checkpatch pointed out an issue, fix it.
Signed-off-by: Hila Gonen <hila.gonen@intel.com>
The new P2P Device will have to be able to scan for
P2P search, so move scanning to use struct wireless_dev
instead of struct net_device.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next
Use the new bool function ether_addr_equal to add
some clarity and reduce the likelihood for misuse
of compare_ether_addr for sorting.
I removed a conversion from scan.c/cmp_bss_core
that appears to be a sorting function.
Done via cocci script:
$ cat compare_ether_addr.cocci
expression a,b;
- !compare_ether_addr(a, b)
+ ether_addr_equal(a, b)
expression a,b;
- compare_ether_addr(a, b)
+ !ether_addr_equal(a, b)
expression a,b;
- !ether_addr_equal(a, b) == 0
expression a,b;
- !ether_addr_equal(a, b) != 0
expression a,b;
- ether_addr_equal(a, b) == 0
expression a,b;
- ether_addr_equal(a, b) != 0
expression a,b;
- !!ether_addr_equal(a, b)
Since the BSS table is organized in a RB tree, the BSSs need to be
comparable. This means that we must define a < and > operator to
the BSS object.
compare_ethr_addr isn't enough since it returns only a binary value.
Since Felix's
cfg80211: use compare_ether_addr on MAC addresses instead of memcmp
Because of the constant size and guaranteed 16 bit alignment, the inline
compare_ether_addr function is much cheaper than calling memcmp.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
The BSS table is corrupted: rb_find_bss can't find the bss.
As a result BSSes are duplicated in the BSS table, and we get stuck
while probing an AP before associating (in STA mode).
Change-Id: I85928756f4328028230832c1565ece7f412f3843
CC: Felix Fietkau <nbd@openwrt.org>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Acked-by: Felix Fietkau <nbd@openwrt.org>
The background scan completion takes more time when the station is
having heavy uplink traffic. The scan state machine decides to fall
back to home channel on every off-channel visit when there are pending
frames in tx queue. bgscan completion took ~30sec on dual band US
regulatory card.
scan period = (20 active channels * probe timeout) +
(12 passive channels * passive probe timeout) +
(32 * timeout on home channel) +
(32 * flush timeout)
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
This is intended to be the timestamp sent by the
peer in the beacon/probe response, not any form
of host timestamp. Clarify the documentation and
variable names.
This is needed by mac80211 to keep a reference
to a BSS alive for the auth process. Remove the
old version of cfg80211_ref_bss() since it's
not actually used.
The problem with PSM when a hidden SSID was used was originally
reported by Juuso Oikarinen.
- When generally scanning, the AP is getting a bss entry with
a zero SSID.
- When associating, a probe-req is sent to the AP with the SSID,
and as a result a probe-response is received with the hidden
SSID in place. As a consequence, a second bss entry is created
for the AP, now with the real SSID.
- After association, mac80211 executes ieee80211_recalc_ps(),
but does not switch to powersave because the beacon-ies are missing.
As result, the STA does not ever enter PSM.
The patch merges in beacon ies of hidden bss from beacon to the probe
response, creating a consistent set of ies in place.
Patch is depended on "cfg80211: fix cmp_ies" made by Johannes.
Signed-off-by: Dmitry Tarnyagin <dmitry.tarnyagin@stericsson.com>
When comparing two items by IE, the sort order
wasn't stable, which could lead to issues in the
rbtree. Make it stable by making a missing IE
sort before a present IE.
Also sort by length first if it differs and then
by contents.
Add function to find vendor-specific ie (along with
vendor-specific ie struct definition and P2P OUI values)
Signed-off-by: Eliad Peller <eliad@wizery.com>
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
A lot of drivers erroneously use wext constants
and don't notice since cfg80211.h includes them.
Make this more split up so drivers needing wext
compatibility from cfg80211 need to explicitly
include that from cfg80211-wext.h.
commit 58389c69150e6032504dfcd3edca6b1975c8b5bc
Author: Johannes Berg <johannes.berg@intel.com>
Date: Mon Jul 18 18:08:35 2011 +0200
cfg80211: allow userspace to control supported rates in scan
made single-band cards crash since it would always
access all wiphy->bands[]. Fix this and reject any
attempts in the new helper ieee80211_get_ratemask()
to do the same, rejecting rates configuration for
unsupported bands.
