path: root/net/wireless/reg.c
2011-12-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2011-11-30cfg80211: amend regulatory NULL dereference fixLuis R. Rodriguez
Johannes' patch for "cfg80211: fix regulatory NULL dereference" broke user regulaotry hints and it did not address the fact that last_request was left populated even if the previous regulatory hint was stale due to the wiphy disappearing. Fix user reguluatory hints by only bailing out if for those regulatory hints where a request_wiphy is expected. The stale last_request considerations are addressed through the previous fixes on last_request where we reset the last_request to a static world regdom request upon reset_regdomains(). In this case though we further enhance the effect by simply restoring reguluatory settings completely. Cc: stable@vger.kernel.org Cc: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-30cfg80211: fix race on init and driver registrationLuis R. Rodriguez
There is a theoretical race that if hit will trigger a crash. The race is between when we issue the first regulatory hint, regulatory_hint_core(), gets processed by the workqueue and between when the first device gets registered to the wireless core. This is not easy to reproduce but it was easy to do so through the regulatory simulator I have been working on. This is a port of the fix I implemented there [1]. [1] https://github.com/mcgrof/regsim/commit/a246ccf81f059cb662eee288aa13100f631e4cc8 Cc: stable@vger.kernel.org Cc: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-22Merge branch 'master' of ↵John W. Linville
2011-11-21cfg80211: fix regulatory NULL dereferenceJohannes Berg
By the time userspace returns with a response to the regulatory domain request, the wiphy causing the request might have gone away. If this is so, reject the update but mark the request as having been processed anyway. Cc: Luis R. Rodriguez <lrodriguez@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Cc: stable@vger.kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-11Merge branch 'master' of ↵John W. Linville
2011-11-09cfg80211: fix bug on regulatory core exit on access to last_requestLuis R. Rodriguez
Commit 4d9d88d1 by Scott James Remnant <keybuk@google.com> added the .uevent() callback for the regulatory device used during the platform device registration. The change was done to account for queuing up udev change requests through udevadm triggers. The change also meant that upon regulatory core exit we will now send a uevent() but the uevent() callback, reg_device_uevent(), also accessed last_request. Right before commiting device suicide we free'd last_request but never set it to NULL so platform_device_unregister() would lead to bogus kernel paging request. Fix this and also simply supress uevents right before we commit suicide as they are pointless. This fix is required for kernels >= v2.6.39 $ git describe --contains 4d9d88d1 v2.6.39-rc1~468^2~25^2^2~21 The impact of not having this present is that a bogus paging access may occur (only read) upon cfg80211 unload time. You may also get this BUG complaint below. Although Johannes could not reproduce the issue this fix is theoretically correct. mac80211_hwsim: unregister radios mac80211_hwsim: closing netlink BUG: unable to handle kernel paging request at ffff88001a06b5ab IP: [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211] PGD 1836063 PUD 183a063 PMD 1ffcb067 PTE 1a06b160 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC CPU 0 Modules linked in: cfg80211(-) [last unloaded: mac80211] Pid: 2279, comm: rmmod Tainted: G W 3.1.0-wl+ #663 Bochs Bochs RIP: 0010:[<ffffffffa030df9a>] [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211] RSP: 0000:ffff88001c5f9d58 EFLAGS: 00010286 RAX: 0000000000000000 RBX: ffff88001d2eda88 RCX: ffff88001c7468fc RDX: ffff88001a06b5a0 RSI: ffff88001c7467b0 RDI: ffff88001c7467b0 RBP: ffff88001c5f9d58 R08: 000000000000ffff R09: 000000000000ffff R10: 0000000000000000 R11: 0000000000000001 R12: ffff88001c7467b0 R13: