compiler to generate better code since the value won't have to be memory-backed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Support multiple network namespaces with netlinkEric W. Biederman
Each netlink socket will live in exactly one network namespace, this includes the controlling kernel sockets. This patch updates all of the existing netlink protocols to only support the initial network namespace. Request by clients in other namespaces will get -ECONREFUSED. As they would if the kernel did not have the support for that netlink protocol compiled in. As each netlink protocol is updated to be multiple network namespace safe it can register multiple kernel sockets to acquire a presence in the rest of the network namespaces. The implementation in af_netlink is a simple filter implementation at hash table insertion and hash table look up time. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM]: xfrm audit callsJoy Latten
This patch modifies the current ipsec audit layer by breaking it up into purpose driven audit calls. So far, the only audit calls made are when add/delete an SA/policy. It had been discussed to give each key manager it's own calls to do this, but I found there to be much redundnacy since they did the exact same things, except for how they got auid and sid, so I combined them. The below audit calls can be made by any key manager. Hopefully, this is ok. Signed-off-by: Joy Latten <latten@austin.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Inline attach_encap_tmpl(), attach_sec_ctx(), and ↵Thomas Graf
attach_one_addr() These functions are only used once and are a lot easier to understand if inlined directly into the function. Fixes by Masahide NAKAMURA. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Remove dependency on rtnetlinkThomas Graf
2007-10-10[XFRM] netlink: Use nlattr instead of rtattrThomas Graf
2007-10-10[XFRM] netlink: Rename attribute array from xfrma[] to attrs[]Thomas Graf
Increases readability a lot. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Enhance indexing of the attribute arrayThomas Graf
nlmsg_parse() puts attributes at array[type] so the indexing method can be simpilfied by removing the obscuring "- 1". Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Establish an attribute policyThomas Graf
Adds a policy defining the minimal payload lengths for all the attributes allowing for most attribute validation checks to be removed from in the middle of the code path. Makes updates more consistent as many format errors are recognised earlier, before any changes have been attempted. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Use nlmsg_parse() to parse attributesThomas Graf
Uses nlmsg_parse() to parse the attributes. This actually changes behaviour as unknown attributes (type > MAXTYPE) no longer cause an error. Instead unknown attributes will be ignored henceforth to keep older kernels compatible with more recent userspace tools. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Use nlmsg_new() and type-safe size calculation helpersThomas Graf
Moves all complex message size calculation into own inlined helper functions and makes use of the type-safe netlink interface. Using nlmsg_new() simplifies the calculation itself as it takes care of the netlink header length by itself. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Clear up some of the CONFIG_XFRM_SUB_POLICY ifdef messThomas Graf
Moves all of the SUB_POLICY ifdefs related to the attribute size calculation into a function. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Move algorithm length calculation to its own functionThomas Graf
Adds alg_len() to calculate the properly padded length of an algorithm attribute to simplify the code. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Use nla_put()/NLA_PUT() variantesThomas Graf
Also makes use of copy_sec_ctx() in another place and removes duplicated code. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Use nlmsg_broadcast() and nlmsg_unicast()Thomas Graf
This simplifies successful return codes from >0 to 0. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[XFRM] netlink: Use nlmsg_data() instead of NLMSG_DATA()Thomas Graf
2007-10-10[XFRM] netlink: Use nlmsg_end() and nlmsg_cancel()Thomas Graf
2007-10-10[XFRM] netlink: Use nlmsg_put() instead of NLMSG_PUT()Thomas Graf
2007-07-31[IPSEC]: Ensure that state inner family is setHerbert Xu
Similar to the issue we had with template families which specified the inner families of policies, we need to set the inner families of states as the main xfrm user Openswan leaves it as zero. af_key is unaffected because the inner family is set by it and not the KM. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07xfrm: Add security check before flushing SAD/SPDJoy Latten
