path: root/net/wireless/wext-sme.c
2012-03-12cfg80211: Add background scan period attribute.Bala Shanmugam
Receive background scan period as part of connect command and pass the same to the driver. Signed-off-by: Bala Shanmugam <bkamatch@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-08cfg80211: remove unused wext handler exportsJohannes Berg
A lot of code is dedicated to giving drivers the ability to use cfg80211's wext handlers without completely converting. However, only orinoco is currently using this, and it is only partially using it. We reduce the size of both the source and binary by removing those that nobody needs. If a driver shows up that needs it during conversion, we can add back those that are needed. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08cfg80211: split wext compatibility to separate headerJohannes Berg
A lot of drivers erroneously use wext constants and don't notice since cfg80211.h includes them. Make this more split up so drivers needing wext compatibility from cfg80211 need to explicitly include that from cfg80211-wext.h. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-27cfg80211: allow changing port control protocolJohannes Berg
Some vendor specified mechanisms for 802.1X-style functionality use a different protocol than EAP (even if EAP is vendor-extensible). Allow setting the ethertype for the protocol when a driver has support for this. The default if unspecified is EAP, of course. Note: This is suitable only for station mode, not for AP implementation. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-11Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/ath/ar9170/main.c
2010-05-07cfg80211/mac80211: better channel handlingJohannes Berg
Currently (all tested with hwsim) you can do stupid things like setting up an AP on a certain channel, then adding another virtual interface and making that associate on another channel -- this will make the beaconing to move channel but obviously without the necessary IEs data update. In order to improve this situation, first make the configuration APIs (cfg80211 and nl80211) aware of multi-channel operation -- we'll eventually need that in the future anyway. There's one userland API change and one API addition. The API change is that now SET_WIPHY must be called with virtual interface index rather than only wiphy index in order to take effect for that interface -- luckily all current users (hostapd) do that. For monitor interfaces, the old setting is preserved, but monitors are always slaved to other devices anyway so no guarantees. The second userland API change is the introduction of a per virtual interface SET_CHANNEL command, that hostapd should use going forward to make it easier to understand what's going on (it can automatically detect a kernel with this command). Other than mac80211, no existing cfg80211 drivers are affected by this change because they only allow a single virtual interface. mac80211, however, now needs to be aware that the channel settings are per interface now, and needs to disallow (for now) real multi-channel operation, which is another important part of this patch. One of the immediate benefits is that you can now start hostapd to operate on a hardware that already has a connection on another virtual interface, as long as you specify the same channel. Note that two things are left unhandled (this is an improvement -- not a complete fix): * different HT/no-HT modes currently you could start an HT AP and then connect to a non-HT network on the same channel which would configure the hardware for no HT; that can be fixed fairly easily * CSA An AP we're connected to on a virtual interface might indicate switching channels, and in that case we would follow it, regardless of how many other interfaces are operating; this requires more effort to fix but is pretty rare after all Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-28cfg80211: don't set privacy w/o keyJohannes Berg
When wpa_supplicant is used to connect to open networks, it causes the wdev->wext.keys to point to key memory, but that key memory is all empty. Only use privacy when there is a default key to be used. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Tested-by: Luis R. Rodriguez <lrodriguez@atheros.com> Tested-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-09-28cfg80211: wext: don't display BSSID unless associatedJohannes Berg
Currently, cfg80211's SIOCGIWAP implementation returns the BSSID that the user set, even if the connection has since been dropped due to other changes. It only should return the current BSSID when actually connected. Also do a small code cleanup. Reported-by: Thomas H. Guenther <thomas.h.guenther@intel.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Tested-by: Thomas H. Guenther <thomas.h.guenther@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-09-23cfg80211: don't overwrite privacy settingJohannes Berg
When cfg80211 is instructed to connect, it always uses the default WEP key for the privacy setting, which clearly is wrong when using wpa_supplicant. Don't overwrite the setting, and rely on it being false when wpa_supplicant is not running, instead set it to true when we have keys. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14cfg80211: fix locking for SIWFREQJohannes Berg
"cfg80211: validate channel settings across interfaces" contained a locking bug -- in the managed-mode SIWFREQ call it would end up running into a lock recursion. This fixes it by not checking that particular interface for a channel that it needs to stay on, which is as it should be as that's the interface we're setting the channel for. Reported-by: Reinette Chatre <reinette.chatre@intel.com> Reported-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Tested-by: Kalle Valo <kalle.valo@iki.fi> Tested-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14cfg80211: use reassociation when possibleJohannes Berg
With the move of everything related to the SME from mac80211 to cfg80211, we lost the ability to send reassociation frames. This adds them back, but only for wireless extensions. With the userspace SME, it shall control assoc vs. reassoc (it already can do so with the nl80211 interface). I haven't touched the connect() implementation, so it is not possible to reassociate with the nl80211 connect primitive. I think that should be done with the NL80211_CMD_ROAM command, but we'll have to see how that can be handled in the future, especially with fullmac chips. This patch addresses only the immediate regression we had in mac80211, which previously sent reassoc. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14cfg80211: validate channel settings across interfacesJohannes Berg
