Since rdev->sched_scan_req is dereferenced outside the
lock protecting it, this might be done at the wrong
time, causing crashes. Move the dereference to where
it should be - inside the RTNL locked section.
Cc: stable@vger.kernel.org [3.8+]
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
This function is being removed, so remove the reference to it.
To allow scanning and working with 5 MHz and 10 MHz BSS, extend the
inform bss commands and add wrappers to take 5 and 10 MHz bss into
account.
Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de>
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Should help the next person that tries to understand
the bss refcounting logic.
Signed-off-by: Ben Greear <greearb@candelatech.com>
Virtually all code paths in cfg80211 already (need to) hold
the RTNL. As such, there's little point in having another
four mutexes for various parts of the code, they just cause
lock ordering issues (and much of the time, the RTNL and a
few of the others need thus be held.)
Simplify all this by getting rid of the extra four mutexes
and just use the RTNL throughout. Only a few code changes
were needed to do this and we can get rid of a work struct
for bonus points.
The function is only used and needed by the wext code
for scanning, so move it there.
If a P2P device wdev is removed while it has a scan, then the
scan completion might crash later as it is already freed by
that time. To avoid the crash always check the scan completion
when the P2P device is being removed for some reason. If the
driver already canceled it, don't want and free it, otherwise
warn and leak it to avoid later crashes.
In order to do this, locking needs to be changed away from the
rdev mutex (which can't always be guaranteed). For now, use
the sched_scan_mtx instead, I'll rename it to just scan_mtx in
a later patch.
In the odd case that while updating information from a beacon,
a BSS was found that is part of a hidden group, we drop the
new information. In this case, however, we leak the IE buffer
from the update, and erroneously update the entry's timestamp
so it will never time out. Fix both these issues.
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Add new NL80211_CMD_RADAR_DETECT, which starts the Channel
Availability Check (CAC). This command will also notify the
usermode about events (CAC finished, CAC aborted, radar
detected, NOP finished).
Once radar detection has started it should continuously
monitor for radars as long as the channel is active.
This patch enables DFS for AP mode in nl80211/cfg80211.
Based on original patch by Victor Goldenshtein <victorg@ti.com>
[remove WIPHY_FLAG_HAS_RADAR_DETECT again -- my mistake]
cfg80211_find_vendor_ie() was checking only that the vendor IE would
fit in the remaining IEs buffer. If a corrupt includes a vendor IE
that is too small, we could potentially overrun the IEs buffer.
Fix this by checking that the vendor IE fits in the reported IE length
field and skip it otherwise.
Reported-by: Jouni Malinen <j@w1.fi>
Signed-off-by: Luciano Coelho <coelho@ti.com>
[change BUILD_BUG_ON to != 1 (from >= 2)]
While technically the TSF isn't an IE, it can be
necessary to distinguish between the TSF from a
beacon and a probe response, in particular in
order to know the next DTIM TBTT, as not all APs
are spec compliant wrt. TSF==0 being a DTIM TBTT
and thus the DTIM count needs to be taken into
account as well.
To allow this, move the TSF into the IE struct
so it can be known whence it came.
There's no way scan BSS IEs can be NULL as even
if the allocation fails the frame is discarded.
Remove some code checking for this and document
that it is always non-NULL.
Currently, cfg80211 will copy beacon IEs from a previously
received hidden SSID beacon to a probe response entry, if
that entry is created after the beacon entry. However, if
it is the other way around, or if the beacon is updated,
such changes aren't propagated.
Fix this by tracking the relation between the probe
response and beacon BSS structs in this case.
In case drivers have private data stored in a BSS struct
and need access to such data from a beacon entry, cfg80211
now provides the hidden_beacon_bss pointer from the probe
response entry to the beacon entry.
This prepares for using the spinlock instead of krefs
which is needed in the next patch to track the refs
of combined BSSes correctly.
Acked-by: Bing Zhao <bzhao@marvell.com> [mwifiex]
Add inline wrappers for the BSS struct krefs
to be able to extend them easily later.
This local variable is only used once, so remove it.
Instead of annotating with a comment, add a lockdep
annotation which also serves as documentation.