Currently we check for permission before deleting entries from SAD and SPD, (see security_xfrm_policy_delete() security_xfrm_state_delete()) However we are not checking for authorization when flushing the SPD and the SAD completely. It was perhaps missed in the original security hooks patch. This patch adds a security check when flushing entries from the SAD and SPD. It runs the entire database and checks each entry for a denial. If the process attempting the flush is unable to remove all of the entries a denial is logged the the flush function returns an error without removing anything. This is particularly useful when a process may need to create or delete its own xfrm entries used for things like labeled networking but that same process should not be able to delete other entries or flush the entire database. Signed-off-by: Joy Latten<latten@austin.ibm.com> Signed-off-by: Eric Paris <eparis@parisplace.org> Signed-off-by: James Morris <jmorris@namei.org>
2007-05-04[XFRM] SPD info TLV aggregationJamal Hadi Salim
Aggregate the SPD info TLVs. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[XFRM] SAD info TLV aggregationxJamal Hadi Salim
Aggregate the SAD info TLVs. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-28[XFRM]: Export SPD infoJamal Hadi Salim
With this patch you can use iproute2 in user space to efficiently see how many policies exist in different directions. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[XFRM]: Missing bits to SAD info.Jamal Hadi Salim
This brings the SAD info in sync with net-2.6.22/net-2.6 Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[XFRM]: Export SAD info.Jamal Hadi Salim
On a system with a lot of SAs, counting SAD entries chews useful CPU time since you need to dump the whole SAD to user space; i.e something like ip xfrm state ls | grep -i src | wc -l I have seen taking literally minutes on a 40K SAs when the system is swapping. With this patch, some of the SAD info (that was already being tracked) is exposed to user space. i.e you do: ip xfrm state count And you get the count; you can also pass -s to the command line and get the hash info. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Switch cb_lock spinlock to mutex and allow to override itPatrick McHardy
Switch cb_lock to mutex and allow netlink kernel users to override it with a subsystem specific mutex for consistent locking in dump callbacks. All netlink_dump_start users have been audited not to rely on any side-effects of the previously used spinlock. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Directly return -EINTR from netlink_dump_start()Thomas Graf
Now that all users of netlink_dump_start() use netlink_run_queue() to process the receive queue, it is possible to return -EINTR from netlink_dump_start() directly, therefore simplying the callers. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Remove error pointer from netlink message handlerThomas Graf
The error pointer argument in netlink message handlers is used to signal the special case where processing has to be interrupted because a dump was started but no error happened. Instead it is simpler and more clear to return -EINTR and have netlink_run_queue() deal with getting the queue right. nfnetlink passed on this error pointer to its subsystem handlers but only uses it to signal the start of a netlink dump. Therefore it can be removed there as well. This patch also cleans up the error handling in the affected message handlers to be consistent since it had to be touched anyway. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Ignore control messages directly in netlink_run_queue()Thomas Graf
Changes netlink_rcv_skb() to skip netlink controll messages and don't pass them on to the message handler. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Ignore !NLM_F_REQUEST messages directly in netlink_run_queue()Thomas Graf
netlink_rcv_skb() is changed to skip messages which don't have the NLM_F_REQUEST bit to avoid every netlink family having to perform this check on their own. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Use nlmsg_trim() where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-13[IPSEC] XFRM_USER: kernel panic when large security contexts in ACQUIREJoy Latten