ffff88001d2eda78 R14: ffffffff8164a840 R15: 0000000000000001 FS: 00007f8a91d8a6e0(0000) GS:ffff88001fc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88001a06b5ab CR3: 000000001c62e000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process rmmod (pid: 2279, threadinfo ffff88001c5f8000, task ffff88000023c780) Stack: ffff88001c5f9d98 ffffffff812ff7e5 ffffffff8176ab3d ffff88001c7468c2 000000000000ffff ffff88001d2eda88 ffff88001c7467b0 ffff880000114820 ffff88001c5f9e38 ffffffff81241dc7 ffff88001c5f9db8 ffffffff81040189 Call Trace: [<ffffffff812ff7e5>] dev_uevent+0xc5/0x170 [<ffffffff81241dc7>] kobject_uevent_env+0x1f7/0x490 [<ffffffff81040189>] ? sub_preempt_count+0x29/0x60 [<ffffffff814cab1a>] ? _raw_spin_unlock_irqrestore+0x4a/0x90 [<ffffffff81305307>] ? devres_release_all+0x27/0x60 [<ffffffff8124206b>] kobject_uevent+0xb/0x10 [<ffffffff812fee27>] device_del+0x157/0x1b0 [<ffffffff8130377d>] platform_device_del+0x1d/0x90 [<ffffffff81303b76>] platform_device_unregister+0x16/0x30 [<ffffffffa030fffd>] regulatory_exit+0x5d/0x180 [cfg80211] [<ffffffffa032bec3>] cfg80211_exit+0x2b/0x45 [cfg80211] [<ffffffff8109a84c>] sys_delete_module+0x16c/0x220 [<ffffffff8108a23e>] ? trace_hardirqs_on_caller+0x7e/0x120 [<ffffffff814cba02>] system_call_fastpath+0x16/0x1b Code: <all your base are belong to me> RIP [<ffffffffa030df9a>] reg_device_uevent+0x1a/0x50 [cfg80211] RSP <ffff88001c5f9d58> CR2: ffff88001a06b5ab ---[ end trace 147c5099a411e8c0 ]--- Reported-by: Johannes Berg <johannes@sipsolutions.net> Cc: Scott James Remnant <keybuk@google.com> Cc: stable@vger.kernel.org Signed-off-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31net: add moduleparam.h for users of module_param/MODULE_PARM_DESCPaul Gortmaker
These files were getting access to these two via the implicit presence of module.h everywhere. They aren't modules, so they don't need the full module.h inclusion though. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-22Merge branch 'master' of github.com:davem330/netDavid S. Miller
Conflicts: MAINTAINERS drivers/net/Kconfig drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c drivers/net/ethernet/broadcom/tg3.c drivers/net/wireless/iwlwifi/iwl-pci.c drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c drivers/net/wireless/rt2x00/rt2800usb.c drivers/net/wireless/wl12xx/main.c
2011-09-16wireless: Reset beacon_found while updating regulatoryRajkumar Manoharan
During the association, the regulatory is updated by country IE that reaps the previously found beacons. The impact is that after a STA disconnects *or* when for any reason a regulatory domain change happens the beacon hint flag is not cleared therefore preventing future beacon hints to be learned. This is important as a regulatory domain change or a restore of regulatory settings would set back the passive scan and no-ibss flags on the channel. This is the right place to do this given that it covers any regulatory domain change. Cc: stable@kernel.org Reviewed-by: Luis R. Rodriguez <mcgrof@gmail.com> Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com> Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-14cfg80211: reorder code to obsolete forward declarationSven Neumann
Reorder functions to remove the need for a forward declaration introduced by the last commit. Signed-off-by: Sven Neumann <s.neumann@raumfeld.com> Cc: John W. Linville <linville@tuxdriver.com> Cc: Luis R. Rodriguez <mcgrof@gmail.com> Cc: Daniel Mack <daniel@zonque.org> Cc: linux-wireless@vger.kernel.org Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-14cfg80211: hold reg_mutex when updating regulatorySven Neumann
The function wiphy_update_regulatory() uses the static variable last_request and thus needs to be called with reg_mutex held. This is the case for all users in reg.c, but the function was exported for use by wiphy_register(), from where it is called without the lock being held. Fix this by making wiphy_update_regulatory() private and introducing regulatory_update() as a wrapper that acquires and holds the lock. Signed-off-by: Sven Neumann <s.neumann@raumfeld.com> Cc: John W. Linville <linville@tuxdriver.com> Cc: Luis R. Rodriguez <mcgrof@gmail.com> Cc: Daniel Mack <daniel@zonque.org> Cc: linux-wireless@vger.kernel.org Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-13cfg80211: print bandwidth in chan_reg_rule_print_dbg()Pavel Roskin
