path: root/net/wireless/util.c
2014-01-09cfg80211: Add a function to get the number of supported channelsIlan Peer
Add a utility function to get the number of channels supported by the device, and update the places in the code that need this data. Signed-off-by: Ilan Peer <ilan.peer@intel.com> [replace another occurrence in libertas, fix kernel-doc, fix bugs] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-30cfg80211/mac80211: correct qos-map lockingJohannes Berg
Since the RTNL can't always be held, use wdev/sdata locking for the qos-map dereference in mac80211. This requires cfg80211 to consistently lock it, which it was missing in one place. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-19cfg80211: Add support for QoS mappingKyeyoon Park
This allows QoS mapping from external networks to be implemented as defined in IEEE Std 802.11-2012, 10.24.9. APs can use this to advertise DSCP ranges and exceptions for mapping frames to a specific UP over Wi-Fi. The payload of the QoS Map Set element (IEEE Std 802.11-2012, 8.4.2.97) is sent to the driver through the new NL80211_ATTR_QOS_MAP attribute to configure the local behavior either on the AP (based on local configuration) or on a station (based on information received from the AP). Signed-off-by: Kyeyoon Park <kyeyoonp@qca.qualcomm.com> Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-10-28nl80211/cfg80211: enable DFS for IBSS modeSimon Wunderlich
To use DFS in IBSS mode, userspace is required to react to radar events. It can inform nl80211 that it is capable of doing so by adding a NL80211_ATTR_HANDLE_DFS attribute when joining the IBSS. This attribute is supplied to let the kernelspace know that the userspace application can and will handle radar events, e.g. by intiating channel switches to a valid channel. DFS channels may only be used if this attribute is supplied and the driver supports it. Driver support will be checked even if a channel without DFS will be initially joined, as a DFS channel may be chosen later. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> [fix attribute name in commit message] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-10-02cfg80211: vlan priority handling in WMMcedric Voncken
If the VLAN tci is set in skb->vlan_tci use the priority field to determine the WMM priority. Signed-off-by: cedric Voncken <cedric.voncken@acksys.fr> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-07-16cfg80211/mac80211: get mandatory rates based on scan widthSimon Wunderlich
Mandatory rates for 5 and 10 MHz are different from the rates used for 20 MHz in 2.4 GHz mode, as they use OFDM only. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
2013-05-25cfg80211: remove some locked wrappers from sme APIJohannes Berg
By making all the API functions require wdev locking we can clean up the API a bit, getting rid of the locking version of each function. This also decreases the size of cfg80211 by a small amount. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-25cfg80211: vastly simplify lockingJohannes Berg
Virtually all code paths in cfg80211 already (need to) hold the RTNL. As such, there's little point in having another four mutexes for various parts of the code, they just cause lock ordering issues (and much of the time, the RTNL and a few of the others need thus be held.) Simplify all this by getting rid of the extra four mutexes and just use the RTNL throughout. Only a few code changes were needed to do this and we can get rid of a work struct for bonus points. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-24{cfg,mac}80211: move mandatory rates calculation to cfg80211Ashok Nagarajan
Move mandatory rates calculation to cfg80211, shared with non mac80211 drivers. Signed-off-by: Ashok Nagarajan <ashok@cozybit.com> [extend documentation] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-16cfg80211: add 60GHz regulatory classVladimir Kondratiev
Add regulatory class for 60GHz band, according to the last specification. Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-24Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
2013-04-22cfg80211: invert P2P-Device vs. netdev check orderingJohannes Berg
In cfg80211_can_use_iftype_chan(), check for P2P Device first, and then for netdevs. This doesn't really change anything but makes the code a bit easier to read since it may not be obvious for everyone at first that a P2P device has no netdev. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-16cfg80211: add ieee80211_operating_class_to_bandJohannes Berg
This function converts a (global only!) operating class to an internal band identifier. This will be needed for extended channel switch support. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-28net: add ETH_P_802_3_MINSimon Horman
Add a new constant ETH_P_802_3_MIN, the minimum ethernet type for an 802.3 frame. Frames with a lower value in the ethernet type field are Ethernet II. Also update all the users of this value that David Miller and I could find to use the new constant. Also correct a bug in util.c. The comparison with ETH_P_802_3_MIN should be >= not >. As suggested by Jesse Gross. Compile tested only. Cc: David Miller <davem@davemloft.net> Cc: Jesse Gross <jesse@nicira.com> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: John W. Linville <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Bart De Schuymer <bart.de.schuymer@pandora.be> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: Gustavo Padovan <gustavo@padovan.org> Cc: Johan Hedberg <johan.hedberg@gmail.com> Cc: linux-bluetooth@vger.kernel.org Cc: netfilter-devel@vger.kernel.org Cc: bridge@lists.linux-foundation.org Cc: linux-wireless@vger.kernel.org Cc: linux1394-devel@lists.sourceforge.net Cc: linux-media@vger.kernel.org Cc: netdev@vger.kernel.org Cc: dev@openvswitch.org Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-11cfg80211: fix radar check for P2P_DEVICEIlan Peer
