path: root/net/unix
2009-10-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sh_eth.c
2009-10-18AF_UNIX: Fix deadlock on connecting to shutdown socketTomoki Sekiyama
I found a deadlock bug in UNIX domain socket, which makes able to DoS attack against the local machine by non-root users. How to reproduce: 1. Make a listening AF_UNIX/SOCK_STREAM socket with an abstruct namespace(*), and shutdown(2) it. 2. Repeat connect(2)ing to the listening socket from the other sockets until the connection backlog is full-filled. 3. connect(2) takes the CPU forever. If every core is taken, the system hangs. PoC code: (Run as many times as cores on SMP machines.) int main(void) { int ret; int csd; int lsd; struct sockaddr_un sun; /* make an abstruct name address (*) */ memset(&sun, 0, sizeof(sun)); sun.sun_family = PF_UNIX; sprintf(&sun.sun_path[1], "%d", getpid()); /* create the listening socket and shutdown */ lsd = socket(AF_UNIX, SOCK_STREAM, 0); bind(lsd, (struct sockaddr *)&sun, sizeof(sun)); listen(lsd, 1); shutdown(lsd, SHUT_RDWR); /* connect loop */ alarm(15); /* forcely exit the loop after 15 sec */ for (;;) { csd = socket(AF_UNIX, SOCK_STREAM, 0); ret = connect(csd, (struct sockaddr *)&sun, sizeof(sun)); if (-1 == ret) { perror("connect()"); break; } puts("Connection OK"); } return 0; } (*) Make sun_path[0] = 0 to use the abstruct namespace. If a file-based socket is used, the system doesn't deadlock because of context switches in the file system layer. Why this happens: Error checks between unix_socket_connect() and unix_wait_for_peer() are inconsistent. The former calls the latter to wait until the backlog is processed. Despite the latter returns without doing anything when the socket is shutdown, the former doesn't check the shutdown state and just retries calling the latter forever. Patch: The patch below adds shutdown check into unix_socket_connect(), so connect(2) to the shutdown socket will return -ECONREFUSED. Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama.qu@hitachi.com> Signed-off-by: Masanori Yoshida <masanori.yoshida.tv@hitachi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: mark net_proto_ops as constStephen Hemminger
All usages of structure net_proto_ops should be declared const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-11net: unix: fix sending fds in multiple buffersMiklos Szeredi
Kalle Olavi Niemitalo reported that: "..., when one process calls sendmsg once to send 43804 bytes of data and one file descriptor, and another process then calls recvmsg three times to receive the 16032+16032+11740 bytes, each of those recvmsg calls returns the file descriptor in the ancillary data. I confirmed this with strace. The behaviour differs from Linux 2.6.26, where reportedly only one of those recvmsg calls (I think the first one) returned the file descriptor." This bug was introduced by a patch from me titled "net: unix: fix inflight counting bug in garbage collector", commit 6209344f5. And the reason is, quoting Kalle: "Before your patch, unix_attach_fds() would set scm->fp = NULL, so that if the loop in unix_stream_sendmsg() ran multiple iterations, it could not call unix_attach_fds() again. But now, unix_attach_fds() leaves scm->fp unchanged, and I think this causes it to be called multiple times and duplicate the same file descriptors to each struct sk_buff." Fix this by introducing a flag that is cleared at the start and set when the fds attached to the first buffer. The resulting code should work equivalently to the one on 2.6.26. Reported-by: Kalle Olavi Niemitalo <kon@iki.fi> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-09net: adding memory barrier to the poll and receive callbacksJiri Olsa
Adding memory barrier after the poll_wait function, paired with receive callbacks. Adding fuctions sock_poll_wait and sk_has_sleeper to wrap the memory barrier. Without the memory barrier, following race can happen. The race fires, when following code paths meet, and the tp->rcv_nxt and __add_wait_queue updates stay in CPU caches. CPU1 CPU2 sys_select receive packet ... ... __add_wait_queue update tp->rcv_nxt ... ... tp->rcv_nxt check sock_def_readable ... { schedule ... if (sk->sk_sleep && waitqueue_active(sk->sk_sleep)) wake_up_interruptible(sk->sk_sleep) ... } If there was no cache the code would work ok, since the wait_queue and rcv_nxt are opposit to each other. Meaning that once tp->rcv_nxt is updated by CPU2, the CPU1 either already passed the tp->rcv_nxt check and sleeps, or will get the new value for tp->rcv_nxt and will return with new data mask. In both cases the process (CPU1) is being added to the wait queue, so the waitqueue_active (CPU2) call cannot miss and will wake up CPU1. The bad case is when the __add_wait_queue changes done by CPU1 stay in its cache, and so does the tp->rcv_nxt update on CPU2 side. The CPU1 will then endup calling schedule and sleep forever if there are no more data on the socket. Calls to poll_wait in following modules were ommited: net/bluetooth/af_bluetooth.c net/irda/af_irda.c net/irda/irnet/irnet_ppp.c net/mac80211/rc80211_pid_debugfs.c net/phonet/socket.c net/rds/af_rds.c net/rfkill/core.c net/sunrpc/cache.c net/sunrpc/rpc_pipe.c net/tipc/socket.c Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-31New helper - current_umask()Al Viro