There's no reason for it to require external
locking, move it into the function.
The comment about allocating the IEs together with
the BSS struct is no longer true, remove it. Also
fix a typo in the same area.
As Thomas pointed out, cfg80211_get_mesh() is
unused and can be removed.
Cc: Thomas Pedersen <thomas@cozybit.com>
Instead of first checking if a BSS is an MBSS
and then doing the comparisons, inline it all
into the BSS comparison function. This avoids
doing the IE searches twice and is also a lot
less code.
When trying to find a hidden SSID, the lookup function
is done wrong; the code is trying to combine the two
lookups into one, and as a consequence doesn't always
find the entry at all. To understand this, consider a
case where multiple BSS entries with the same channel
and BSSID exist but have different SSID length. Then
comparing against the probe response SSID length is
bound to cause problems since the hidden one might be
either zeroed out or zero-length.
To fix this we need to do two lookups for the two ways
to hide SSIDs.
Instead of duplicating the rbtree functions, pass
an argument to the compare function. This removes
the code duplication for the two searches.
Now that mac80211 no longer uses this API, remove
it completely. If anyone needs it again, we can
revert this patch of course, but mac80211 was the
only user right now.
We do a:
sprintf(buf, " Last beacon: %ums ago",
elapsed_jiffies_msecs(bss->ts));
elapsed_jiffies_msecs() can return a 10 digit number so "buf" needs to
be 31 characters long.
When a BSS struct is updated, the IEs are currently
overwritten or freed. This can lead to races if some
other CPU is accessing the BSS struct and using the
IEs concurrently.
Fix this by always allocating the IEs in a new struct
that holds the data and length and protecting access
to this new struct with RCU.
The cmp_bss() comparator function uses memcmp() to
compare the SSID. This means that cmp_hidden_bss()
needs to similarly return a number bigger than zero
(use 1) instead of -1 when ie1 is bigger than ie2,
which is the case if an ie2 byte is non-zero.
Fix a number of indentation and similar issues.
There's no need to stop the machine, just leak
the BSS entry if there's an issue with its hold
counter when freeing.
Currently, mac80211 checks the DS params IE if present and
uses it for the (primary) BSS channel, instead of the one
that the frame was received on. This is particularly useful
in the 2.4 GHz band since a frame is often received on one
of the adjacent channels due to overlap.
Move this code to cfg80211 so other drivers also do this.
Additionally, on 5 GHz, in particular with some (possibly)
upcoming changes in 802.11ai and duplicate transmissions
when wider channels are used, something similar happens.
So if present, also use the (primary) channel information
contained in the HT operation IE.
Also add tracing to the API functions that drivers
(and mac80211) can call in cfg80211.
Signed-off-by: Beni Lev <beni.lev@intel.com>
Reviewed-by: Johannes Berg <johannes.berg@intel.com>
This will allow adding central tracing like in mac80211.
Signed-off-by: Hila Gonen <hila.gonen@intel.com>
Add an NL80211_SCAN_FLAG_FLUSH flag that causes old bss cache
entries to be flushed on scan completion. This is useful for
collecting guaranteed fresh scan/survey result (e.g. on resume).
For normal scan, flushing only happens on successful completion
of a scan; i.e. it does not happen if the scan is aborted.
For scheduled scan, previous scan results are flushed everytime
when we get new scan results.
This feature is enabled by default. Drivers can disable it by
unsetting the NL80211_FEATURE_SCAN_FLUSH flag.
Signed-off-by: Sam Leffler <sleffler@chromium.org>
Tested-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
[invert polarity of feature flag to account for old kernels]
bss_release() and __cfg80211_unlink_bss() function definitions
are moved at the begining of the file. They are used in next
patch in this series.
checkpatch pointed out an issue, fix it.
The new P2P Device will have to be able to scan for
P2P search, so move scanning to use struct wireless_dev
instead of struct net_device.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next
Use the new bool function ether_addr_equal to add
some clarity and reduce the likelihood for misuse
of compare_ether_addr for sorting.
I removed a conversion from scan.c/cmp_bss_core
that appears to be a sorting function.