Two spaces and the second "KHz" suggest that the code author meant to print the bandwidth but forgot it. The code appears in commit e702d3cf already with two spaces and "KHz" in place of the bandwidth. Signed-off-by: Pavel Roskin <proski@gnu.org> Acked-by: Luis R. Rodriguez <mcgrof@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-09cfg80211: Update REG_DBG_PRINT macro and usesJoe Perches
Several uses were missing terminating newlines. Typo fix and macro neatening. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-26wireless: fix a typo in ignore_reg_updateMihai Moldovan
Just a typo fix changing regulaotry to regulatory. Signed-off-by: Mihai Moldovan <ionic@ionic.de> CC: John W. Linville <linville@tuxdriver.com> CC: Mohammed Shafi <shafi.wireless@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-26cfg80211: really ignore the regulatory requestSven Neumann
At the beginning of wiphy_update_regulatory() a check is performed whether the request is to be ignored. Then the request is sent to the driver nevertheless. This happens even if last_request points to NULL, leading to a crash in the driver: [<bf01d864>] (lbs_set_11d_domain_info+0x28/0x1e4 [libertas]) from [<c03b714c>] (wiphy_update_regulatory+0x4d0/0x4f4) [<c03b714c>] (wiphy_update_regulatory+0x4d0/0x4f4) from [<c03b4008>] (wiphy_register+0x354/0x420) [<c03b4008>] (wiphy_register+0x354/0x420) from [<bf01b17c>] (lbs_cfg_register+0x80/0x164 [libertas]) [<bf01b17c>] (lbs_cfg_register+0x80/0x164 [libertas]) from [<bf020e64>] (lbs_start_card+0x20/0x88 [libertas]) [<bf020e64>] (lbs_start_card+0x20/0x88 [libertas]) from [<bf02cbd8>] (if_sdio_probe+0x898/0x9c0 [libertas_sdio]) Fix this by returning early. Also remove the out: label as it is not any longer needed. Signed-off-by: Sven Neumann <s.neumann@raumfeld.com> Cc: linux-wireless@vger.kernel.org Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Daniel Mack <daniel@zonque.org> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/iwlwifi/iwl-agn-tx.c net/mac80211/sta_info.h
2011-05-10wireless: Fix warnings due to -Wunused-but-set-variableRajkumar Manoharan
These warnings are exposed by gcc 4.6. net/wireless/reg.c: In function 'freq_reg_info_regd': net/wireless/reg.c:675:38: warning: variable 'pr' set but not used [-Wunused-but-set-variable] net/wireless/lib80211_crypt_wep.c: In function 'lib80211_wep_build_iv': net/wireless/lib80211_crypt_wep.c:99:12: warning: variable 'len' set but not used [-Wunused-but-set-variable] Signed-off-by: Rajkumar Manoharan <rmanoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/libertas/if_cs.c drivers/net/wireless/rtlwifi/pci.c net/bluetooth/l2cap_sock.c
2011-04-26cfg80211: fix regresion on reg user timeoutLuis R. Rodriguez
The patch "cfg80211: add a timer for invalid user reg hints" introduced a regression for the case where a secondary identical regulatory hint from a user is sent. What would happen is the second hint would schedule delayed work in to catch a timeout but since we are never processing it given that the hint was already applied we'd always hit the timeout and and restore regulatory settings back to world regulatory domain. This is fixed by simply avoiding sheduling work if the hint was already applied. Tested-by: Felix Fietkau <nbd@openwrt.org> Reported-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-12Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/ath/ar9170/main.c drivers/net/wireless/ath/ar9170/phy.c drivers/net/wireless/zd1211rw/zd_rf_rf2959.c
2011-04-07cfg80211: add a timer for invalid user reg hintsLuis R. Rodriguez