current->fs->umask is what most of fs_struct users are doing. Put that into a helper function. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-02-26unix: remove some pointless conditionals before kfree_skb()Wei Yongjun
Remove some pointless conditionals before kfree_skb(). Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-31introduce new LSM hooks where vfsmount is available.Kentaro Takeda
Add new LSM hooks for path-based checks. Call them on directory-modifying operations at the points where we still know the vfsmount involved. Signed-off-by: Kentaro Takeda <takedakn@nttdata.co.jp> Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Toshiharu Harada <haradats@nttdata.co.jp> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits) net: Allow dependancies of FDDI & Tokenring to be modular. igb: Fix build warning when DCA is disabled. net: Fix warning fallout from recent NAPI interface changes. gro: Fix potential use after free sfc: If AN is enabled, always read speed/duplex from the AN advertising bits sfc: When disabling the NIC, close the device rather than unregistering it sfc: SFT9001: Add cable diagnostics sfc: Add support for multiple PHY self-tests sfc: Merge top-level functions for self-tests sfc: Clean up PHY mode management in loopback self-test sfc: Fix unreliable link detection in some loopback modes sfc: Generate unique names for per-NIC workqueues 802.3ad: use standard ethhdr instead of ad_header 802.3ad: generalize out mac address initializer 802.3ad: initialize ports LACPDU from const initializer 802.3ad: remove typedef around ad_system 802.3ad: turn ports is_individual into a bool 802.3ad: turn ports is_enabled into a bool 802.3ad: make ntt bool ixgbe: Fix set_ringparam in ixgbe to use the same memory pools. ... Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due to the conversion to %pI (in this networking merge) and the addition of doing IPv6 addresses (from the earlier merge of CIFS).
2008-12-04Merge branch 'master' into nextJames Morris
Conflicts: fs/nfsd/nfs4recover.c Manually fixed above to use new creds API functions, e.g. nfs4_save_creds(). Signed-off-by: James Morris <jmorris@namei.org>
2008-12-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ixgbe/ixgbe_main.c drivers/net/smc91x.c
2008-11-26net: Fix soft lockups/OOM issues w/ unix garbage collectordann frazier
This is an implementation of David Miller's suggested fix in: https://bugzilla.redhat.com/show_bug.cgi?id=470201 It has been updated to use wait_event() instead of wait_event_interruptible(). Paraphrasing the description from the above report, it makes sendmsg() block while UNIX garbage collection is in progress. This avoids a situation where child processes continue to queue new FDs over a AF_UNIX socket to a parent which is in the exit path and running garbage collection on these FDs. This contention can result in soft lockups and oom-killing of unrelated processes. Signed-off-by: dann frazier <dannf@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25net: Use a percpu_counter for sockets_allocatedEric Dumazet
Instead of using one atomic_t per protocol, use a percpu_counter for "sockets_allocated", to reduce cache line contention on heavy duty network servers. Note : We revert commit (248969ae31e1b3276fc4399d67ce29a5d81e6fd9 net: af_unix can make unix_nr_socks visbile in /proc), since it is not anymore used after sock_prot_inuse_add() addition Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-24net: Make sure BHs are disabled in sock_prot_inuse_add()Eric Dumazet
The rule of calling sock_prot_inuse_add() is that BHs must be disabled. Some new calls were added where this was not true and this tiggers warnings as reported by Ilpo. Fix this by adding explicit BH disabling around those call sites, or moving sock_prot_inuse_add() call inside an existing BH disabled section. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-23net: Make sure BHs are disabled in sock_prot_inuse_add()David S. Miller
The rule of calling sock_prot_inuse_add() is that BHs must be disabled. Some new calls were added where this was not true and this tiggers warnings as reported by Ilpo. Fix this by adding explicit BH disabling around those call sites. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19net: af_unix should use KERN_INFO instead of KERN_DEBUGEric Dumazet
As spotted by Joe Perches, we should use KERN_INFO in unix_sock_destructor() Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19include/net net/ - csum_partial - remove unnecessary castsJoe Perches