Radar is not required for P2P_DEVICE interfaces. Signed-off-by: Ilan Peer <ilan.peer@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-01-24cfg80211: fix channel check in cfg80211_can_use_iftype_chanSimon Wunderlich
In commit "cfg80211: check radar interface combinations" a regression was introduced which might lead to NULL dereference if the argument chan = NULL, which might happen in IBSS/wext case (and probably others). Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-01-16cfg80211: check radar interface combinationsSimon Wunderlich
To ease further DFS development regarding interface combinations, use the interface combinations structure to test for radar capabilities. Drivers can specify which channel widths they support, and in which modes. Right now only a single AP interface is allowed, but as the DFS code evolves other combinations can be enabled. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-30cfg80211: fix BSS struct IE access racesJohannes Berg
When a BSS struct is updated, the IEs are currently overwritten or freed. This can lead to races if some other CPU is accessing the BSS struct and using the IEs concurrently. Fix this by always allocating the IEs in a new struct that holds the data and length and protecting access to this new struct with RCU. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-26nl80211/cfg80211: add VHT MCS supportJohannes Berg
Add support for reporting and calculating VHT MCSes. Note that I'm not completely sure that the bitrate calculations are correct, nor that they can't be simplified. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-26cfg80211: change function signature of cfg80211_get_p2p_attr()Arend van Spriel
The function cfg80211_get_p2p_attr() can fail and returns a negative error code. However, the return type is unsigned int. The largest positive number is determined by desired_len variable in the function, which is u16. So changing the return type to int to allow easy error checking. Also change the type for the attribute to enum for improved type checking. Signed-off-by: Arend van Spriel <arend@broadcom.com> [fix indentation, don't use u8 attr variable] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-06wireless: add utility function to get P2P attributeJohannes Berg
Parsing the P2P attributes can be tricky as their contents can be split across multiple (vendor) IEs. Thus, it's not possible to parse them like IEs (by returning a pointer to the data.) Instead, provide a function that copies the attribute data into a caller-provided buffer and returns the size needed (useful in case the buffer was too small.) Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-10-29Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/mwifiex/cfg80211.c
2012-10-26mac80211: verify that skb data is presentJohannes Berg
A number of places in the mesh code don't check that the frame data is present and in the skb header when trying to access. Add those checks and the necessary pskb_may_pull() calls. This prevents accessing data that doesn't actually exist. To do this, export ieee80211_get_mesh_hdrlen() to be able to use it in mac80211. Cc: stable@vger.kernel.org Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-10-26wireless: drop invalid mesh address extension framesJohannes Berg
The mesh header can have address extension by a 4th or a 5th and 6th address, but never both. Drop such frames in 802.11 -> 802.3 conversion along with any frames that have the wrong extension. Cc: stable@vger.kernel.org Reviewed-by: Javier Cardona <javier@cozybit.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-10-18cfg80211: add wrappers for registered_device_opsHila Gonen
This will allow adding central tracing like in mac80211. Signed-off-by: Hila Gonen <hila.gonen@intel.com> Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-08-24Merge branch 'master' of ↵John W. Linville
2012-08-20cfg80211: add P2P Device abstractionJohannes Berg
In order to support using a different MAC address for the P2P Device address we must first have a P2P Device abstraction that can be assigned a MAC address. This abstraction will also be useful to support offloading P2P operations to the device, e.g. periodic listen for discoverability. Currently, the driver is responsible for assigning a MAC address to the P2P Device, but this could be changed by allowing a MAC address to be given to the NEW_INTERFACE command. As it has no associated netdev, a P2P Device can only be identified by its wdev identifier but the previous patches allowed using the wdev identifier in various APIs, e.g. remain-on-channel. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-08-06cfg80211: process pending events when unregistering net deviceDaniel Drake