We have no other option but to inform userspace that we have queued up their regulatory hint request when we are given one given that nl80211 operates atomically on user requests. The best we can do is accept the request, and add a delayed work item for processing failure and cancel it if we succeeed. Upon failure we restore the regulatory settings and ignore the user input. This fixes this reported bug: https://bugzilla.kernel.org/show_bug.cgi?id=28112 Reported-by: gregoryx.alagnou@intel.com Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-07cfg80211: fix regulatory restore upon user hintsLuis R. Rodriguez
When we restore regulatory settings its possible CRDA will not reply because of a bogus user entry. In this case the bogus entry will prevent any further processing on cfg80211 for regulatory domains even if we restore regulatory settings. To prevent this we suck out all pending requests when restoring regulatory settings and add them back into the queue after we have queued up the reset work. The impact of not having this applied is that a user with privileges can issue a userspace regulatory hint while we are disasocciating and this would prevent any further processing of regulatory domains. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-09net/wireless: add COUNTRY to to regulatory device ueventScott James Remnant
Regulatory devices issue change uevents to inform userspace of a need to call the crda tool; however these can often be sent before udevd is running, and were not previously included in the results of udevadm trigger (which requests a new change event using the /uevent attribute of the sysfs object). Add a uevent function to the device type which includes the COUNTRY information from the last request if it has yet to be processed, the case of multiple requests is already handled in the code by checking whether an unprocessed one is queued in the same manner and refusing to queue a new one. The existing udev rule continues to work as before. Signed-off-by: Scott James Remnant <keybuk@google.com> Acked-By: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-21cfg80211: Extend channel to frequency mapping for 802.11jBruno Randolf
Extend channel to frequency mapping for 802.11j Japan 4.9GHz band, according to IEEE802.11 section 17.3.8.3.2 and Annex J. Because there are now overlapping channel numbers in the 2GHz and 5GHz band we can't map from channel to frequency without knowing the band. This is no problem as in most contexts we know the band. In places where we don't know the band (and WEXT compatibility) we assume the 2GHz band for channels below 14. This patch does not implement all channel to frequency mappings defined in 802.11, it's just an extension for 802.11j 20MHz channels. 5MHz and 10MHz channels as well as 802.11y channels have been omitted. The following drivers have been updated to reflect the API changes: iwl-3945, iwl-agn, iwmc3200wifi, libertas, mwl8k, rt2x00, wl1251, wl12xx. The drivers have been compile-tested only. Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: Brian Prodoehl <bprodoehl@gmail.com> Acked-by: Luciano Coelho <coelho@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-04cfg80211: fix transposition of words in printkBob Copeland
Fixes the misplaced article in the following: "cfg80211: Updating information on frequency 5785 MHz for 20 a MHz width channel with regulatory rule:" Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-12-16cfg80211: fix null pointer dereference with a custom regulatory requestLuis R. Rodriguez