The first argument to csum_partial is const void * casts to char/u8 * are not necessary Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-17net: af_unix should update its inuse counterEric Dumazet
This patch is a preparation to namespace conversion of /proc/net/protocols In order to have relevant information for UNIX protocol, we should use sock_prot_inuse_add() to update a (percpu and pernamespace) counter of inuse sockets. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-17net: af_unix can make unix_nr_socks visbile in /procEric Dumazet
Currently, /proc/net/protocols displays socket counts only for TCP/TCPv6 protocols We can provide unix_nr_socks for free here, this counter being already maintained in af_unix Before patch : # grep UNIX /proc/net/protocols UNIX 428 -1 -1 NI 0 yes kernel After patch : # grep UNIX /proc/net/protocols UNIX 428 98 -1 NI 0 yes kernel Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16net: Cleanup of af_unixEric Dumazet
This is a pure cleanup of net/unix/af_unix.c to meet current code style standards Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-14Merge branch 'master' into nextJames Morris
Conflicts: security/keys/internal.h security/keys/process_keys.c security/keys/request_key.c Fixed conflicts above by using the non 'tsk' versions. Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the UNIX socket protocolDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: netdev@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-11-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/message/fusion/mptlan.c drivers/net/sfc/ethtool.c net/mac80211/debugfs_sta.c
2008-11-09net: unix: fix inflight counting bug in garbage collectorMiklos Szeredi
Previously I assumed that the receive queues of candidates don't change during the GC. This is only half true, nothing can be received from the queues (see comment in unix_gc()), but buffers could be added through the other half of the socket pair, which may still have file descriptors referring to it. This can result in inc_inflight_move_tail() erronously increasing the "inflight" counter for a unix socket for which dec_inflight() wasn't previously called. This in turn can trigger the "BUG_ON(total_refs < inflight_refs)" in a later garbage collection run. Fix this by only manipulating the "inflight" counter for sockets which are candidates themselves. Duplicating the file references in unix_attach_fds() is also needed to prevent a socket becoming a candidate for GC while the skb that contains it is not yet queued. Reported-by: Andrea Bittau <a.bittau@cs.ucl.ac.uk> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath5k/base.c net/8021q/vlan_core.c
2008-11-03net: '&' reduxAlexey Dobriyan
I want to compile out proc_* and sysctl_* handlers totally and stub them to NULL depending on config options, however usage of & will prevent this, since taking adress of NULL pointer will break compilation. So, drop & in front of every ->proc_handler and every ->strategy handler, it was never needed in fact. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-01af_unix: clean up net/unix/af_unix.c garbage.c sysctl_net_unix.cJianjun Kong
clean up net/unix/af_unix.c garbage.c sysctl_net_unix.c Signed-off-by: Jianjun Kong <jianjun@zeuux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-01af_unix: netns: fix problem of return valueJianjun Kong
fix problem of return value net/unix/af_unix.c: unix_net_init() when error appears, it should return 'error', not always return 0. Signed-off-by: Jianjun Kong <jianjun@zeuux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-23[PATCH] assorted path_lookup() -> kern_path() conversionsAl Viro
more nameidata eviction Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-13net: Rationalise email address: Network Specific PartsAlan Cox
Clean up the various different email addresses of mine listed in the code to a single current and valid address. As Dave says his network merges for 2.6.28 are now done this seems a good point to send them in where they won't risk disrupting real changes. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (39 commits) [PATCH] fix RLIM_NOFILE handling [PATCH] get rid of corner case in dup3() entirely [PATCH] remove remaining namei_{32,64}.h crap [PATCH] get rid of indirect users of namei.h [PATCH] get rid of __user_path_lookup_open [PATCH] f_count may wrap around [PATCH] dup3 fix [PATCH] don't pass nameidata to __ncp_lookup_validate() [PATCH] don't pass nameidata to gfs2_lookupi() [PATCH] new (local) helper: user_path_parent() [PATCH] sanitize __user_walk_fd() et.al. [PATCH] preparation to __user_walk_fd cleanup [PATCH] kill nameidata passing to permission(), rename to inode_permission() [PATCH] take noexec checks to very few callers that care Re: [PATCH 3/6] vfs: open_exec cleanup [patch 4/4] vfs: immutable inode checking cleanup [patch 3/4] fat: dont call notify_change [patch 2/4] vfs: utimes cleanup [patch 1/4] vfs: utimes: move owner check into inode_change_ok() [PATCH] vfs: use kstrdup() and check failing allocation ...