libertas currently calls cfg80211_disconnected() when it is being brought down. This causes an event to be allocated, but since the wdev is already removed from the rdev by the time that the event processing work executes, the event is never processed or freed. http://article.gmane.org/gmane.linux.kernel.wireless.general/95666 Fix this leak, and other possible situations, by processing the event queue when a device is being unregistered. Thanks to Johannes Berg for the suggestion. Signed-off-by: Daniel Drake <dsd@laptop.org> Cc: stable@vger.kernel.org Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-31cfg80211: unify IE searchVladimir Kondratiev
Remove ah-hoc IE search code found in the ieee80211_bss_get_ie() and use cfg80211_find_ie() instead. Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-12cfg80211: fix locking and lockdep complaintsJohannes Berg
To call cfg80211_get_chan_state() we need to lock the wdev, so we need to lock the wdev_iter mutex in cfg80211_can_use_iftype_chan(). This needs to use nested locking for lockdep. Also, cfg80211_get_chan_state() doesn't actually use the rdev, so remove that completely including the lock assertion that isn't needed. Reported-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-09nl80211: prepare for non-netdev wireless devsJohannes Berg
In order to support a P2P device abstraction and Bluetooth high-speed AMPs, we need to have a way to identify virtual interfaces that don't have a netdev associated. Do this by adding a NL80211_ATTR_WDEV attribute to identify a wdev which may or may not also be a netdev. To simplify things, use a 64-bit value with the high 32 bits being the wiphy index for this new wdev identifier in the nl80211 API. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-05cfg80211: bitrate calculation for 60gVladimir Kondratiev
60g band uses different from .11n MCS scheme, so bitrate should be calculated differently Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-05{nl,cfg}80211: support high bitratesVladimir Kondratiev
Until now, a u16 value was used to represent bitrate value. With VHT bitrates this becomes too small. Introduce a new 32-bit bitrate attribute. nl80211 will report both the new and the old attribute, unless the bitrate doesn't fit into the old u16 attribute in which case only the new one will be reported. User space tools encouraged to prefer the 32-bit attribute, if available (since it won't be available on older kernels.) Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com> [reword commit message and comments a bit] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-02cfg80211: add 802.11ad (60gHz band) supportVladimir Kondratiev
Add enumerations for both cfg80211 and nl80211. This expands wiphy.bands etc. arrays. Extend channel <-> frequency translation to cover 60g band and modify the rate check logic since there are no legacy mandatory rates (only MCS is used.) Signed-off-by: Vladimir Kondratiev <qca_vkondrat@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-29cfg80211: respect iface combinations when starting operationMichal Kazior
devlist_mtx locking is changed to accomodate changes. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-29cfg80211: add channel checking for iface combinationsMichal Kazior
.connect cannot be handled since the driver scans and connects on its own. It is up to the driver then to refuse a connection (with -EBUSY for example). Non-fixed channel IBSSes always take a single channel resource. For example two non-fixed channel IBSSes always take up 2 num_different_channels, even if they operate on the same channel at a given point of time. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-29cfg80211: track monitor interfaces countMichal Kazior
Implements .set_monitor_enabled(wiphy, enabled). Notifies driver upon change of interface layout. If only monitor interfaces become present it is called with 2nd argument being true. If non-monitor interface appears then 2nd argument is false. Driver is notified only upon change. This makes it more obvious about the fact that cfg80211 supports single monitor channel. Once we implement multi-channel we don't want to allow setting monitor channel while other interface types are running. Otherwise it would be ambiguous once we start considering num_different_channels. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-29cfg80211: .stop_ap when interface is going downMichal Kazior
We'll need this for proper channel tracking (which is going to be needed for channel context accounting and finding matching/active interface combination). Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-09cfg80211: check iface combinations only when iface is runningMichal Kazior
Don't validate interface combinations on a stopped interface. Otherwise we might end up being able to create a new interface with a certain type, but won't be able to change an existing interface into that type. This also skips some other functions when interface is stopped and changing interface type. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-05cfg80211: fix interface combinations checkJohannes Berg
If a given interface combination doesn't contain a required interface type then we missed checking that and erroneously allowed it even though iface type wasn't there at all. Add a check that makes sure that all interface types are accounted for. Cc: stable@kernel.org Reported-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-nextJohn W. Linville