Once we moved the core regulatory request to the queue and let the scheduler process it last_request will have been left NULL until the schedular decides to process the first request. When this happens and we are loading a driver with a custom regulatory request like all Atheros drivers we end up with a NULL pointer dereference. We fix this by checking if the request was a custom one. BUG: unable to handle kernel NULL pointer dereference at 0000000000000004 IP: [<ffffffffa016de87>] freq_reg_info_regd.clone.2+0x27/0x130 [cfg80211] PGD 71f91067 PUD 712b2067 PMD 0 Oops: 0000 [#1] PREEMPT SMP last sysfs file: /sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1/firmware/2-1/loading CPU 0 Modules linked in: ath9k_htc(+) ath9k_common ath9k_hw ath <etc> Pid: 3094, comm: insmod Tainted: G W 2.6.37-rc5-wl #16 INVALID/28427ZQ RIP: 0010:[<ffffffffa016de87>] [<ffffffffa016de87>] freq_reg_info_regd.clone.2+0x27/0x130 [cfg80211] RSP: 0018:ffff88007045db78 EFLAGS: 00010282 RAX: 0000000000000000 RBX: ffffffffa047d9a0 RCX: ffff88007045dbd0 RDX: 0000000000004e20 RSI: 000000000024cde0 RDI: ffff8800700483e0 RBP: ffff88007045db98 R08: ffffffffa02f5b40 R09: 0000000000000001 R10: 000000000000000e R11: 0000000000000001 R12: 0000000000000000 R13: ffff88007004e3b0 R14: 0000000000000000 R15: ffff880070048340 FS: 00007f635a707700(0000) GS:ffff880077400000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000004 CR3: 00000000708a9000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process insmod (pid: 3094, threadinfo ffff88007045c000, task ffff8800713e3ec0) Stack: ffffffffa047d9a0 0000000000000000 ffff88007004e3b0 0000000000000000 ffff88007045dc08 ffffffffa016e147 000000007045dc08 0000000000000002 ffff8800700483e0 ffffffffa02f5b40 ffff88007045dbd8 0000000000000000 Call Trace: [<ffffffffa016e147>] wiphy_apply_custom_regulatory+0x137/0x1d0 [cfg80211] [<ffffffffa047a690>] ? ath9k_reg_notifier+0x0/0x50 [ath9k_htc] [<ffffffffa02f47f7>] ath_regd_init+0x347/0x430 [ath] [<ffffffffa047b1f5>] ath9k_htc_probe_device+0x6c5/0x960 [ath9k_htc] [<ffffffffa0472a2c>] ath9k_htc_hw_init+0xc/0x30 [ath9k_htc] [<ffffffffa04747e6>] ath9k_hif_usb_probe+0x216/0x3b0 [ath9k_htc] [<ffffffffa03bb6bc>] usb_probe_interface+0x10c/0x210 [usbcore] [<ffffffff812aec26>] driver_probe_device+0x96/0x1c0 [<ffffffff812aedf3>] __driver_attach+0xa3/0xb0 [<ffffffff812aed50>] ? __driver_attach+0x0/0xb0 [<ffffffff812adaae>] bus_for_each_dev+0x5e/0x90 [<ffffffff812ae8c9>] driver_attach+0x19/0x20 [<ffffffff812ae438>] bus_add_driver+0x168/0x320 [<ffffffff812af071>] driver_register+0x71/0x140 [<ffffffff811fc4a8>] ? __raw_spin_lock_init+0x38/0x70 [<ffffffffa03ba39c>] usb_register_driver+0xdc/0x190 [usbcore] [<ffffffffa03a2000>] ? ath9k_htc_init+0x0/0x4f [ath9k_htc] [<ffffffffa047499e>] ath9k_hif_usb_init+0x1e/0x20 [ath9k_htc] [<ffffffffa03a202b>] ath9k_htc_init+0x2b/0x4f [ath9k_htc] [<ffffffff8100212f>] do_one_initcall+0x3f/0x180 [<ffffffff8109ef5b>] sys_init_module+0xbb/0x200 [<ffffffff8100bf52>] system_call_fastpath+0x16/0x1b Code: <etc, who cares> RIP [<ffffffffa016de87>] freq_reg_info_regd.clone.2+0x27/0x130 [cfg80211] RSP <ffff88007045db78> CR2: 0000000000000004 ---[ end trace 79e4193601c8b713 ]--- Reported-by: Sujith Manoharan <Sujith.Manoharan@atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24net/wireless: Use pr_<level> and netdev_<level>Joe Perches
No change in output for pr_<level> prefixes. netdev_<level> output is different, arguably improved. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22cfg80211: Fix regulatory bug with multiple cards and delaysLuis R. Rodriguez
When two cards are connected with the same regulatory domain if CRDA had a delayed response then cfg80211's own set regulatory domain would still be the world regulatory domain. There was a bug on cfg80211's logic such that it assumed that once you pegged a request as the last request it was already the currently set regulatory domain. This would mean we would race setting a stale regulatory domain to secondary cards which had the same regulatory domain since the alpha2 would match. We fix this by processing each regulatory request atomically, and only move on to the next one once we get it fully processed. In the case CRDA is not present we will simply world roam. This issue is only present when you have a slow system and the CRDA processing is delayed. Because of this it is not a known regression. Without this fix when a delay is present with CRDA the second card would end up with an intersected regulatory domain and not allow it to use the channels it really is designed for. When two cards with two different regulatory domains were inserted you'd end up rejecting the second card's regulatory domain request. This fails with mac80211_hswim's regtest=2 (two requests, same alpha2) and regtest=3 (two requests, different alpha2) module parameter options. This was reproduced and tested against mac80211_hwsim using this CRDA delayer: #!