Reported-by: Pavel Roskin <proski@gnu.org>
Tested-by: Pavel Roskin <proski@gnu.org>
Some P2P scans are not allowed to advertise
11b rates, but that is a rather special case
so instead of having that, allow userspace
to request the rate sets (per band) that are
advertised in scan probe request frames.
Since it's needed in two places now, factor
out some common code parsing a rate array.
drivers/net/wireless/ath/ath5k/sysfs.c
net/bluetooth/l2cap_core.c
net/mac80211/wpa.c
If we try to stop a scheduled scan while it is not running, we should
return -ENOENT instead of simply ignoring the command and returning
success. This is more consistent with other parts of the code.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Luciano Coelho <coelho@ti.com>
If the 'driver_initiated' function argument to
__cfg80211_stop_sched_scan() is not 0 then we'll return an
uninitialized 'err' from the function.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
There was a deadlock when rfkill-blocking a wireless interface,
because we were locking the rdev mutex on NETDEV_GOING_DOWN to stop
sched_scans that were eventually running. The rfkill block code was
already holding a mutex under rdev:
kernel: =======================================================
kernel: [ INFO: possible circular locking dependency detected ]
kernel: 3.0.0-rc1-00049-g1fa7b6a #57
kernel: -------------------------------------------------------
kernel: kworker/0:1/4525 is trying to acquire lock:
kernel: (&rdev->mtx){+.+.+.}, at: [<ffffffff8164c831>] cfg80211_netdev_notifier_call+0x131/0x5b0
kernel:
kernel: but task is already holding lock:
kernel: (&rdev->devlist_mtx){+.+.+.}, at: [<ffffffff8164dcef>] cfg80211_rfkill_set_block+0x4f/0xa0
kernel:
kernel: which lock already depends on the new lock.
To fix this, add a new mutex specifically for sched_scan, to protect
the sched_scan_req element in the rdev struct, instead of using the
global rdev mutex.
Reported-by: Duane Griffin <duaneg@dghda.com>
Commit 0a35d36 ("cfg80211: Use capability info to detect mesh beacons")
assumed that probe response with both ESS and IBSS bits cleared
means that the frame was sent by a mesh sta.
However, these capabilities are also being used in the p2p_find phase,
and the mesh-validation broke it.
Rename the WLAN_CAPABILITY_IS_MBSS macro, and verify that mesh ies
exist before assuming this frame was sent by a mesh sta.
When sched_scan_stopped was called by the driver, mac80211 calls
cfg80211, which in turn was calling mac80211 back with a flag
"driver_initiated". This flag was used so that mac80211 would do the
necessary cleanup but would not call the driver. This was enough to
prevent the bounce back between the driver and mac80211, but not
between mac80211 and cfg80211.
To fix this, we now do the cleanup in mac80211 before calling
cfg80211. To help with locking issues, the workqueue was moved from
cfg80211 to mac80211.
Implement new functionality for scheduled scan offload. With this feature we
can scan automatically at certain intervals.
The idea is that the hardware can perform scan automatically and filter on
desired results without waking up the host unnecessarily.
Add NL80211_CMD_START_SCHED_SCAN and NL80211_CMD_STOP_SCHED_SCAN
commands to the nl80211 interface. When results are available they are
reported by NL80211_CMD_SCHED_SCAN_RESULTS events. The userspace is
informed when the scheduled scan has stopped with a
NL80211_CMD_SCHED_SCAN_STOPPED event, which can be triggered either by
the driver or by a call to NL80211_CMD_STOP_SCHED_SCAN.
Mesh beacons no longer use all-zeroes BSSID. Beacon frames for MBSS,
infrastructure BSS, or IBSS are differentiated by the Capability
Information field in the Beacon frame. A mesh STA sets the ESS and IBSS
subfields to 0 in transmitted Beacon or Probe Response management
frames.
Signed-off-by: Javier Cardona <javier@cozybit.com>
This patch adds to the fix "fix BSS double-unlinking"
(commit 3207390a8b58bfc1335750f91cf6783c48ca19ca) by Johannes Berg.
It turns out, that the double-unlinking scenario can also occur if expired
BSS elements are removed whilst an interface is performing association.
To work around that, replace list_del with list_del_init also in the
"cfg80211_bss_expire" function, so that the check for whether the BSS still is
in the list works correctly in cfg80211_unlink_bss.
Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com>
In cfg80211_inform_bss_frame() wiphy is first dereferenced on privsz
initialisation and then it is checked for NULL. This patch fixes that.
Signed-off-by: Mariusz Kozlowski <mk@lab.zgora.pl>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
When a cached BSS struct is updated because a new beacon was received,
the code replaces the cached information elements by the IEs from the
new beacon. However it did not update the pub.information_elements
and pub.len_information_elements fields leaving them either pointing
to the old beacon IEs or in an inconsistent state where the data is
replaced by the new beacon IEs but len_information_elements still has
its value from the first beacon.
Fix this by updating the information elements fields if they are
pointing to beacon IEs.
Signed-off-by: Sven Neumann <s.neumann@raumfeld.com>
When multiple interfaces are actively trying
to associate with the same BSS, they may both
find that the BSS isn't there and then try to
unlink it. This can cause errors since the
unlinking code can't currently deal with items
that have already been unlinked.
Normally this doesn't happen as most people
don't try to use multiple station interfaces
that associate at the same time too.
Fix this by using the list entry as a flag to
see if the item is still on a list.
Cc: stable@kernel.org
Reported-by: Ben Greear <greearb@candelatech.com>
Tested-by: Hun-Kyi Wynn <hkwynn@candelatech.com>
When kernel-internal users use cfg80211_get_bss()
to get a reference to a BSS struct, they may end
up getting one that would have been removed from
the list if there had been any userspace access
to the list. This leads to inconsistencies and
problems.
Fix it by making cfg80211_get_bss() ignore BSSes
that cfg80211_bss_expire() would remove.
Fixes http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2180
Reported-by: Jiajia Zheng <jiajia.zheng@intel.com>
Tested-by: Jiajia Zheng <jiajia.zheng@intel.com>
signal_type is enum cfg80211_signal_type.
This fixes the gcc warning:
scan.c: In function `cfg80211_inform_bss':
scan.c:518:6: warning: comparison between `enum cfg80211_signal_type' and `enum nl80211_bss'
scan.c: In function `cfg80211_inform_bss_frame':
scan.c:574:6: warning: comparison between `enum cfg80211_signal_type' and `enum nl80211_bss'
Signed-off-by: Sujith <Sujith.Manoharan@atheros.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This new function (previously a static function
called just "find_ie" can be used to find a
specific IE in a buffer of IEs.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Store information elements from Beacon and Probe Response frames in
separate buffers to allow both sets to be made available through
nl80211. This allows user space applications to get access to IEs from
Beacon frames even if we have received Probe Response frames from the
BSS. Previously, the IEs from Probe Response frames would have
overridden the IEs from Beacon frames.
This feature is of somewhat limited use since most protocols include
the same (or extended) information in Probe Response frames. However,
there are couple of exceptions where the IEs from Beacon frames could
be of some use: TIM IE is only included in Beacon frames (and it would
be needed to figure out the DTIM period used in the BSS) and at least
some implementations of Wireless Provisioning Services seem to include
the full IE only in Beacon frames).
The new BSS attribute for scan results is added to allow both the IE
sets to be delivered. This is done in a way that maintains the
previously used behavior for applications that are not aware of the
new NL80211_BSS_BEACON_IES attribute.
Signed-off-by: Jouni Malinen <j@w1.fi>
If there's an invalid channel or SSID, the code leaks
the scan request. Always free the scan request, unless
it was successfully given to the driver.
Reported-by: Dan Carpenter <error27@gmail.com>
Acked-by: Dan Carpenter <error27@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
Not including net/atm/
Compiled tested x86 allyesconfig only
Added a > 80 column line or two, which I ignored.
Existing checkpatch plaints willfully, cheerfully ignored.
This patch moves the works cleanup, scan and events to a cfg80211
dedicated workqueue.
Platform driver like eeepc-laptop ought to use works to rfkill (as
new rfkill does lock in rfkill_unregister and the platform driver is
called from rfkill_switch_all which also lock the same mutex).
This raise a new issue in itself that the work scheduled by the platform
driver to the global worqueue calls wiphy_unregister which flush_work
scan and event works (which thus flush works on the global workqueue inside
a work on the global workqueue) and also put on hold the wdev_cleanup_work
(which prevents the dev_put on netdev thus indefinite Usage count error on
wifi device).