When sending a security context of 50+ characters in an ACQUIRE message, following kernel panic occurred. kernel BUG in xfrm_send_acquire at net/xfrm/xfrm_user.c:1781! cpu 0x3: Vector: 700 (Program Check) at [c0000000421bb2e0] pc: c00000000033b074: .xfrm_send_acquire+0x240/0x2c8 lr: c00000000033b014: .xfrm_send_acquire+0x1e0/0x2c8 sp: c0000000421bb560 msr: 8000000000029032 current = 0xc00000000fce8f00 paca = 0xc000000000464b00 pid = 2303, comm = ping kernel BUG in xfrm_send_acquire at net/xfrm/xfrm_user.c:1781! enter ? for help 3:mon> t [c0000000421bb650] c00000000033538c .km_query+0x6c/0xec [c0000000421bb6f0] c000000000337374 .xfrm_state_find+0x7f4/0xb88 [c0000000421bb7f0] c000000000332350 .xfrm_tmpl_resolve+0xc4/0x21c [c0000000421bb8d0] c0000000003326e8 .xfrm_lookup+0x1a0/0x5b0 [c0000000421bba00] c0000000002e6ea0 .ip_route_output_flow+0x88/0xb4 [c0000000421bbaa0] c0000000003106d8 .ip4_datagram_connect+0x218/0x374 [c0000000421bbbd0] c00000000031bc00 .inet_dgram_connect+0xac/0xd4 [c0000000421bbc60] c0000000002b11ac .sys_connect+0xd8/0x120 [c0000000421bbd90] c0000000002d38d0 .compat_sys_socketcall+0xdc/0x214 [c0000000421bbe30] c00000000000869c syscall_exit+0x0/0x40 --- Exception: c00 (System Call) at 0000000007f0ca9c SP (fc0ef8f0) is in userspace We are using size of security context from xfrm_policy to determine how much space to alloc skb and then putting security context from xfrm_state into skb. Should have been using size of security context from xfrm_state to alloc skb. Following fix does that Signed-off-by: Joy Latten <latten@austin.ibm.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-22[NET]: fix up misplaced inlines.Dave Jones
Turning up the warnings on gcc makes it emit warnings about the placement of 'inline' in function declarations. Here's everything that was under net/ Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-07[IPSEC]: xfrm audit hook misplaced in pfkey_delete and xfrm_del_saEric Paris
Inside pfkey_delete and xfrm_del_sa the audit hooks were not called if there was any permission/security failures in attempting to do the del operation (such as permission denied from security_xfrm_state_delete). This patch moves the audit hook to the exit path such that all failures (and successes) will actually get audited. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Venkat Yekkirala <vyekkirala@trustedcs.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-07[IPSEC]: xfrm_policy delete security check misplacedEric Paris
The security hooks to check permissions to remove an xfrm_policy were actually done after the policy was removed. Since the unlinking and deletion are done in xfrm_policy_by* functions this moves the hooks inside those 2 functions. There we have all the information needed to do the security check and it can be done before the deletion. Since auditing requires the result of that security check err has to be passed back and forth from the xfrm_policy_by* functions. This patch also fixes a bug where a deletion that failed the security check could cause improper accounting on the xfrm_policy (xfrm_get_policy didn't have a put on the exit path for the hold taken by xfrm_policy_by*) It also fixes the return code when no policy is found in xfrm_add_pol_expire. In old code (at least back in the 2.6.18 days) err wasn't used before the return when no policy is found and so the initialization would cause err to be ENOENT. But since err has since been used above when we don't get a policy back from the xfrm_policy_by* function we would always return 0 instead of the intended ENOENT. Also fixed some white space damage in the same area. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Venkat Yekkirala <vyekkirala@trustedcs.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-28[NET]: Fix kfree(skb)Patrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-28[XFRM] xfrm_user: Fix return values of xfrm_add_sa_expire.David S. Miller
As noted by Kent Yoder, this function will always return an error. Make sure it returns zero on success. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[XFRM]: Fix OOPSes in xfrm_audit_log().David S. Miller
Make sure that this function is called correctly, and add BUG() checking to ensure the arguments are sane. Based upon a patch by Joy Latten. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] XFRM: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[XFRM]: User interface for handling XFRM_MSG_MIGRATEShinta Sugimoto
Add user interface for handling XFRM_MSG_MIGRATE. The message is issued by user application. When kernel receives the message, procedure of updating XFRM databases will take place. Signed-off-by: Shinta Sugimoto <shinta.sugimoto@ericsson.com> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-03[XFRM_USER]: avoid pointless void ** castsChristoph Hellwig
All ->doit handlers want a struct rtattr **, so pass down the right type. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