/bin/bash echo $COUNTRY >> /tmp/log sleep 2 /sbin/crda.orig And these regulatory tests: modprobe mac80211_hwsim regtest=2 modprobe mac80211_hwsim regtest=3 Reported-by: Mark Mentovai <mark@moxienet.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Tested-by: Mark Mentovai <mark@moxienet.com> Tested-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22cfg80211: move mutex locking to reg_process_pending_hints()Luis R. Rodriguez
This will be required in the next patch and it makes the next patch easier to review. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Tested-by: Mark Mentovai <mark@moxienet.com> Tested-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22cfg80211: move reg_work and reg_todo aboveLuis R. Rodriguez
These will be used earlier in the next few patches. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Tested-by: Mark Mentovai <mark@moxienet.com> Tested-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22cfg80211: put core regulatory request into queueLuis R. Rodriguez
This will simplify the synchronization for pending requests. Without this we have a race between the core and when we restore regulatory settings, although this is unlikely its best to just avoid that race altogether. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Tested-by: Mark Mentovai <mark@moxienet.com> Tested-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-15cfg80211: prefix REG_DBG_PRINT() with cfg80211Luis R. Rodriguez
Everyone's doing it, its the cool thing. Cc: Easwar Krishnan <easwar.krishnan@atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-15cfg80211: add debug print when processing a channelLuis R. Rodriguez
In the worst case you are seeing really odd things you want more information than what is provided right now, for those that insist and want debug info through CONFIG_CFG80211_REG_DEBUG provide a print of when we are processing a channel and with what regulatory rule. Cc: Easwar Krishnan <easwar.krishnan@atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-15cfg80211: add debug print when disabling a channel on a custom regdLuis R. Rodriguez
2010-11-15cfg80211: add debug prints for when we ignore regulatory hintsLuis R. Rodriguez
This can help with debugging issues. You will only see these with CONFIG_CFG80211_REG_DEBUG enabled. Cc: Easwar Krishnan <easwar.krishnan@atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-15cfg80211: fix disabling channels based on hintsLuis R. Rodriguez
After a module loads you will have loaded the world roaming regulatory domain or a custom regulatory domain. Further regulatory hints are welcomed and should be respected unless the regulatory hint is coming from a country IE as the IEEE spec allows for a country IE to be a subset of what is allowed by the local regulatory agencies. So disable all channels that do not fit a regulatory domain sent from a unless the hint is from a country IE and the country IE had no information about the band we are currently processing. This fixes a few regulatory issues, for example for drivers that depend on CRDA and had no 5 GHz freqencies allowed were not properly disabling 5 GHz at all, furthermore it also allows users to restrict devices further as was intended. If you recieve a country IE upon association we will also disable the channels that are not allowed if the country IE had at least one channel on the respective band we are procesing. This was the original intention behind this design but it was completely overlooked... Cc: David Quan <david.quan@atheros.com> Cc: Jouni Malinen <jouni.malinen@atheros.com> cc: Easwar Krishnan <easwar.krishnan@atheros.com> Cc: stable@kernel.org Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-15cfg80211: fix allowing country IEs for WIPHY_FLAG_STRICT_REGULATORYLuis R. Rodriguez