Currently, there's a problem that affects regulatory enforcement and connection stability, in that it is possible to switch the channel while connected to a network or joined to an IBSS. The problem comes from the fact that we only validate the channel against the current interface's type, not against any other interface. Thus, you have any type of interface up, additionally bring up a monitor mode interface and switch the channel on the monitor. This will obviously also switch the channel on the other interface. The problem now is that if you do that while sending beacons for IBSS mode, you can switch to a disabled channel or a channel that doesn't allow beaconing. Combined with a managed mode interface connected to an AP instead of an IBSS interface, you can easily break the connection that way. To fix this, this patch validates any channel change with all available interfaces, and disallows such changes on secondary interfaces if another interface is connected to an AP or joined to an IBSS. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14wireless: display wext SSID when connected by cfg80211Zhu Yi
cfg80211 displays correct link info when connected by wext. But if the connection is setup by cfg80211, wext cannot display the SSID. This patch fixed this issue. Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-29cfg80211: combine IWESSID handlersJohannes Berg
Since we now have handlers IWESSID for all modes, we can combine them into one. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-29cfg80211: combine IWAP handlersJohannes Berg
Since we now have IWAP handlers for all modes, we can combine them into one. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-29cfg80211: combine iwfreq implementationsJohannes Berg
Until now we implemented iwfreq for managed mode, we needed to keep the implementations separate, but now that we have all versions implemented we can combine them and export just one handler. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-24cfg80211: don't optimise wext calls too muchJohannes Berg
In the wext code I tried to not reconnect all the time when the user wasn't really sure what they were doing, like setting the BSSID back to the same value it was. However, this optimisation should only be done while associated so that setting the BSSID back to the same value that it was actually triggers a new association if not currently associated. To achieve, that, put the relevant code into the !IDLE case instead. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Tested-by: Kalle Valo <kalle.valo@iki.fi> Tested-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-24cfg80211: fix wext setting SSIDJohannes Berg
Pavel reported that you can't set the SSID from "foo" to "bar". I tried reproducing, but used different values, with different lengths, and thus never saw the obvious problem. Reported-by: Pavel Roskin <proski@gnu.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-24cfg80211: don't look at wdev->ssid for giwessidJohannes Berg
This variable is only used internally, _while_ connected. If we use it, the sequence # iwconfig wlan1 essid foo <connects> # iwconfig wlan1 essid "" <disconnects> # iwconfig will still display "foo" as the SSID afterwards, which is obviously quite bogus. Fix this by only displaying the wext SSID, if present. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-24cfg80211: rework key operationJohannes Berg
This reworks the key operation in cfg80211, and now only allows, from userspace, configuring keys (via nl80211) after the connection has been established (in managed mode), the IBSS been joined (in IBSS mode), at any time (in AP[_VLAN] modes) or never for all the other modes. In order to do shared key authentication correctly, it is now possible to give a WEP key to the AUTH command. To configure static WEP keys, these are given to the CONNECT or IBSS_JOIN command directly, for a userspace SME it is assumed it will configure it properly after the connection has been established. Since mac80211 used to check the default key in IBSS mode to see whether or not the network is protected, it needs an update in that area, as well as an update to make use of the WEP key passed to auth() for shared key authentication. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10cfg80211: fix lockingJohannes Berg
Over time, a lot of locking issues have crept into the smarts of cfg80211, so e.g. scan completion can race against a new scan, IBSS join can race against leaving an IBSS, etc. Introduce a new per-interface lock that protects most of the per-interface data that we need to keep track of, and sprinkle assertions about that lock everywhere. Some things now need to be offloaded to work structs so that we don't require being able to sleep in functions the drivers call. The exception to that are the MLME callbacks (rx_auth etc.) that currently only mac80211 calls because it was easier to do that there instead of in cfg80211, and future drivers implementing those calls will, if they ever exist, probably need to use a similar scheme like mac80211 anyway... In order to be able to handle _deauth and _disassoc properly, introduce a cookie passed to it that will determine locking requirements. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10cfg80211: keep track of BSSesJohannes Berg
In order to avoid problems with BSS structs going away while they're in use, I've long wanted to make cfg80211 keep track of them. Without the SME, that wasn't doable but now that we have the SME we can do this too. It can keep track of up to four separate authentications and one association, regardless of whether it's controlled by the cfg80211 SME or the userspace SME. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10cfg80211: managed mode wext compatibilityJohannes Berg
This adds code to make it possible to use the cfg80211 connect() API with wireless extensions, and because the previous patch added emulation of that API with auth() and assoc(), by extension also supports wext on that. At the same time, removes code from mac80211 for wext, but doesn't yet clean up mac80211's mlme code more. Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