Done via cocci script:
$ cat compare_ether_addr.cocci
expression a,b;
- !compare_ether_addr(a, b)
+ ether_addr_equal(a, b)
expression a,b;
- compare_ether_addr(a, b)
+ !ether_addr_equal(a, b)
expression a,b;
- !ether_addr_equal(a, b) == 0
expression a,b;
- !ether_addr_equal(a, b) != 0
expression a,b;
- ether_addr_equal(a, b) == 0
expression a,b;
- ether_addr_equal(a, b) != 0
expression a,b;
- !!ether_addr_equal(a, b)
Since the BSS table is organized in a RB tree, the BSSs need to be
comparable. This means that we must define a < and > operator to
the BSS object.
compare_ethr_addr isn't enough since it returns only a binary value.
Since Felix's
cfg80211: use compare_ether_addr on MAC addresses instead of memcmp
Because of the constant size and guaranteed 16 bit alignment, the inline
compare_ether_addr function is much cheaper than calling memcmp.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
The BSS table is corrupted: rb_find_bss can't find the bss.
As a result BSSes are duplicated in the BSS table, and we get stuck
while probing an AP before associating (in STA mode).
Change-Id: I85928756f4328028230832c1565ece7f412f3843
CC: Felix Fietkau <nbd@openwrt.org>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Acked-by: Felix Fietkau <nbd@openwrt.org>
The background scan completion takes more time when the station is
having heavy uplink traffic. The scan state machine decides to fall
back to home channel on every off-channel visit when there are pending
frames in tx queue. bgscan completion took ~30sec on dual band US
regulatory card.
scan period = (20 active channels * probe timeout) +
(12 passive channels * passive probe timeout) +
(32 * timeout on home channel) +
(32 * flush timeout)
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
This is intended to be the timestamp sent by the
peer in the beacon/probe response, not any form
of host timestamp. Clarify the documentation and
variable names.
This is needed by mac80211 to keep a reference
to a BSS alive for the auth process. Remove the
old version of cfg80211_ref_bss() since it's
not actually used.
The problem with PSM when a hidden SSID was used was originally
reported by Juuso Oikarinen.
- When generally scanning, the AP is getting a bss entry with
a zero SSID.
- When associating, a probe-req is sent to the AP with the SSID,
and as a result a probe-response is received with the hidden
SSID in place. As a consequence, a second bss entry is created
for the AP, now with the real SSID.
- After association, mac80211 executes ieee80211_recalc_ps(),
but does not switch to powersave because the beacon-ies are missing.
As result, the STA does not ever enter PSM.
The patch merges in beacon ies of hidden bss from beacon to the probe
response, creating a consistent set of ies in place.
Patch is depended on "cfg80211: fix cmp_ies" made by Johannes.
Signed-off-by: Dmitry Tarnyagin <dmitry.tarnyagin@stericsson.com>
When comparing two items by IE, the sort order
wasn't stable, which could lead to issues in the
rbtree. Make it stable by making a missing IE
sort before a present IE.
Also sort by length first if it differs and then
by contents.
Add function to find vendor-specific ie (along with
vendor-specific ie struct definition and P2P OUI values)
Signed-off-by: Eliad Peller <eliad@wizery.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
A lot of drivers erroneously use wext constants
and don't notice since cfg80211.h includes them.
Make this more split up so drivers needing wext
compatibility from cfg80211 need to explicitly
include that from cfg80211-wext.h.
commit 58389c69150e6032504dfcd3edca6b1975c8b5bc
Author: Johannes Berg <johannes.berg@intel.com>
Date: Mon Jul 18 18:08:35 2011 +0200
cfg80211: allow userspace to control supported rates in scan
made single-band cards crash since it would always
access all wiphy->bands[]. Fix this and reject any
attempts in the new helper ieee80211_get_ratemask()
to do the same, rejecting rates configuration for
unsupported bands.
Reported-by: Pavel Roskin <proski@gnu.org>
Tested-by: Pavel Roskin <proski@gnu.org>
Some P2P scans are not allowed to advertise
11b rates, but that is a rather special case
so instead of having that, allow userspace
to request the rate sets (per band) that are
advertised in scan probe request frames.
Since it's needed in two places now, factor
out some common code parsing a rate array.