We should be enabling country IE hints for WIPHY_FLAG_STRICT_REGULATORY even if we haven't yet recieved regulatory domain hint for the driver if it needed one. Without this Country IEs are not passed on to drivers that have set WIPHY_FLAG_STRICT_REGULATORY, today this is just all Atheros chipset drivers: ath5k, ath9k, ar9170, carl9170. This was part of the original design, however it was completely overlooked... Cc: Easwar Krishnan <easwar.krishnan@atheros.com> Cc: stable@kernel.org Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-15cfg80211: pass the reg hint initiator to helpersLuis R. Rodriguez
This is required later. Cc: Easwar Krishnan <easwar.krishnan@atheros.com> Cc: stable@kernel.org signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-25cfg80211: fix regression on processing country IEsLuis R. Rodriguez
The patch 4f366c5: wireless: only use alpha2 regulatory information from country IE removed some complex intersection we were always doing between the AP's country IE info and what we got from CRDA. When CRDA sent us back a regulatory domain we would do some sanity checks on that regulatory domain response we just got. Part of these sanity checks included checking that we already had performed an intersection for the request of NL80211_REGDOM_SET_BY_COUNTRY_IE type. This mean that cfg80211 was only processing country IEs for cases where we already had an intersection, but since we removed enforcing this this is no longer required, we should just apply the country IE country hint with the data received from CRDA. This patch has fixes intended for kernels >= 2.6.36. Cc: stable@kernel.org Reported-by: Easwar Krishnan <easwar.krishnan@atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-16cfg80211/mac80211: use lockdep_assert_heldJohannes Berg
Instead of using a WARN_ON(!mutex_is_locked()) use lockdep_assert_held() which compiles away completely when lockdep isn't enabled, and also is a more accurate assertion since it checks that the current thread is holding the mutex. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-16wireless: upcase alpha2 values in queue_regulatory_requestJohn W. Linville
This provides a little more flexibility for human users, and it allows us to use isalpha rather than the custom is_alpha_upper. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-28cfg80211: Update of regulatory request initiator handlingYuri Ershov
In some cases there could be possible dereferencing freed pointer. The update is intended to avoid this issue. Signed-off-by: Yuri Ershov <ext-yuri.ershov@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-26wireless: remove unneeded variable from regulatory_hint_11d()Dan Carpenter
The "rd" variable isn't needed any more since 4f366c5dabcb "wireless: only use alpha2 regulatory information from country IE" Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-20wireless: remove unnecessary reg_same_country_ie_hintJohn W. Linville
"Might as well remove reg_same_country_ie_hint() completely since we already dealt with suspend/resume through the regulatory hint disconnect." -- Luis Reported-by: Luis R. Rodriguez <mcgrof@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-20wireless: only use alpha2 regulatory information from country IEJohn W. Linville
The meaning and/or usage of the country IE is somewhat poorly defined. In practice, this means that regulatory rulesets in a country IE are often incomplete and might be untrustworthy. This removes the code associated with interpreting those rulesets while preserving respect for country "alpha2" codes also contained in the country IE. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-24wireless: mark reg_mutex as staticJohn W. Linville
2010-06-18wireless: move regulatory_init to .init.textUwe Kleine-König
regulatory_init is only called by cfg80211_init which is in .init.text, too. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
