path: root/net/wireless/wext.c
2008-08-13wext: Send name on eventsJamal Hadi Salim
In the minimal the wireless extensions oughta send at least the name in addition to the ifindex. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19netns: Use net_eq() to compare net-namespaces for optimization.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, namespace is always &init_net. Compiler will be able to omit namespace comparisons with this patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16wext: Create IW_REQUEST_FLAG_COMPAT and set it as needed.David S. Miller
Now low-level WEXT ioctl handlers can do compat handling when necessary. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16wext: Dispatch and handle compat ioctls entirely in net/wireless/wext.cDavid S. Miller
Next we can kill the hacks in fs/compat_ioctl.c and also dispatch compat ioctls down into the driver and 80211 protocol helper layers in order to handle iw_point objects embedded in stream replies which need to be translated. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16wext: Pull top-level ioctl dispatch logic into helper function.David S. Miller
2008-06-16wext: Pass iwreq pointer down into standard/private handlers.David S. Miller
They have no need to see the object as an ifreq. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16wext: Parameterize the standard/private handlers.David S. Miller
The WEXT standard and private handlers to use are now arguments to wireless_process_ioctl(). Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-16wext: Pull ioctl permission checking out into helper function.David S. Miller
2008-06-16wext: Extract private call iw_point handling into seperate functions.David S. Miller
2008-06-16wext: Extract standard call iw_point handling into seperate function.David S. Miller
2008-06-16wext: Make adjust_priv_size() take a "struct iw_point *".David S. Miller
2008-06-16wext: Remove inline from get_priv_size() and adjust_priv_size().David S. Miller
The compiler inlines when appropriate. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-01-28WEXT: remove unused variableMasakazu Mokuno
As event_type_pk_size[] is not used, Remove it. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28[NET]: Consolidate net namespace related proc files creation.Denis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Make rtnetlink infrastructure network namespace aware (v3)Denis V. Lunev
After this patch none of the netlink callback support anything except the initial network namespace but the rtnetlink infrastructure now handles multiple network namespaces. Changes from v2: - IPv6 addrlabel processing Changes from v1: - no need for special rtnl_unlock handling - fixed IPv6 ndisc Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-20[WIRELESS] WEXT: Fix userspace corruption on 64-bit.David S. Miller
On 64-bit systems sizeof(struct ifreq) is 8 bytes larger than sizeof(struct iwreq). For GET calls, the wireless extension code copies back into userspace using sizeof(struct ifreq) but userspace and elsewhere only allocates a "struct iwreq". Thus, this copy writes past the end of the iwreq object and corrupts whatever sits after it in memory. Fix the copy_to_user() length. This particularly hurts the compat case because the wireless compat code uses compat_alloc_userspace() and right after this allocated buffer is the current bottom of the user stack, and that's what gets overwritten by the copy_to_user() call. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Fix race when opening a proc file while a network namespace is exiting.Eric W. Biederman
The problem: proc_net files remember which network namespace the are against but do not remember hold a reference count (as that would pin the network namespace). So we currently have a small window where the reference count on a network namespace may be incremented when opening a /proc file when it has already gone to zero. To fix this introduce maybe_get_net and get_proc_net. maybe_get_net increments the network namespace reference count only if it is greater then zero, ensuring we don't increment a reference count after it has gone to zero. get_proc_net handles all of the magic to go from a proc inode to the network namespace instance and call maybe_get_net on it. PROC_NET the old accessor is removed so that we don't get confused and use the wrong helper function. Then I fix up the callers to use get_proc_net and handle the case case where get_proc_net returns NULL. In that case I return -ENXIO because effectively the network namespace has already gone away so the files we are trying to access don't exist anymore. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[WIRELESS]: Use type safe netlink interfaceThomas Graf
Makes use of the type safe netlink interface and adds a warning if the message is too big for NLMSG_DEFAULT_SIZE to help debug. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-26[WEXT]: Misc code cleanups.Johannes Berg
Just a few things that didn't fit in with the other patches. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[WEXT]: Reduce inline abuse.Johannes Berg
This patch removes a bunch of inline abuse from wext. Most functions that were marked inline are only used once so the compiler will inline them anyway, others are used multiple times but there's no requirement for them to be inline since they aren't in any fast paths. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[WEXT]: Move EXPORT_SYMBOL statements where they belong.Johannes Berg
EXPORT_SYMBOL statements are supposed to go together with the symbol they're exporting. This patch moves them accordingly. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[WEXT]: Cleanup early ioctl call path.Johannes Berg
This patch makes the code in wireless_process_ioctl somewhat more readable. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[WEXT]: Remove options.Johannes Berg
This patch kills the two options in wext that are required to be enabled anyway because they influence the userspace API. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[WEXT]: Remove dead debug code.Johannes Berg
This patch kills a whole bunch of code that can only ever be used by defining some things in wext.c. Also, the things that are printed are mostly useless since the API is fairly well-tested. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[WEXT]: Clean up how wext is called.Johannes Berg
This patch cleans up the call paths from the core code into wext. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[WEXT]: Move to net/wirelessJohannes Berg
This patch moves dev/core/wireless.c to net/wireless/wext.c. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