Signed-off-by: Alban Browaeys <prahal@yahoo.com>
Signed-off-by: Rui Paulo <rpaulo@gmail.com>
Currently it is possible to request a scan on only
disabled channels, which could be problematic for
some drivers. Reject such scans, and also ignore
disabled channels that are given. This resuls in
the scan begin/end event only including channels
that are actually used.
This makes the mac80211 check for disabled channels
superfluous. At the same time, remove the no-IBSS
check from mac80211 -- nothing says that we should
not find any networks on channels that cannot be
used for an IBSS, even when operating in IBSS mode.
Refactor wext to
* split out iwpriv handling
* split out iwspy handling
* split out procfs support
* allow cfg80211 to have wireless extensions compat code
w/o CONFIG_WIRELESS_EXT
After this, drivers need to
- select WIRELESS_EXT - for wext support
- select WEXT_PRIV - for iwpriv support
- select WEXT_SPY - for iwspy support
except cfg80211 -- which gets new hooks in wext-core.c
and can then get wext handlers without CONFIG_WIRELESS_EXT.
Wireless extensions procfs support is auto-selected
based on PROC_FS and anything that requires the wext core
(i.e. WIRELESS_EXT or CFG80211_WEXT).
Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de>
WEXT's "struct iw_freq" can also be used to handle a channel. This patch now
uses cfg80211_wext_freq() instead of hand-converting the frequency. That
allows user-space to specify channels as well, like with SIOCSIWFREQ.
Handles the case when SIOCSIWSCAN specified iw_scan_req.num_channels and
iw_scan_req.channels[].
The find_ie() function uses a size_t for the len parameter, and
directly uses len as a loop variable. If any received packets
are malformed, it is possible for the decrease of len to overflow,
and since the result is unsigned, the loop will not terminate.
Change it to a signed int so the loop conditional works for
negative values.
This fixes the following soft lockup:
[38573.102007] BUG: soft lockup - CPU#0 stuck for 61s! [phy0:2230]
[38573.102007] Modules linked in: aes_i586 aes_generic fuse af_packet ipt_REJECT xt_tcpudp nf_conntrack_ipv4 nf_defrag_ipv4 xt_state iptable_filter ip_tables x_tables acpi_cpufreq binfmt_misc dm_mirror dm_region_hash dm_log dm_multipath dm_mod kvm_intel kvm uinput i915 arc4 ecb drm snd_hda_codec_idt ath5k snd_hda_intel hid_apple mac80211 usbhid appletouch snd_hda_codec snd_pcm ath cfg80211 snd_timer i2c_algo_bit ohci1394 video snd processor ieee1394 rfkill ehci_hcd sg sky2 backlight snd_page_alloc uhci_hcd joydev output ac thermal button battery sr_mod applesmc cdrom input_polldev evdev unix [last unloaded: scsi_wait_scan]
[38573.102007] irq event stamp: 2547724535
[38573.102007] hardirqs last enabled at (2547724534): [<c1002ffc>] restore_all_notrace+0x0/0x18
[38573.102007] hardirqs last disabled at (2547724535): [<c10038f4>] apic_timer_interrupt+0x28/0x34
[38573.102007] softirqs last enabled at (92950144): [<c103ab48>] __do_softirq+0x108/0x210
[38573.102007] softirqs last disabled at (92950274): [<c1348e74>] _spin_lock_bh+0x14/0x80
[38573.102007]
[38573.102007] Pid: 2230, comm: phy0 Tainted: G W (2.6.31-rc7-wl #8) MacBook1,1
[38573.102007] EIP: 0060:[<f8ea2d50>] EFLAGS: 00010292 CPU: 0
[38573.102007] EIP is at cmp_ies+0x30/0x180 [cfg80211]
[38573.102007] EAX: 00000082 EBX: 00000000 ECX: ffffffc1 EDX: d8efd014
[38573.102007] ESI: ffffff7c EDI: 0000004d EBP: eee2dc50 ESP: eee2dc3c
[38573.102007] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
[38573.102007] CR0: 8005003b CR2: d8efd014 CR3: 01694000 CR4: 000026d0
[38573.102007] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
[38573.102007] DR6: ffff0ff0 DR7: 00000400
[38573.102007] Call Trace:
[38573.102007] [<f8ea2f8d>] cmp_bss+0xed/0x100 [cfg80211]