2012-05-16cfg80211: add warning when calculating MCS rates >= 32Johannes Berg
cfg80211_calculate_bitrate() doesn't work for MCS rates 32 or higher, and it has always returned 0 in that case. Warn if it ever really happens. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-09wireless: Convert compare_ether_addr to ether_addr_equal by handJoe Perches
spatch/coccinelle isn't perfect. It doesn't understand __aligned(x) and doesn't convert functions it can't parse. Convert the remaining compare_ether_addr uses. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-09wireless: Convert compare_ether_addr to ether_addr_equalJoe Perches
Use the new bool function ether_addr_equal to add some clarity and reduce the likelihood for misuse of compare_ether_addr for sorting. I removed a conversion from scan.c/cmp_bss_core that appears to be a sorting function. Done via cocci script: $ cat compare_ether_addr.cocci @@ expression a,b; @@ - !compare_ether_addr(a, b) + ether_addr_equal(a, b) @@ expression a,b; @@ - compare_ether_addr(a, b) + !ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) == 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) != 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) == 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) != 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !!ether_addr_equal(a, b) + ether_addr_equal(a, b) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Fix merge between commit 3adadc08cc1e ("net ax25: Reorder ax25_exit to remove races") and commit 0ca7a4c87d27 ("net ax25: Simplify and cleanup the ax25 sysctl handling") The former moved around the sysctl register/unregister calls, the later simply removed them. With help from Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-16cfg80211: enforce lack of interface combinationsJohannes Berg
My grand plan to allow drivers to gradually move over to advertising virtual interface combinations and only enforce with drivers that do want it enforced doesn't seem to be working out, only Christian ever added the advertising (to carl9170), nobody else did. Begin enforcing combinations in cfg80211 so that users can rely on the information reported about a device. Cc: "Luis R. Rodriguez" <mcgrof@qca.qualcomm.com> Cc: Jouni Malinen <jouni@qca.qualcomm.com> Cc: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com> Cc: Senthil Balasubramanian <senthilb@qca.qualcomm.com> Cc: Kalle Valo <kvalo@qca.qualcomm.com> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Nick Kossifidis <mickflemm@gmail.com> Cc: Bob Copeland <me@bobcopeland.com> Cc: Bing Zhao <bzhao@marvell.com> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Ivo van Doorn <IvDoorn@gmail.com> Cc: Gertjan van Wingerde <gwingerde@gmail.com> Cc: Helmut Schaa <helmut.schaa@googlemail.com> Cc: Luciano Coelho <coelho@ti.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-13cfg80211: fix interface combinations check.Lukasz Kucharczyk
Signed-off-by: Lukasz Kucharczyk <lukasz.kucharczyk@tieto.com> Cc: stable@vger.kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-06cfg80211: expose cfg80211_calculate_bitrate()Thomas Pedersen
Signed-off-by: Thomas Pedersen <thomas@cozybit.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-04wireless: Treat IPv6 diffserv the same as IPv4 for 802.11eDave Täht
Wireless will select a different hardware queue based on the top 3 bits of the diffserv field, for ipv4. Extend that queue selection mechanism to ipv6, and make the calls orthogonal. Signed-off-by: Dave Täht <dave.taht@bufferbloat.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-13cfg80211: Fix race in bss timeoutVasanthakumar Thiagarajan
It is quite possible to run into a race in bss timeout where the drivers see the bss entry just before notifying cfg80211 of a roaming event but it got timed out by the time rdev->event_work got scehduled from cfg80211_wq. This would result in the following WARN-ON() along with the failure to notify the user space of the roaming. The other situation which is happening with ath6kl that runs into issue is when the driver reports roam to same AP event where the AP bss entry already got expired. To fix this, move cfg80211_get_bss() from __cfg80211_roamed() to cfg80211_roamed(). [158645.538384] WARNING: at net/wireless/sme.c:586 __cfg80211_roamed+0xc2/0x1b1() [158645.538810] Call Trace: [158645.538838] [<c1033527>] warn_slowpath_common+0x65/0x7a [158645.538917] [<c14cfacf>] ? __cfg80211_roamed+0xc2/0x1b1 [158645.538946] [<c103354b>] warn_slowpath_null+0xf/0x13 [158645.539055] [<c14cfacf>] __cfg80211_roamed+0xc2/0x1b1 [158645.539086] [<c14beb5b>] cfg80211_process_rdev_events+0x153/0x1cc [158645.539166] [<c14bd57b>] cfg80211_event_work+0x26/0x36 [158645.539195] [<c10482ae>] process_one_work+0x219/0x38b [158645.539273] [<c14bd555>] ? wiphy_new+0x419/0x419 [158645.539301] [<c10486cb>] worker_thread+0xf6/0x1bf [158645.539379] [<c10485d5>] ? rescuer_thread+0x1b5/0x1b5 [158645.539407] [<c104b3e2>] kthread+0x62/0x67 [158645.539484] [<c104b380>] ? __init_kthread_worker+0x42/0x42 [158645.539514] [<c151309a>] kernel_thread_helper+0x6/0xd Reported-by: Kalle Valo <kvalo@qca.qualcomm.com> Signed-off-by: Vasanthakumar Thiagarajan <vthiagar@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