2008-07-26[PATCH] f_count may wrap aroundAl Viro
make it atomic_long_t; while we are at it, get rid of useless checks in affs, hfs and hpfs - ->open() always has it equal to 1, ->release() - to 0. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-25net: convert BUG_TRAP to generic WARN_ONIlpo Järvinen
Removes legacy reinvent-the-wheel type thing. The generic machinery integrates much better to automated debugging aids such as kerneloops.org (and others), and is unambiguous due to better naming. Non-intuively BUG_TRAP() is actually equal to WARN_ON() rather than BUG_ON() though some might actually be promoted to BUG_ON() but I left that to future. I could make at least one BUILD_BUG_ON conversion. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-28Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl4965-base.c
2008-06-27af_unix: fix 'poll for write'/connected DGRAM socketsRainer Weikusat
For n:1 'datagram connections' (eg /dev/log), the unix_dgram_sendmsg routine implements a form of receiver-imposed flow control by comparing the length of the receive queue of the 'peer socket' with the max_ack_backlog value stored in the corresponding sock structure, either blocking the thread which caused the send-routine to be called or returning EAGAIN. This routine is used by both SOCK_DGRAM and SOCK_SEQPACKET sockets. The poll-implementation for these socket types is datagram_poll from core/datagram.c. A socket is deemed to be writeable by this routine when the memory presently consumed by datagrams owned by it is less than the configured socket send buffer size. This is always wrong for PF_UNIX non-stream sockets connected to server sockets dealing with (potentially) multiple clients if the abovementioned receive queue is currently considered to be full. 'poll' will then return, indicating that the socket is writeable, but a subsequent write result in EAGAIN, effectively causing an (usual) application to 'poll for writeability by repeated send request with O_NONBLOCK set' until it has consumed its time quantum. The change below uses a suitably modified variant of the datagram_poll routines for both type of PF_UNIX sockets, which tests if the recv-queue of the peer a socket is connected to is presently considered to be 'full' as part of the 'is this socket writeable'-checking code. The socket being polled is additionally put onto the peer_wait wait queue associated with its peer, because the unix_dgram_recvmsg routine does a wake up on this queue after a datagram was received and the 'other wakeup call' is done implicitly as part of skb destruction, meaning, a process blocked in poll because of a full peer receive queue could otherwise sleep forever if no datagram owned by its socket was already sitting on this queue. Among this change is a small (inline) helper routine named 'unix_recvq_full', which consolidates the actual testing code (in three different places) into a single location. Signed-off-by: Rainer Weikusat <rweikusat@mssgmbh.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/tx.c
2008-06-17af_unix: fix 'poll for write'/ connected DGRAM socketsRainer Weikusat
The unix_dgram_sendmsg routine implements a (somewhat crude) form of receiver-imposed flow control by comparing the length of the receive queue of the 'peer socket' with the max_ack_backlog value stored in the corresponding sock structure, either blocking the thread which caused the send-routine to be called or returning EAGAIN. This routine is used by both SOCK_DGRAM and SOCK_SEQPACKET sockets. The poll-implementation for these socket types is datagram_poll from core/datagram.c. A socket is deemed to be writeable by this routine when the memory presently consumed by datagrams owned by it is less than the configured socket send buffer size. This is always wrong for connected PF_UNIX non-stream sockets when the abovementioned receive queue is currently considered to be full. 'poll' will then return, indicating that the socket is writeable, but a subsequent write result in EAGAIN, effectively causing an (usual) application to 'poll for writeability by repeated send request with O_NONBLOCK set' until it has consumed its time quantum. The change below uses a suitably modified variant of the datagram_poll routines for both type of PF_UNIX sockets, which tests if the recv-queue of the peer a socket is connected to is presently considered to be 'full' as part of the 'is this socket writeable'-checking code. The socket being polled is additionally put onto the peer_wait wait queue associated with its peer, because the unix_dgram_sendmsg routine does a wake up on this queue after a datagram was received and the 'other wakeup call' is done implicitly as part of skb destruction, meaning, a process blocked in poll because of a full peer receive queue could otherwise sleep forever if no datagram owned by its socket was already sitting on this queue. Among this change is a small (inline) helper routine named 'unix_recvq_full', which consolidates the actual testing code (in three different places) into a single location. Signed-off-by: Rainer Weikusat <rweikusat@mssgmbh.