[38573.102007] [<f8ea33e4>] cfg80211_bss_update+0x84/0x410 [cfg80211]
[38573.102007] [<f8ea3884>] cfg80211_inform_bss_frame+0x114/0x180 [cfg80211]
[38573.102007] [<f97255ff>] ieee80211_bss_info_update+0x4f/0x180 [mac80211]
[38573.102007] [<f972b118>] ieee80211_rx_bss_info+0x88/0xf0 [mac80211]
[38573.102007] [<f9739297>] ? ieee802_11_parse_elems+0x27/0x30 [mac80211]
[38573.102007] [<f972b224>] ieee80211_rx_mgmt_probe_resp+0xa4/0x1c0 [mac80211]
[38573.102007] [<f972bc59>] ieee80211_sta_rx_queued_mgmt+0x919/0xc50 [mac80211]
[38573.102007] [<c1009707>] ? sched_clock+0x27/0xa0
[38573.102007] [<c105ffd0>] ? mark_held_locks+0x60/0x80
[38573.102007] [<c1348be5>] ? _spin_unlock_irqrestore+0x55/0x70
[38573.102007] [<c134baa5>] ? sub_preempt_count+0x85/0xc0
[38573.102007] [<c1348bce>] ? _spin_unlock_irqrestore+0x3e/0x70
[38573.102007] [<c12c1c0f>] ? skb_dequeue+0x4f/0x70
[38573.102007] [<f972c021>] ieee80211_sta_work+0x91/0xb80 [mac80211]
[38573.102007] [<c10479af>] worker_thread+0x18f/0x320
[38573.102007] [<c104794e>] ? worker_thread+0x12e/0x320
[38573.102007] [<f972bf90>] ? ieee80211_sta_work+0x0/0xb80 [mac80211]
[38573.102007] [<c104cbb0>] ? autoremove_wake_function+0x0/0x50
[38573.102007] [<c1047820>] ? worker_thread+0x0/0x320
[38573.102007] [<c104c854>] kthread+0x84/0x90
[38573.102007] [<c104c7d0>] ? kthread+0x0/0x90
[38573.102007] [<c1003ab7>] kernel_thread_helper+0x7/0x10
Signed-off-by: Bob Copeland <me@bobcopeland.com>
When we lose a scan, cfg80211 tries to clean up after
the driver. However, it currently does this too early,
it does this in GOING_DOWN already instead of DOWN, so
it may happen with mac80211. Besides fixing this, also
make it more robust by leaking the scan request so if
the driver later actually finishes the scan, it won't
crash. Also check in ___cfg80211_scan_done whether a
scan request is still pending and exit if not.
Reported-by: Felix Fietkau <nbd@openwrt.org>
Tested-by: Felix Fietkau <nbd@openwrt.org>
If you trigger a scan request on an interface and then
take it down, or rmmod the module or unplug the device
the driver might "forget" to cancel the scan request.
That is a bug in the driver, but the current behaviour
is that we just hang endlessly waiting for the netdev
refcount to become 0 which it never will. To improve
robustness, check for this situation in cfg80211, warn
about it and clean up behind the driver. I don't just
clean up silently because it's likely that the driver
also has some internal state it has now leaked.
Additionally, this fixes a locking bug, clearing the
scan_req pointer should be done under the rdev lock.
Finally, we also need to _wait_ for the scan work and
not just abort it since it might be pending and wanting
to do a cleanup.
The memory layout for scan requests was rather wrong,
we put the scan SSIDs before the channels which could
lead to the channel pointers being unaligned in memory.
It turns out that using a pointer to the channel array
isn't necessary anyway since we can embed a zero-length
array into the struct.
In order for userspace to be able to figure out whether
it obtained a consistent snapshot of data or not when
using netlink dumps, we need to have a generation number
in each dump message that indicates whether the list has
changed or not -- its value is arbitrary.
This patch adds such a number to all dumps, this needs
some mac80211 involvement to keep track of a generation
number to start with when adding/removing mesh paths or
stations.
The wiphy and netdev lists can be fully handled within
cfg80211, of course, but generation numbers need to be
stored there as well.
arch/microblaze/include/asm/socket.h
These pointers can be NULL, the is_mesh() case isn't
ever hit in the current kernel, but cmp_ies() can be
hit under certain conditions.
Cc: stable@kernel.org [2.6.29, 2.6.30]