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (22 commits) tun: Multicast handling in tun_chr_ioctl() needs proper locking. [NET]: Fix heavy stack usage in seq_file output routines. [AF_UNIX] Initialise UNIX sockets before general device initcalls [RTNETLINK]: Fix bogus ASSERT_RTNL warning iwlwifi: Fix built-in compilation of iwlcore (part 2) tun: Fix minor race in TUNSETLINK ioctl handling. ppp_generic: use stats from net_device structure iwlwifi: Don't unlock priv->mutex if it isn't locked wireless: rndis_wlan: modparam_workaround_interval is never below 0. prism54: prism54_get_encode() test below 0 on unsigned index mac80211: update mesh EID values b43: Workaround DMA quirks mac80211: fix use before check of Qdisc length net/mac80211/rx.c: fix off-by-one mac80211: Fix race between ieee80211_rx_bss_put and lookup routines. ath5k: Fix radio identification on AR5424/2424 ssb: Fix all-ones boardflags b43: Add more btcoexist workarounds b43: Fix HostFlags data types b43: Workaround invalid bluetooth settings ...
2008-04-24[AF_UNIX] Initialise UNIX sockets before general device initcallsDavid Woodhouse
When drivers call request_module(), it tries to do something with UNIX sockets and triggers a 'runaway loop modprobe net-pf-1' warning. Avoid this by initialising AF_UNIX support earlier. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-19[PATCH] r/o bind mounts: get callers of vfs_mknod/create/mkdir()Dave Hansen
This takes care of all of the direct callers of vfs_mknod(). Since a few of these cases also handle normal file creation as well, this also covers some calls to vfs_create(). So that we don't have to make three mnt_want/drop_write() calls inside of the switch statement, we move some of its logic outside of the switch and into a helper function suggested by Christoph. This also encapsulates a fix for mknod(S_IFREG) that Miklos found. [AV: merged mkdir handling, added missing nfsd pieces] Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-12[AF_UNIX]: Use SEQ_START_TOKENJoe Perches
2008-03-26[NET] NETNS: Omit namespace comparision without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce an inline net_eq() to compare two namespaces. Without CONFIG_NET_NS, since no namespace other than &init_net exists, it is always 1. We do not need to convert 1) inline vs inline and 2) inline vs &init_net comparisons. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-26[NET] NETNS: Omit seq_net_private->net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, no namespace other than &init_net exists, no need to store net in seq_net_private. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-05net: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-14Introduce path_put()Jan Blunck
* Add path_put() functions for releasing a reference to the dentry and vfsmount of a struct path in the right order * Switch from path_release(nd) to path_put(&nd->path) * Rename dput_path() to path_put_conditional() [akpm@linux-foundation.org: fix cifs] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: <linux-fsdevel@vger.kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Embed a struct path into struct nameidata instead of nd->{dentry,mnt}Jan Blunck
This is the central patch of a cleanup series. In most cases there is no good reason why someone would want to use a dentry for itself. This series reflects that fact and embeds a struct path into nameidata. Together with the other patches of this series - it enforced the correct order of getting/releasing the reference count on <dentry,vfsmount> pairs - it prepares the VFS for stacking support since it is essential to have a struct path in every place where the stack can be traversed - it reduces the overall code size: without patch series: text data bss dec hex filename 5321639 858418 715768 6895825 6938d1 vmlinux with patch series: text data bss dec hex filename 5320026 858418 715768 6894212 693284 vmlinux This patch: Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix cifs] [akpm@linux-foundation.org: fix smack] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28[NET]: Add some acquires/releases sparse annotations.Eric Dumazet
Add __acquires() and __releases() annotations to suppress some sparse warnings. example of warnings : net/ipv4/udp.c:1555:14: warning: context imbalance in 'udp_seq_start' - wrong count at exit net/ipv4/udp.c:1571:13: warning: context imbalance in 'udp_seq_stop' - unexpected unlock Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
